Hi all, having an issue coding up module 13. Followed all other guides but no success on adjusting code accordingly so reverted back to original. Have tried adjusting third byte as per other suggestions but code rejected.
Results from full scan:
Welcome any guidance as I believe this is all that is left! Westfalia kit is good and nice after market setup which integrates with factory swivel bar pretty well
Many thanks for any pointers.
Cheers
Paul
VCDS Version: Release 12.12.2 (x64)
Data version: 20140212
Saturday,30,August,2014,00:53:43:52379
Chassis Type: 8R (8T0)
Scan: 01 02 03 05 08 09 0E 10 13 14 15 16 17 19 1B 20 42 46 52 53
55 56 5F 62 69 6C 6D 72
VIN: WAUZZZ8R09A005482 Mileage: 88380km/54916miles
Address 01: Engine (J623-CCWA) Labels: 059-907-401-CAP.clb
Part No SW: 8R0 907 401 J HW: 8K1 907 401 A
Component: 3.0TDI EDC17 H01 0008
Revision: 15H01---
Coding: 0121002C240F0A20
Shop #: WSC 06335 123 12345
ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
ROD: EV_ECM30TDI0118R0907401J.rod
VCID: 3972C442B89509D69C9-806C
4330 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 88385 km
Date: 2014.08.29
Time: 23:43:54
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8R0 927 156 AD HW: 0B5 927 156 E
Component: 0B5 30 TDIRdW H04 0002
Revision: --H04--- Serial number: 0000000349
Shop #: WSC 00060 210 176746
ASAM Dataset: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 7DFA1052EC3DF5F6F01-8028
Address 03: ABS Brakes (J104) Labels: 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 C HW: 8R0 907 379 C
Component: ESP8 quattro H06 0230
Coding: 0FFD00
Shop #: WSC 06335 001 12345
VCID: 4084A9A6D34F581EDB7-8015
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 AQ HW: 8K0 907 064 AQ
Component: BCM2 1.1 H80 0143
Coding: 051500
Shop #: WSC 06335 000 00000
VCID: 7F06EA5AEE31E7E6E2D-802A
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
Part No SW: 8T2 820 043 T HW: 8T2 820 043 T
Component: KLIMA 3 ZONEN H06 0140
Revision: D1000000 Serial number: 0124.09.080237
Coding: 36150000
VCID: 438EA6AAC2594306C65-8016
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000248302
Coding: 2600D0914074AF311F01000300001D0D4F9DE74800010141000000
VCID: 3064F96663EFC89E2B7-8065
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 080625 H10 0041
Coding: 01DD13
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA
Component: E1 - LDS H07 0080
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 L HW: 4E0 035 110 A
Component: CDC-MP3-Pana H47 0050
Revision: 00000011
VCID: 21420C2238057116B49-8074
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 E HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0020
Revision: 11001001 Serial number: 52840828702712
Coding: 310105
VCID: 3B7EDE4ABAA93BC68E5-806E
Address 13: Auto Dist. Reg (J428) Labels: Redir Fail!
