Lane Assist retrofit help (2015 mk7 GTI)
ASR
C?ID=270252
Side Assist/Blind spot retrofit help (2015 mk7 GTI)
I need to pick your brains on this, I installed a Side Assist retrofit kit from an online supplier. everything is hooked up and coded, however I cannot get communications between some controllers. The part number for the radar sensors is different from the ones normally used on these cars, but the seller swears that they are the same... here is my autoscan after the retrofit.
Sunday,10,September,2017,17:18:42:24044
VCDS Version: 17.8.0.1 (x64)
VIN: 3VW4T7AU2XXXXXXX   License Plate:
Mileage: 52348km-32527mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 47 52 55 5F
          75 A9
VIN: 3VW4T7AU2XXXXXXXX   Mileage: 52348km-32527miles
Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0006
   Revision: --H13---
   Coding: 091D00324424002F1000
   Shop #: WSC 00066 790 00202
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C79EA0D4756DB2606-8078
   Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4511
   Revision: 05853104    Serial number: TFK01412101379
   ROD: EV_TCMDQ250021_VW37.rod
   VCID: 2977131948A4CE0EFD-807C
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-ESP-V1.clb
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 53454000000334
   Coding: 01FA6BA13427096F0080020681C32980D62C9000408194B410435050C085
   Shop #: WSC 01383 790 50316
   VCID: 47B3B5A1FEF0187E0B-8012
   Revision: 00021000    Serial number: 0356326553
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3A55DC55BD02759684-806E
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 00020004200100000000000010000000
   VCID: 46ADB8A5F9FA0176F0-8012
   Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
   Revision: --------    Serial number: 86580601151384
   Coding: 00111A464041A27969E44000011407201800000000000000000000000000
   Shop #: WSC 00066 790 00206
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4AB58C95EDE2E51614-801E
   Component: WWS    141205  043 0581
   Serial number:         150211015942
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y14M11D26H22M52S13
   Coding: 06A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H02 0003
   Serial number: 0000FST0001WOUF00000
   Coding: 181801
                    Reset counter: 161
                    Mileage: 52099 km
                    Date: 2017.09.05
                    Time: 13:10:39
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391433812357
   Coding: 0031151011
   VCID: 3D5FD749AC2C42AEA1-8068
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 14121403271837
   Coding: 01001200FE033B
   VCID: 3851C65D830E678672-806C
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM01SKSC
   VCID: 51879BF900B4D6CE55-8004
   Occupant Detection:
   Serial number: IBH0000J1500029IVO0Q
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 000 612 14
   Serial number: 35700000000A30543210
   Subsystem 3 - Part No SW: -----------    HW: 480 000 612 14
   Serial number: 35800000000597303213
   Subsystem 4 - Part No SW: -----------    HW: 480 401 311 14
   Serial number: 3510002BB188FC11D06C
   Subsystem 5 - Part No SW: -----------    HW: 480 401 311 14
   Serial number: 35200029D188FC109327
   Subsystem 6 - Part No SW: -----------    HW: 480 402 511 14
   Serial number: 3550002B718B3A749314
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 511 14
   Serial number: 3560002B718B3A7261DA
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141218400156
   Coding: 0410
   ROD: EV_SMLSVALEOMQB_VW37.rod
   VCID: 042962AD8F46F366AE-8050
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   Part No SW: 5G1 920 856     HW: 5G1 920 856
   Component: KOMBI         342 4270
   Coding: 0BAD091A2988CF0502897A091000000000000000
   VCID: 6BFB291182D81C1E4F-803E
16777008 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
                    Reset counter: 125
                    Mileage: 52348 km
                    Date: 2017.09.10
                    Time: 17:07:47
16776982 - Databus
                    Reset counter: 125
                    Mileage: 52348 km
                    Date: 2017.09.10
                    Time: 17:07:44
   Revision: --------    Serial number: 16011510000552
   Coding: 0101000820085900FF00002A1C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07029
   ROD: EV_GatewConti_011.rod
   VCID: 72C53475A5F2CDD68C-8026
