Side Assist/Blind spot retrofit help (2015 mk7 GTI)
I need to pick your brains on this, I installed a Side Assist retrofit kit from an online supplier. everything is hooked up and coded, however I cannot get communications between some controllers. The part number for the radar sensors is different from the ones normally used on these cars, but the seller swears that they are the same... here is my autoscan after the retrofit.
Address 3C: DTCs cleared
Address 5F,5G0 035 844 ,channel IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,adapted from,Databus extended ,to,Terminal 15 ,
Address 5F: DTCs cleared
Address 5F,5G0 035 844 ,channel IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,adapted from,Terminal 15 ,to,Databus extended ,
Sunday,10,September,2017,17:18:42:24044
VCDS Version: 17.8.0.1 (x64)
VIN: 3VW4T7AU2XXXXXXX License Plate:
Mileage: 52348km-32527mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 47 52 55 5F
75 A9
VIN: 3VW4T7AU2XXXXXXXX Mileage: 52348km-32527miles
Address 01: Engine (J623-CXCA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0006
Revision: --H13---
Coding: 091D00324424002F1000
Shop #: WSC 00066 790 00202
ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
ROD: EV_ECM20TFS0205G0906259A.rod
VCID: 2C79EA0D4756DB2606-8078
Part No SW: 0D9 300 041 T HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4511
Revision: 05853104 Serial number: TFK01412101379
ROD: EV_TCMDQ250021_VW37.rod
VCID: 2977131948A4CE0EFD-807C
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 53454000000334
Coding: 01FA6BA13427096F0080020681C32980D62C9000408194B410435050C085
Shop #: WSC 01383 790 50316
VCID: 47B3B5A1FEF0187E0B-8012
Revision: 00021000 Serial number: 0356326553
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3A55DC55BD02759684-806E
Part No SW: 5GM 907 426 A HW: 5GM 907 426 A
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 00020004200100000000000010000000
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 46ADB8A5F9FA0176F0-8012
Part No SW: 5Q0 937 087 R HW: 5Q0 937 087 R
Component: BCM PQ37BOSCH 028 0145
Revision: -------- Serial number: 86580601151384
Coding: 00111A464041A27969E44000011407201800000000000000000000000000
Shop #: WSC 00066 790 00206
ROD: EV_BCMBOSCH_014.rod
VCID: 4AB58C95EDE2E51614-801E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 141205 043 0581
Serial number: 150211015942
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S3Y14M11D26H22M52S13
Coding: 06A8DD
Sun Roof:
Subsystem 3 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H02 0003
Serial number: 0000FST0001WOUF00000
Coding: 181801
329480 - Heated Passenger Seat
B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
Fault Frequency: 6
Reset counter: 161
Mileage: 52099 km
Date: 2017.09.05
Time: 13:10:39
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39391433812357
Coding: 0031151011
VCID: 3D5FD749AC2C42AEA1-8068
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 14121403271837
Coding: 01001200FE033B
ASAM Dataset: EV_ACCMRRBoschVW372 001015
VCID: 3851C65D830E678672-806C
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM01SKSC
VCID: 51879BF900B4D6CE55-8004
Occupant Detection:
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J1500029IVO0Q
Coding: 303131
Subsystem 2 - Part No SW: ----------- HW: 480 000 612 14
Serial number: 35700000000A30543210
Subsystem 3 - Part No SW: ----------- HW: 480 000 612 14
Serial number: 35800000000597303213
Subsystem 4 - Part No SW: ----------- HW: 480 401 311 14
Serial number: 3510002BB188FC11D06C
Subsystem 5 - Part No SW: ----------- HW: 480 401 311 14
Serial number: 35200029D188FC109327
Subsystem 6 - Part No SW: ----------- HW: 480 402 511 14
Serial number: 3550002B718B3A749314
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 511 14
Serial number: 3560002B718B3A7261DA
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20141218400156
