Monday,28,August,2017,18:33:31:22573
VCDS Version: 17.8.0.1 (x64)
Workshop Code: 123 12345 076128
VIN: WVGZZZ1TZHW0 License Plate:
Mileage: 4610km-2864mi Repair Order:
Chassis Type: 1T-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 55 5F
VIN: WVGZZZ1TZHW0 Mileage: 4610km-2864miles
Address 01: Engine (J623-CJSA) Labels: None
Part No SW: 5N0 906 264 HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13---
Coding: 092500122464050B2000
ASAM Dataset: EV_ECM18TFS0205N0906264 001002
ROD: EV_ECM18TFS0205N0906264.rod
VCID: 6ED3A692B1CF283668-803A
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0CW 300 041 F HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1005
Revision: 00005026 Serial number: CU501611155547
ROD: EV_TCMDQ200021_VW26.rod
VCID: 387F40CA830BA68672-806C
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH
Component: ESC H62 0743
Revision: 00000000 Serial number: 63516000001007
Coding: 0CEA6AA034262372477A060240CC4930562CC4E2600292751842F078C202420000040212121212B235351919323200
ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
VCID: 79F985CEF8817F8ECD-802C
Part No SW: 5G0 907 044 CJ HW: 5G0 907 044 CJ
Component: Climatronic H04 1801
Revision: 00001K10
Coding: 0802000420011001100510000010102A
ROD: EV_ACClimaBHBVW37X_006_VW27.rod
VCID: 71E9BDEEA0F137CE75-8024
Air quality sensor:
Part No SW: 5Q0 937 086 BG HW: 5Q0 937 086 BG
Component: BCM PQ37BOSCH 032 0223
Revision: -------- Serial number: 865815121601II
ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
ROD: EV_BCMBOSCH_017_VW27.rod
VCID: 000FE82A9B5B2E468A-8054
Subsystem 1 - Part No SW: 5TB 955 119 A HW: 5TB 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 161031 043 0608
Serial number: 161118050453
Component: RLHS 042 0105
Serial number: S2Y16M12D30H06M39S13
Coding: 00A8DD
Serial number: 000000000ZY1631610NK
Serial number: 00000000000037108561
Part No SW: 5QA 919 294 A HW: 5QA 919 294
Component: PDC 8 KanalH07 0038
Serial number: 000308418616353
Coding: 0471051011
ASAM Dataset: EV_EPHVA18AU3700000 009031
ROD: EV_EPHVA18AU3700000.rod
VCID: 4A9B0A02EDE7241614-801E
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 C
Component: ACC BOSCH MQB H04 0195
Coding: 3200678251FFC428949C8045
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 356149FE94195BEE69-8060
Part No SW: 5Q0 959 655 AS HW: 5Q0 959 655 AS
Component: AirbagVW21 003 0317
Serial number: 003TMR2G1X04
Coding: 98FCC0C00C0000005C5450CF000800000065
VCID: 1129DD6EC03157CE15-8044
Subsystem 1 - Part No SW: ----------- HW: 480 001 212 16
Serial number: 357000000002180D002+
Subsystem 2 - Part No SW: ----------- HW: 480 001 212 16
Serial number: 35800000000756351022
Subsystem 3 - Part No SW: ----------- HW: 480 411 912 16
Component: SideSensor_Dr 003 0189
Serial number: 351001A053C0B0E03F30
Subsystem 4 - Part No SW: ----------- HW: 480 411 912 16
Component: SideSensor_Pr 003 0189
Serial number: 352001A053C8BE432ECN
Subsystem 5 - Part No SW: ----------- HW: 480 401 512 16
Serial number: 3550001B923B3B34A410
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 402 403 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001A120E2715866W
Subsystem 7 - Part No SW: ----------- HW: 480 402 403 16
Component: PedP_Sensor_P 000 6149
Serial number: 2290001A120E271484E
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 402 403 16
Component: PedP_Sensor_C 000 6149
Serial number: 2300001AB20E2712D3E%
Subsystem 9 - Part No SW: ----------- HW: 480 002 003 17
Serial number: I0M000000006086C822+
Subsystem 10 - Part No SW: ----------- HW: 480 002 003 17
Serial number: I0N00000000C286C8227
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 5Q0 953 507 GH HW: 5Q0 953 549 E
Revision: -------- Serial number: 13121608490326
Coding: 0410
VCID: 020BE22295573C569C-8056
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5TA 920 750 A HW: 5TA 920 750 A
Component: KOMBI 305 8311
Coding: 07A401082F80000801886B011400000000000000
VCID: 428B2222D5D7FC56DC-8016
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0005748989
Coding: 030100047F085900FB0002581C0F00010001050000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 2F6D7B967645613E23-807A
Subsystem 2 - Part No SW: 5TA 959 442 B HW: 5TA 959 442 B Labels: 3C8-959-537.CLB
Serial number: 3421606343700792AS2B
Coding: 2D0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 8951862404
Component: TSG FS 020 0041
Serial number: 011216EKU27767
Coding: 003A02208000040000001000
VCID: 43852726CACDF55ED7-8016
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012715949
Address 44: Steering Assist (J500) Labels:. 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0001284538
Coding: 01000010004001
ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
VCID: 408F282ADBDBEE46CA-8014
Component: TSG BFS 020 0041
Serial number: 041216EL336149
Coding: 003A00208000040000801000
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012672504
Coding: 090000
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 07CA020009000000
ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
VCID: 75E189FED4991BEEA9-8020
Part No SW: 3Q0 035 846 A HW: 3Q0 035 846 A
Component: MU-S-N-ER 840 0751
Coding: 02730801FF0000005111000100080A001F01008401200100CF
ROD: EV_MUStd4CDELP_VW26.rod
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H71 6121
Serial number: VWZ6Z9S3560339
End-------------------------(Elapsed Time: 04:00)--------------------------