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0101
   Serial number: 29140002882510035044
   Coding: 29FFFF
   Revision: 00000000    Serial number: 15000015223004
   Coding: 5D00000000000000
   VCID: 3449F26D9F6683E65E-8060
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 5QD 907 686     HW: 5QD 907 686
   Serial number: 6055910562
   Coding: 02011103
   ROD: EV_HREntryHella_VW32.rod
   VCID: 0E3D4085D10A893608-805A
   Lane Change Assistant 2:
341261 - Databus
                    Reset counter: 125
                    Mileage: 52348 km
                    Date: 2017.09.10
                    Time: 17:08:25
   Serial number: 12011506050B9W
   Coding: 003F1320D000040000000000
   VCID: 40A1AEBDDBDE2F46CA-8014
   Serial number: 00000000000000594835
   Coding: 011000
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 9302
   ROD: EV_SteerAssisMQB.rod
   VCID: 3753C5618E1068FE7B-8062
23552 - Databus
                    Reset counter: 125
                    Mileage: 52348 km
                    Date: 2017.09.10
                    Time: 17:08:41
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 13.25 V
                    Temperature: 42.0 °C
                    KFC: 5C
                    KFA: 00 00
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 13.34 V
                    uAdSensI_SwitchedKl30_xdu16: 13.34 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
21760 - Databus
                    Reset counter: 125
                    Mileage: 52348 km
                    Date: 2017.09.10
                    Time: 17:08:41
                    Motor status: 01
                    KFC: 55
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 13.22 V
                    uAdSensI_SwitchedKl30_xdu16: 13.21 V
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0060
   Serial number: VWZ8Z1EC4023K5U
   Coding: 22000000AAAAAA0000
   ASAM Dataset: EV_AMPMst12C1ALPI 001007
   ROD: EV_AMPMst12C1ALPI.rod
   VCID: 63EB41316A08545EF7-8036
   Serial number: 3001150605063O
   Coding: 003F1320DC00040000000000
   VCID: 3FA3AD41A62050BEB3-806A
   Serial number: 00000000000000432560
   Coding: 091000
   Coding: 021A01010B000400
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0645
   Serial number: V7B00401151412
   Coding: 027300000000000021220002001800001F0203340100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 64E9422D6F0653660E-8030
0020 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 126
                    Mileage: 52348 km
                    Date: 2017.09.10
                    Time: 17:09:11
                    Voltage terminal 30: 13.2 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
6665 - No Communcation  with Front Display/Control Module
          U0257 00 [009] - -
                    Reset counter: 126
                    Mileage: 52348 km
                    Date: 2017.09.10
                    Time: 17:12:08
6691 - Data Bus for Control/Display
          U10AD 00 [009] - No Communications
                    Reset counter: 126
                    Mileage: 52348 km
                    Date: 2017.09.10
                    Time: 17:09:15
   Component: OCULowMQBUS   007 0564
   Shop #: WSC 00066 790 00123
   ROD: EV_OCULowMQB_VW37.rod
   VCID: 43ABA1B1CAC8345ED7-8016
0036 - Databus
                    Reset counter: 164
13633792 - Databus
                    Reset counter: 164
9457171 - Audio signal output 1
          B14F1 13 [009] - Open Circuit
                    Reset counter: 108
                    Mileage: 51999 km
                    Date: 2017.09.02
                    Time: 20:05:55
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 150
                    Mileage: 52004 km
                    Date: 2017.09.04
                    Time: 10:25:24
   Component: SAS-GEN 2     H06 0014
   Serial number: 141125201646
End-------------------------(Elapsed Time: 04:18)--------------------------
Address 3C: DTCs cleared
Address 5F,5G0 035 844 ,channel IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,adapted from,Databus extended ,to,Terminal 15 ,
Address 5F: DTCs cleared
Address 5F,5G0 035 844 ,channel IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,adapted from,Terminal 15 ,to,Databus extended ,
iichel
Eindhoven, NB, NL
C?ID=284912
Looks like an Aliexpress kit?
ibis_white
C?ID=236086
Where's the A5 module?
ASR
C?ID=270252
