Seat alhambra 2015 ABS Coding from 4Motion
jeroenveer
C?ID=299782
Hi,
I have a Seat alhambra from 2015 and installed 4Motion in the car.
ABS system needs to be recoded to accept 4motion.
anyone who can help me with the ABS coding?
current coding: 12F0449A2921C26D087E480922C7944310391700F00B4993
22-AWD is added to car.
Tuesday,03,October,2017,15:59:18:06109
VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4401.4
VIN: VSSZZZ7NZGV711794   License Plate:
Mileage: 40770km-25333mi   Repair Order:
Chassis Type: 7N (7N0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 18 19 22 25 2B 36 3C 42 44
          46 4C 4F 52 53 55 5F 61 62 69 6C 6D 72 A5 BE BF
VIN: VSSZZZ7NZGV711794   Mileage: 40770km-25333miles
22-AWD -- Status: Not registered 0001
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-DEDA)       Labels: None
   Part No SW: 06K 906 071 BC    HW: 06K 907 425 C
   Component: R4 2.0l TFS   H13 3069
   Revision: --H13---
   Coding: 001D00BA2424010A3000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM20TFS02006K906071BC 001003
   ROD: EV_ECM20TFS02006K906071BC.rod
   VCID: 6D921D0CBC86232932-8038
17178 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 40773 km
                    Date: 2017.10.03
                    Time: 15:55:15
                    Engine speed: 0.00 /min
                    Coolant temperature: 72 °C
                    Intake air temperature: 59 °C
                    Voltage terminal 30: 11.953 V
                    Drivetrain coordinator: ACC fault status-ACC: Not active: although TSK passive
                    Drivetrain coordinator: ACC fault status-Start and stop request: Set at stopping speed
                    Drivetrain coordinator: ACC fault status-Bit 2: Not transmitted simultaneously
                    Drivetrain coordinator: ACC fault status-Bit 3: Does not reactivate after DTC-induced shutdown
                    Drivetrain coordinator: ACC fault status-Bit 4: Not active when limiter active
                    Drivetrain coordinator: ACC fault status-Bit 5: Transmits no undefined signals
                    Drivetrain coordinator: ACC fault status-Bit 6: Not active when main switch off
                    Drivetrain coordinator: ACC fault status-Bit 7: Not active when driver braking
                    Drivetrain coordinator: ACC fault status-Bit 8: Not active during the EPB emer. braking
                    Drivetrain coordinator: brake fault status-ESP: no error
                    Drivetrain coordinator: brake fault status-Deceleration controller: Available
                    Drivetrain coordinator: brake fault status-TSK/ESP handshake: no error
                    Drivetrain coordinator: brake fault status-Bit 1: no error
                    Drivetrain coordinator: brake fault status-Bit 3: Not malfunction due to inaccurate engine torque
                    Drivetrain coordinator: brake fault status-Bit 4: No indication of TSK message consistency error
                    Drivetrain coordinator: brake fault status-Bit 6: Automatic engagement OK
                    Drivetrain coordinator: brake fault status: 4
                    Drivetrain coordinator: brake function status-Parking Brake: not active
                    Drivetrain coordinator: brake function status-ACC: Not braking
                    Drivetrain coordinator: brake function status-ESP: Not invoking TSK braking
                    Drivetrain coordinator: brake function status-Driver: Not braking
                    Drivetrain coordinator: brake function status-Hill descent control: passive
                    Drivetrain coordinator: brake function status-ASR: no intervention
                    Drivetrain coordinator: brake function status-MSR: no intervention
                    Drivetrain coordinator: brake function status-ADS: no intervention
                    Drivetrain coordinator: brake function status-ABS: no intervention
                    Drivetrain coordinator: brake function status-EDL: no intervention
                    Drivetrain coordinator: brake function status-ASP: no intervention
                    Drivetrain coordinator: brake function status-AWV2: No warning pressure
                    Drivetrain coordinator: brake function status-Bit 4: no intervention
                    Drivetrain coordinator: brake function status-Bit 11: not passively cycled
                    Drivetrain coordinator: brake function status-Bit 12: not passively cycled
                    Drivetrain coordinator: brake function status-Bit 13: Standstill not detected
