Hey all!
What a first post this is going to be. Somewhat scared and excited
I'm from a relative shameful background.
Myself, as I think quite a few people don't care to admit, started out with a eBay-version of the VCDS-interface.
Lately, I've come to realise that I'm not actually a thief, and acknowledged the fact that people have worked tirelessly to develop both hardware and software (Even though the seller swore it was a genuine verison). So, I bought the new HEX-V2 directly from Ross-Tech. It is reasonably priced, and I wanted to "repent" my sins. Despite this (Which I actually didn't have to share with you, but honesty lasts longer, I'm lead to believe), I hope you'll welcome me in reaching me a hand on this one.
So hey, here I am.
When I had the chinese version, I think the software was limited to ver. 14.1 - I've done several mods on my car, and one which I did was to enter the engine module 01, and change the idle speed from the adaption menu.
Now, I get sporadic air-flow errors whilst idling, and sometimes clutch engagement from standstill seems "edgy", so I want to change the idle speed back. It was 800rpm to begin with, and I changed it to 600rpm. Don't ask me why - Because I honestly don't know.
Anyway, I tried changing the idle speed back to normal, but now when I open Engine 01 -> Adaption -> Idle speed, it says I need a security access code.
I can't remember if I ever entered that on the 14.1 version, but I'm used to a pop-up showing the corresponding security access codes. This pop up does not show on the latest version.
I tried code 12233, and the engine control module locked up. How do I find the appropriate code?
The car is a 2010 VW Passat 3.2FSI (AXZ engine code).
All help will be very appreciated, thanks!
So hey, here I am.
Tuesday,12,September,2017,19:43:44:12369
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: WVWZZZ3CZAE057230 License Plate:
Chassis Type: 3C-N/A (3C0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 36 42 44 46 52 53 55
62 65 72
VIN: WVWZZZ3CZAE057230 Mileage: 270490km-168074miles
10-Park/Steer Assist -- Status: Not registered 0001
Address 01: Engine (AXZ) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 HB HW: 03H 906 032 AB
Component: P3.2-FSI-EU4 G 4845
Revision: 5GH04--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 05311 000 00000
VCID: 698CB511257AE75FEC4-803C
000807 - Knock Sensor 1 (G61)
P0327 - 002 - Signal too Low - Intermittent
Mileage: 268402 km
Date: 2011.12.03
Time: 23:54:26
RPM: 2602 /min
Load: 73.3 %
Speed: 35.0 km/h
Temperature: 85.0°C
Temperature: 24.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.843 V
012408 - Throttle Control
P3078 - 002 - Airflow at Idle too Low - Intermittent
Mileage: 269536 km
Date: 2011.12.25
Time: 21:26:37
RPM: 621 /min
Load: 24.3 %
Temperature: 88.0°C
Temperature: 23.0°C
Voltage: 13.208 V
Part No SW: 02E 300 011 DA HW: 02E 927 770 AM
Component: GSG DSG AG6 531 1982
Revision: 06253104 Serial number: 00001509260786
Shop #: WSC 04940 001 00001
VCID: 51FC7DF1ADEA3F9F844-8004
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --025--- Serial number: 00000795617354
Coding: 0000395
VCID: 629EA23DD84CB4072DE-8036
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 EB HW: 3C0 907 044 EB
Component: ClimatronicPQ46 133 1010
Revision: 00133026 Serial number: 00000000000000
VCID: 6594B921C962C33FC8C-8030
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000003327726
Coding: F78E8B07500214001F00325A32000000801B354364400100000000000000
Shop #: WSC 00027 218 80666
VCID: 3330177937366D8F968-8066
Subsystem 1 - Part No: 3C1 955 419 B Labels: 1KX-955-119.CLB
Component: Wischer 140709 006 0208
Coding: 00049045
Shop #: WSC 00027
