Seat Ateca 2016 (model year 2017) Retrofit Westfalia trailier hitch
Derek
UK (ilexa)
C?ID=56983
Hello
Can anyone offer some guidance to coding on this for retrofitting a trailer module please?
I don't want to start changing the codings and then find it's dealer only because of the Auto Distance Regulation or ESP
Monday,04,September,2017,13:54:08:22523
VCDS Version: 17.8.0.1 (x64)
VIN: VSSZZZ5FZH6529535   License Plate:
Mileage: 11417km-7094mi   Repair Order:
Chassis Type  5F-SE37 (3Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 22 2B 42 44 52 5F 69
VIN: VSSZZZ5FZH6529535   Mileage: 11417km-7094miles
69-Trailer -- Status: Not registered 0001
Address 01: Engine (J623-DFFA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BC    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H24 3191
   Revision: B4H24---
   Coding: 01190012032605093000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM20TDI01104L906026BC 004002
   ROD: EV_ECM20TDI01104L906026BC_004_SE37.rod
   VCID: 6CD1A33D87DC0C2646-8038
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 63276000000689
   Coding: 22EE8A9234220C75077C070362C82844512C30E0E046147B10605078E003430000100212121212A635351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_SK37.rod
   VCID: 76E58155C990C6F6A0-8022
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0423621456
   Coding: 032C0C0E03
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   ROD: EV_KessyHellaMQBAB_004_SE37.rod
   VCID: 3C71537DB73C5CA696-8068
   Part No SW: 5F0 907 044 AL    HW: 5F0 907 044 AL
   Component: Climatronic   H05 1801
   Revision: 00001K09
   Coding: 06100104200110011005000000101020
   Shop #: WSC 73430 790 00063
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 70E9B74DABF4E8C67A-8024
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001631601296
   ROD: EV_BCMBOSCH_017_SE37.rod
   VCID: 7F0B6471E6AA87BEF3-802A
   Subsystem 1 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serial number: S5Y16M11D21H16M37S03
   Coding: 00996E
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY16204131R
   Serial number: 00000000000067656412
   Part No SW: 5Q0 919 283 G    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0056
   Revision: --------    Serial number: 39231631608281
   Coding: 0001150001
   ROD: EV_EPHVA14AU3700000_002_AU37.rod
   VCID: 3D775E79AC2655AEA1-8068
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 2A00408150FF8728749C8065004083
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_001_VW27.rod
   VCID: 3B735061B2325B9E9F-806E
1229 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Fault Frequency: 22
                    Reset counter: 145
                    Mileage: 11236 km
                    Date: 2017.09.02
                    Time: 00:39:52
                    Dynamic environmental data: 02 85
                    Voltage terminal 15: 14.4 V
                    Control Module temperature: 60 °C
                    Longitudinal_acceleration_vehicle_reference: -0.00 m/s²
   Part No SW: 3Q0 959 655 AK    HW: 3Q0 959 655 AK
   Component: Airbag VW21   004 0306
   Revision: --------    Serial number: 003R6PQL4YR1
   Coding: 98CCC0C0000000005C5400CC008800000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
   ROD: EV_AirbaVW21TS6VW48X_VW27.rod
   VCID: 071BFC91BE7ACF7ECB-8052
   Subsystem 1 - Part No SW: -----------    HW: 454 000 411 16
   Serial number: 35700000000829F05E1Q
   Subsystem 2 - Part No SW: -----------    HW: 454 000 511 16
   Serial number: 358000000006B945AF1Y
   Subsystem 3 - Part No SW: -----------    HW: 454 803 010 16
   Serial number: 351006FE25A0D000000V
   Subsystem 4 - Part No SW: -----------    HW: 454 800 511 16
   Serial number: 352006D605E0D000000O
   Subsystem 5 - Part No SW: -----------    HW: 454 800 511 16
