Current Versions
   #81
hubbend
San Diego, CA, USA
C?ID=208928
Macbook Air here; I'm running Windows 8 x64 via VMware Fusion, updated no problem.
I was going to borrow a buddies Windows laptop but thought I would see if I could get it to update. Tried installing Win 7 but the same issue - update failed. What finally worked was installing the special usb driver that is packaged with 12.2.3. Once that driver was installed, I ran 14.8.1 and voila - update from 1.92 to 1.93.
   #82
Keithuk
Stoke on Trent, England
C?ID=122432
When you install all versions of VCDS and Beta it installs the USB drivers separately make sure you click on it.
Now the strange thing is its lists the normal and Beta USB drivers separately in Programs and Features.
Windows Driver Package - Ross-Tech USB Driver Package (05/12/2014 2.10.00)
Windows Driver Package - Ross-Tech USB Driver Package (06/16/2010 2.06.02)
Why does each one need different USB drivers?
   #83
They don't. We just publish updated USB drivers every once in a while. This keeps us compatible with newer versions of Windows and things like USB 3 ports. However there have been occasions where the latest drivers have been troublesome. Hence we tend to introduce new driver versions with Beta versions of VCDS and continue to ship Releases with drivers that are known to be working well -- or at least where we understand what issues may arise with them.
   #84
Shaun
A slew of updates releasing today. Highlights are CB V0.4119 which supports updating via USB from a windows PC via the config utility. Look for a new config utility V1.957 in the new VCDS release. Give it a try.
Also FW 0.208 fixes an issue that could cause 404 pages to be displayed.
Datasets 00000029 and 00000030 contain updated ASAM data and labels
--Shaun
   #85
VCDS-Beta 14.9.0
  • Fewer restrictions on 10-VIN HEX-NET interfaces.
  • Usage counters for most interfaces
  • Improved handling of control modules having invalid WSC or Equipment Numbers.
  • Several small fixes aimed at reducing confusion.
  • New HEX-NET Configuration Utility able to update the interface.
  • Requires latest HEX-NET firmware, but you should be able to use the new Configuration Utility to update your HEX-NET.
jakematic
NC USA
C?ID=129085
Very nice job.
Everything immediately knew about the updates and 14.9 launched the browser for me :D
Never saw an ASAM update before...
Edit: Or label file updates. SWEET!
romad
Prescott, AZ
C?ID=208765
The 00000029 update took about 20 minutes, but the 00000030 update just sits at 0%. I tried it about 4 times, re-booted the Hex-Net, but no joy so I quit. I'll try again in a couple of days.
   #88
Is that stand-alone or with the Configuration Utility?
romad
Prescott, AZ
C?ID=208765
Just the Hex-Net plugged into my iMac via USB and accessed via Firefox web browser. I can't remember exactly what was downloaded, but there were 2 downloads before the Dataset 00000029. After each download I go to Options>Check for Updates.
OK, I just launched it again and it is downloading Dataset 00000030 - looks like there are 892 blocks to download.
It just finished; took about 15 minutes. I checked for any more updates and it said I was up to date.
JSWTDI09
Las Vegas, Nevada
C?ID=96924
I also had an issue with the dataset update. The first few updates worked as usual (I was using the VCDS-Mobile update button through a browser), but when it got to the last dataset update it said it was updating, but I never got any progress bar or any indication that anything was happening. I tried twice (rebooting the hex-net each time) and I let it sit there for over 25 minutes. Then I decided to try the new configuration java app and *presto* the final (0030) update occurred in seconds. Kudos on the new configuration program and it's "check for updates" feature. My only suggestion would be to put an icon on the desktop for it instead of making us look for it. Now VCDS-Mobile says I am up to date.
On a totally separate note; VCDS Beta: I have recently acquired a relatively small (8") tablet that runs Windows 8.1 (yeah , I know, Classic Shell helps a lot). Anyway, given the growing popularity of tablet and other touch screen computers and given that a Hex-Net makes a great wireless interface for the classic Windows VCDS; it might be worth looking into making VCDS more "finger friendly". Much of it is already great with big buttons, etc. However, there are a few places with drop down text options (like choosing a chassis type for autoscan) where my fat fingers have a hard time selecting the right car type. Larger font options or a more tablet friendly interface should be possible. Even check boxes with a big select button would be an improvement because you could fumble with the check boxes before pressing the select button. Like I said, most of VCDS is already pretty "finger friendly". There are only a few places where improvements could be made. Its just something different to consider.
Have Fun!
   #91
romad
Prescott, AZ
C?ID=208765
Are you using a Windows PC or Mac? I did not see a new HexNetConfig.jar application for my Mac. I have HexNetConfigV1.9.jar
   #92
jakematic
NC USA
C?ID=129085
1.957 was included with 14.9 at C:\Ross-Tech\VCDS-Beta\ but I don't see it on the downloads page yet.
   #93
We included 1.957 with the VCDS Beta because it seems to work well on Windows, but there appear to be some issues with doing updates via USB on Mac OS at the moment. We're working on that. We'll make a version available as a stand-alone download once we're reasonably confident it works reliably on Mac OS.
VCDS Release 14.10.0
Yes, it's a Release.
The primary difference to 14.9.0 is the button on the [Options] screen that changes from [LEDs] to [Config] and launches the HEX-NET Configuration utility.
The utility included with 14.10.0 is version 1.957, which seems stable on Windows. We also have 1.958 available for Mac users, but we've had a few reports of issues with it on Windows when certain HID peripherals are installed. Mac users are hereby encouraged to try version 1.958 and give us feedback.
jakematic
NC USA
C?ID=129085
Interestingly neither HN thinks it needs and update via the web interface but the utility does, with two different results.
Haven't done any updates in case you need additional information.
   #96
Shaun
The utility has the ability to update some things that the web interface does not currently check for. That is why you are seeing an update here. You should download it.
--Shaun
   #97
jakematic
NC USA
C?ID=129085
Thanks Shaun.
Guess I better get used to using the utility :D
176 seems to be stuck in a loop on ROD data.
Edit: Quitting utility and rebooting HN didn't help, and crashed the utility this time.
Observations:
Checking for updates...
Update found!
Updated rod data needed
Changelog:
Applying update...
Downloading CFB
Updating CFB
Downloading DS update
Unpacking DS update
Update completed successfully
Process:               java [39514]
Path:                  /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/bin/java
Identifier:            net.java.openjdk.cmd
Version:               1.0 (1.0)
Code Type:             X86-64 (Native)
Parent Process:        bash [32771]
Responsible:           Terminal [553]
User ID:               501
Date/Time:             2014-10-31 19:13:51.611 -0400
OS Version:            Mac OS X 10.10 (14A388a)
Report Version:        11
Anonymous UUID:        F3C78316-1B6F-692E-141B-CAB73CF21846
Time Awake Since Boot: 120000 seconds
Crashed Thread:        34  Java: Thread-10
Exception Type:        EXC_BAD_ACCESS (SIGABRT)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
VM Regions Near 0:
    __TEXT                 000000010a7cc000-000000010a7dd000 [   68K] r-x/rwx SM=COW  /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/bin/java
Application Specific Information:
abort() called
Thread 0:: AppKit Thread  Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib        	0x00007fff990d452e mach_msg_trap + 10
1   libsystem_kernel.dylib        	0x00007fff990d369f mach_msg + 55
2   com.apple.CoreFoundation      	0x00007fff98bd5b14 __CFRunLoopServiceMachPort + 212
3   com.apple.CoreFoundation      	0x00007fff98bd4fdb __CFRunLoopRun + 1371
4   com.apple.CoreFoundation      	0x00007fff98bd4838 CFRunLoopRunSpecific + 296
5   com.apple.HIToolbox           	0x00007fff9718b43f RunCurrentEventLoopInMode + 235
6   com.apple.HIToolbox           	0x00007fff9718b1ba ReceiveNextEventCommon + 431
7   com.apple.HIToolbox           	0x00007fff9718affb _BlockUntilNextEventMatchingListInModeWithFilter + 71
8   com.apple.AppKit              	0x00007fff91818821 _DPSNextEvent + 964
9   com.apple.AppKit              	0x00007fff91817fd0 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 194
10  libosxapp.dylib               	0x000000011d83f6f4 -[NSApplicationAWT nextEventMatchingMask:untilDate:inMode:dequeue:] + 124
11  com.apple.AppKit              	0x00007fff9180bf73 -[NSApplication run] + 594
12  libosxapp.dylib               	0x000000011d83f557 +[NSApplicationAWT runAWTLoopWithApp:] + 156
13  liblwawt.dylib                	0x000000011d797ba9 -[AWTStarter starter:] + 873
14  com.apple.Foundation          	0x00007fff94291f4c __NSThreadPerformPerform + 293
15  com.apple.CoreFoundation      	0x00007fff98be3661 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
16  com.apple.CoreFoundation      	0x00007fff98bd57ed __CFRunLoopDoSources0 + 269
17  com.apple.CoreFoundation      	0x00007fff98bd4e1f __CFRunLoopRun + 927
18  com.apple.CoreFoundation      	0x00007fff98bd4838 CFRunLoopRunSpecific + 296
19  java                          	0x000000010a7d33b0 CreateExecutionEnvironment + 871
20  java                          	0x000000010a7cdb5c JLI_Launch + 1952
21  java                          	0x000000010a7d370d main + 101
22  java                          	0x000000010a7cd3b4 start + 52
Thread 1:
0   libsystem_kernel.dylib        	0x00007fff990d9486 __semwait_signal + 10
1   java                          	0x000000010a7d29b0 ContinueInNewThread0 + 102
2   java                          	0x000000010a7ce7c7 ContinueInNewThread + 201
3   java                          	0x000000010a7d2785 JVMInit + 315
4   java                          	0x000000010a7ce545 JLI_Launch + 4489
5   java                          	0x000000010a7d370d main + 101
6   java                          	0x000000010a7d3042 apple_main + 92
7   libsystem_pthread.dylib       	0x00007fff8f3f42fc _pthread_body + 131
8   libsystem_pthread.dylib       	0x00007fff8f3f4279 _pthread_start + 176
9   libsystem_pthread.dylib       	0x00007fff8f3f24b1 thread_start + 13
Thread 2:: Dispatch queue: com.apple.libdispatch-manager
0   libsystem_kernel.dylib        	0x00007fff990da22e kevent64 + 10
1   libdispatch.dylib             	0x00007fff8ee28a6a _dispatch_mgr_thread + 52
Thread 3:
0   libsystem_kernel.dylib        	0x00007fff990d9132 __psynch_cvwait + 10
1   libjvm.dylib                  	0x000000010be16e39 os::PlatformEvent::park() + 173
2   libjvm.dylib                  	0x000000010bdf70ce ParkCommon(ParkEvent*, long long) + 42
3   libjvm.dylib                  	0x000000010bdf78c0 Monitor::IWait(Thread*, long long) + 160
4   libjvm.dylib                  	0x000000010bdf7a9c Monitor::wait(bool, long, bool) + 246
5   libjvm.dylib                  	0x000000010beef9f6 Threads::destroy_vm() + 80
6   libjvm.dylib                  	0x000000010bd098a3 jni_DestroyJavaVM + 223
7   java                          	0x000000010a7ceb06 JavaMain + 805
8   libsystem_pthread.dylib       	0x00007fff8f3f42fc _pthread_body + 131
9   libsystem_pthread.dylib       	0x00007fff8f3f4279 _pthread_start + 176
10  libsystem_pthread.dylib       	0x00007fff8f3f24b1 thread_start + 13
Thread 4:
4   libjvm.dylib                  	0x000000010bdf7b1d Monitor::wait(bool, long, bool) + 375
5   libjvm.dylib                  	0x000000010bc68c8e GCTaskManager::get_task(unsigned int) + 56
6   libjvm.dylib                  	0x000000010bc69b83 GCTaskThread::run() + 349
7   libjvm.dylib                  	0x000000010be1b1d6 java_start(Thread*) + 294
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
1   libjvm.dylib                  	0x000000010be17deb os::PlatformEvent::park(long long) + 385
2   libjvm.dylib                  	0x000000010bdf78c0 Monitor::IWait(Thread*, long long) + 160
3   libjvm.dylib                  	0x000000010bdf7b1d Monitor::wait(bool, long, bool) + 375
4   libjvm.dylib                  	0x000000010bf2a8c0 VMThread::loop() + 444
5   libjvm.dylib                  	0x000000010bf2a36b VMThread::run() + 121
6   libjvm.dylib                  	0x000000010be1b1d6 java_start(Thread*) + 294
Thread 13:: Java: Reference Handler
2   libjvm.dylib                  	0x000000010be0fe67 ObjectMonitor::wait(long long, bool, Thread*) + 757
3   libjvm.dylib                  	0x000000010bebf4b3 ObjectSynchronizer::wait(Handle, long long, Thread*) + 203
4   libjvm.dylib                  	0x000000010bd2af1c JVM_MonitorWait + 156
5   ???                           	0x000000010c6c1628 0 + 4503377448
6   ???                           	0x000000010c68f4b4 0 + 4503172276
7   ???                           	0x00000000df5d8a65 0 + 3747449445
Thread 14:: Java: Finalizer
6   ???                           	0x000000010c6885f8 0 + 4503143928
7   ???                           	0xe0001ee4df5d8df8 0 + 16140935032844684792
Thread 15:: Java: Signal Dispatcher
0   libsystem_kernel.dylib        	0x00007fff990d456a semaphore_wait_trap + 10
1   libjvm.dylib                  	0x000000010be194b0 check_pending_signals(bool) + 128
2   libjvm.dylib                  	0x000000010be15db8 signal_thread_entry(JavaThread*, Thread*) + 57
3   libjvm.dylib                  	0x000000010beefb57 JavaThread::thread_main_inner() + 155
4   libjvm.dylib                  	0x000000010bef125f JavaThread::run() + 419
5   libjvm.dylib                  	0x000000010be1b1d6 java_start(Thread*) + 294
6   libsystem_pthread.dylib       	0x00007fff8f3f42fc _pthread_body + 131
7   libsystem_pthread.dylib       	0x00007fff8f3f4279 _pthread_start + 176
8   libsystem_pthread.dylib       	0x00007fff8f3f24b1 thread_start + 13
Thread 16:: Java: C2 CompilerThread0
4   libjvm.dylib                  	0x000000010bdf7a84 Monitor::wait(bool, long, bool) + 222
5   libjvm.dylib                  	0x000000010bbc0eab CompileQueue::get() + 153
6   libjvm.dylib                  	0x000000010bbc1a43 CompileBroker::compiler_thread_loop() + 425
7   libjvm.dylib                  	0x000000010beefb57 JavaThread::thread_main_inner() + 155
8   libjvm.dylib                  	0x000000010bef125f JavaThread::run() + 419
9   libjvm.dylib                  	0x000000010be1b1d6 java_start(Thread*) + 294
10  libsystem_pthread.dylib       	0x00007fff8f3f42fc _pthread_body + 131
11  libsystem_pthread.dylib       	0x00007fff8f3f4279 _pthread_start + 176
12  libsystem_pthread.dylib       	0x00007fff8f3f24b1 thread_start + 13
Thread 17:: Java: C2 CompilerThread1
Thread 18:: Java: Service Thread
5   libjvm.dylib                  	0x000000010be6f1e5 ServiceThread::service_thread_entry(JavaThread*, Thread*) + 109
6   libjvm.dylib                  	0x000000010beefb57 JavaThread::thread_main_inner() + 155
7   libjvm.dylib                  	0x000000010bef125f JavaThread::run() + 419
8   libjvm.dylib                  	0x000000010be1b1d6 java_start(Thread*) + 294
9   libsystem_pthread.dylib       	0x00007fff8f3f42fc _pthread_body + 131
10  libsystem_pthread.dylib       	0x00007fff8f3f4279 _pthread_start + 176
11  libsystem_pthread.dylib       	0x00007fff8f3f24b1 thread_start + 13
Thread 19:
4   libjvm.dylib                  	0x000000010bef002a WatcherThread::sleep() const + 126
5   libjvm.dylib                  	0x000000010bef0eed WatcherThread::run() + 243
Thread 20:: Java: AWT-Shutdown
5   ???                           	0x000000010c568698 0 + 4501964440
6   ???                           	0x000000010c55c058 0 + 4501913688
7   ???                           	0x000000010c55c058 0 + 4501913688
8   ???                           	0x000000010c55c706 0 + 4501915398
9   ???                           	0x000000010c5564e7 0 + 4501890279
10  libjvm.dylib                  	0x000000010bcd6bb0 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 554
11  libjvm.dylib                  	0x000000010bcd70c7 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 283
12  libjvm.dylib                  	0x000000010bcd7204 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 74
13  libjvm.dylib                  	0x000000010bd261ea thread_entry(JavaThread*, Thread*) + 173
14  libjvm.dylib                  	0x000000010beefb57 JavaThread::thread_main_inner() + 155
15  libjvm.dylib                  	0x000000010bef125f JavaThread::run() + 419
16  libjvm.dylib                  	0x000000010be1b1d6 java_start(Thread*) + 294
17  libsystem_pthread.dylib       	0x00007fff8f3f42fc _pthread_body + 131
18  libsystem_pthread.dylib       	0x00007fff8f3f4279 _pthread_start + 176
19  libsystem_pthread.dylib       	0x00007fff8f3f24b1 thread_start + 13
Thread 21:
0   libsystem_kernel.dylib        	0x00007fff990d9946 __workq_kernreturn + 10
1   libsystem_pthread.dylib       	0x00007fff8f3f24a1 start_wqthread + 13
Thread 22:
5   com.apple.AppKit              	0x00007fff9197b8f7 _NSEventThread + 137
Thread 23:: Java: AWT-EventQueue-0
0   libjvm.dylib                  	0x000000010befe4df typeArrayKlass::array_klass_impl(typeArrayKlassHandle, bool, int, Thread*) + 587
1   libjvm.dylib                  	0x000000010baa3d52 arrayKlass::allocate_arrayArray(int, int, Thread*) + 250
2   libjvm.dylib                  	0x000000010bcd2e9c InterpreterRuntime::anewarray(JavaThread*, constantPoolOopDesc*, int, int) + 68
3   ???                           	0x000000010c574305 0 + 4502012677
4   ???                           	0x000000010c55c058 0 + 4501913688
5   ???                           	0x000000010c55c233 0 + 4501914163
6   ???                           	0x000000010c55c233 0 + 4501914163
8   ???                           	0x000000010c55c058 0 + 4501913688
9   ???                           	0x000000010c55c058 0 + 4501913688
10  ???                           	0x000000010c55c058 0 + 4501913688
11  ???                           	0x000000010c55c058 0 + 4501913688
12  ???                           	0x000000010c55c058 0 + 4501913688
13  ???                           	0x000000010c55c058 0 + 4501913688
14  ???                           	0x000000010c55c058 0 + 4501913688
15  ???                           	0x000000010c70ffd4 0 + 4503699412
Thread 24:: Java: Java2D Queue Flusher
2   libjvm.dylib                  	0x000000010be0fe78 ObjectMonitor::wait(long long, bool, Thread*) + 774
7   ???                           	0x000000010c5564e7 0 + 4501890279
8   libjvm.dylib                  	0x000000010bcd6bb0 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 554
9   libjvm.dylib                  	0x000000010bcd70c7 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 283
10  libjvm.dylib                  	0x000000010bcd7204 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 74
11  libjvm.dylib                  	0x000000010bd261ea thread_entry(JavaThread*, Thread*) + 173
12  libjvm.dylib                  	0x000000010beefb57 JavaThread::thread_main_inner() + 155
13  libjvm.dylib                  	0x000000010bef125f JavaThread::run() + 419
14  libjvm.dylib                  	0x000000010be1b1d6 java_start(Thread*) + 294
15  libsystem_pthread.dylib       	0x00007fff8f3f42fc _pthread_body + 131
16  libsystem_pthread.dylib       	0x00007fff8f3f4279 _pthread_start + 176
17  libsystem_pthread.dylib       	0x00007fff8f3f24b1 thread_start + 13
Thread 25:: Java: Java2D Disposer
7   ???                           	0xe00010dbdf5d8df8 0 + 16140919601027190264
Thread 26:: Java: hid4java event worker
1   libjvm.dylib                  	0x000000010be17bd7 Parker::park(bool, long long) + 483
2   libjvm.dylib                  	0x000000010bf05752 Unsafe_Park + 126
3   ???                           	0x000000010c568698 0 + 4501964440
5   ???                           	0x000000010c55c058 0 + 4501913688
6   ???                           	0x000000010c55c706 0 + 4501915398
7   ???                           	0x000000010c55c8e1 0 + 4501915873
8   ???                           	0x000000010c55c233 0 + 4501914163
10  ???                           	0x000000010c55c706 0 + 4501915398
11  ???                           	0x000000010c5564e7 0 + 4501890279
12  libjvm.dylib                  	0x000000010bcd6bb0 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 554
13  libjvm.dylib                  	0x000000010bcd70c7 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 283
14  libjvm.dylib                  	0x000000010bcd7204 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 74
15  libjvm.dylib                  	0x000000010bd261ea thread_entry(JavaThread*, Thread*) + 173
16  libjvm.dylib                  	0x000000010beefb57 JavaThread::thread_main_inner() + 155
17  libjvm.dylib                  	0x000000010bef125f JavaThread::run() + 419
18  libjvm.dylib                  	0x000000010be1b1d6 java_start(Thread*) + 294
19  libsystem_pthread.dylib       	0x00007fff8f3f42fc _pthread_body + 131
20  libsystem_pthread.dylib       	0x00007fff8f3f4279 _pthread_start + 176
21  libsystem_pthread.dylib       	0x00007fff8f3f24b1 thread_start + 13
Thread 27:: Java: hid4java event worker
Thread 28:: Java: hid4java event worker
3   ???                           	0x000000010c6c1eaa 0 + 4503379626
Thread 29:: Java: hid4java Device Scanner
2   libjvm.dylib                  	0x000000010be17f3a os::sleep(Thread*, long long, bool) + 204
3   libjvm.dylib                  	0x000000010bd25c32 JVM_Sleep + 269
4   ???                           	0x000000010c568698 0 + 4501964440
Thread 30:: Java: TimerQueue
1   libjvm.dylib                  	0x000000010be17be8 Parker::park(bool, long long) + 500
4   ???                           	0x000000010c6f95a8 0 + 4503606696
5   ???                           	0x00000000e0021edc 0 + 3758235356
Thread 31:: Java: Thread-2
Thread 32:: CVDisplayLink
1   com.apple.CoreVideo           	0x00007fff9a598ff8 CVDisplayLink::waitUntil(unsigned long long) + 240
2   com.apple.CoreVideo           	0x00007fff9a5984b3 CVDisplayLink::runIOThread() + 511
3   com.apple.CoreVideo           	0x00007fff9a59829b startIOThread(void*) + 147
4   libsystem_pthread.dylib       	0x00007fff8f3f42fc _pthread_body + 131
5   libsystem_pthread.dylib       	0x00007fff8f3f4279 _pthread_start + 176
6   libsystem_pthread.dylib       	0x00007fff8f3f24b1 thread_start + 13
Thread 33:
Thread 34 Crashed:: Java: Thread-10
0   libsystem_kernel.dylib        	0x00007fff990d9282 __pthread_kill + 10
1   libsystem_c.dylib             	0x00007fff8bcf1b73 abort + 129
2   libjvm.dylib                  	0x000000010be1aba3 os::abort(bool) + 25
3   libjvm.dylib                  	0x000000010bf25230 VMError::report_and_die() + 2316
4   libjvm.dylib                  	0x000000010be1c53d JVM_handle_bsd_signal + 1083
5   libsystem_platform.dylib      	0x00007fff95b79f1a _sigtramp + 26
6   com.apple.CoreFoundation      	0x00007fff98ba7544 CFBasicHashCreateCopy + 1188
7   com.apple.CoreFoundation      	0x00007fff98bc1fd0 CFSetCreateCopy + 144
8   jna5346453421313311029.tmp    	0x000000012252ede6 hid_open_path + 470
9   jna3258978828267461289.tmp    	0x00000001224dc94c ffi_call_unix64 + 76
10  jna3258978828267461289.tmp    	0x00000001224dc456 ffi_call + 630
11  jna3258978828267461289.tmp    	0x00000001224d32f5 Java_com_sun_jna_Native_ffi_1prep_1cif + 1621
12  jna3258978828267461289.tmp    	0x00000001224d38d2 Java_com_sun_jna_Native_invokePointer + 34
13  ???                           	0x000000010c568698 0 + 4501964440
14  ???                           	0x000000010c55c175 0 + 4501913973
15  ???                           	0x000000010c55c233 0 + 4501914163
16  ???                           	0x000000010c55c233 0 + 4501914163
17  ???                           	0x000000010c55c233 0 + 4501914163
18  ???                           	0x000000010c55c8e1 0 + 4501915873
19  ???                           	0x000000010c55c8e1 0 + 4501915873
20  ???                           	0x000000010c55c233 0 + 4501914163
21  ???                           	0x000000010c55c233 0 + 4501914163
22  ???                           	0x000000010c55c233 0 + 4501914163
23  ???                           	0x000000010c55c233 0 + 4501914163
24  ???                           	0x000000010c55c233 0 + 4501914163
25  ???                           	0x000000010c55c058 0 + 4501913688
26  ???                           	0x000000010c55c706 0 + 4501915398
27  ???                           	0x000000010c5564e7 0 + 4501890279
28  libjvm.dylib                  	0x000000010bcd6bb0 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 554
29  libjvm.dylib                  	0x000000010bcd70c7 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 283
30  libjvm.dylib                  	0x000000010bcd7204 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 74
31  libjvm.dylib                  	0x000000010bd261ea thread_entry(JavaThread*, Thread*) + 173
32  libjvm.dylib                  	0x000000010beefb57 JavaThread::thread_main_inner() + 155
33  libjvm.dylib                  	0x000000010bef125f JavaThread::run() + 419
34  libjvm.dylib                  	0x000000010be1b1d6 java_start(Thread*) + 294
35  libsystem_pthread.dylib       	0x00007fff8f3f42fc _pthread_body + 131
36  libsystem_pthread.dylib       	0x00007fff8f3f4279 _pthread_start + 176
37  libsystem_pthread.dylib       	0x00007fff8f3f24b1 thread_start + 13
Thread 35:
Thread 36:
Thread 34 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x0000000000000006  rcx: 0x0000000129ba0498  rdx: 0x0000000000000000
  rdi: 0x000000000000e01b  rsi: 0x0000000000000006  rbp: 0x0000000129ba04c0  rsp: 0x0000000129ba0498
   r8: 0x0000000129ba0470   r9: 0x0000000129ba3000  r10: 0x0000000008000000  r11: 0x0000000000000206
  r12: 0x000000010c226560  r13: 0x00007ffd4acbbaf0  r14: 0x0000000129ba3000  r15: 0x000000010be1f8e4
  rip: 0x00007fff990d9282  rfl: 0x0000000000000206  cr2: 0x00007fff7b324fd8
Logical CPU:     0
Error Code:      0x02000148
Trap Number:     133
Binary Images:
       0x10a7cc000 -        0x10a7dcfef +java (1.0 - 1.0) <25FD55B9-8D1B-34F0-9D74-C58E45F63DC0> /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/bin/java
       0x10a913000 -        0x10a91bfff +libverify.dylib (1) <C42EBBF2-FDE6-342B-9B75-7D91194E47C1> /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libverify.dylib
       0x10a920000 -        0x10a941fe7 +libjava.dylib (1) <D662B2DB-D0FD-3F7B-95E3-05F1E4513363> /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libjava.dylib
       0x10a95a000 -        0x10a95ffff +libzip.dylib (1) <50D7966F-6590-3F9A-A42B-7E7EE016493E> /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libzip.dylib
       0x10ba00000 -        0x10c145fef +libjvm.dylib (1) <F52622EB-BFF2-352F-A786-EF12A3584FA1> /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/server/libjvm.dylib
       0x11b85e000 -        0x11b865ff7  com.apple.java.JavaRuntimeSupport (15.0.0 - 15.0.0) <B62645D3-3CA7-345D-AEF5-DF9B1EB4B345> /System/Library/Frameworks/JavaVM.framework/Frameworks/JavaRuntimeSupport.framework/JavaRuntimeSupport
       0x11b874000 -        0x11b87cff7  JavaNativeFoundation (73) <97AD7993-1883-353C-9703-739ECD4030DE> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation
       0x11b888000 -        0x11b88cfff  com.apple.JavaVM (14.9.9 - 14.9.9) <456DE71B-D7A2-38AE-A1AD-62A4A272ED57> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
       0x11b894000 -        0x11b898fff  JavaLaunching (40) <C44347E5-4926-3BE4-91F0-F683911454A9> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
       0x11d5b2000 -        0x11d5c0ff7 +libnet.dylib (1) <7C54B7E4-AA6F-369A-9F18-B208C88FE856> /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libnet.dylib
       0x11d60f000 -        0x11d67afff +libawt.dylib (1) <5F027771-D669-392F-8DD7-CBA3EA5DD87D> /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libawt.dylib
       0x11d6be000 -        0x11d783fff +libmlib_image.dylib (1) <95F6D0B2-3A92-305F-A6AE-822BC990901B> /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libmlib_image.dylib
       0x11d78a000 -        0x11d7fafff +liblwawt.dylib (1) <67D8EEBE-BFB2-3252-9164-A95F4520588A> /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/lwawt/liblwawt.dylib
       0x11d83e000 -        0x11d843fff +libosxapp.dylib (1) <8CE761D7-7DAA-36BA-8424-BF74590F8C1D> /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libosxapp.dylib
       0x11f83a000 -        0x11f857fff +libsunec.dylib (1) <7969D854-D44E-32D9-84CD-78C8C83A7ED7> /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libsunec.dylib
       0x11f8b0000 -        0x11f8b7fff +libosx.dylib (1) <CA53A3EA-455D-360E-B212-92956E695FAD> /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libosx.dylib
       0x11f998000 -        0x11f99cfff +libosxui.dylib (1) <6DEBE72D-64CA-35EA-916D-A1345245C18F> /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libosxui.dylib
       0x1205fb000 -        0x1205fbfef +cl_kernels (???) <998E15D6-C4BC-4E96-AAD3-15CCAC9FD400> cl_kernels
       0x12060a000 -        0x12060aff5 +cl_kernels (???) <D32FBC93-48C0-4F38-B467-8B5555182C49> cl_kernels
       0x12060c000 -        0x1206f2fef  unorm8_bgra.dylib (2.4.5) <90797750-141F-3114-ACD0-A71363968678> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
       0x1218a5000 -        0x1218e8fff +libfontmanager.dylib (1) <E84CB8A2-95A1-3261-B2BA-0CA135C8DA41> /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libfontmanager.dylib
       0x12244c000 -        0x122454fff +libnio.dylib (1) <35EB86B3-C421-3C01-A286-B9213B95C70A> /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libnio.dylib
       0x1224cf000 -        0x1224e0fff +jna3258978828267461289.tmp (4) <8541B498-CC6F-ED0E-36E4-D2159AF66015> /private/var/folders/*/jna3258978828267461289.tmp
       0x12252d000 -        0x12252fff7 +jna5346453421313311029.tmp (0) <C074EEBB-E7AB-378E-BD5D-73096AC5B7D6> /var/folders/*/jna5346453421313311029.tmp
       0x122533000 -        0x12253efff  com.apple.iokit.IOHIDLib (2.0.0 - 2.0.0) <7A27B325-E6BC-3E64-BD0A-67A2FEE3CA53> /System/Library/Extensions/IOHIDFamily.kext/Contents/PlugIns/IOHIDLib.plugin/Contents/MacOS/IOHIDLib
    0x123400000000 -     0x123400497fff  com.apple.driver.AppleIntelHD4000GraphicsGLDriver (10.0.86 - 10.0.0) <918E1A1E-B083-309D-A26E-0D4C0DB9E6CD> /System/Library/Extensions/AppleIntelHD4000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD4000GraphicsGLDriver
    0x7fff6489c000 -     0x7fff648d2837  dyld (353.2.1) <4696A982-1500-34EC-9777-1EF7A03E2659> /usr/lib/dyld
    0x7fff8b2a1000 -     0x7fff8b2c6ff7  libJPEG.dylib (1231) <35F13BD9-AA92-3510-B5BB-420DA15AE7F2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff8bc0d000 -     0x7fff8bc0dfff  com.apple.Cocoa (6.8 - 21) <EAC0EA1E-3C62-3B28-A941-5D8B1E085FF8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff8bc0e000 -     0x7fff8bc0ffff  libSystem.B.dylib (1213) <DA954461-EC6A-3DF0-8551-6FC810627627> /usr/lib/libSystem.B.dylib
    0x7fff8bc10000 -     0x7fff8bc39ffb  libxslt.1.dylib (13) <AED1143F-B848-3E73-81ED-71356F25F084> /usr/lib/libxslt.1.dylib
    0x7fff8bc94000 -     0x7fff8bd20fff  libsystem_c.dylib (1044.1.2) <C185E862-7424-3210-B528-6B822577A4B8> /usr/lib/system/libsystem_c.dylib
    0x7fff8bd5f000 -     0x7fff8bd61fff  com.apple.CoreDuetDebugLogging (1.0 - 1) <9A6E5710-EA99-366E-BF40-9A65EC1B46A1> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
    0x7fff8bd62000 -     0x7fff8bd67fff  com.apple.DiskArbitration (2.6 - 2.6) <0DFF4D9B-2AC3-3B82-B5C5-30F4EFBD2DB9> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff8bf04000 -     0x7fff8bf09ff7  libmacho.dylib (862) <126CA2ED-DE91-308F-8881-B9DAEC3C63B6> /usr/lib/system/libmacho.dylib
    0x7fff8bf0a000 -     0x7fff8c35dfc7  com.apple.vImage (8.0 - 8.0) <33BE7B31-72DB-3364-B37E-C322A32748C5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff8c35e000 -     0x7fff8c386ffb  libRIP.A.dylib (772) <9262437A-710A-397D-8E34-1CBFEA1FC5E1> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x7fff8c387000 -     0x7fff8c3c2fff  com.apple.Symbolication (1.4 - 56045) <D64571B1-4483-3FE2-BD67-A91360F79727> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fff8c3cc000 -     0x7fff8c4affff  libcrypto.0.9.8.dylib (52) <7208EEE2-C090-383E-AADD-7E1BD1321BEC> /usr/lib/libcrypto.0.9.8.dylib
    0x7fff8c743000 -     0x7fff8cf9afff  com.apple.CoreGraphics (1.600.0 - 772) <D3E7C973-BD01-32EB-90A8-AA69976CE955> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff8d027000 -     0x7fff8d04ffff  libsystem_info.dylib (459) <B85A85D5-8530-3A93-B0C3-4DEC41F79478> /usr/lib/system/libsystem_info.dylib
    0x7fff8d050000 -     0x7fff8d099ff3  com.apple.HIServices (1.22 - 519) <59D78E07-C3F1-3272-88F1-876B836D5517> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff8d09a000 -     0x7fff8d0a3fff  libGFXShared.dylib (11.0.7) <EC449E3A-D9D2-3494-8B6C-DEB7B11EEDAB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff8d423000 -     0x7fff8d472ff7  libstdc++.6.dylib (104.1) <803F6AC8-87DC-3E24-9E80-729B551F6FFF> /usr/lib/libstdc++.6.dylib
    0x7fff8d473000 -     0x7fff8d49efff  com.apple.DictionaryServices (1.2 - 229) <6789EC43-CADA-394D-8FE8-FC3A2DD136B9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff8d49f000 -     0x7fff8d4a8ff7  libsystem_notify.dylib (133.1.1) <61147800-F320-3DAA-850C-BADF33855F29> /usr/lib/system/libsystem_notify.dylib
    0x7fff8d4a9000 -     0x7fff8d4a9ff7  libunc.dylib (29) <5676F7EA-C1DF-329F-B006-D2C3022B7D70> /usr/lib/system/libunc.dylib
    0x7fff8d4aa000 -     0x7fff8d8dafff  com.apple.vision.FaceCore (3.1.6 - 3.1.6) <C3B823AA-C261-37D3-B4AC-C59CE91C8241> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff8d9c1000 -     0x7fff8d9f4ff7  com.apple.MediaKit (16 - 757) <345EDAFE-3E39-3B0F-8D84-54657EC4396D> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fff8d9f5000 -     0x7fff8d9f7ff7  libquarantine.dylib (76) <DC041627-2D92-361C-BABF-A869A5C72293> /usr/lib/system/libquarantine.dylib
    0x7fff8d9f8000 -     0x7fff8db35fff  com.apple.ImageIO.framework (3.3.0 - 1038) <611BDFBA-4BAA-36A8-B7E0-3830F3375E53> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff8db36000 -     0x7fff8db4fff7  com.apple.CFOpenDirectory (10.10 - 187) <0ECA5D80-A045-3A2C-A60C-E1605F3AB6BD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff8db50000 -     0x7fff8db5bfff  com.apple.CommerceCore (1.0 - 376) <64B64D4A-A57E-35CE-86BE-C451042AB12F> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x7fff8db5c000 -     0x7fff8dcebfff  libGLProgrammability.dylib (11.0.7) <AF37E7F3-16C8-3747-9CC6-A442C0153DC6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fff8dcee000 -     0x7fff8dd07fff  com.apple.openscripting (1.4 - 162) <80DFF366-B950-3F79-903F-99DA0FFDB570> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff8e423000 -     0x7fff8e425fff  libCVMSPluginSupport.dylib (11.0.7) <29D775BB-A11D-3140-A478-2A0DA1A87420> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff8e426000 -     0x7fff8e519ff7  libJP2.dylib (1231) <58849E48-9CD2-38A1-9D48-FCE630F473EB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff8e51a000 -     0x7fff8e51bff7  com.apple.print.framework.Print (10.0 - 265) <3BC4FE7F-78A0-3E57-8F4C-520E7EFD36FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff8e51c000 -     0x7fff8e6ccff7  com.apple.QuartzCore (1.10 - 361.11) <7382E4A9-10B0-3877-B9D7-FA84DC71BA55> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff8e6cd000 -     0x7fff8e6d1ff7  com.apple.LoginUICore (3.0 - 3.0) <86C742AF-8F8A-3AD6-AFD3-DEC66815B5C0> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
    0x7fff8e6d2000 -     0x7fff8e6dfff7  libxar.1.dylib (254) <CE10EFED-3066-3749-838A-6A15AC0DBCB6> /usr/lib/libxar.1.dylib
    0x7fff8e9a0000 -     0x7fff8e9faff7  com.apple.LanguageModeling (1.0 - 1) <ACA93FE0-A0E3-333E-AE3C-8EB7DE5F362F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff8ea6d000 -     0x7fff8ea78ff7  libcsfde.dylib (471) <797691FA-FC0A-3A95-B6E8-BDB75AEAEDFD> /usr/lib/libcsfde.dylib
    0x7fff8ea79000 -     0x7fff8ea7dfff  com.apple.CommonPanels (1.2.6 - 96) <F9ECC8AF-D9CA-3350-AFB4-5113A9B789A5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff8ec25000 -     0x7fff8ec8cff7  com.apple.framework.CoreWiFi (3.0 - 300.4) <19269C1D-EB29-384A-83F3-7DDDEB7D9DAD> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff8ec8d000 -     0x7fff8edaefff  com.apple.LaunchServices (644.10 - 644.10) <0B1C68BC-0AEB-38E2-ABC8-E92728FEC475> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff8edfa000 -     0x7fff8ee0cff7  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <CE9FABB4-1C5D-3F9B-9BB8-5CC50C3E5E31> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
    0x7fff8ee1c000 -     0x7fff8ee1eff7  libutil.dylib (38) <471AD65E-B86E-3C4A-8ABD-B8665A2BCE3F> /usr/lib/libutil.dylib
    0x7fff8ee1f000 -     0x7fff8ee23ff7  libGIF.dylib (1231) <A349BA73-301E-3EDE-8A31-8ACE827C289E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff8ee24000 -     0x7fff8ee4eff7  libdispatch.dylib (442.1.4) <502CF32B-669B-3709-8862-08188225E4F0> /usr/lib/system/libdispatch.dylib
    0x7fff8ee4f000 -     0x7fff8ee72ff7  com.apple.framework.familycontrols (4.1 - 410) <41499068-0AB2-38CB-BE6A-F0DD0F06AB52> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
    0x7fff8ee73000 -     0x7fff8ee76ff7  libdyld.dylib (353.2.1) <19FAF435-C165-3374-9DEF-D7BBA7D61DB6> /usr/lib/system/libdyld.dylib
    0x7fff8eebf000 -     0x7fff8ef33fff  com.apple.ApplicationServices.ATS (360 - 375) <62828B40-231D-3F81-8067-1903143DCB6B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff8ef34000 -     0x7fff8ef36fff  libsystem_configuration.dylib (699.1.5) <9FBA1CE4-97D0-347E-A443-93ED94512E92> /usr/lib/system/libsystem_configuration.dylib
    0x7fff8ef37000 -     0x7fff8ef39ff7  libsystem_coreservices.dylib (9) <41B7C578-5A53-31C8-A96F-C73E030B0938> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff8ef3a000 -     0x7fff8ef6affb  com.apple.GSS (4.0 - 2.0) <D033E7F1-2D34-339F-A814-C67E009DE5A9> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff8ef6b000 -     0x7fff8efa5ffb  com.apple.DebugSymbols (115 - 115) <6F03761D-7C3A-3C80-8031-AA1C1AD7C706> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff8efa6000 -     0x7fff8efaaff7  com.apple.TCC (1.0 - 1) <AFC32F8F-BCD5-313C-B66E-5AB8591EC066> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff8f052000 -     0x7fff8f07dff3  libarchive.2.dylib (30) <8CBB4416-EBE9-3574-8ADC-44655D245F39> /usr/lib/libarchive.2.dylib
    0x7fff8f07e000 -     0x7fff8f07fff7  libodfde.dylib (22) <52D0ABCD-F464-362C-86EA-ACA10993F556> /usr/lib/libodfde.dylib
    0x7fff8f082000 -     0x7fff8f097ffb  libCGInterfaces.dylib (294.1) <1A6AADE6-09EC-3054-85F9-E6A3607EBA70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fff8f098000 -     0x7fff8f367ff3  com.apple.CoreImage (10.0.33) <6E3DDA29-718B-3BDB-BFAF-F8C201BF93A4> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff8f36c000 -     0x7fff8f36effb  libCGXType.A.dylib (772) <7CB71BC6-D8EC-37BC-8243-41BAB086FAAA> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x7fff8f3ca000 -     0x7fff8f3f0ff7  com.apple.ChunkingLibrary (2.1 - 163.1) <3514F2A4-38BD-3849-9286-B3B991057742> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff8f3f1000 -     0x7fff8f3fafff  libsystem_pthread.dylib (105.1.4) <26B1897F-0CD3-30F3-B55A-37CB45062D73> /usr/lib/system/libsystem_pthread.dylib
