Hello guys!
Ever since I bought my car back in 2014, I've been annoyed at the original Cruise Control.
In isolation, it works fine - but the whole concept of cruise control kind of requires you to be dead alone on the road.
So, I've wanted to retrofit adaptive cruise control for my car!
I've checked if this is possible before, and I've been told it cannot be done unless the car came specced with it from factory.
Now, I'm half-doubtful about this, since it's virtually possible to buy any component and/or control module for any given VW, and in my recently aquired VCDS I have the possibility of activating the Adaptive Cruise Control feature.
Obviously, I've not tried that since I'm probably missing a heap of components.
Anyways, I wanted to check with you guys - Who knows this stuff well - If this can be done.
Is the answer yes? Great! I'll just need to figure out what I need to buy and do. My qualified guess tells me I need:
I'm asking for much now I know, so please know that I greatly appreciate any given answers
- A front-mounted radar (I think the 3C/B6 has the radar in the front emblem)
- A new cruise control module (CAN-unit)
- A new handle-column for the steering wheel
- A new ABS-pump (I think - The car has Auto-Hold which I believe utilizes the ABS-pump for braking purposes)
- Some clever coding in VCDS
Tuesday,12,September,2017,19:43:44:12369
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: WVWZZZ3CZAE057230 License Plate:
Chassis Type: 3C-N/A (3C0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 36 42 44 46 52 53 55
62 65 72
VIN: WVWZZZ3CZAE057230 Mileage: 270490km-168074miles
10-Park/Steer Assist -- Status: Not registered 0001
Address 01: Engine (AXZ) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 HB HW: 03H 906 032 AB
Component: P3.2-FSI-EU4 G 4845
Revision: 5GH04--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 05311 000 00000
VCID: 698CB511257AE75FEC4-803C
000807 - Knock Sensor 1 (G61)
P0327 - 002 - Signal too Low - Intermittent
Mileage: 268402 km
Date: 2011.12.03
Time: 23:54:26
RPM: 2602 /min
Load: 73.3 %
Speed: 35.0 km/h
Temperature: 85.0°C
Temperature: 24.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.843 V
012408 - Throttle Control
P3078 - 002 - Airflow at Idle too Low - Intermittent
Mileage: 269536 km
Date: 2011.12.25
Time: 21:26:37
RPM: 621 /min
Load: 24.3 %
Temperature: 88.0°C
Temperature: 23.0°C
Voltage: 13.208 V
Part No SW: 02E 300 011 DA HW: 02E 927 770 AM
Component: GSG DSG AG6 531 1982
Revision: 06253104 Serial number: 00001509260786
Shop #: WSC 04940 001 00001
VCID: 51FC7DF1ADEA3F9F844-8004
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --025--- Serial number: 00000795617354
Coding: 0000395
VCID: 629EA23DD84CB4072DE-8036
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 EB HW: 3C0 907 044 EB
Component: ClimatronicPQ46 133 1010
Revision: 00133026 Serial number: 00000000000000
VCID: 6594B921C962C33FC8C-8030
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000003327726
Coding: F78E8B07500214001F00325A32000000801B354364400100000000000000
Shop #: WSC 00027 218 80666
VCID: 3330177937366D8F968-8066
Subsystem 1 - Part No: 3C1 955 419 B Labels: 1KX-955-119.CLB
Component: Wischer 140709 006 0208
Coding: 00049045
Shop #: WSC 00027
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 160909 046 0204
Coding: 00131149
Shop #: WSC 00027
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 3C8 919 475 A HW: 3C8 919 475
Component: PARKHILFE 8K H07 0009
Revision: -------- Serial number: 08720924603904
Coding: 100102
Shop #: WSC 05314 000 00000
VCID: 323E127DC42C64879DE-8066
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0070
Revision: 00000000 Serial number: 15090903270001
Coding: 010180
VCID: 2708F329FFEE112F3A0-8072
Part No SW: 5N0 959 655 H HW: 5N0 959 655 H
Component: J234__025 VW10 HI 1916
Revision: 20013000 Serial number: 003E1PKCQE3W
Coding: 0012853
VCID: 42DE42BD788CD4070DE-8016
Subsystem 1 - Serial number: 6332MTS628722449
Subsystem 2 - Serial number: 6342MTS680052369
Subsystem 3 - Serial number: 6351HTS6PM8N09KJ
Subsystem 4 - Serial number: 6361HTS61P4119KJ
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
Component: J0527 0030
Revision: 00032000 Serial number: 3C9953507CN
Coding: 0001612
VCID: 74B2D46572B82AB74F2-8020
Subsystem 1 - Part No: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H07 0022
Coding: 00000227
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb
Part No SW: 3C8 920 880 F HW: 3C8 920 880 F
Component: KOMBI H03 0132
Coding: 161F00
ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
VCID: 2F381B09D79E496FF20-807A
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 L HW: 3C0 907 951
Component: J533__Gateway H13 0152
Revision: H13 Serial number: 3300P099290305
Coding: FD8BFF07000002002002
Shop #: WSC 00027 218 81049
VCID: 2A0E0A1DE0FC2C4725E-807E
Reset counter: 195
Mileage: 270492 km
Date: 2012.02.03
Time: 19:34:37
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BS 907 554 A HW: 0BS 907 554 A
Component: Haldex 4Motion 4013
Coding: 0000005
VCID: 44D244A56298DA373F2-8010
Part No SW: 3C0 959 433 AM HW: 3C0 959 433 AM
Component: IMMO 052 0383
Revision: 00052000 Serial number: VWZCZ000000000
Shop #: WSC 00040 218 58589
VCID: 75B4E96179C233BF78C-8020
Component: ELV 027 0380
3C0905861G ELV 027 0380
Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
Component: Sitzverstellung 1101
Revision: 00005000 Serial number: 00000000000000
VCID: 2F381B09DB1E496FF20-807A
Part No SW: 1K0 959 701 AS HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1501
Revision: 71009005 Serial number: 00000876798916
Coding: 0004599
VCID: 7F580B494BFE79EF220-802A
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 P HW: 5N1 909 148 J
Component: J500__APA-BS KL.318 1202
Revision: 1BH04737 Serial number: 00131890007201
Coding: 0000258
Shop #: WSC 00610 218 138159
VCID: 3FD84B490B7EB9EF620-806A
Component: KSG PQ46 RDK 052 0412
Coding: 0091020051034E7630041F1F700ACFCE705801
Subsystem 1 - Part No: 1K8 951 605
Component: LIN BACKUP HORN H09 9002
Component: Neigungssensor 004 0611
Part No SW: 1K0 959 702 AS HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1501
Revision: 71009005 Serial number: 00000759198910
Coding: 0004598
VCID: 005A88B5360006175BA-8054
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 010 Serial number: 00000000034334
Coding: 0000057
VCID: 2C020C05EA083277D72-8078
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Component: AFS-Steuergeraet 0142
Coding: 2346177
VCID: 3432146532386AB78F2-8060
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000035
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000001085550
Coding: 0000208
VCID: 70BAD87506A01697ABA-8024
Component: RDK 0453
Coding: 0161211
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0307
Revision: 41004101 Serial number: 00000001083423
Coding: 0000208
VCID: 71BCDD710DAA1F9FA44-8024
End----------(Elapsed Time: 01:32, VBatt start/end: 12.3V/12.3V)-----------