Coding: 0410
ROD: EV_SMLSVALEOMQB_VW37.rod
VCID: 042962AD8F46F366AE-8050
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5G1 920 856 HW: 5G1 920 856
Component: KOMBI 342 4270
Coding: 0BAD091A2988CF0502897A091000000000000000
VCID: 6BFB291182D81C1E4F-803E
16777008 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
Reset counter: 125
Mileage: 52348 km
Date: 2017.09.10
Time: 17:07:47
16776982 - Databus
Reset counter: 125
Mileage: 52348 km
Date: 2017.09.10
Time: 17:07:44
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 16011510000552
Coding: 0101000820085900FF00002A1C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07029
ROD: EV_GatewConti_011.rod
VCID: 72C53475A5F2CDD68C-8026
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0101
Serial number: 29140002882510035044
Coding: 29FFFF
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000015223004
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 3449F26D9F6683E65E-8060
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 5QD 907 686 HW: 5QD 907 686
Component: HRE_Master H12 0071
Serial number: 6055910562
Coding: 02011103
ROD: EV_HREntryHella_VW32.rod
VCID: 0E3D4085D10A893608-805A
341261 - Databus
Reset counter: 125
Mileage: 52348 km
Date: 2017.09.10
Time: 17:08:25
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 12011506050B9W
Coding: 003F1320D000040000000000
VCID: 40A1AEBDDBDE2F46CA-8014
Serial number: 00000000000000594835
Coding: 011000
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 9302
ROD: EV_SteerAssisMQB.rod
VCID: 3753C5618E1068FE7B-8062
23552 - Databus
Reset counter: 125
Mileage: 52348 km
Date: 2017.09.10
Time: 17:08:41
Motor status: 01
System status: Driving mode
Supply voltage: 13.25 V
Temperature: 42.0 °C
KFC: 5C
KFA: 00 00
Environmental conditions: 5F
uioUdNotFilt_xdu16: 13.34 V
uAdSensI_SwitchedKl30_xdu16: 13.34 V
21760 - Databus
Reset counter: 125
Mileage: 52348 km
Date: 2017.09.10
Time: 17:08:41
Motor status: 01
KFC: 55
KFA: 00 00
uioUdNotFilt_xdu16: 13.22 V
uAdSensI_SwitchedKl30_xdu16: 13.21 V
Part No SW: 5G0 035 456 HW: 5G0 035 456
Component: MIB_lite_amp H40 0060
Serial number: VWZ8Z1EC4023K5U
Coding: 22000000AAAAAA0000
ASAM Dataset: EV_AMPMst12C1ALPI 001007
ROD: EV_AMPMst12C1ALPI.rod
VCID: 63EB41316A08545EF7-8036
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 3001150605063O
Coding: 003F1320DC00040000000000
VCID: 3FA3AD41A62050BEB3-806A
Serial number: 00000000000000432560
Coding: 091000
Component: AFS-ECU H07 0090
Coding: 021A01010B000400
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0645
Serial number: V7B00401151412
Coding: 027300000000000021220002001800001F0203340100010002
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 64E9422D6F0653660E-8030
B11CF 53 [009] - Deactivated
Reset counter: 126
Mileage: 52348 km
Date: 2017.09.10
Time: 17:09:11
Voltage terminal 30: 13.2 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: Not available
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
6665 - No Communcation with Front Display/Control Module
U0257 00 [009] - -
Reset counter: 126
Mileage: 52348 km
Date: 2017.09.10
Time: 17:12:08
6691 - Data Bus for Control/Display
U10AD 00 [009] - No Communications
Reset counter: 126
Mileage: 52348 km
Date: 2017.09.10
Time: 17:09:15
Component: OCULowMQBUS 007 0564
Coding: 02730002C2823A017F1E06000000
Shop #: WSC 00066 790 00123
ROD: EV_OCULowMQB_VW37.rod
VCID: 43ABA1B1CAC8345ED7-8016
0036 - Databus
Reset counter: 164
13633792 - Databus
Reset counter: 164
9457171 - Audio signal output 1
B14F1 13 [009] - Open Circuit
Reset counter: 108
Mileage: 51999 km
Date: 2017.09.02
Time: 20:05:55
7170 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 150
Mileage: 52004 km
Date: 2017.09.04
Time: 10:25:24
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 141125201646
End-------------------------(Elapsed Time: 04:18)--------------------------
