Sticky Current Versions
Sticky
   #42
Shaun
CB V0.4109 is out, with support for CAN TP1.6 1281, needed for a few (special snowflakes) specific modules
Also has some reliability and performance tweaks for VCDS comms, mainly for beta 14.7
Also out is FW V0.187, which has several behind the scenes tweaks and fixes
--Shaun
VCDS Beta 14.7.0
  • Requires CB v4109 and FW 0.187 so update your HEX-NET first!
  • Drastically optimized timeouts and error processing, should make WiFi more reliable and faster
  • HEX-NET will be faster on UDS modules, especially those with slaves
  • Fixed potential buffer overflow if WiFi is unreliable during HEX-NET comms init with controller
  • Merged USB and WiFi send routines
  • Moved all out of sequence packet buffering to one place
  • Fixed some out of sequence packets not being pulled in the right order
  • More OBD2 fixes (Mode 9 type 11)
  • Fixed some fails to re-initialize variables used with modules not responding normally to ID commands (for all interfaces)
  • Fixed Polo 6R UDS platform determination
  • Added work-around for buggy firmware in TRW 0x44 preventing MWB 80 from displaying
  • Fixed forced & incorrect coding suggestion for certain new airbag modules
  • Fixed Phaeton airbag freeze frame claiming to have mileage but not having it.
   #44
VCDS Beta 14.7.1
  • Requires CB v4109 and FW 0.187 -- which you already have if you're currently using 14.7.0.
  • Offers to open VCDS-Mobile for firmware update if connected in infrastructure mode
  • Fix for Basic Settings in UDS modules & HEX-NET
   #45
Shaun
Cb Version 0.4110 is out, which has support for measuring value/BS group zero
   #46
Awesome! The guys with old distributor-pump TDIs will be thrilled!
Shaun
CB V0.4111 is released, with a fix for manually entering group zero and a fix for a possible memory leak when force closing a session during kline comms
--Shaun
   #48
VCDS Beta 14.7.2
  • Requires CB v0.4111, so update your HEX-NET first.
  • Fix for CAN telegram timing and recovery if controller sends keep-alive between two telegrams
  • Fix for slow inter-telegram timing on CAN/TP20 for non HEX-NET interfaces
  • Workaround for Touareg 46 K-line flood when requesting DTCs
  • Fix slowness when Adapation channel N/A on KWP2000/CAN TP20
  • Fix slowness when terminating basic settings on KWP2000/CAN TP20
  • Fix potential missing slave ID on some 46 controllers (e.g. Touareg)
  • A number new/updated label files; Data Version 20140714
jakematic
NC USA
C?ID=129085
This seems to create an infinite loop, at least for me.
After the install it asks to download ~16MB, runs the whole install, then does it again once VCDS launches, over and over.
Only way I've found to get out is to untick the Run Now after install completes, or click cancel when it asked to update the Data Version.
Same scenario on 2 machines.
   #50
It's possible I fat-fingered something on the update server...
[Time passes]
It ain't obvious. Nope. That isn't the problem. I do see what the problem is though. Somebody goofed and it wasn't me, but I should caught it. I put a work-around on the server for now.
Sorry about that!
I'll go re-do the distro now and fix it right.
Keithuk
Stoke on Trent, England
C?ID=122432
I've just downloaded and installed the latest Beta 14.7.2 Data Version 20140714. A message says:
Installed data version 20140701
Latest data version 20140714
Would you like to download and install the latest version?
I downloaded it again and installed it but the same message still shows. The download site says Beta 14.7.2 Data Version 20140714 so how come it didn't install correctly. The About says Beta 14.7.2 Data Version 20140701.
   #52
Right, the Data Version was specified incorrectly.
It's fixed now.
Shaun
CB V0.4112 is released, contains improvements to HTTP timing that should make downloads faster to start and more reliable.
Also tweaks to autoscan formatting to make it more in line with classic VCDS
   #55
romad
Prescott, AZ
C?ID=208765
Better check the server; I just hang at:
"Updating: 0%"
"Preparing to update..."
It has been there for about 30 minutes.
I've:
Disconnected and reconnected the Hex-Net from my iMac
Canceled the update and later tried again.
No problem with recent the previous updates.
Shutting down for the night.
   #56
jakematic
NC USA
C?ID=129085
Try it now romad - mine just updated fine.
EDIT: Jinxed myself. One of them updated like a champ, the other one is exhibiting the same symptoms as yours :(
EDIT II: Rebooted HN 3 times and it's downloading now... :)
romad
Prescott, AZ
C?ID=208765
OK, it worked, sorta.
Told it to download the update and it did, then went into rebooting. Error message popped up saying something was wrong with my Hex-Net and the update had failed. Started the download again and was told I was up-to-date! Ran a self-test and got these results:
Test Results:
APP Id (1) CodeBlock V0.4112 API V4
FW version: 0.187.
Dataset: 00000027
K1: OK
K2: OK
CAN: Testing
VCDS-Cloud: OK
Config: OK
   #58
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
The "update failed" message seems to be common. It is a cosmetic problem only and it can be ignored if your version display is up-to-date.
The occasional upgrade download stall also seems to be common. Several people here have hit it, myself included, and I'm not sure what conditions trigger it. Shaun's release notes imply that might be fixed now, but there might be a chicken-and-egg issue: you need to upgrade to have the fix for smoother upgrading. :)
Jason
   #59
Shaun
A full set of updates coming at you today. FW 0.196 includes a lot of cumulative tweaks and bug fixes, including changes to TCP timing and Kline handling.
CB 0.4114 has support for wifi FW updates and a fix for certain KW2000 packets with a long format header. Dataset 00000028 has the update file for the previous mentioned wifi firmware, updating it to version 310C. More details in the main post above.
--Shaun
   #60
jakematic
NC USA
C?ID=129085
Wow massive update, thanks Shaun.
I think it took 4 or 5 checks to get them all.
Lost track since I was flipping between interfaces :rolleyes:
