2007 Audi Q7 had ecu read and came back with a skc that is 5 digits
mejho
C?ID=309579
Ecu dump for security code. SKC came back as a 5 digit 1XXX8 is this normal? Meaning 5 digit code. This code should be it for key adaption and is it necessary to go through the ecu or would this code work fro sec/start authorization module?
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Yes this car has 5 digit SKC.
mejho
C?ID=309579
I have enclosed an auto scan for Q7 any help very appreciated
the following is auto scan as of today. Had a dump for skc came back as 5 digit code cannot get new key adapted to car. The numerous systems off line are an obvious problem as well. Any help or direction of where to start would be appreciated. Thanks
Wednesday,20,September,2017,19:39:31:43981
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
          55 56 61 62 65 69 6D 6F 72 77
   Mileage: 189640km-117836miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601100607161
   Coding: 0000131
   Shop #: WSC 31414 790 00001
   Subsystem 1 - Part No: 4F0 910 131 J
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 220 G
   Component: FBSAUDIC6 IDG   H01 0053
16347 - Control Module - EEPROM Error
                    Fault Status: 01111110
                    Reset counter: 158
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L0 910 731 N    HW: 4E0 035 729
   Component: Interfacebox    H43 4140
   Revision: 00000000    Serial number: 308KZ067513676
   Coding: 0002003
00658 - Control Head
                    Reset counter: 158
                    Time: 12:45:19
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 198
                    Time: 12:28:38
02244 - Button in Control Head is Stuck
                    Time: 18:10:08
                    Bin. Bits: 00000011
                    Bin. Bits:      111
                    Reset counter: 198
                    Time: 13:22:00
                    Reset counter: 198
                    Time: 17:32:23
                    Bin. Bits:      001
   Component: KLIMABETAETIGUNGH05 0060
   Coding: 0524326
   Component: ILM Fahrer      H17 0240
   Coding: 0014123
                    Fault Status: 01111011
                    Reset counter: 158
                    Mileage: 189640 km
                    Date: 2006.11.23
                    Time: 16:18:00
01494 - Bulb for Parking Lamps; Left (M1)
                    Reset counter: 158
                    Mileage: 189640 km
                    Date: 2006.11.23
                    Time: 17:02:00
01498 - Bulb for Parking Lamps; Right (M3)
                    Reset counter: 158
                    Mileage: 189640 km
                    Date: 2006.11.23
                    Time: 17:02:00
   Part No SW: 4L0 910 110 A    HW: 4L0 035 110
   Component: MP3-Changer     H43 0350
   Revision: 00043000    Serial number: AUZ5ZBF1019772
                    Reset counter: 198
                    Time: 13:22:25
02446 - Disk Drive Mechanical Malfunction
                    Reset counter: 198
                    Time: 12:00:35
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Component: SDAR SIRIUS     H06 0080
                    Fault Status: 00100001
                    Reset counter: 198
                    Mileage: 189643 km
                    Date: 2006.11.23
                    Time: 16:54:38
                    Voltage: 15.80 V
Address 15: Airbags
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H08 0230
   Revision: 00H08000    Serial number: 90054063010194
   Coding: 0002042
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 980 H
   Component: KOMBIINSTR. M73 H17 0170
   Revision: 00700000    Serial number: 5HH73EYC6
   Coding: 2641268
   Shop #: WSC 06128 067 57207
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468     HW: 4L0 907 468
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0900B06B12809F
   Coding: E7D7BE77303A02
   Shop #: WSC 06117 444 84511
01304 - Radio
                    Reset counter: 158
                    Mileage: 189643 km
                    Date: 2006.11.23
                    Time: 12:23:01
   Part No SW: 4F0 910 760     HW: 4L0 959 760
   Component: Sitzmemory FS   H01 0100
   Revision: 00000000    Serial number: 00000000896401
   Coding: 0082946
   Part No SW: 4E0 910 888 D    HW: 4E0 919 887 L
   Component: MNS US          H48 0970
   Revision: 00000000    Serial number: 313KQ067513086
                    Reset counter: 198
                    Time: 13:22:19
                    Hex Value: 0x5845
                    Hex Value: 0x0054
                    Reset counter: 198
                    Time: 16:53:09
                    Hex Value: 0x4565
                    Hex Value: 0x00A4
                    Reset counter: 196
                    Time: 19:55:49
                    Bin. Bits:     1100
Address 46: Central Conv.
Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
   Component: DSP-High AU716  H03 0150
   Coding: 0000016
                    Mileage: 189644 km
                    Date: 2016.12.05
                    Voltage: 8.30 V
   Component: ILM Beifahrer   H10 0080
   Coding: 0012001
                    Reset counter: 198
                    Time: 16:53:00
                    Voltage: 16.100 V
Address 52: Door Elect, Pass.
Address 55: Headlight Range
Address 56: Radio
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Component: J0644 BEM       H12 0530
   Component: von VA0  2611192794
                    Mileage: 189643 km
                    Date: 2006.11.23
                    Time: 12:05:16
Address 62: Door, Rear Left
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273 B    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000900036852
   Coding: 0062424
                    Reset counter: 196
                    Time: 19:55:48
                    (no units): 3.0
                    (no units): 36.0
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 198
                    Time: 19:16:55
                    (no units): 75.0
                    (no units): 61.0
                        Not Recogn.
                        Not Recogn.
Address 69: Trailer        Labels: 4E0-910-383.lbl
   Component: ANHAENGERELEKTR 004 0060
                    Reset counter: 198
                    Time: 19:53:00
                    Reset counter: 198
                    Time: 17:05:00
Address 6D: Trunk Elect.        Labels: None
   Component: ValeoHeckdeckel H21 0280
   Shop #: WSC 98765 666 38354
                    Mileage: 189643 km
                    Date: 2006.11.23
                    Reset counter: 198
                    Time: 19:49:48
Address 6F: Centr. Conv. II
Address 72: Door, Rear Right
   Component: Handyvorb2      H16 1130
   Coding: 0010900
Jetta 97
C?ID=81680
If you tell us little history on it , maybe we can be able to figure out what is going on?
Was it running before?
Did car had key at all, and where did you get key?
More we know , it will be easy to help you.
mejho
C?ID=309579
I purchased car at impound auction, no keys, not running...so no real history on car. I purchased new key at dealer, based on VIN of vehicle. Battery was shot when I received vehicle. I put new battery in car. I of course have not towed/flatbed car to dealer for key adaption. Had recent dump from ecu to get skc code. I have code and reinstalled ecu. The login did not take code. you can see from auto scan that many systems seem to be offline/inaccessible.
Thanks again for response
Zenerdiode
Newcastle, England
C?ID=24330
Hi Damien,
How are you collecting the results of your Auto-Scan? I'm not so much talking about using HTML-Code tags against Code tags, but there seems to be some stuff missing from your scan. Did you use the 'Copy' button once the scan completed? That's generally the quickest and easiest method as it places the entire scan on the clip-board for an easy right-click paste into the forum.
Jetta 97
C?ID=81680
Many systems are Off line because ignition is not On, That is normal on this car .
Can you please clear all codes and see what comes back and post here , When you post Auto scan use #,
you want to have it in [ CODE ] Auto scan [ CODE ]
I am worry about this code:
Coding: 0000131
Reset counter: 158
mejho
C?ID=309579
scan after clearing codes.
Sorry for clipping last scan post. This is the scan after clearing codes. I cannot get access to immobilizer it comes back as not communicating with software.
 Thursday,21,September,2017,15:19:20:43981
Chassis Type: 4L0
07-Control Head -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
47-Sound System -- Status: Cannot be reached 1100
Address 01: Engine
Address 15: Airbags
   Coding: 2641268
01304 - Radio
                    Reset counter: 158
                    Mileage: 189643 km
                    Date: 2006.11.23
                    Time: 13:04:41
Address 56: Radio
Address 69: Trailer
End----(Elapsed Time: 00:37, VBatt start/end: 12.2V/12.3V. VIgn 0.0V)------
mejho
C?ID=309579
Christopher,
I see what you meant, I must of clipped the bottom off when I did select all. Thanks
Jetta 97
C?ID=81680
You have to turn Hazards On, hold the brake for 30 Sec then and switch light of and on, After this you should be able to communicate with 05-Start Authorization and all other modules what has wake up signal.
mejho
C?ID=309579
I missed the hazards part, have done brake pedal and flicked the highbeam switch to flash lights. I will try that.
I have been able to open 05 start authorization module but the others still were not communicating. I will try this tonight or tomorrow and report my findings.
Thank you for the help.
mejho
C?ID=309579
Did the hazards,brake and lights flash. Would not bring immobilizer module on line and ecu not online or cannot be reach. Here is the results of the auto scan right after trying to wake system up
  Saturday,23,September,2017,16:01:24:43981
Chassis Type: 4L0
Address 01: Engine
   Coding: 0000131
   Part No SW: 4L0 910 043     HW: 4L0 820 043 F
   Revision: 00---012    Serial number: 00000000198185
   Coding: 0524326
   Shop #: WSC 06117 444 53447
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Coding: 0014123
   Subsystem 1 - Component: Fehler Lin-Slave 01
   Subsystem 2 - Component: Fehler Lin-Slave 02
                    Reset counter: 158
                    Time: 12:30:00
                    Reset counter: 158
                    Time: 12:45:00
                    Reset counter: 158
                    Mileage: 189640 km
                    Date: 2006.11.25
                    Time: 12:45:00
Address 15: Airbags
   Coding: 0002042
   Coding: 2641268
01304 - Radio
                    Reset counter: 158
                    Mileage: 189643 km
                    Date: 2006.11.23
                    Time: 13:04:41
   Coding: 0082946
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Revision:             Serial number: 00000000060095
   Coding: 0012001
Address 56: Radio
   Part No SW: 4L0 910 181     HW: 4L0 915 181
   Revision: --------    Serial number: 00000000062442
   Subsystem 1 - Part No: 4F0 915 105 D
   Coding: 344630393135313035442056413032363131313932373934
                    Date: 2006.11.23
                    Time: 12:58:50
   Coding: 0062424
                    Reset counter: 196
                    Time: 19:55:48
                    (no units): 3.0
                    (no units): 36.0
                        Not Recogn.
                        Not Recogn.
                    Fault Status: 10100100
                    Fault Frequency: 143
                    Reset counter: 198
                    Mileage: 181969 km
                    Date: 2016.07.28
                    Time: 19:16:55
                    (no units): 75.0
                    Voltage: 14.20 V
                    (no units): 61.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Part No SW: 4E0 910 383 C    HW: 4E0 907 383 C
   Coding: 0000002
                    Reset counter: 198
                    Time: 19:53:00
                    Reset counter: 198
                    Time: 17:05:00
                    Reset counter: 198
                    Mileage: 189643 km
                    Date: 2006.11.23
                    Time: 12:43:26
02242 - Rear Lid Lock Button in Luggage Compartment (E406)
                    Fault Frequency: 45
                    Reset counter: 198
                    Mileage: 187894 km
                    Date: 2016.10.01
                    Time: 19:49:48
End----(Elapsed Time: 01:19, VBatt start/end: 13.3V/13.3V. VIgn 0.0V)------
Immobilizer module in this car is Address 05: Acc/Start Auth. and it's on-line in the above scan.
Gone But Not Forgotten
Sounds to me like OP should check terminal relays and fuses plus ignition switch.....and especially for water ingress in all known tsb areas starting with modules that are dead to wake!
Kessy is indeed awake but with dtc for eeprom.....most likely has water ingress and should be checked.
mejho
C?ID=309579
Uwe,
Thanks, I was not sure if it was a separate or part of that module. I tried to do the key adaption through this, did not accept code. Will dive into it further. Again thank you.
mejho
C?ID=309579
Jack,
Thank you. I will explore those areas and definitely check modules for water, seems to be a common issue.
Jetta 97
C?ID=81680
Uwe,
VCDS will not be able to adopt keys on this car. I tied that before and every time same situation like you have , refuse SKC .
Can you go to 05- Acc/Start Auth
Measuring block 22, 23, 24 and post data here in all fields?
Also go to Advance ID-1A , and copy paste all data here , please?
Measuring block 22, 23, 24 and post data here in all fields.
Why?
The controllers are clearly off line.........!
Individual block values isn't going to tell you shit until stuff is corrected to be back online.
Marrying a key or no marrying a key!
All OP needs to do first is get it to start and die with com then play GeKo.
And by start and die I mean trigger starter remote if ESC is running interference.