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 160909 046 0204
Coding: 00131149
Shop #: WSC 00027
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 3C8 919 475 A HW: 3C8 919 475
Component: PARKHILFE 8K H07 0009
Revision: -------- Serial number: 08720924603904
Coding: 100102
Shop #: WSC 05314 000 00000
VCID: 323E127DC42C64879DE-8066
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0070
Revision: 00000000 Serial number: 15090903270001
Coding: 010180
VCID: 2708F329FFEE112F3A0-8072
Part No SW: 5N0 959 655 H HW: 5N0 959 655 H
Component: J234__025 VW10 HI 1916
Revision: 20013000 Serial number: 003E1PKCQE3W
Coding: 0012853
VCID: 42DE42BD788CD4070DE-8016
Subsystem 1 - Serial number: 6332MTS628722449
Subsystem 2 - Serial number: 6342MTS680052369
Subsystem 3 - Serial number: 6351HTS6PM8N09KJ
Subsystem 4 - Serial number: 6361HTS61P4119KJ
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
Component: J0527 0030
Revision: 00032000 Serial number: 3C9953507CN
Coding: 0001612
VCID: 74B2D46572B82AB74F2-8020
Subsystem 1 - Part No: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H07 0022
Coding: 00000227
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb
Part No SW: 3C8 920 880 F HW: 3C8 920 880 F
Component: KOMBI H03 0132
Coding: 161F00
ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
VCID: 2F381B09D79E496FF20-807A
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 L HW: 3C0 907 951
Component: J533__Gateway H13 0152
Revision: H13 Serial number: 3300P099290305
Coding: FD8BFF07000002002002
Shop #: WSC 00027 218 81049
VCID: 2A0E0A1DE0FC2C4725E-807E
Reset counter: 195
Mileage: 270492 km
Date: 2012.02.03
Time: 19:34:37
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BS 907 554 A HW: 0BS 907 554 A
Component: Haldex 4Motion 4013
Coding: 0000005
VCID: 44D244A56298DA373F2-8010
Part No SW: 3C0 959 433 AM HW: 3C0 959 433 AM
Component: IMMO 052 0383
Revision: 00052000 Serial number: VWZCZ000000000
Shop #: WSC 00040 218 58589
VCID: 75B4E96179C233BF78C-8020
Component: ELV 027 0380
3C0905861G ELV 027 0380
Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
Component: Sitzverstellung 1101
Revision: 00005000 Serial number: 00000000000000
VCID: 2F381B09DB1E496FF20-807A
Part No SW: 1K0 959 701 AS HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1501
Revision: 71009005 Serial number: 00000876798916
Coding: 0004599
VCID: 7F580B494BFE79EF220-802A
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 P HW: 5N1 909 148 J
Component: J500__APA-BS KL.318 1202
Revision: 1BH04737 Serial number: 00131890007201
Coding: 0000258
Shop #: WSC 00610 218 138159
VCID: 3FD84B490B7EB9EF620-806A
Component: KSG PQ46 RDK 052 0412
Coding: 0091020051034E7630041F1F700ACFCE705801
Subsystem 1 - Part No: 1K8 951 605
Component: LIN BACKUP HORN H09 9002
Component: Neigungssensor 004 0611
Part No SW: 1K0 959 702 AS HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1501
Revision: 71009005 Serial number: 00000759198910
Coding: 0004598
VCID: 005A88B5360006175BA-8054
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 010 Serial number: 00000000034334
Coding: 0000057
VCID: 2C020C05EA083277D72-8078
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Component: AFS-Steuergeraet 0142
Coding: 2346177
VCID: 3432146532386AB78F2-8060
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000035
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000001085550
Coding: 0000208
VCID: 70BAD87506A01697ABA-8024
Component: RDK 0453
Coding: 0161211
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0307
Revision: 41004101 Serial number: 00000001083423
Coding: 0000208
VCID: 71BCDD710DAA1F9FA44-8024
End----------(Elapsed Time: 01:32, VBatt start/end: 12.3V/12.3V)-----------