    0x7fff8f3fb000 -     0x7fff8f52bfff  com.apple.UIFoundation (1.0 - 1) <8E030D93-441C-3997-9CD2-55C8DFAC8B84> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff8f56b000 -     0x7fff8f5f4fff  com.apple.CoreSymbolication (3.1 - 56072) <8CE81C95-49E8-389F-B989-67CC452C08D0> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff8f603000 -     0x7fff8f61dff7  libextension.dylib (55) <17514AB2-C503-3D49-A725-EBC1140567A6> /usr/lib/libextension.dylib
    0x7fff8f628000 -     0x7fff8f63aff7  com.apple.ImageCapture (9.0 - 9.0) <7FB65DD4-56B5-35C4-862C-7A2DED991D1F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff8f63b000 -     0x7fff8f646fff  libGL.dylib (11.0.7) <C53344AD-8CE6-3111-AB94-BD4CA89ED84E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff8f647000 -     0x7fff8f653ff7  libGPUSupportMercury.dylib (11.0.7) <C04F6E18-3043-3096-A6E6-F6431ADC41D3> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fff8f654000 -     0x7fff8f674fff  com.apple.IconServices (47.1 - 47.1) <E83DFE3B-6541-3736-96BB-26DC5D0100F1> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff8f675000 -     0x7fff8f679fff  libpam.2.dylib (20) <E805398D-9A92-31F8-8005-8DC188BD8B6E> /usr/lib/libpam.2.dylib
    0x7fff8f785000 -     0x7fff8f78aff7  libunwind.dylib (35.3) <BE7E51A0-B6EA-3A54-9CCA-9D88F683A6D6> /usr/lib/system/libunwind.dylib
    0x7fff8f78b000 -     0x7fff8f919fff  libBLAS.dylib (1128) <497912C1-A98E-3281-BED7-E9C751552F61> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff8f91a000 -     0x7fff8f98eff3  com.apple.securityfoundation (6.0 - 55126) <E7FB7A4E-CB0B-37BA-ADD5-373B2A20A783> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff8f992000 -     0x7fff8f9adff7  com.apple.aps.framework (4.0 - 4.0) <9955CAFD-D56B-36E9-BB41-6F7F73317EB5> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
    0x7fff8fc35000 -     0x7fff8fc86ff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <CC57353D-8D25-3579-8A66-30A09F7BEED0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff8fc87000 -     0x7fff8fc95ff7  com.apple.opengl (11.0.7 - 11.0.7) <B5C4DF85-37BD-3984-98D1-90A5043DA984> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff8fd3f000 -     0x7fff8fe31fff  libxml2.2.dylib (26) <B834E7C8-EC3E-3382-BC5A-DA38DC4D720C> /usr/lib/libxml2.2.dylib
    0x7fff8feb9000 -     0x7fff8fef9ff7  libGLImage.dylib (11.0.7) <7CBCEB4B-D22F-3116-8B28-D1C22D28C69D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff8ff11000 -     0x7fff8ff17fff  libsystem_trace.dylib (72.1.3) <A9E6B7D8-C327-3742-AC54-86C94218B1DF> /usr/lib/system/libsystem_trace.dylib
    0x7fff8ff18000 -     0x7fff8ff9afff  com.apple.PerformanceAnalysis (1.0 - 1) <478055FE-1A94-31C7-A1A2-D67F19CA6A74> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff8ff9b000 -     0x7fff9019eff3  com.apple.CFNetwork (720.0.9 - 720.0.9) <78EE1B88-394F-3BB8-93A6-E068990559EC> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff9019f000 -     0x7fff901a1ff7  libsystem_sandbox.dylib (358.1.1) <DB9962EF-8898-31CC-9B87-E01F8CE74C9D> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff901a2000 -     0x7fff901a2fff  com.apple.CoreServices (62 - 62) <9E4577CA-3FC3-300D-AB00-87ADBDDA2E37> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff901e7000 -     0x7fff9027cff7  com.apple.ColorSync (4.9.0 - 4.9.0) <F06733BD-A10C-3DB3-B050-825351130392> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff9027d000 -     0x7fff90291ff7  com.apple.ProtectedCloudStorage (1.0 - 1) <52CFE68A-0663-3756-AB5B-B42195026052> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fff90320000 -     0x7fff9034efff  com.apple.CoreServicesInternal (221.1 - 221.1) <51BAE6D2-84F3-392A-BFEC-A3B47B80A3D2> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff90353000 -     0x7fff90353fff  libOpenScriptingUtil.dylib (162) <EFD79173-A9DA-3AE6-BE15-3948938204A6> /usr/lib/libOpenScriptingUtil.dylib
    0x7fff9038b000 -     0x7fff903cbff7  com.apple.CloudDocs (1.0 - 280.1) <21D7E10A-99EF-34BE-82D7-29A6F1761DE5> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fff90428000 -     0x7fff90454fff  com.apple.framework.SystemAdministration (1.0 - 1.0) <F2A164C7-4813-3F27-ABF7-810A5F4FA51D> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
    0x7fff90460000 -     0x7fff904cffff  com.apple.SearchKit (1.4.0 - 1.4.0) <BFD6D876-36BA-3A3B-9F15-3E2F7DE6E89D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff904d0000 -     0x7fff904eaff7  liblzma.5.dylib (7) <1D03E875-A7C0-3028-814C-3C27F7B7C079> /usr/lib/liblzma.5.dylib
    0x7fff90b4f000 -     0x7fff90b9eff7  com.apple.opencl (2.4.2 - 2.4.2) <6AE26E08-6EFC-3E1B-B202-EFA9C3E5B9D4> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff90b9f000 -     0x7fff90ba1fff  com.apple.EFILogin (2.0 - 2) <F0269EE2-3686-3A8A-8B83-F86974E35E90> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff9105f000 -     0x7fff91061ff7  com.apple.SecCodeWrapper (4.0 - 238) <F450AB10-B0A4-3B55-A1B9-563E55C99333> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fff910a0000 -     0x7fff910a0fff  com.apple.ApplicationServices (48 - 48) <5BF7910B-C328-3BF8-BA4F-CE52B574CE01> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff910a1000 -     0x7fff910b0fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <D1E527E4-C561-352F-9457-E8C50232793C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff910b1000 -     0x7fff910b4fff  com.apple.IOSurface (97 - 97) <D4B4D2B2-7B16-3174-9EA6-55E0A10B452D> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff910b5000 -     0x7fff910c9ff7  com.apple.MultitouchSupport.framework (260.30 - 260.30) <28728A7D-E048-3B14-9932-839A87D381FE> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff915b7000 -     0x7fff915fdff7  libauto.dylib (186) <A260789B-D4D8-316A-9490-254767B8A5F1> /usr/lib/libauto.dylib
    0x7fff915fe000 -     0x7fff91605ff7  libcompiler_rt.dylib (35) <BF8FC133-EE10-3DA6-9B90-92039E28678F> /usr/lib/system/libcompiler_rt.dylib
    0x7fff91620000 -     0x7fff91624fff  libCoreVMClient.dylib (79) <FC4E08E3-749E-32FF-B5E9-211F29864831> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff916bc000 -     0x7fff916bffff  com.apple.xpc.ServiceManagement (1.0 - 1) <7E9E6BB7-AEE7-3F59-BAC0-59EAF105D0C8> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff91770000 -     0x7fff917befff  libcurl.4.dylib (83.1.2) <337A1FF8-E8B1-3173-9F29-C0D4C851D8E1> /usr/lib/libcurl.4.dylib
    0x7fff917bf000 -     0x7fff917c3fff  libcache.dylib (69) <45E9A2E7-99C4-36B2-BEE3-0C4E11614AD1> /usr/lib/system/libcache.dylib
    0x7fff917f4000 -     0x7fff92335fff  com.apple.AppKit (6.9 - 1343.14) <7E32F178-C705-3E83-81C5-FB31D5507B3A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff92352000 -     0x7fff92375fff  com.apple.Sharing (328.3 - 328.3) <FDEE49AD-8804-3760-9C14-8D1D10BBEA37> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff9238b000 -     0x7fff92396ff7  com.apple.DirectoryService.Framework (10.10 - 187) <813211CD-725D-31B9-ABEF-7B28DE2CB224> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x7fff92656000 -     0x7fff926ceff7  com.apple.SystemConfiguration (1.14 - 1.14) <C269BCFD-ACAB-3331-BC7C-0430F0E84817> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff92711000 -     0x7fff92741fff  libsystem_m.dylib (3086.1) <1E12AB45-6D96-36D0-A226-F24D9FB0D9D6> /usr/lib/system/libsystem_m.dylib
    0x7fff92752000 -     0x7fff9275affb  libcopyfile.dylib (118.1.2) <0C68D3A6-ACDD-3EF3-991A-CC82C32AB836> /usr/lib/system/libcopyfile.dylib
    0x7fff9278b000 -     0x7fff927eaff3  com.apple.AE (681 - 681) <7F544183-A515-31A8-B45F-89A167F56216> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff927eb000 -     0x7fff92805ff7  com.apple.Kerberos (3.0 - 1) <7760E0C2-A222-3709-B2A6-B692D900CEB1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff9281e000 -     0x7fff92820fff  com.apple.ExceptionHandling (1.5 - 10) <C3A6EB3D-C0B3-371F-99D8-AF5495498091> /System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling
    0x7fff92821000 -     0x7fff92acbff7  com.apple.GeoServices (1.0 - 982.4.10) <B77D4082-4FBB-3F6E-AB9F-3BBBA34C0DC3> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
    0x7fff92acc000 -     0x7fff92accfff  com.apple.Accelerate (1.10 - Accelerate 1.10) <227E2491-1DDB-336F-BF83-773CECEC66F1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff92acd000 -     0x7fff92acefff  libsystem_secinit.dylib (18) <581DAD0F-6B63-3A48-B63B-917AF799ABAA> /usr/lib/system/libsystem_secinit.dylib
    0x7fff92ea1000 -     0x7fff93050fff  GLEngine (11.0.7) <3CB7447A-1A1D-3D55-A6A4-4814B49F6678> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7fff93565000 -     0x7fff93566fff  liblangid.dylib (117) <B54A4AA0-2E53-3671-90F5-AFF711C0EB9E> /usr/lib/liblangid.dylib
    0x7fff93567000 -     0x7fff935d3fff  com.apple.framework.CoreWLAN (5.0 - 500.35.2) <ACBAAB0A-BCC7-37CF-AAFB-2DA1733F2682> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff93663000 -     0x7fff93663fff  com.apple.Carbon (154 - 157) <6E3AEB9D-7643-36BE-A7E5-D08886649257> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff93664000 -     0x7fff9366bfff  libCGCMS.A.dylib (772) <E64DC779-A6CF-3B1F-8E57-C09C0B10670F> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
    0x7fff9366c000 -     0x7fff93760ff7  libFontParser.dylib (134) <506126F8-FDCE-3DE1-9DCA-E07FE658B597> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff937be000 -     0x7fff93825ff7  com.apple.datadetectorscore (6.0 - 396.1) <5D348063-1528-3E2F-B587-9E82970506F9> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff93831000 -     0x7fff9383cff7  libkxld.dylib (2782.1.97) <CB1A1B57-54BE-3573-AE0C-B90ED6BAEEE2> /usr/lib/system/libkxld.dylib
    0x7fff9383d000 -     0x7fff93845ff7  com.apple.AppleSRP (5.0 - 1) <01EC5144-D09A-3D6A-AE35-F6D48585F154> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fff93846000 -     0x7fff9384efff  libsystem_dnssd.dylib (561.1.1) <62B70ECA-E40D-3C63-896E-7F00EC386DDB> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff93c12000 -     0x7fff93c31fff  com.apple.CoreDuet (1.0 - 1) <36AA9FD5-2685-314D-B364-3FA4688D86BD> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
    0x7fff93c32000 -     0x7fff93c39fff  com.apple.NetFS (6.0 - 4.0) <1581D25F-CC07-39B0-90E8-5D4F3CF84EBA> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff93c3a000 -     0x7fff93cb0fe7  libcorecrypto.dylib (233.1.2) <E1789801-3985-3949-B736-6B3378873301> /usr/lib/system/libcorecrypto.dylib
    0x7fff93cb1000 -     0x7fff93f98ffb  com.apple.CoreServices.CarbonCore (1108.1 - 1108.1) <55A16172-ACC0-38B7-8409-3CB92AF33973> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff93feb000 -     0x7fff93feefff  com.apple.help (1.3.3 - 46) <CA4541F4-CEF5-355C-8F1F-EA65DC1B400F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff9402b000 -     0x7fff94033ff7  com.apple.icloud.FindMyDevice (1.0 - 1) <D198E170-3610-3727-BC87-73AD249CA097> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
    0x7fff94034000 -     0x7fff94075fff  libGLU.dylib (11.0.7) <8037342E-1ECD-385F-B4C3-545CE97B76AE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff94076000 -     0x7fff94087ff7  libz.1.dylib (55) <88C7C7DE-04B8-316F-8B74-ACD9F3DE1AA1> /usr/lib/libz.1.dylib
    0x7fff941a1000 -     0x7fff941b1ff7  libbsm.0.dylib (34) <A3A2E56C-2B65-37C7-B43A-A1F926E1A0BB> /usr/lib/libbsm.0.dylib
    0x7fff9422c000 -     0x7fff9455aff7  com.apple.Foundation (6.9 - 1151.16) <18EDD673-A010-3E99-956E-DA594CE1FA80> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff9455b000 -     0x7fff945c9ffb  com.apple.Heimdal (4.0 - 2.0) <B852ACA1-4C64-3E2A-A9D3-6D4C80AD9429> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff946fd000 -     0x7fff9470aff7  libbz2.1.0.dylib (36) <2DF83FBC-5C08-39E1-94F5-C28653791B5F> /usr/lib/libbz2.1.0.dylib
    0x7fff94713000 -     0x7fff9471cff3  com.apple.CommonAuth (4.0 - 2.0) <F4C266BE-2E0E-36B4-9DE7-C6B4BF410FD7> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff9471d000 -     0x7fff94727ff7  com.apple.NetAuth (5.0 - 5.0) <B9EC5425-D38D-308C-865F-207E0A98BAC7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff94b2d000 -     0x7fff94b32ffb  libheimdal-asn1.dylib (398.1.2) <F9463B34-AAF5-3488-AD0C-85937C81FC5E> /usr/lib/libheimdal-asn1.dylib
    0x7fff94b85000 -     0x7fff94d6aff3  libicucore.A.dylib (531.30) <EF0E7544-E317-3550-A962-6AE65E78AF17> /usr/lib/libicucore.A.dylib
    0x7fff94d9e000 -     0x7fff951abff7  libLAPACK.dylib (1128) <F9201AE7-B031-36DB-BCF8-971E994EF7C1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff955a6000 -     0x7fff955cefff  libxpc.dylib (559.1.22) <9437C02E-A07B-38C8-91CB-299FAA63083D> /usr/lib/system/libxpc.dylib
    0x7fff955cf000 -     0x7fff955d3fff  com.apple.IOAccelerator (156.4 - 156.4) <56092CAF-5F0F-3DCA-9047-4F6B93425BFD> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff955d4000 -     0x7fff956ecffb  com.apple.CoreText (352.0 - 454.1) <AB07DF12-BB1F-3275-A8A3-45F14BF872BF> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff956ed000 -     0x7fff9571afff  com.apple.Accounts (113 - 113) <3145FCC2-D297-3DD1-B74B-9E7DBB0EE33C> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
