Mk4 security access code
JIMENEZ
Columbia
C?ID=170890
Could someone help me with security access number for this controller? I need to activate the cruise control function but when I try to do that with long codding helper the controller said "error!" Thanks
Thursday,28,August,2014,16:50:22:36145
Chassis Type: 9M (1J - VW Golf/Bora IV (1998 > 2006))
          76
VIN: 3VWSE29M9DM000834   Mileage: 15320km/9519miles
   Part No: 06A 906 012 AE
   Component: 1.8L R4/5VT     G   0903
   Coding: 00003
   Shop #: WSC 78901
   VCID: 5FCD63BADDB0ADE6C2D-5142
   3VWSE29M9DM000834     VWZ7Z0M1021119
18107 - Powertrain Data Bus
            P1699 - 35-00 - Missing Message from Steering Wheel Electronics
17977 - Cruise Control Switch (E45)
            P1569 - 35-10 - Implausible Signal - Intermittent
Address 02: Auto Trans        Labels: 09G-927-750.lbl
   Part No SW: 09G 927 750 LJ    HW: 09G 927 750 LJ
   Component: AQ 250 6F           1658
   Revision: 00H95000    Serial number:
   Coding: 0000328
   Shop #: WSC 00066 000 00000
   VCID: 8407CCD6C496AE3E3FF-5142
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 K
   Component: ASR FRONT MK60      0103
   Coding: 0018945
   VCID: 326BDA0EAEA2508E5D3-5142
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 01000
   Shop #: WSC 00066
   VCID: 21492542AB44DB16B49-5142
01273 - Fresh Air Blower (V2)
            37-10 - Faulty - Intermittent
   Part No: 1C0 909 605 A
   Component: 23 AIRBAG VW51 02   0011
   Coding: 12851
   Shop #: WSC 00066
   VCID: 224B2A4EAE42C00EAD3-5106
   Part No: 1J5 920 826 Q
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 01332
   Shop #: WSC 28017
   VCID: 3C77F4362CE696FE87F-5124
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00066
   VCID: F0EF9006B02EA29EEB7-5106
Login with 11463 should turn cruise on. But it I think it is already on and the reason it doesn't work is these fault codes:
