Passat B6 A/C
Klaus Ludwig
C?ID=227092
Hi all,
A friend has an issue with the A/C on a 2009 B6 Passat (UK based).
It doesn't work at all and hasn't done since he has had the car.
All A/C fuses on drivers side fuse panel are OK
Believe compressor is likely to be variable load type (no clutch), though I have not confirmed 100%
No A/C fault codes on VCDS
Refrigerant charge has been confirmed OK by a non specialist shop that uses computerised evacuation/recharge system.
Refrigerant pressure (as indicated on VCDS) does not change when A/C switched on and off. Tiny change if engine revs are increased.
Noted no compressor current (actual) indicated, though perhaps that is normal.
Not sure if pressure shown on VCDS is the LP or HP?
Here are a few VCDS parameters when A/C is switched on and engine is idling:-
Saturday,30,September,2017,16:15:27:56826
VCDS Version: 17.8.0.1 (x64)
VIN:    License Plate: ********
                Address 08: Auto HVAC  (1K0 820 047 JD)
16:14:48
      Compressor Current (actual)
  0.820 A   Compressor Current (specified)
  900 /min   Compressor Speed
  3.2 Nm   Compressor Load
  7.8 bar   Refrigerant Pressure
  14.0 %   Radiator Fan Activation (actual)
  30.0 %   Radiator Fan Activation (spec.)
  15.5°C   Outside Temp. (filtered)
  49.0°C   Coolant Temperature
  20.0°C   Evaporator Temperature
  27.0°C   Interior Temperature
and the AutoScan
Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: Release 17.1.1(x64) Data version: 20170106 DS267.0 www.Ross-Tech.com
Dealer/Shop Name: Workshop Code: 000 00000 000000
Self-Diagnosis Log Saturday,30,September,2017,13:18:43:56826
VIN: WVWZZZ3CZ9E098608 License Plate: ******** Mileage: 266390km-165527mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 6C
VIN: WVWZZZ3CZ9E098608 Mileage: 266390km-165527miles
16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010 6C-Back-up Cam. -- Status: OK 0000
                                ------------------------------------------------------------------------------- Address 01: Engine (CBD) Labels: 03L-906-022-CBA.clb
  Part No SW: 03L 906 022 BT HW: 03L 907 309 Component: R4 2,0L EDC 0000SG 6214
Revision: 13H01--- Serial number: VWZCZ000000000 Coding: 0000071
    Shop #: WSC 00363 210 85044 VCID: 78FFCCFD0B0EB181ED-802C
  No fault code found. Readiness: 0 0 0 0 0
Self-Diagnosis Log Saturday,30,September,2017,13:18:43:56826 Page 2
VIN: WVWZZZ3CZ9E098608 License Plate: VE58 FRO
     Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb PartNoSW:3C0614109T HW:3C0614109T Component: J104 C4 440 V2 0013
Revision: --025--- Serial number: 00000786438999 Coding: 0001286
     Shop #: WSC 05311 000 00000 VCID: 2F6D37A1BEC0B6397C-807A
 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-820-047.lbl
  Part No SW: 1K0 820 047 JD HW: 1K0 820 047 JD Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000 Shop #: WSC 00000 000 00000
    VCID: 6FEDF7A17E40F6393C-803A No fault code found.
  ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
  PartNoSW:3C8937049D HW:3C8937049D
Revision: 00H54000 Serial number: 00000009125181
Coding: 00880F0700041A00470A00000F000000000859435C000120000000000000 Shop #: WSC 05124 000 00000
     VCID: 326B3ED5ADF29BD113-8066
 Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB Component: Wischer 201108 022 0601
Coding: 00046997
Shop #: WSC 05124
No fault code found. -------------------------------------------------------------------------------
Self-Diagnosis Log Saturday,30,September,2017,13:18:43:56826 Page 3
     Address 15: Airbags Labels: 5N0-959-655.lbl PartNoSW:5N0959655A HW:5N0959655A Component: J234__00Q VW10 HI 1815
Revision: 19013000 Serial number: 0039DPQZAV1O Coding: 0012369
     Shop #: WSC 05311 000 00000 VCID: 3B7513F17AB85A99C0-806E
  Subsystem 1 - Serial number: 6333FTS691633018 Subsystem 2 - Serial number: 6343FTS635553408 Subsystem 3 - Serial number: 6353ETS6R6PVVVNR Subsystem 4 - Serial number: 6363ETS6RQ45V5KJ Subsystem 5 - Serial number: 00000000000000000 Subsystem 6 - Serial number: 00000000000000000
       ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
  Part No SW: 3C0 953 549 AT HW: 3C0 953 549 AT Component: J0527 0030
Revision: 00034000 Serial number: 3C9953507CE Coding: 0000004
    Shop #: WSC 05314 000 00000 VCID: 7EF3DAE5292A8FB1A7-802A
 ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
  PartNoSW:3C0920971R HW:3C0920971R Component: KOMBI H04 0107
Coding: 460F00
    Shop #: WSC 05314 115 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040 ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod VCID: 346738CD9FE695E101-8060
Self-Diagnosis Log Saturday,30,September,2017,13:18:43:56826 Page 4
     Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb Part No SW: 3C0 907 530 L HW: 3C0 907 951 Component: J533__Gateway H13 0152
Revision: H13 Serial number: 3300P08C0804AD Coding: F9801F06404202002003
     Shop #: WSC 05314 000 00000 VCID: 2A5B26B58522D311AB-807E
 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb
  Part No SW: 3C0 959 433 AQ HW: 3C0 959 433 AQ Component: IMMO 044 0383
Revision: 00044000 Serial number: VWZCZ000000000 Shop #: WSC 131071 1023 2097151
    VCID: 79F9C9F93004A88992-802C
 Subsystem 1 - Part No: 3C0 905 861 G Component: ELV 027 0380 3C0905861G ELV 027 0380
Self-Diagnosis Log Saturday,30,September,2017,13:18:43:56826 Page 5
     Address 37: Navigation (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 680 B HW: 1T0 035 680 BX Component: RNS-MID H03 1200
Revision: AB001001 Serial number: VWZ6Z7H6306026 Coding: 000004000000000000
     Shop #: WSC 00000 000 00000 VCID: 2D512DA974CCC4294E-8078
  000- -
  Fault Status: 01100000 Fault Priority: 5
Fault Frequency: 254 Reset counter: 140 Mileage: 258328 km Time Indication: 0
      00878 - Connection to Speaker Front Left 007 - Short to Ground
Fault Status: 01100111 Fault Priority: 5
       ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
  Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N Component: J386 TUER-SG FT 1518
Revision: 72009005 Serial number: 00000628989110 Coding: 0000565
    Shop #: WSC 05311 000 00000 VCID: 6FEDF7A17E40F6393C-803A
 ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
  Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 195 2501 Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C5720AD8FD6CD2159-8078
Self-Diagnosis Log Saturday,30,September,2017,13:18:43:56826 Page 6
Address 46: Central Conv. Labels: 3C0-959-433-46.clb Part No SW: 3C0 959 433 AQ HW: 3C0 959 433 AQ Component: KSG PQ46 ELV 044 0612
Revision: 00044000 Serial number: VWZCZ000000000 Coding: 0191020851030E763004941570085BCE103C01 Shop #: WSC 05311 000 00000
 Subsystem 1 - Part No: 1K0 951 605 D Component: LIN BACKUP HORN H08 9001
Subsystem 2 - Part No: 3C0 951 171 C Component: Neigungssensor 004 0611
Subsystem 3 - Part No: 3C0 951 171 C Component: Innenraumueberw.004 0611
       ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
  Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N Component: J387 TUER-SG BT 1518
Revision: 72009005 Serial number: 00000513489111 Coding: 0000564
    Shop #: WSC 05311 000 00000 VCID: 70EFF4DD637EE9C125-8024
  012 - Electrical Fault in Circuit - Intermittent Freeze Frame:
  Fault Status: 00101100 Fault Priority: 4
Fault Frequency: 7 Reset counter: 153 Mileage: 262653 km Time Indication: 0 Date: 2011.10.29 Time: 17:29:45
Self-Diagnosis Log Saturday,30,September,2017,13:18:43:56826 Page 7
     Address 53: Parking Brake Labels: 5N0-907-801.clb PartNoSW:3C8907801A HW:3C8907801A Component: J540 EPB3 VW-10498 0003
Revision: 009 Serial number: 00000000217648 Coding: 0000057
     Shop #: WSC 05311 000 00000 VCID: 285FDCBD9B2EE101BD-807C
  Fault Status: 00111100 Fault Priority: 1
Fault Frequency: 6 Reset counter: 177 Mileage: 265380 km Time Indication: 0 Date: 2012.01.07 Time: 07:41:03
        Freeze Frame: Voltage: 11.00 V
  Count: 10
Speed: 0.0 km/h Hex Value: 0x12E0 Hex Value: 0x0001 Hex Value: 0x0202
Self-Diagnosis Log Saturday,30,September,2017,13:18:43:56826 Page 8
     Address 56: Radio (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 680 B HW: 1T0 035 680 BX Component: RNS-MID H03 1200
  000- -
       ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
  Part No SW: 3C0 907 441 HW: 3C0 907 441 Component: J772__Rearview 0042
Revision: 00H05000 Serial number: PA8 J8X0064 Coding: 0000007
    Shop #: WSC 05311 000 00000 VCID: 5FCD87618EE066B98C-800A
End-------------------------(Elapsed Time: 01:45)--------------------------
Any feedback appreciated
Danners74
C?ID=273244
Yes they are variable displacement. Check the gas content first around 525grammes should be in there. The compressor is more than likely the cause. They shear on the pulley end. Rather pants idea.
Hi all,
16:14:48
and the AutoScan
Coding: 00046997
Shop #: WSC 05124
Coding: 460F00
  000- -
  Count: 10
  000- -
Klaus Ludwig
C?ID=227092
Thanks Danners74! Looks like it may be interesting to access.The fact that there is virtually no change in pressure when the throttle is applied ties in with your comments. Might have a look at it sometime!
Jef
HQ
Start engine, let idle. Set HVAC to coldest setting. Connected to HVAC and look at MVB group 001.1, what is the Shut-Off Code number?
Klaus Ludwig
C?ID=227092
Hi Jef,
I have checked for Shut-Off Code number as suggested (HCAV on coldest setting).
Selected HVAC data:-
Tuesday,17,October,2017,11:25:13:27553
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
Mileage: 165616   Repair Order:
11:24:00
  0.0   Compressor Shut-Off Code
  700 /min   Engine Speed
  2.6 Nm   Compressor Load
  7.4 bar   Refrigerant Pressure
  0.0 %   Radiator Fan Activation (actual)
  12.0∞C   Outside Temp. (filtered)
  61.0∞C   Coolant Temperature
  14.0∞C   Evaporator Temperature
  ON   Fan/Blower Status
Not sure what this indicates...
Klaus Ludwig
C?ID=227092
I believe it indicates that most likely the compressor is not doing what it is supposed to - as opposed to having tripped / cut out.
Jef
HQ
You would be correct... if the HVAC has no reason to shut the compressor down, but the compressor is not working to factory design, then odds are the compressor itself is dead.
Klaus Ludwig
C?ID=227092
Thanks! - Seems the most likely given other feedback elsewhere, but appreciate your advice. Always good to know that VCDS can give a little more insight into what is going on if you know where to look.