    0x7fff95722000 -     0x7fff9577dfff  libTIFF.dylib (1231) <ACC9ED11-EED8-3A23-B452-3F40FF7EF435> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff9582d000 -     0x7fff95835ffb  com.apple.CoreServices.FSEvents (1210 - 1210) <782A9C69-7A45-31A7-8960-D08A36CBD0A7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff95836000 -     0x7fff958f9ff7  libvMisc.dylib (512) <A4E39464-52EA-34CB-9FFE-53E79B3C65F5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff95978000 -     0x7fff95a8ffe7  libvDSP.dylib (512) <52777555-F051-3BC2-A2D2-9645907E836D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff95a90000 -     0x7fff95a9dfff  com.apple.ProtocolBuffer (1 - 225.1) <2D502FBB-D2A0-3937-A5C5-385FA65B3874> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff95a9e000 -     0x7fff95b74ff3  com.apple.DiskImagesFramework (10.10 - 389.1) <7DE2208C-BD55-390A-8167-4F9F11750C4B> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x7fff95b75000 -     0x7fff95b7dfff  libsystem_platform.dylib (63) <64E34079-D712-3D66-9CE2-418624A5C040> /usr/lib/system/libsystem_platform.dylib
    0x7fff95b7e000 -     0x7fff95b7ffff  libDiagnosticMessagesClient.dylib (100) <2EE8E436-5CDC-34C5-9959-5BA218D507FB> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff95be0000 -     0x7fff95bf6ff7  libsystem_asl.dylib (267) <F153AC5B-0542-356E-88C8-20A62CA704E2> /usr/lib/system/libsystem_asl.dylib
    0x7fff95c8e000 -     0x7fff95cc6fff  com.apple.RemoteViewServices (2.0 - 99) <C9A62691-B0D9-34B7-B71C-A48B5F4DC553> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff95cc7000 -     0x7fff95cf9ff3  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <C6DB0A07-F8E4-3837-BCA9-225F460EDA81> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fff95cfa000 -     0x7fff95cfbfff  com.apple.TrustEvaluationAgent (2.0 - 25) <2D61A2C3-C83E-3A3F-8EC1-736DBEC250AB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff95d96000 -     0x7fff95dadff7  libLinearAlgebra.dylib (1128) <E78CCBAA-A999-3B65-8EC9-06DB15E67C37> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff95dae000 -     0x7fff95e3ffff  com.apple.cloudkit.CloudKit (259.2.3 - 259.2.3) <6F955140-D522-32B3-B34B-BD94C5D94E7A> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
    0x7fff95e45000 -     0x7fff95fb0ff7  com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <E5A68E3A-79E7-36A3-9C6B-E1DF75ADDA95> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff95fb1000 -     0x7fff95fbbff7  com.apple.CrashReporterSupport (10.10 - 629) <EC97EA5E-3190-3717-A4A9-2F35A447E7A6> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff95fbc000 -     0x7fff9605afff  com.apple.Metadata (10.7.0 - 916) <DA8A1D18-19FE-37B3-BE12-85C5B0A00736> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff961a0000 -     0x7fff962afffb  com.apple.desktopservices (1.9 - 1.9) <6EDAC73F-C42C-3FF7-B67D-FCCA1CFC5405> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff962b0000 -     0x7fff96352fff  com.apple.Bluetooth (4.3.0 - 4.3.0f10) <70922125-2A01-37AE-9CB8-D8A9578092E4> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff96353000 -     0x7fff96366ff7  com.apple.CoreBluetooth (1.0 - 1) <FA9B43B3-E183-3040-AE25-66EF9870CF35> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff96367000 -     0x7fff96459ff7  libiconv.2.dylib (42) <2A06D02F-8B76-3864-8D96-64EF5B40BC6C> /usr/lib/libiconv.2.dylib
    0x7fff9645a000 -     0x7fff964cbff7  com.apple.framework.IOKit (2.0.2 - 1050.1.21) <E4139120-1631-35D0-AA76-B1F4043844BE> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff964cc000 -     0x7fff964f6fff  GLRendererFloat (11.0.7) <3B3B74F4-E63C-3241-8807-E2407C4020B2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x7fff96509000 -     0x7fff965a8df7  com.apple.AppleJPEG (1.0 - 1) <9BB3D7DF-630A-3E1C-A124-12D6C4D0DE70> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff965a9000 -     0x7fff965a9fff  com.apple.audio.units.AudioUnit (1.12 - 1.12) <76EF1C9D-DEA4-3E55-A134-4099B2FD2CF2> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff966cb000 -     0x7fff966dcff7  libsystem_coretls.dylib (35.1.2) <EBBF7EF6-80D8-3F8F-825C-B412BD6D22C0> /usr/lib/system/libsystem_coretls.dylib
    0x7fff966dd000 -     0x7fff966f9ff7  libsystem_malloc.dylib (53.1.1) <19BCC257-5717-3502-A71F-95D65AFA861B> /usr/lib/system/libsystem_malloc.dylib
    0x7fff966fa000 -     0x7fff966fcff7  com.apple.securityhi (9.0 - 55006) <B1E09986-7AF0-3BD1-BAA1-B5514DFB7CD1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff966fd000 -     0x7fff9677afff  com.apple.CoreServices.OSServices (640.3 - 640.3) <EF21E94C-1B34-38F2-AD1E-5BF3AC8C8A23> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff9715c000 -     0x7fff9715cfff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <A48738CA-5B6F-3D14-97E9-2BFDFC3DCC06> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff9715d000 -     0x7fff9745ffff  com.apple.HIToolbox (2.1.1 - 756) <07287312-97EC-3894-96F6-5CB6BA5E0081> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff9751f000 -     0x7fff97521fff  libRadiance.dylib (1231) <746E9989-E89C-3027-A418-5F99CE131C93> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff97522000 -     0x7fff97524fff  com.apple.OAuth (25 - 25) <EE765AF0-2BB6-3689-9EAA-689BF1F02A0D> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
    0x7fff97525000 -     0x7fff9752bfff  com.apple.speech.recognition.framework (5.0.9 - 5.0.9) <BB2D573F-0A01-379F-A2BA-3C454EDCB111> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff9752c000 -     0x7fff97580fff  libc++.1.dylib (120) <1B9530FD-989B-3174-BB1C-BDC159501710> /usr/lib/libc++.1.dylib
    0x7fff97581000 -     0x7fff97596ff7  com.apple.AppContainer (4.0 - 238) <9481F305-359A-33E6-93F1-89A25FA14E00> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
    0x7fff9775b000 -     0x7fff97775ff7  com.apple.AppleVPAFramework (1.0.30 - 1.0.30) <D47A2125-C72D-3298-B27D-D89EA0D55584> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
    0x7fff97776000 -     0x7fff978b8fff  libsqlite3.dylib (168) <7B580EB9-9260-35FE-AE2F-276A2C242BAB> /usr/lib/libsqlite3.dylib
    0x7fff978b9000 -     0x7fff97905ff7  libcups.2.dylib (408) <9CECCDE3-51D7-3028-830C-F58BD36E3317> /usr/lib/libcups.2.dylib
    0x7fff97906000 -     0x7fff97908fff  com.apple.loginsupport (1.0 - 1) <35A2A071-606C-39A5-8C11-E4CAF98D934C> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff97909000 -     0x7fff9791bfff  libsasl2.2.dylib (193) <E523DD05-544B-3430-8AA9-672408A5AF8B> /usr/lib/libsasl2.2.dylib
    0x7fff9791c000 -     0x7fff9791cff7  libkeymgr.dylib (28) <77845842-DE70-3CC5-BD01-C3D14227CED5> /usr/lib/system/libkeymgr.dylib
    0x7fff97921000 -     0x7fff9792efff  com.apple.SpeechRecognitionCore (2.0.32 - 2.0.32) <87F0C88D-502D-3217-8B4A-8388288568BA> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff9792f000 -     0x7fff9793aff7  com.apple.speech.synthesis.framework (5.2.6 - 5.2.6) <9434AA45-B6BD-37F7-A866-172196A7F91B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff9793b000 -     0x7fff97943fe7  libcldcpuengine.dylib (2.4.5) <DF810F9A-1755-3283-82C3-D8192BCD8016> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fff988e9000 -     0x7fff98936ff3  com.apple.print.framework.PrintCore (10.0 - 451) <3CA58254-D14F-3913-9DFB-CAC499570CC7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff98951000 -     0x7fff989e2ff7  libCoreStorage.dylib (471) <5CA37ED3-320C-3469-B4D2-6F045AFE03A1> /usr/lib/libCoreStorage.dylib
    0x7fff989e3000 -     0x7fff98a1bffb  libsystem_network.dylib (411) <C0B2313D-47BE-38A9-BEE6-2634A4F5E14B> /usr/lib/system/libsystem_network.dylib
    0x7fff98a1c000 -     0x7fff98ab0fff  com.apple.ink.framework (10.9 - 213) <8E029630-1530-3734-A446-13353F0E7AC5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff98ab7000 -     0x7fff98abdff7  libsystem_networkextension.dylib (167.1.10) <29AB225B-D7FB-30ED-9600-65D44B9A9442> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff98abe000 -     0x7fff98adbffb  libresolv.9.dylib (57) <26B38E61-298A-3C3A-82C1-3B5E98AD5E29> /usr/lib/libresolv.9.dylib
    0x7fff98adc000 -     0x7fff98ae0fff  libsystem_stats.dylib (163.1.4) <1DB04436-5974-3F16-86CC-5FF5F390339C> /usr/lib/system/libsystem_stats.dylib
    0x7fff98ae1000 -     0x7fff98b0cfff  libc++abi.dylib (125) <88A22A0F-87C6-3002-BFBA-AC0F2808B8B9> /usr/lib/libc++abi.dylib
    0x7fff98b0d000 -     0x7fff98b0effb  libremovefile.dylib (35) <3485B5F4-6CE8-3C62-8DFD-8736ED6E8531> /usr/lib/system/libremovefile.dylib
    0x7fff98b63000 -     0x7fff98ef9fff  com.apple.CoreFoundation (6.9 - 1151.16) <F2B088AF-A5C6-3FAE-9EB4-7931AF6359E4> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff98fcb000 -     0x7fff98fd6fff  libcommonCrypto.dylib (60061) <D381EBC6-69D8-31D3-8084-5A80A32CB748> /usr/lib/system/libcommonCrypto.dylib
    0x7fff99007000 -     0x7fff990c2ff7  com.apple.DiscRecording (9.0 - 9000.4.1) <F70E600E-9668-3DF2-A3A8-61813DF9E2EE> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fff990c3000 -     0x7fff990e0fff  libsystem_kernel.dylib (2782.1.97) <93E0E0A9-75B6-3904-BB4E-4BC7C05F4B6B> /usr/lib/system/libsystem_kernel.dylib
    0x7fff9910f000 -     0x7fff9911bff7  com.apple.OpenDirectory (10.10 - 187) <1D0066FC-1DEB-381B-B15C-4C009E0DF850> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff9911c000 -     0x7fff991dbfff  com.apple.backup.framework (1.6 - 1.6) <373C7CF8-2A85-3B59-BFBC-FFA3FAE2293D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fff991dc000 -     0x7fff9950ffff  libmecabra.dylib (666) <2CE5540A-D412-3D53-9E11-86C24D61713B> /usr/lib/libmecabra.dylib
    0x7fff99510000 -     0x7fff99511ff7  libsystem_blocks.dylib (65) <9615D10A-FCA7-3BE4-AA1A-1B195DACE1A1> /usr/lib/system/libsystem_blocks.dylib
    0x7fff99514000 -     0x7fff9952eff3  com.apple.Ubiquity (1.3 - 313) <DF56A657-CC6E-3BE2-86A0-71F07127724C> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
    0x7fff9952f000 -     0x7fff9954bfff  com.apple.GenerationalStorage (2.0 - 209.11) <9FF8DD11-25FB-3047-A5BF-9415339B3EEC> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff9954c000 -     0x7fff9954cff7  liblaunch.dylib (559.1.22) <8A988924-8BE7-35FE-BF7D-322E90EFE49E> /usr/lib/system/liblaunch.dylib
    0x7fff99808000 -     0x7fff99819fff  libcmph.dylib (1) <46EC3997-DB5E-38AE-BBBB-A035A54AD3C0> /usr/lib/libcmph.dylib
    0x7fff9981a000 -     0x7fff99a82ffb  com.apple.security (7.0 - 57031.1.35) <66CFAFF2-980E-3B99-B7E0-7D7751F6283C> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff99a83000 -     0x7fff99ac9ffb  libFontRegistry.dylib (134) <01B8034A-45FD-3360-A347-A1896F591363> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff99aca000 -     0x7fff99ae5ff7  libCRFSuite.dylib (34) <D64842BE-7BD4-3D0C-9842-1D202F7C2A51> /usr/lib/libCRFSuite.dylib
    0x7fff99aff000 -     0x7fff99b36ffb  com.apple.LDAPFramework (2.4.28 - 194.5) <4CFE8010-CE3F-35EC-90BA-529B74321029> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fff99b3e000 -     0x7fff99c65fff  com.apple.coreui (2.1 - 305) <BB430677-D1F7-38DD-8F05-70E54352B8B5> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff9a538000 -     0x7fff9a573fff  com.apple.QD (301 - 301) <C4D2AD03-B839-350A-AAF0-B4A08F8BED77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff9a574000 -     0x7fff9a595fff  com.apple.framework.Apple80211 (10.0 - 1000.57.3) <F64EB1A1-57F3-3ABA-97D0-DB7C926FD07F> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff9a596000 -     0x7fff9a5c3fff  com.apple.CoreVideo (1.8 - 145.1) <18DB07E0-B927-3260-A234-636F298D1917> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff9a701000 -     0x7fff9a726ff7  libPng.dylib (1231) <2D5AC0EE-4056-3F76-97E7-BBD415F072B5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff9a727000 -     0x7fff9a9a1fff  com.apple.CoreData (110 - 526) <AEEDAF00-D38F-3A15-B3C9-73732940CC55> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff9a9aa000 -     0x7fff9a9f6fff  com.apple.corelocation (1486.17 - 1615.21) <DB68CEB9-0D51-3CB9-86A4-B0400CE6C515> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
    0x7fff9aab4000 -     0x7fff9ac99267  libobjc.A.dylib (646) <3B60CD90-74A2-3A5D-9686-B0772159792A> /usr/lib/libobjc.A.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 1
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 74857
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=205.2M resident=98.2M(48%) swapped_out_or_unallocated=107.0M(52%)
Writable regions: Total=4.6G written=137.0M(3%) resident=220.0M(5%) swapped_out=0K(0%) unallocated=4.4G(95%)
REGION TYPE                      VIRTUAL
ATS (font support)                 31.9M
ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
CG backing stores                  2368K
CG image                           1172K
CG shared images                    304K
CoreAnimation                         8K
CoreImage                             8K
CoreServices                          8K
CoreUI image data                    84K
Dispatch continuations             16.0M
Foundation                            4K
IOKit                              66.1M
Kernel Alloc Once                     8K
MALLOC                            161.5M
MALLOC (admin)                       32K
MALLOC_LARGE (reserved)            1024K        reserved VM address space (unallocated)
Memory Tag 242                       12K
OpenCL                               16K
OpenGL GLSL                         256K
STACK GUARD                        56.1M
