Removing hill hold on 5Q0 614 517 ABS?
jimmy007
C?ID=316731
Are there any known tweaks to 5Q0 614 517 ABS (2017 Golf)? I'm hoping to disable hill hold assist, but I can't find any docs for this part.
Address 03: ABS Brakes (J104) Labels:| 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AQ HW: 5Q0 614 517 AF
Component: ESC H62 0400
Revision: 00000000 Serial number: 50177000000740
Coding: 04FA6AA1242209754078020480C52920562490024001943400435050C002430000000012121212B835351919323200
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
ROD: EV_Brake1UDSContiMK100ESP_036_VW37.rod
VCID: 005A88F64A8D7ED75BA-8054
Jimmy: the way to disable hill hold in the older ABS modules used to be to set Byte 25, Bit 0 =0 & Bit 1=0. Your module has the newer/larger 46 x Byte module. However, in your module Byte 25 has a value hex43 (or binary 01000011). So Bit0 & Bit1 are both set high - suggesting the the same tweak might work . But I'm guessing.
Coding: 04FA6AA1242209754078020480C52920562490024001943400[B][COLOR="#0000FF"][SIZE=4]43[/SIZE][/COLOR][/B]5050C002430000000012121212B835351919323200
[B]New Code?[/B]
04FA6AA1242209754078020480C52920562490024001943400[B][COLOR="#0000FF"][SIZE=4]40[/SIZE][/COLOR][/B]5050C002430000000012121212B835351919323200
jimmy007
C?ID=316731
Thanks, that seemed to work. Mega back-rolling kudos to you guys for a great product + great support.
localstring
C?ID=349217
Sorry guys for bringing this up again, but I guess it isn't necessary to start a new topic for this.
Because you guys helped me out really great the last time :thanks: I would like to ask you this hoping that someone could help me again.
I have a Seat Leon Facelift (2017) and also the newer (46 Byte) ABS module, nearly the same as jimmy007 but with hill hold not enabled.
Adresse 03: Bremsenelektronik (J104)       Labeldatei: 5Q0-907-379-IPB-V1.clb
   Teilenummer SW: 5Q0 614 517 CF    HW: 5Q0 614 517 AD
   Bauteil: ESC           H25 0513
   Revision: 00000000    Seriennummer: 60657000002378
   Codierung: 20EE6A92342521708780060140CC2804562C84E16002147518[B][COLOR="#0000FF"][SIZE=4]42[/SIZE][/COLOR][/B]5074C229430000000012121212B835351919323200
   Betriebsnr.: WSC 00049 770 00102
   ASAM Datensatz: EV_Brake1UDSContiMK100IPB 036010
   ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
   VCID: 77AA1D386F4116CFFB3-8022
I want to enable the hill hold assist because I like the "classic" hill hold better than auto hold.
So I assume I have to set Byte 25, Bit 0=1, which changes my coding to
20EE6A92342521708780060140CC2804562C84E16002147518[B][COLOR="#0000FF"][SIZE=4]43[/SIZE][/COLOR][/B]5074C229430000000012121212B835351919323200
Can I apply this coding especially considering the fact that my car has Auto Hold or would there be any trouble?
I should also mention that my module's SW/HW is slightly different from jimmy's.
Btw: May I ask, jimmy007 do you have DSG or manual? Do you have auto hold?