Readiness: 1110 0001
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0BH 300 043 T    HW: 0BH 927 711 C
   Component: TVS DQ500-7A  H05 2299
   Revision: 00H05V01
   ROD: EV_TCMDQ500021_VW41.rod
   VCID: 383CFC588344568111-806C
Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CF    HW: 5N0 614 109 CF
   Component: ESC-EBC460iV1 H10 0013
   Serial number: A00YBK3
   Coding: 12F0449A2921C26D087E480922C7944310391700F00B4993
   ASAM Dataset: EV_Brake1ESCEPBTRW 006353
   ROD: EV_Brake1ESCEPBTRW_006.rod
   VCID: 71AA017CA0BEC7C916-8024
0764 - TPMS Display
          C1146 F0 [137] - Not Available
                    Reset counter: 96
                    Mileage: 40773 km
                    Date: 2017.10.03
                    Time: 15:41:56
                    Additional_Codes: 00 00 00 0C 05 7F 00 08 0A
                    DTC: 00 02 FC
                    Additional2: 02 05 01 05 05 00 81 00 81 00
0789 - Coding of a Function Inconsistent
          B2030 00 [137] -  -
                    Reset counter: 96
                    Mileage: 40773 km
                    Additional_Codes: 00 00 00 0C 14 7F 00 0F 08
                    DTC: 00 03 15
                    Additional2: 02 00 01 05 05 00 53 00 53 00
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0381365337
   Coding: 03100C
   Shop #: WSC 00020 999 39850
   ROD: EV_KESSYPQ35G_VW01.rod
   VCID: 373EFF648E5A59F918-8062
   Part No SW: 7N0 907 044 AC    HW: 7N0 907 044 AC
   Component: Clima-Sharan  H02 0606
   Revision: 00001K04
   Coding: 0210104549
   Shop #: WSC 00020 790 00001
   Slave 1:
   Subsystem 1 - Part No SW: 7N0 907 049 C    HW: 7N0 907 049 C
   Component: KBT-H  004 0103
   Serial number: 20151001000000024166
   Part No SW: 5K0 937 086 T    HW: 5K0 937 086 T
   Component: BCM PQ35 M    122 0183
   Revision: BC122001
   Coding: 60590A3F8925E1C4508800C8B400897403D50008676D2DB26484C720A2C1
   Shop #: WSC 00020 790 00000
   VCID: 45C285ACCCB63B699A-8010
   Subsystem 1 - Part No SW: 7N1 955 119 B    HW: 7N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS428 030915  024 0644
   Serial number: 15082803065621
   Coding: 004DBD
   Component: RLHS  037 0059
   Serial number: S3Y15M10D20H11M14S56
   Coding: 0228BB
Address 10: Park/Steer Assist (J791)       Labels: 1Q0-919-475.clb
   Part No SW: 7N0 919 475 E    HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0005
   Serial number: 000305183615283
   Coding: 0171167051
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_EPHVA3CVW428GP00 001005
   ROD: EV_EPHVA2CVW428GP00.rod
   VCID: 3D32ED4CAC6673A9C2-8068
13637426 - Databus
                    Reset counter: 96
                    Mileage: 39764 km
                    Date: 2017.09.19
                    Time: 19:06:19
13637427 - Databus
                    Fault Frequency: 54
                    Reset counter: 96
                    Mileage: 39750 km
                    Date: 2017.09.19
                    Time: 12:32:47
Address 14: Susp. Elect. (J250)       Labels: 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 18061500210002
   Coding: 010180
   VCID: 271E2F2456FAC97988-8072
   Part No SW: 7N0 959 655 D    HW: 7N0 959 655 D
   Component: VW10Airbag10X H15 0016
   Serial number: 003PWPLDB4NS
   Coding: 003058
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 40CC94B8DB941E41A9-8014
   Serial number: 3493ETS6019A4CB1B9D5
   Serial number: 3503ETS608211D21BDDO
   Serial number: 3513ETS601CA4CB1B9D1
   Serial number: 3523ETS609A9CD71BDDG
   Serial number: 35540TS60CA1AD41B9DZ
   Part No SW: 5K0 953 501 DQ    HW: 5K0 953 569 AP
   Revision: FF010042    Serial number: 20151010100154
   Coding: 3112240000
   VCID: 7CB42048F7FCBAA1B5-8028
   Subsystem 1 - Part No SW: 7N5 919 719     HW: 7N5 919 719   Labels: 3C8-959-537.CLB
   Serial number: 000000000A0728030915
   Coding: 011000
   Part No SW: 7N5 920 880     HW: 7N5 920 880
   Component: KOMBI         H04 1007
   Coding: 140F010800
   VCID: 75A2356CD4D6EBE9CA-8020
   Part No: 5K0 963 271 E
   Component: Zuheizer        051 2807
   Revision: 00051000    Serial number: 09029171000000
   Coding: 0000041
   VCID: 312AC17CA83E87C956-8064
   Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1663
   Revision:   H56       Serial number: 051015F1000529
   Coding: 468232
   VCID: 72A80E70ADB8FCD1EF-8026
            000 -  -
                    Mileage: 40773 km
                    Date: 2017.10.03
                    Time: 15:53:47
   Part No SW: 0AY 907 554 F    HW: 0AY 907 554 F
   Component: Haldex4Motion H52 7521