Stack                              39.3M
Stack (reserved)                    520K        reserved VM address space (unallocated)
VM_ALLOCATE                       586.0M
VM_ALLOCATE (reserved)              3.7G        reserved VM address space (unallocated)
__DATA                             17.5M
__GLSLBUILTINS                     2588K
__IMAGE                             528K
__LINKEDIT                         74.4M
__TEXT                            130.8M
__UNICODE                           544K
mapped file                        75.7M
shared memory                        68K
TOTAL                               5.0G
TOTAL, minus reserved VM space      1.2G
Model: Macmini6,2, BootROM MM61.0106.B03, 4 processors, Intel Core i7, 2.6 GHz, 16 GB, SMC 2.8f1
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x859B, 0x435438473353313630424D2E4D3136464444
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x859B, 0x435438473353313630424D2E4D3136464444
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x10E), Broadcom BCM43xx 1.0 (7.15.124.12.8)
Bluetooth: Version 4.3.0f10 14890, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: USB Ethernet, Ethernet, en4
PCI Card: scsi, SCSI Bus Controller, Thunderbolt@195,0,0
Serial ATA Device: APPLE SSD SM256E, 251 GB
USB Device: Hub
USB Device: USB2.0 Hub
USB Device: Yubico Yubikey II
USB Device: Hub
USB Device: USB 2.0 Hub [MTT]
USB Device: HD Pro Webcam C920
USB Device: Hex-Net
USB Device: Hex-Net
USB Device: Smart-UPS 1500 FW:COM 02.1 / UPS.05.D
USB Device: Hub
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: IR Receiver
USB Device: DasKeyboard
Thunderbolt Bus: Mac mini, Apple Inc., 23.4
Thunderbolt Device: Mini, Drobo, 1, 26.3
hs_err_pid39514.log which was dumped into the pwd of the jar
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00007fff98ba7544, pid=39514, tid=57371
# JRE version: Java(TM) SE Runtime Environment (7.0_51-b13) (build 1.7.0_51-b13)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (24.51-b03 mixed mode bsd-amd64 compressed oops)
# Problematic frame:
# C  [CoreFoundation+0x44544]  CFBasicHashCreateCopy+0x4a4
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# If you would like to submit a bug report, please visit:
#   http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
---------------  T H R E A D  ---------------
Current thread (0x00007ffd4d170000):  JavaThread "Thread-10" [_thread_in_native, id=57371, stack(0x0000000129aa3000,0x0000000129ba3000)]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0x0000000000000000
Registers:
RAX=0x0000000000000000, RBX=0x0000000000000000, RCX=0x0000000000000000, RDX=0x0040100080200c03
RSP=0x0000000129ba0d00, RBP=0x0000000129ba0d70, RSI=0x00007ffd4acbbb20, RDI=0x0000000000000000
R8 =0x0000000000000003, R9 =0x00000000fff80000, R10=0x0000000064a160c2, R11=0x00007ffd51e00000
R12=0x0000000000000000, R13=0x00007ffd4acbbaf0, R14=0x00007ffd4ae6bd60, R15=0x0000000000000000
RIP=0x00007fff98ba7544, EFLAGS=0x0000000000010246, ERR=0x0000000000000004
  TRAPNO=0x000000000000000e
Top of Stack: (sp=0x0000000129ba0d00)
0x0000000129ba0d00:   0000000000000000 0000000000000000
0x0000000129ba0d10:   0000000000000000 0000000000000000
0x0000000129ba0d20:   0000000000000000 0000000000000000
0x0000000129ba0d30:   0000000000000000 00000000a7baadb1
0x0000000129ba0d40:   000000000000000d 00007fff7b326070
0x0000000129ba0d50:   0000000000000011 00007ffd4ae6bd60
0x0000000129ba0d60:   00007fff7d3c49d8 00007fff7d3c5cf0
0x0000000129ba0d70:   0000000129ba15c0 00007fff98bc1fd0
0x0000000129ba0d80:   00000006fbfe68b8 00000006faee8f08
0x0000000129ba0d90:   0000000000000000 0000000129ba0db0
0x0000000129ba0da0:   0000000129ba0e08 000000010c55c233
0x0000000129ba0db0:   0000000000000060 00000007aae7c968
0x0000000129ba0dc0:   0000000700000c58 0000000129ba0dc8
0x0000000129ba0dd0:   00000006fb4d8a35 0000000129ba0e20
0x0000000129ba0de0:   00000006fb4d9d78 00000006fbfe67d8
0x0000000129ba0df0:   00000006fb4d8a48 0000000000000000
0x0000000129ba0e00:   00007fff7d3879c0 00007ffd51a58e60
0x0000000129ba0e10:   0000000129ba1460 00007fff7d3c47a8
0x0000000129ba0e20:   0000000129ba0e50 00007fff98b81520
0x0000000129ba0e30:   0000000000000004 0000000000000002
0x0000000129ba0e40:   00007ffd51a58e60 0000000000000000
0x0000000129ba0e50:   0000000129ba0fa0 00007fff98b6d048
0x0000000129ba0e60:   00007ffd519340f8 0000000000000001
0x0000000129ba0e70:   0000000129ba0eb0 00007ffd4d170000
0x0000000129ba0e80:   000000000000000c 21eb0d26c23ae422
0x0000000129ba0e90:   ffffffffffffffff 0000000129ba0fb8
0x0000000129ba0ea0:   00007ffd51a59120 00007ffd51a58a60
0x0000000129ba0eb0:   0000000000000003 00007ffdfc008198
0x0000000129ba0ec0:   00007ffd51934100 00007ffd51a00790
0x0000000129ba0ed0:   00000007aae7d910 00007ffd4d170000
0x0000000129ba0ee0:   0000000129ba0f10 000000010bcdd786
0x0000000129ba0ef0:   000000010a7e9a00 00007ffd4c8f8db0
Instructions: (pc=0x00007fff98ba7544)
0x00007fff98ba7524:   b9 ad ba a5 48 8d 80 f8 ff ff 01 48 89 45 c8 45
0x00007fff98ba7534:   31 ff 66 2e 0f 1f 84 00 00 00 00 00 48 8b 45 b8
0x00007fff98ba7544:   4e 8b 34 20 49 8d 46 01 48 83 f8 02 0f 82 9a 00
0x00007fff98ba7554:   00 00 4c 3b 75 c8 bb 00 00 00 00 49 0f 45 de b8
Register to memory mapping:
RAX=0x0000000000000000 is an unknown value
RBX=0x0000000000000000 is an unknown value
RCX=0x0000000000000000 is an unknown value
RDX=0x0040100080200c03 is an unknown value
RSP=0x0000000129ba0d00 is pointing into the stack for thread: 0x00007ffd4d170000
RBP=0x0000000129ba0d70 is pointing into the stack for thread: 0x00007ffd4d170000
RSI=0x00007ffd4acbbb20 is an unknown value
RDI=0x0000000000000000 is an unknown value
R8 =0x0000000000000003 is an unknown value
R9 =0x00000000fff80000 is an unknown value
R10=0x0000000064a160c2 is an unknown value
R11=0x00007ffd51e00000 is an unknown value
R12=0x0000000000000000 is an unknown value
R13=0x00007ffd4acbbaf0 is an unknown value
R14=0x00007ffd4ae6bd60 is an unknown value
R15=0x0000000000000000 is an unknown value
Stack: [0x0000000129aa3000,0x0000000129ba3000],  sp=0x0000000129ba0d00,  free space=1015k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C  [CoreFoundation+0x5efd0]  CFSetCreateCopy+0x90
C  [jna5346453421313311029.tmp+0x1de6]  hid_open_path+0x1d6
C  [jna3258978828267461289.tmp+0xd94c]  ffi_call_unix64+0x4c
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  com.sun.jna.Native.invokePointer(JI[Ljava/lang/Object;)J+0
j  com.sun.jna.Function.invokePointer(I[Ljava/lang/Object;)Lcom/sun/jna/Pointer;+6
j  com.sun.jna.Function.invoke([Ljava/lang/Object;Ljava/lang/Class;Z)Ljava/lang/Object;+426
j  com.sun.jna.Function.invoke(Ljava/lang/Class;[Ljava/lang/Object;Ljava/util/Map;)Ljava/lang/Object;+262
j  com.sun.jna.Library$Handler.invoke(Ljava/lang/Object;Ljava/lang/reflect/Method;[Ljava/lang/Object;)Ljava/lang/Object;+316
j  com.sun.proxy.$Proxy0.hid_open_path(Ljava/lang/String;)Lcom/sun/jna/Pointer;+16
j  org.hid4java.jna.HidApi.open(Ljava/lang/String;)Lorg/hid4java/jna/HidDeviceStructure;+4
j  org.hid4java.HidDeviceManager.open(Ljava/lang/String;IILjava/lang/String;)Lorg/hid4java/HidDevice;+1
j  org.hid4java.HidServices.getHidDevice(Ljava/lang/String;IILjava/lang/String;)Lorg/hid4java/HidDevice;+9
j  com.ross_tech.hexnetconfig.HexNetHidDeviceInfo.open()Lcom/ross_tech/hexnetconfig/HexNetHidDevice;+21
j  com.ross_tech.hexnetconfig.HexNetCore.get_all_hexnet_serials()Ljava/util/ArrayList;+36
j  com.ross_tech.hexnetconfig.UpdateFrame.download_update()V+5326
j  com.ross_tech.hexnetconfig.UpdateFrame$2$1.run()V+50
j  java.lang.Thread.run()V+11
v  ~StubRoutines::call_stub
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
=>0x00007ffd4d170000 JavaThread "Thread-10" [_thread_in_native, id=57371, stack(0x0000000129aa3000,0x0000000129ba3000)]
  0x00007ffd4c2ee000 JavaThread "Thread-2" [_thread_blocked, id=80139, stack(0x0000000123010000,0x0000000123110000)]
  0x00007ffd4c087000 JavaThread "TimerQueue" daemon [_thread_blocked, id=78603, stack(0x0000000122f0d000,0x000000012300d000)]
  0x00007ffd4d228800 JavaThread "hid4java Device Scanner" daemon [_thread_in_native, id=75523, stack(0x000000012287d000,0x000000012297d000)]
  0x00007ffd4d226000 JavaThread "hid4java event worker" daemon [_thread_blocked, id=75011, stack(0x0000000122755000,0x0000000122855000)]
  0x00007ffd4d177800 JavaThread "hid4java event worker" daemon [_thread_blocked, id=74499, stack(0x0000000122652000,0x0000000122752000)]
  0x00007ffd4b0d6800 JavaThread "hid4java event worker" daemon [_thread_blocked, id=73987, stack(0x000000012254f000,0x000000012264f000)]
  0x00007ffd4d104000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=53783, stack(0x000000012234a000,0x000000012244a000)]
  0x00007ffd4d0c5800 JavaThread "Java2D Queue Flusher" daemon [_thread_blocked, id=52487, stack(0x0000000121a10000,0x0000000121b10000)]
  0x00007ffd4b067000 JavaThread "DestroyJavaVM" [_thread_blocked, id=3847, stack(0x000000010c454000,0x000000010c554000)]
  0x00007ffd4c08c000 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=44319, stack(0x000000012190d000,0x0000000121a0d000)]
  0x00007ffd4b8ea000 JavaThread "AWT-Shutdown" [_thread_blocked, id=29715, stack(0x000000011ecec000,0x000000011edec000)]
  0x00007ffd4d0b3000 JavaThread "AppKit Thread" daemon [_thread_in_native, id=8207, stack(0x00007fff553b4000,0x00007fff55434000)]
  0x00007ffd4b829000 JavaThread "Service Thread" daemon [_thread_blocked, id=19715, stack(0x000000011d3a8000,0x000000011d4a8000)]
  0x00007ffd4c030800 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=19203, stack(0x000000011d2a5000,0x000000011d3a5000)]
  0x00007ffd4c02f000 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=18691, stack(0x000000011d1a2000,0x000000011d2a2000)]
  0x00007ffd4c00e800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=15383, stack(0x000000011d09f000,0x000000011d19f000)]
  0x00007ffd4c00c800 JavaThread "Finalizer" daemon [_thread_blocked, id=13571, stack(0x000000011b75c000,0x000000011b85c000)]
  0x00007ffd4c00a000 JavaThread "Reference Handler" daemon [_thread_blocked, id=13059, stack(0x000000011b659000,0x000000011b759000)]
Other Threads:
  0x00007ffd4d052000 VMThread [stack: 0x000000011b556000,0x000000011b656000] [id=12547]
  0x00007ffd4b819000 WatcherThread [stack: 0x000000011d4ab000,0x000000011d5ab000] [id=20227]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
 PSYoungGen      total 274944K, used 8058K [0x00000007aaa80000, 0x00000007bc180000, 0x0000000800000000)
  eden space 264192K, 3% used [0x00000007aaa80000,0x00000007ab25e820,0x00000007bac80000)
  from space 10752K, 0% used [0x00000007bac80000,0x00000007bac80000,0x00000007bb700000)
  to   space 10752K, 0% used [0x00000007bb700000,0x00000007bb700000,0x00000007bc180000)
 ParOldGen       total 174592K, used 9342K [0x0000000700000000, 0x000000070aa80000, 0x00000007aaa80000)
  object space 174592K, 5% used [0x0000000700000000,0x000000070091f878,0x000000070aa80000)
 PSPermGen       total 21504K, used 18599K [0x00000006fae00000, 0x00000006fc300000, 0x0000000700000000)
  object space 21504K, 86% used [0x00000006fae00000,0x00000006fc029dc0,0x00000006fc300000)
Card table byte_map: [0x000000010f616000,0x000000010fe40000] byte_map_base: 0x000000010be3f000
Polling page: 0x000000010a950000
Code Cache  [0x000000010c556000, 0x000000010c7c6000, 0x000000010f556000)
 total_blobs=1123 nmethods=617 adapters=460 free_code_cache=47323Kb largest_free_block=48368960
Compilation events (10 events):
Event: 71.291 Thread 0x00007ffd4c030800  659             java.awt.Component::isShowing (38 bytes)
Event: 71.292 Thread 0x00007ffd4c030800 nmethod 659 0x000000010c716bd0 code [0x000000010c716d20, 0x000000010c716dd8]
Event: 71.791 Thread 0x00007ffd4c02f000  660             java.awt.Color::getAlpha (12 bytes)
Event: 71.792 Thread 0x00007ffd4c02f000 nmethod 660 0x000000010c6f6290 code [0x000000010c6f63e0, 0x000000010c6f6458]
Event: 72.576 Thread 0x00007ffd4c030800  663   !         sun.awt.image.SurfaceManager::getManager (47 bytes)
Event: 72.579 Thread 0x00007ffd4c030800 nmethod 663 0x000000010c6c1750 code [0x000000010c6c18c0, 0x000000010c6c1aa8]
Event: 73.672 Thread 0x00007ffd4c02f000  664             sun.java2d.pipe.BufferedContext::validate (518 bytes)
Event: 73.688 Thread 0x00007ffd4c02f000 nmethod 664 0x000000010c6b4210 code [0x000000010c6b44a0, 0x000000010c6b53e0]
Event: 74.211 Thread 0x00007ffd4c030800  665             java.lang.Short::<init> (10 bytes)
Event: 74.211 Thread 0x00007ffd4c030800 nmethod 665 0x000000010c7169d0 code [0x000000010c716b00, 0x000000010c716b58]
GC Heap History (10 events):
Event: 76.555 GC heap before
{Heap before GC invocations=231 (full 114):
 PSYoungGen      total 274944K, used 160K [0x00000007aaa80000, 0x00000007bc180000, 0x0000000800000000)
  eden space 264192K, 0% used [0x00000007aaa80000,0x00000007aaa80000,0x00000007bac80000)
  from space 10752K, 1% used [0x00000007bac80000,0x00000007baca8000,0x00000007bb700000)
  object space 174592K, 5% used [0x0000000700000000,0x000000070091f808,0x000000070aa80000)
 PSPermGen       total 21504K, used 18596K [0x00000006fae00000, 0x00000006fc300000, 0x0000000700000000)
  object space 21504K, 86% used [0x00000006fae00000,0x00000006fc029310,0x00000006fc300000)
Event: 76.576 GC heap after
