Some Tweaks in V.W. Tiguan 2013
Mexicano
C?ID=219864
I have a V.W. Tiguan 2013 and would like to know if I could do the following and how:
1) I would like to "close" the sunroof and windows(if open) with only one touch of "arm" button on remote control, at this time I have to "hold" the button untill the sunroof is completly close
2) I would like the horn to sound when I Open/Close-Arm/Disarm, using the remote control, at this time only position lights blink
This is an scan from the car:
Wednesday,27,August,2014,19:57:02:40443
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WVGDZ65N9DW088060   License Plate:
Mileage:    Repair Order: Tiguan-08-27-14
Chassis Type: 5N (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 4C 4F 52 53 56 62
          72 77
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 06J 906 027 GD    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 04 3409
   Revision: P3H07---    Serial number:
   Coding: 0423010A19070160
   VCID: 73E5C7E51228D386965-8026
008817 - Oxygen (Lambda) Sensor Signal B1 S2
               P2271 - 000 - too Rich - Intermittent
                    Mileage: 24340 km
                    Date: 2016.14.27
                    Time: 17:14:37
                    RPM: 1850 /min
                    Load: 9.4 %
                    Speed: 98.0 km/h
                    Temperature: 99.0°C
                    Temperature: 51.0°C
                    Absolute Pres.: 770.0 mbar
                    Voltage: 13.843 V
000314 - Oxygen (Lambda) Sensor B1 S2
               P013A - 000 - Response too Slow Rich to Lean - MIL ON
                    Fault Status: 11100000
                    Mileage: 24340 km
                    Date: 2016.14.27
                    Time: 17:14:37
                    RPM: 1850 /min
                    Load: 9.4 %
                    Speed: 98.0 km/h
                    Temperature: 99.0°C
                    Temperature: 51.0°C
                    Voltage: 13.843 V
Address 02: Auto Trans        Labels: 09G-927-750.lbl
   Part No SW: 09G 927 750 NK    HW: 09G 927 750 NK
   Component: AQ 250 6F           2253
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 871D0335F6B04F265AD-80D2
   Part No SW: 5N0 614 109 BD    HW: 5N0 614 109 BD
   Component: J104   C6 450M VD44 0011
   Revision: --H07---    Serial number: 00000006737421
   Coding: 0005158
   VCID: 6ED3D691790AFE6E79B-803B
   Part No SW: 5K0 907 044 GR    HW: 5K0 907 044 GR
   Component: Climatronic   H19 1313
   Revision: 00001004
   Coding: 0010002002
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 81091D2D10947116149-80D4
   Part No SW: 5K0 937 086 N    HW: 5K0 937 086 N
   Component: BCM PQ35 M    021 0068
   Revision: BJ021001
   Coding: 68180A3B80253EC4408800C0340081244B51A788536D8D60648040000040
   VCID: 3F8D5BD5AEE047E6A2D-806A
   Subsystem 1 - Part No: 5N1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS 110213 03  32  0010
   Coding: 009795
   Component: RLS 260213 05  54  0403
   Coding: 03304D
                    Reset counter: 87
                    Mileage: 24003 km
                    Date: 2016.14.20
                    Time: 16:46:33
                        Term 15 Off
                    Voltage: 12.45 V
   Component: J234__20J VW10 HI   2118
   Revision: 26019000    Serial number: 003L7P3JCJYE
   Coding: 0012362
   VCID: 7CF7ECD93F769CFEC7F-8029
   Subsystem 1 - Serial number: 6332MTS673280453
   Subsystem 2 - Serial number: 6342MTS669920463
   Subsystem 3 - Serial number: 6351HTS6DIGVQBKJ
   Subsystem 4 - Serial number: 6361HTS68DKSQBKJ
   Part No SW: 5K0 953 501 AT    HW: 5K0 953 569 H
   Revision: FF010041    Serial number: 20130225100280
   Coding: 199A140000
   VCID: 7CF7ECD9F7769CFEC7F-8029
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0032
   Coding: 830000
   Part No SW: 5N0 920 883     HW: 5N0 920 883
   Component: KOMBI         H05 0505
   Coding: 311F01
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: F1E94DED20346196E49-80A4
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 160213F2000446
   Coding: 356002
   VCID: 76E3FEF1C15AC6AEB1B-8023
   Component: IMMO          H05 0505
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EADB5A810DE2924EA53-80BF
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664365752
   Coding: 010100
   VCID: 2A5B1A814562D24EE53-807F
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0503
   Revision: 13110009    Serial number: 0006520518
   Coding: 0004BC
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 387F30C983CE70DE637-806D
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D
   Component: J388__TSG-HL  008 1504
   Serial number: 00000007644517
   Coding: 000490
   Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.285 1202
   Revision: 1BH04839    Serial number: 00130490042201
   Coding: 0000258
   VCID: 3F8D5BD56EE047E6A2D-806A
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 050B0500
   VCID: EFED4B953E007766F2D-80BA
   Component: J245EE20SKB13  H05 0220
   Component: J394EE20SKB13  H05 0220
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0006524726
   Coding: 0004BC
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 397935CDB8C469D69C9-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D
   Component: J389__TSG-HR  008 1504
   Serial number: 00000007636522
   Coding: 000490
   Revision:   H19       Serial number: 00000000784218
   Coding: 0026157
   VCID: 36633EF141DA86AE71B-8063
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
   Component: Radio RCD510  005 0236
   Revision: 00000001    Serial number: VWZ1Z3N1961990
   Coding: 0100041004000C
   VCID: 2447F4B92746043EDFF-8071
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007664318817
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3A7B2AC1BDC262CE953-806F
bambazonke
Mackay Qld Australia
C?ID=240542
You need to add an alarm siren for the "chirp" to sound when locking unlocking the car see my link below as to how to fit one and recode the BCM for it to work
http://www.mytiguan.com/index.php?/topic/14298-retro-fitting-an-oem-siren-for-anti-theft-alarm-ata/
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Revision: BC021001
Coding: 40180A3BE83730C0400800C0340081EC4F59AA88436D81606480C7000041
VCID: 3E5DF366A9820DCA23-806B
Subsystem 1 - Part No SW: 5N2 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 11061 013 0203
Coding: 009795
Component: RLS 140612 05 54 0403
Coding: 07304D
No fault code found.[/COLOR]
One touch closing was avaliable in early models of the Tiguan that had a real #46 module. These functions are now incorporated in the #9 BCM module. Many a Golf 6 owner as well as new Tiguan owner's have requested for this function but the coding is yet to discovered in this module.
Mexicano
C?ID=219864
Revision: BC021001
Coding: 009795
Coding: 07304D
Thanks a lot!