   Serial number: HA1-00020.11.13
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_SK12.rod
   VCID: 4ED0BA8011C0F8312B-801A
   Component: IMMO          H04 1007
   Coding: 000007
   VCID: 6A9816108D68341157-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Revision: 00000000    Serial number: 15000163967004
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 302CC4786B348EC159-8064
   Part No SW: 3C8 959 760 F    HW: 3C8 959 760 F
   Component: Sitzmemory    H02 1301
   Revision: 00H02000
   Coding: 000018
   Shop #: WSC 12336 024 394758
   VCID: 383CFC588B44568111-806C
Address 3C: Lane Change (J1086)       Labels: None
   Component: HRE_Master    H11 0071
   Serial number: 0382401571
   Coding: 02011102
   ROD: EV_HREntryHella.rod
   VCID: 3C34E048B77C7AA1F5-8068
   Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
   Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
   Component: TSG FA        H04 0561
   Revision:             Serial number: 0000170034463
   Coding: 01112F20DE00411001
   VCID: 49DA899CE0AEDF097E-801C
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.325 1401
   Revision: 1BH04739    Serial number: 00152430229801
   Coding: 0000258
   VCID: 41CA91BC189E1749A6-8014
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1663
   Coding: 050B0500
   VCID: 6FAE0704BE8AD13900-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
   Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
   Component: TSG BF        H04 0561
   Revision:             Serial number: 0000170054736
   Coding: 01112D209E00411001
   VCID: 48DC8C98FBA4260161-801C
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Component: AFS-ECU       H05 0111
   Coding: 06B200000B000000
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3B0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3B0000
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 7N5 035 680 A    HW: 7N5 035 680 A
   Component: MU-S-ND-ER    H22 0245
   Serial number: SEZAZ2R8901503
   Coding: 04240801FF00000011111101008808001F0100840020010086
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 312AC17C603E87C956-8064
   Subsystem 1 - Part No SW: 6P0 919 866 M    HW: -----------
   Component: ECE1 2017  --- 0730
   Component: Batt.regelung H56 1663
   Coding: 032F7859
   VCID: 71AA017CA8BEC7C916-8024
   Component: J367-BDM  H07 0180
   Serial number: 32275900421491785511
Address 62: Door, Rear Left (J388)       Labels: 7N0-959-794.clb
   Part No SW: 7N0 959 794 L    HW: 7N0 959 794 H
   Component: TSG HL        H02 0561
   Revision:             Serial number: 0000169877223
   Coding: 01006D200000411001
   VCID: 4CD4B088EFDCCA2145-8018
Address 69: Trailer (J345)       Labels: 7N0-907-383.clb
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Towbar module H09 0120
   Revision: 3A001001    Serial number: ÀÁ006789000000
   Coding: 410C040001000000
   VCID: 73A60B74D2A2F5D9E4-8026
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-907-441.clb
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 012408012201000700
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAAU914.rod
Address 6D: Trunk Elect. (J605)       Labels: 7N0-959-107.clb
   Part No SW: 7N0 959 107 G    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0250
   Revision: 41011001    Serial number: 260500902
   Coding: 0733334002
   ASAM Dataset: EV_HDSGVW428 201138
   ROD: EV_HDSGVW428_VW36.rod
   VCID: 3B36E354B2727D99FC-806E
Address 72: Door, Rear Right (J389)       Labels: 7N0-959-794.clb
   Component: TSG HR        H02 0561
   Revision:             Serial number: 0000169876970
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 C    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0023
   Serial number: 07081511P10755
   Coding: 030402080000040100261302C080400090000E100020
   ROD: EV_MFKBoschMQBB.rod
Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
   Part No SW: 7N0 959 244 B    HW: 7N0 959 244 B
   Component: Schiebetuer_l 005 2414
   Serial number: 15384754
   ASAM Dataset: EV_AST A03704
   ROD: EV_AST.rod
Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
   Component: Schiebetuer_r 005 2414
   Serial number: 15384292
   ROD: EV_AST.rod
End----------(Elapsed Time: 02:18, VBatt start/end: 12.1V/12.1V)-----------
Moved to Retrofits.
dnoermann
C?ID=358118
Sorry for beeing a bit late.
Change ABS Coding
to
12F0449A4921C26D087E480922C7964310391700F00B4993
But you will need to change Engine Coding to 4Motion, too, it could be that you need to change Engine SW for this.
Spacewalker
Poland
C?ID=159607
also registere
in GW