Heap after GC invocations=231 (full 114):
 PSYoungGen      total 274944K, used 0K [0x00000007aaa80000, 0x00000007bc180000, 0x0000000800000000)
 ParOldGen       total 174592K, used 9335K [0x0000000700000000, 0x000000070aa80000, 0x00000007aaa80000)
  object space 174592K, 5% used [0x0000000700000000,0x000000070091de60,0x000000070aa80000)
Event: 76.577 GC heap before
{Heap before GC invocations=232 (full 114):
 PSYoungGen      total 274944K, used 5363K [0x00000007aaa80000, 0x00000007bc180000, 0x0000000800000000)
  eden space 264192K, 2% used [0x00000007aaa80000,0x00000007aafbcce8,0x00000007bac80000)
 PSPermGen       total 21504K, used 18597K [0x00000006fae00000, 0x00000006fc300000, 0x0000000700000000)
  object space 21504K, 86% used [0x00000006fae00000,0x00000006fc0295f8,0x00000006fc300000)
Event: 76.578 GC heap after
Heap after GC invocations=232 (full 114):
  from space 10752K, 1% used [0x00000007bb700000,0x00000007bb728000,0x00000007bc180000)
  to   space 10752K, 0% used [0x00000007bac80000,0x00000007bac80000,0x00000007bb700000)
Event: 76.578 GC heap before
{Heap before GC invocations=233 (full 115):
Event: 76.597 GC heap after
Heap after GC invocations=233 (full 115):
  from space 10752K, 0% used [0x00000007bb700000,0x00000007bb700000,0x00000007bc180000)
 ParOldGen       total 174592K, used 9336K [0x0000000700000000, 0x000000070aa80000, 0x00000007aaa80000)
  object space 174592K, 5% used [0x0000000700000000,0x000000070091e0c0,0x000000070aa80000)
Event: 76.738 GC heap before
{Heap before GC invocations=234 (full 115):
  eden space 264192K, 2% used [0x00000007aaa80000,0x00000007aafbce18,0x00000007bac80000)
Event: 76.740 GC heap after
Heap after GC invocations=234 (full 115):
 PSYoungGen      total 274944K, used 224K [0x00000007aaa80000, 0x00000007bc180000, 0x0000000800000000)
  from space 10752K, 2% used [0x00000007bac80000,0x00000007bacb8000,0x00000007bb700000)
Event: 76.740 GC heap before
{Heap before GC invocations=235 (full 116):
Event: 76.761 GC heap after
Heap after GC invocations=235 (full 116):
Deoptimization events (10 events):
Event: 44.120 Thread 0x00007ffd4c08c000 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x000000010c6d43b0 method=sun.java2d.pipe.BufferedContext.validate(Lsun/java2d/pipe/hw/AccelSurface;Lsun/java2d/pipe/hw/AccelSurface;Lsun/java2d/pipe/Region;Ljava/awt/Composite;Ljava/awt/geom/Affin
Event: 45.213 Thread 0x00007ffd4c1e1800 Uncommon trap: reason=unreached action=reinterpret pc=0x000000010c6bf378 method=java.io.PrintStream.print(Ljava/lang/String;)V @ 1
Event: 45.635 Thread 0x00007ffd4d228800 Uncommon trap: reason=null_check action=make_not_entrant pc=0x000000010c6e1f2c method=com.sun.jna.Pointer.getValue(JLjava/lang/Class;Ljava/lang/Object;)Ljava/lang/Object; @ 7
Event: 50.016 Thread 0x00007ffd4d0b3000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000000010c672290 method=sun.java2d.loops.SurfaceType.pixelFor(ILjava/awt/image/ColorModel;)I @ 6
Event: 55.345 Thread 0x00007ffd4d228800 Uncommon trap: reason=null_check action=make_not_entrant pc=0x000000010c6f4bf4 method=com.sun.jna.Structure.readField(Lcom/sun/jna/Structure$StructField;)Ljava/lang/Object; @ 43
Event: 55.858 Thread 0x00007ffd4d228800 Uncommon trap: reason=null_check action=make_not_entrant pc=0x000000010c6fe904 method=com.sun.jna.Structure.readField(Lcom/sun/jna/Structure$StructField;)Ljava/lang/Object; @ 59
Event: 56.065 Thread 0x00007ffd4d170000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000000010c62cde0 method=sun.security.provider.DigestBase.engineUpdate([BII)V @ 128
Event: 56.066 Thread 0x00007ffd4d170000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000000010c62cde0 method=sun.security.provider.DigestBase.engineUpdate([BII)V @ 128
Event: 61.473 Thread 0x00007ffd4d228800 Uncommon trap: reason=null_check action=make_not_entrant pc=0x000000010c71f63c method=com.sun.jna.Structure.readField(Lcom/sun/jna/Structure$StructField;)Ljava/lang/Object; @ 69
Event: 61.985 Thread 0x00007ffd4d228800 Uncommon trap: reason=null_check action=make_not_entrant pc=0x000000010c727e34 method=com.sun.jna.Structure.readField(Lcom/sun/jna/Structure$StructField;)Ljava/lang/Object; @ 79
Internal exceptions (10 events):
Event: 71.498 Thread 0x00007ffd4d170000 Threw 0x00000007aab14ca8 at /HUDSON/workspace/7u-2-build-macosx-x86_64/jdk7u51/527/hotspot/src/share/vm/prims/jni.cpp:717
Event: 71.498 Thread 0x00007ffd4d170000 Threw 0x00000007aab17d08 at /HUDSON/workspace/7u-2-build-macosx-x86_64/jdk7u51/527/hotspot/src/share/vm/prims/jni.cpp:717
Event: 71.499 Thread 0x00007ffd4d170000 Threw 0x00000007aab1ada0 at /HUDSON/workspace/7u-2-build-macosx-x86_64/jdk7u51/527/hotspot/src/share/vm/prims/jni.cpp:717
Event: 71.499 Thread 0x00007ffd4d170000 Threw 0x00000007aab1de40 at /HUDSON/workspace/7u-2-build-macosx-x86_64/jdk7u51/527/hotspot/src/share/vm/prims/jni.cpp:717
Event: 72.500 Thread 0x00007ffd4d170000 Threw 0x00000007aab20d08 at /HUDSON/workspace/7u-2-build-macosx-x86_64/jdk7u51/527/hotspot/src/share/vm/prims/jni.cpp:717
Event: 72.502 Thread 0x00007ffd4d170000 Threw 0x00000007aab24610 at /HUDSON/workspace/7u-2-build-macosx-x86_64/jdk7u51/527/hotspot/src/share/vm/prims/jni.cpp:717
Event: 73.199 Thread 0x00007ffd4d170000 Threw 0x00000007aab2fe40 at /HUDSON/workspace/7u-2-build-macosx-x86_64/jdk7u51/527/hotspot/src/share/vm/prims/jni.cpp:717
Event: 73.199 Thread 0x00007ffd4d170000 Threw 0x00000007aab30380 at /HUDSON/workspace/7u-2-build-macosx-x86_64/jdk7u51/527/hotspot/src/share/vm/prims/jni.cpp:717
Event: 73.199 Thread 0x00007ffd4d170000 JVM_StopThread thread JavaThread 0x00007ffd4d3e0800 as oop 0x00000007aab2eb50 [exception 0x0000000129ba2730]
Event: 73.199 Thread 0x00007ffd4d3e0800 Threw 0x00000007aab347c8 at /HUDSON/workspace/7u-2-build-macosx-x86_64/jdk7u51/527/hotspot/src/share/vm/prims/jvm.cpp:2965
Events (10 events):
Event: 76.304 Executing VM operation: ParallelGCSystemGC
Event: 76.327 Executing VM operation: ParallelGCSystemGC done
Event: 76.470 Executing VM operation: ParallelGCSystemGC
Event: 76.492 Executing VM operation: ParallelGCSystemGC done
Event: 76.554 Executing VM operation: ParallelGCSystemGC
Event: 76.576 Executing VM operation: ParallelGCSystemGC done
Event: 76.577 Executing VM operation: ParallelGCSystemGC
Event: 76.597 Executing VM operation: ParallelGCSystemGC done
Event: 76.738 Executing VM operation: ParallelGCSystemGC
Event: 76.761 Executing VM operation: ParallelGCSystemGC done
Dynamic libraries:
0x000000000b299000 	/System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x000000000b299000 	/System/Library/Frameworks/Security.framework/Versions/A/Security
0x000000000b299000 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x000000000b299000 	/usr/lib/libz.1.dylib
0x000000000b299000 	/usr/lib/libSystem.B.dylib
0x000000000b299000 	/usr/lib/libobjc.A.dylib
0x000000000b299000 	/System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x000000000b299000 	/System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x000000000b299000 	/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x000000000b299000 	/System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x000000000b299000 	/System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x000000000b299000 	/System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x000000000b299000 	/System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x000000000b299000 	/System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x000000000b299000 	/System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x000000000b299000 	/System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x000000000b299000 	/System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x000000000b299000 	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x000000000b299000 	/System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x000000000b299000 	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x000000000b299000 	/usr/lib/libauto.dylib
0x000000000b299000 	/usr/lib/libicucore.A.dylib
0x000000000b299000 	/usr/lib/libxml2.2.dylib
0x000000000b299000 	/System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x000000000b299000 	/System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x000000000b299000 	/System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x000000000b299000 	/usr/lib/liblangid.dylib
0x000000000b299000 	/System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x000000000b299000 	/System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x000000000b299000 	/usr/lib/libDiagnosticMessagesClient.dylib
0x000000000b299000 	/System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x000000000b299000 	/System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x000000000b299000 	/System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x000000000b299000 	/System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x000000000b299000 	/System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x000000000b299000 	/System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x000000000b299000 	/System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x000000000b299000 	/System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x000000000b299000 	/usr/lib/libextension.dylib
0x000000000b299000 	/System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x000000000b299000 	/usr/lib/libarchive.2.dylib
0x000000000b299000 	/System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x000000000b299000 	/System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x000000000b299000 	/usr/lib/libCRFSuite.dylib
0x000000000b299000 	/usr/lib/libc++.1.dylib
0x000000000b299000 	/usr/lib/libc++abi.dylib
0x000000000b299000 	/usr/lib/system/libcache.dylib
0x000000000b299000 	/usr/lib/system/libcommonCrypto.dylib
0x000000000b299000 	/usr/lib/system/libcompiler_rt.dylib
0x000000000b299000 	/usr/lib/system/libcopyfile.dylib
0x000000000b299000 	/usr/lib/system/libcorecrypto.dylib
0x000000000b299000 	/usr/lib/system/libdispatch.dylib
0x000000000b299000 	/usr/lib/system/libdyld.dylib
0x000000000b299000 	/usr/lib/system/libkeymgr.dylib
0x000000000b299000 	/usr/lib/system/liblaunch.dylib
0x000000000b299000 	/usr/lib/system/libmacho.dylib
0x000000000b299000 	/usr/lib/system/libquarantine.dylib
0x000000000b299000 	/usr/lib/system/libremovefile.dylib
0x000000000b299000 	/usr/lib/system/libsystem_asl.dylib
0x000000000b299000 	/usr/lib/system/libsystem_blocks.dylib
0x000000000b299000 	/usr/lib/system/libsystem_c.dylib
0x000000000b299000 	/usr/lib/system/libsystem_configuration.dylib
0x000000000b299000 	/usr/lib/system/libsystem_coreservices.dylib
0x000000000b299000 	/usr/lib/system/libsystem_coretls.dylib
0x000000000b299000 	/usr/lib/system/libsystem_dnssd.dylib
0x000000000b299000 	/usr/lib/system/libsystem_info.dylib
0x000000000b299000 	/usr/lib/system/libsystem_kernel.dylib
0x000000000b299000 	/usr/lib/system/libsystem_m.dylib
0x000000000b299000 	/usr/lib/system/libsystem_malloc.dylib
0x000000000b299000 	/usr/lib/system/libsystem_network.dylib
0x000000000b299000 	/usr/lib/system/libsystem_networkextension.dylib
0x000000000b299000 	/usr/lib/system/libsystem_notify.dylib
0x000000000b299000 	/usr/lib/system/libsystem_platform.dylib
0x000000000b299000 	/usr/lib/system/libsystem_pthread.dylib
0x000000000b299000 	/usr/lib/system/libsystem_sandbox.dylib
0x000000000b299000 	/usr/lib/system/libsystem_secinit.dylib
0x000000000b299000 	/usr/lib/system/libsystem_stats.dylib
0x000000000b299000 	/usr/lib/system/libsystem_trace.dylib
0x000000000b299000 	/usr/lib/system/libunc.dylib
0x000000000b299000 	/usr/lib/system/libunwind.dylib
0x000000000b299000 	/usr/lib/system/libxpc.dylib
0x000000000b299000 	/usr/lib/libbz2.1.0.dylib
0x000000000b299000 	/usr/lib/liblzma.5.dylib
0x000000000b299000 	/usr/lib/libbsm.0.dylib
0x000000000b299000 	/usr/lib/libsqlite3.dylib
0x000000000b299000 	/usr/lib/system/libkxld.dylib
0x000000000b299000 	/usr/lib/libxar.1.dylib
0x000000000b299000 	/usr/lib/libpam.2.dylib
0x000000000b299000 	/usr/lib/libOpenScriptingUtil.dylib
0x000000000b299000 	/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x000000000b299000 	/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x000000000b299000 	/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x000000000b299000 	/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x000000000b299000 	/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x000000000b299000 	/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x000000000b299000 	/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x000000000b299000 	/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x000000000b299000 	/System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x000000000b299000 	/System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x000000000b299000 	/System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x000000000b299000 	/System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x000000000b299000 	/usr/lib/libmecabra.dylib
0x000000000b299000 	/System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x000000000b299000 	/usr/lib/libcmph.dylib
0x000000000b299000 	/usr/lib/libiconv.2.dylib