   Serial number: 355001087970D000000F
   Part No SW: 3Q0 953 521 DQ    HW: 5Q0 953 569 A
   Revision: FF035035    Serial number: 20161116500094
   Coding: 1404
   ROD: EV_SMLSVALEOMQB_VW37.rod
   VCID: 020DED859558EA569C-8056
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   Part No SW: 5F0 920 951 D    HW: 5F0 920 951 D
   Component: KOMBI         306 8311
   Coding: 27A42012AB80260001886A011000000000000000
   Shop #: WSC 73430 031 00063
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   VCID: 295F9A2948AED90EFD-807C
          U1110 00 [008] - -
                    Reset counter: 183
                    Mileage: 11345 km
                    Date: 2017.09.03
                    Time: 17:36:50
   Component: GW MQB High   515 5286
   Serial number: 21111610801409
   Coding: 030500F40F086A00EB0022480A0F00010001050000000000000000000000
   Shop #: WSC 33361 790 00114
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F6B7431764AB73E23-807A
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Serial number: 000000000A0555031016
   Coding: 002000
   Serial number: 75410803001611174798
66304 - Databus
          U1124 00 [009] - Additional Installations Detected
                    Fault Frequency: 117
                    Reset counter: 145
                    Mileage: 11236 km
                    Date: 2017.09.02
                    Time: 16:54:06
                    Supply voltage: Terminal 30: 12.3 V
                    Terminal 15: On
   Serial number: HA1-00028.09.16
   Coding: 0001
   VCID: 4A9D05A5EDE8F21614-801E
   Serial number: 16000304068014
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71EFB249A0FEE1CE75-8024
   Component: TSG FS        010 0032
   Serial number: 0000229328555
   Coding: 00311220D001040000001000
   VCID: 479B3C91FEFA0F7E0B-8012
   Serial number: 00000000000012372521
   Coding: 3D0000
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 8107
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 45873699C4F61D6EF9-8010
   Component: TSG BFS       010 0032
   Serial number: 0000229603699
   VCID: 46853195F9F01676F0-8012
   Serial number: 00000000000012426911
   Coding: 250000
Address 5F: Information Electr. (J794)       Labels:* 5F0-035-MIB-STD2.clb
   Part No SW: 5QA 035 858 A    HW: 5QA 035 858 A
   Component: MU-S-ND-ER    H30 0359
   Serial number: SEZAZ2S0203879
   Coding: 04230601D70A000011111101008808232F0100D601200100C6
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SE26.rod
   Subsystem 1 - Part No SW: 575 919 606     HW: 575 919 606
   Component: ABT_High-2_N  H41 1041
   Serial number: SEZ8Z9SCB006LL
   Subsystem 2 - Part No SW: 6P0 919 866 M    HW: -----------
   Component: ECE1 2017  --- 0730
   Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
   Component: Anhaenger     H21 0204
   Revision: 8C001003    Serial number: 0444399029
   Coding: 0100000202000000
   VCID: 3E755975A1204EB6B8-806A
End-------------------------(Elapsed Time: 04:21)--------------------------
Best regards
Derek
NEtech
Denmark
C?ID=56995
The usual:
Disable start/stop with button (if installed)
Change WSC etc. to none zero in VCDS, see here.
[19] > [Installation list] > [69] > [Save coding]
Explanation: [Controller number] - New coding (should all be available in label files)
[01] - 01190012043605093000
[09] - [Adaptation-10] > ENG122979-ENG10896-Vernetzung-Anhaengeranschlussgeraet to "installed" > SA needed
[10] - 0001150101 > SA needed
[13] - 2A00408950FF8728749C8065004083 > SA needed
If you want, it is probably no harm in changing "trailer stabilization" in Adaptation for [ABS-03], but until now I have not seen odis do this.
Derek
UK (ilexa)
C?ID=56983
Thank you Niels
all the best
Derek
Derek
UK (ilexa)
C?ID=56983
Just to close this one off, the car is all done and working, thanks again Niels
Best regards
Derek