Part No SW: 8R0 907 561 HW: 8R0 907 561
Component: ACC2 H01 0020
Coding: 0079B6
VCID: F6E88F7E410B26AE31B-80A3
Reset counter: 143
Mileage: 88385 km
Date: 2014.08.30
Time: 00:32:24
Temperature: 27.0°C
Voltage: 11.14 V
Bin. Bits: 01000
Hex Value: 0x044B
Hex Value: 0x0002
Speed: -3.6 km/h
Lateral Accel.: 0.00 m/s^2
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8R0 907 364 A HW: 8K0 907 364
Component: DAEMPFUNGS-SG H08 0051
Revision: 00000000 Serial number: 08100804630002
Coding: 070181
Shop #: WSC 00048 210 91003
VCID: 3874C1468B9F10DE637-806D
Address 15: Airbags (J234) Labels: 8R0-959-655.clb
Part No SW: 8R0 959 655 B HW: 8R0 959 655 B
Component: AirbagVW-AU10 H02 0310
Serial number: 003E8D024W6$
Coding: 30353131313030303030554A305238523053
ASAM Dataset: EV_AirbaAU10SMEAU416 001001
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 438EA6AACA594306C65-8016
Serial number: 6334MSME42752179A
Serial number: 6344MSME3F063469K
Serial number: 6352QSME57111412%
Serial number: 6362QSME780E1D3AY
Serial number: 63732SME5F0F02283
Crash sensor for front airbag; passenger side:
Serial number: 63832SME3609291A/
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90319HJA0004M
Coding: 00003F
VCID: 3E78D75EA9BB2EEEA9B-806B
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 980 G HW: 8R0 920 980 G
Component: KOMBIINSTR. H07 0224
Revision: 00100000 Serial number: 9EX61M9A8
Coding: 2F0722003F002600010400
VCID: 3D7AD052A4BD35F6B01-8068
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 L HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0094
Revision: 4FB50047 Serial number: 4700F08A108020
Coding: 000303
VCID: 4A908B8EE573924E053-801F
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0100
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 C HW: 8K0 907 144 C
Component: DYNAMIKLENK. H06 0500
Revision: 50001003 Serial number: --------------
Coding: 020000
Shop #: WSC 06334 000 00000
VCID: 2F66FA1A7ED1D76632D-807A
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8K0 857 511 C HW: 8K0 857 511 A
Component: FLA H04 0003
Revision: AA001002
Coding: 02022064747464545425363E
VCID: 3162FC6268E5C196249-8064
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000007811754
Coding: 011D12205001440004
VCID: 4182ACA2D8455116D49-8014
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0115366161
Coding: 013B0E2220393495042005
Shop #: WSC 06342 000 00000
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
Subsystem 4 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J394EE16SKB10 H01 0180
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000007830863
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 F HW: 8K0 907 801 F
Component: EPB Audi B8 H06 0070
Revision: 00000003 Serial number: 00000000252235
VCID: 3260F36E6DE3FA8E5D3-8067
Address 55: Xenon Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 A HW: 8H0 907 357
Component: AFS 1 H01 0020
Coding: 0000022
VCID: 3064F966A3EFC89E2B7-8065
Part No SW: 4F0 035 056 B HW: 4F0 035 056
Component: Radio U STD H43 0020
Revision: AB001007 Serial number: 342J4087518987
Coding: 010003020100000001
VCID: 1F460ADA0E7147E682D-804A
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
Fault Status: 00101011
Reset counter: 163
Voltage: 12.10 V
03029 - Subwoofer (R157)
Reset counter: 183
Voltage: 11.80 V
Reset counter: 183
Mileage: 88385 km
Date: 2014.08.29
Time: 16:15:42
Bin. Bits: 00000000 00000001
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T2 035 666 D HW: 8T2 035 666
Component: H-BN-EU H60 0047
Revision: -------- Serial number: 344JX087508531
Coding: 010101060105E9FF25001F1E000000030001
VCID: 3C7CDD56BFA73CFE87F-8069
Subsystem 1 - Part No: 8R0 060 884
Component: EUROPE 2008 5505
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000007853194
Coding: 010C12204001240004
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 D HW: 8K0 907 383 D
Component: Anhaenger H09 0100
Revision: 1G001001 Serial number: 00008200507765
Coding: 0100000000000000
VCID: 356AC8729C8DEDB6781-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 8R0 907 441 HW: 4L0 907 441 A
Component: J772__Rearview 0070
Revision: --H12--- Serial number: 525PA8-J89A0PH
Coding: 1033010
Shop #: WSC 06435 000 00000
VCID: F3EEB66A92793386165-80A6
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 A HW: 8R0 827 851
Component: J605 Master H24 0210
Revision: -------- Serial number: 8R0827851
VCID: 3A70DB4EB59302CE953-806F
Subsystem 1 - Part No SW: 8R0 827 852 A HW: 8R0 827 852
Component: J756 Slave H24 0240
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000007853244
End ---------------------------------------------------------------------
Cheers
Paul