0x000000000b299000 	/System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x000000000b299000 	/System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x000000000b299000 	/usr/lib/libxslt.1.dylib
0x000000000b299000 	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x000000000b299000 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x000000000b299000 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x000000000b299000 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x000000000b299000 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x000000000b299000 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x000000000b299000 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x000000000b299000 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x000000000b299000 	/System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x000000000b299000 	/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x000000000b299000 	/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x000000000b299000 	/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x000000000b299000 	/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x000000000b299000 	/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x000000000b299000 	/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x000000000b299000 	/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x000000000b299000 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x000000000b299000 	/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x000000000b299000 	/System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x000000000b299000 	/System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x000000000b299000 	/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x000000000b299000 	/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x000000000b299000 	/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x000000000b299000 	/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x000000000b299000 	/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x000000000b299000 	/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x000000000b299000 	/System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x000000000b299000 	/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x000000000b299000 	/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x000000000b299000 	/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x000000000b299000 	/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x000000000b299000 	/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x000000000b299000 	/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x000000000b299000 	/usr/lib/libcups.2.dylib
0x000000000b299000 	/System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x000000000b299000 	/System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x000000000b299000 	/usr/lib/libresolv.9.dylib
0x000000000b299000 	/System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x000000000b299000 	/usr/lib/libheimdal-asn1.dylib
0x000000000b299000 	/System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x000000000b299000 	/System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x000000000b299000 	/System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x000000000b299000 	/System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x000000000b299000 	/System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x000000000b299000 	/System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x000000000b299000 	/System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x000000000b299000 	/System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x000000000b299000 	/System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x000000000b299000 	/System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x000000000b299000 	/System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x000000000b299000 	/System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x000000000b299000 	/System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x000000000b299000 	/System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x000000000b299000 	/System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x000000000b299000 	/System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x000000000b299000 	/System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x000000000b299000 	/System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x000000000b299000 	/System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x000000010ba00000 	/Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/server/libjvm.dylib
0x000000000b299000 	/usr/lib/libstdc++.6.dylib
0x000000010a913000 	/Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libverify.dylib
0x000000010a920000 	/Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libjava.dylib
0x000000010a95a000 	/Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libzip.dylib
0x000000011b85e000 	/System/Library/Frameworks/JavaVM.framework/Frameworks/JavaRuntimeSupport.framework/JavaRuntimeSupport
0x000000011b874000 	/System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation
0x000000011b888000 	/System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
0x000000000b299000 	/System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x000000011b894000 	/System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
0x000000000b299000 	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x000000000b299000 	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x000000000b299000 	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x000000000b299000 	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x000000000b299000 	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x000000000b299000 	/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x000000011d5b2000 	/Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libnet.dylib
0x000000011d60f000 	/Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libawt.dylib
0x000000011d6be000 	/Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/./libmlib_image.dylib
0x000000011d78a000 	/Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/lwawt/liblwawt.dylib
0x000000011d83e000 	/Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libosxapp.dylib
0x000000000b299000 	/System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling
0x000000000b299000 	/System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x000000000b299000 	/System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x000000000b299000 	/System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x000000000b299000 	/System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x000000000b299000 	/System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x000000000b299000 	/System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x000000000b299000 	/System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x000000000b299000 	/System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x000000000b299000 	/System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x000000000b299000 	/System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x000000000b299000 	/System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x000000000b299000 	/System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
0x000000000b299000 	/System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x000000000b299000 	/usr/lib/libcrypto.0.9.8.dylib
0x000000000b299000 	/System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x000000000b299000 	/System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x000000000b299000 	/System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
0x000000000b299000 	/System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x000000000b299000 	/System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x000000000b299000 	/System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x000000000b299000 	/System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x000000000b299000 	/System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x000000000b299000 	/usr/lib/libcsfde.dylib
0x000000000b299000 	/usr/lib/libcurl.4.dylib
0x000000000b299000 	/System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x000000000b299000 	/System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x000000000b299000 	/usr/lib/libCoreStorage.dylib
0x000000000b299000 	/System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x000000000b299000 	/usr/lib/libutil.dylib
0x000000000b299000 	/System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
0x000000000b299000 	/System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x000000000b299000 	/usr/lib/libsasl2.2.dylib
0x000000012060a000 	cl_kernels
0x000000012060c000 	/System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x00000001205fb000 	cl_kernels
0x000000000b299000 	/System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x000000000b299000 	/System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x000000000b299000 	/System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x000000000b299000 	/System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x000000000b299000 	/System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x000000000b299000 	/System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x000000000b299000 	/System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x000000000b299000 	/usr/lib/libodfde.dylib
0x00000001218a5000 	/Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libfontmanager.dylib
0x000000011f998000 	/Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libosxui.dylib
0x000000000b299000 	/System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x000000000b299000 	/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x0000000000000000 	/System/Library/Extensions/AppleIntelHD4000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD4000GraphicsGLDriver
0x000000000b299000 	/System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x000000000b299000 	/System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x000000000b299000 	/System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x000000012244c000 	/Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libnio.dylib
0x00000001224cf000 	/private/var/folders/2q/xxj42hnx4978q3qz9f_l9t5r0000gn/T/jna-3254481/jna3258978828267461289.tmp
0x000000012252d000 	/var/folders/2q/xxj42hnx4978q3qz9f_l9t5r0000gn/T/jna-3254481/jna5346453421313311029.tmp
0x0000000122533000 	/System/Library/Extensions/IOHIDFamily.kext/Contents/PlugIns/IOHIDLib.plugin/Contents/MacOS/IOHIDLib
0x000000000b299000 	/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x000000011f83a000 	/Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libsunec.dylib
0x000000011f8b0000 	/Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/jre/lib/libosx.dylib
VM Arguments:
java_command: HexNetConfigV1.958.jar
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin
SHELL=/bin/bash
DISPLAY=/private/tmp/com.apple.launchd.YzTGds7eQN/org.macosforge.xquartz:0
Signal Handlers:
SIGSEGV: [libjvm.dylib+0x525425], sa_mask[0]=0xfffefeff, sa_flags=0x00000043
SIGBUS: [libjvm.dylib+0x525425], sa_mask[0]=0xfffefeff, sa_flags=0x00000042
SIGFPE: [libjvm.dylib+0x41892a], sa_mask[0]=0xfffefeff, sa_flags=0x00000042
SIGPIPE: [libjvm.dylib+0x41892a], sa_mask[0]=0xfffefeff, sa_flags=0x00000042
SIGXFSZ: [libjvm.dylib+0x41892a], sa_mask[0]=0xfffefeff, sa_flags=0x00000042
SIGILL: [libjvm.dylib+0x41892a], sa_mask[0]=0xfffefeff, sa_flags=0x00000042
SIGUSR1: SIG_DFL, sa_mask[0]=0x63807efb, sa_flags=0x00000000
SIGUSR2: [libjvm.dylib+0x41841c], sa_mask[0]=0x00000000, sa_flags=0x00000042
SIGHUP: [libjvm.dylib+0x4166ab], sa_mask[0]=0xfffefeff, sa_flags=0x00000042
SIGINT: [libjvm.dylib+0x4166ab], sa_mask[0]=0xfffefeff, sa_flags=0x00000042
SIGTERM: [libjvm.dylib+0x4166ab], sa_mask[0]=0xfffefeff, sa_flags=0x00000042
SIGQUIT: [libjvm.dylib+0x4166ab], sa_mask[0]=0xfffefeff, sa_flags=0x00000042
---------------  S Y S T E M  ---------------
OS:Bsduname:Darwin 14.0.0 Darwin Kernel Version 14.0.0: Tue Sep 23 23:01:41 PDT 2014; root:xnu-2782.1.97~6/RELEASE_X86_64 x86_64
rlimit: STACK 8192k, CORE 0k, NPROC 709, NOFILE 10240, AS infinity
load average:2.36 2.31 2.11
CPU:total 8 (4 cores per cpu, 2 threads per core) family 6 model 58 stepping 9, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, aes, erms, ht, tsc, tscinvbit, tscinv
Memory: 4k page, physical 16777216k(4194304k free)
/proc/meminfo:
vm_info: Java HotSpot(TM) 64-Bit Server VM (24.51-b03) for bsd-amd64 JRE (1.7.0_51-b13), built on Dec 18 2013 18:45:56 by "java_re" with gcc 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.11.00)
time: Fri Oct 31 19:13:51 2014
elapsed time: 76 seconds
Guess I better get used to using the utility :D
That particular section of stuff (CFB) is unlikely to get frequent updates.
I'll let Shaun address the loop. Don't sweat it too much right now.
   #99
romad
Prescott, AZ
C?ID=208765
Just to let you know the new Config Utility V1.958 worked fine on Mac OS 10.7.5. Jake, it looks like you have Mac OS 10.10 installed. Ah, yes you do as I see by your post that went up just before mine.
   #100
jakematic
NC USA
C?ID=129085
Well you know me... if it can be broken... it will find me :p
I'll leave it alone unless you guys need any debugs and such.
