Passat 2008 Parking Brake Module broken or wrong coding
Tinqe
Finland
C?ID=111265
I have VW Passat Variant TDI 2008 (registered at end of 2007) and it has problems with parking brake electronics or coding. Parking brake stopped working partially and control module moved only right side motor. VCDS did show something like "CPU 2 error" in parking brake control module, but I have lost that scan (new laptop). I did replace control module with another used part, which should be ok, but there might be something in it or my coding is not right. I did try to do Parking brake replacement and coding with old information from Auto-Scan -log using this manual.
Broblem is with Lateral Acceleration Sensor (G200) being "Not available" at basic setting. Brake Electronics, Measuring Blocks 008, Group 004 can show right values in field 2 as is in the manual and values change, when car is moving. So sensors should be ok? Image of error message at Basic Setting
Longitudinal Acceleration Sensor (G251) Basic Setting is also "Not available" as is Longitudinal Acceleration Sensor (G202), but there is no error message about that in Auto-Scan.
Car has now working parking brake, but ABS and ESP -warning lights are on and Parking Brake malfunction -light is blinking. Parking brake doesn´t automatically release, when trying to move the car.
I would like to know, should I buy new, not used Control module from VW or is it only something in my Basic Setting or Coding?
Sunday,20,August,2017,18:14:13:62902
VCDS Version: 17.8.0.1 (x64)
VIN: WVWZZZ3CZ8E067771   License Plate:
Mileage: 293420km-182322mi   Repair Order: 20170820-01
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 18 19 22 25 42 44 46 52 53 56 62 69 72
          76
VIN: WVWZZZ3CZ8E067771   Mileage: 293420km-182322miles
18-Aux. Heat -- Status: Cannot be reached 1100
69-Trailer -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 906 018 FG    HW: 03G 906 018 FG
   Component: R4 2.0l PPD1.5 G    0907
   Revision: --H45---    Serial number: VWZCZ000000000
   Coding: 0000172
   Shop #: WSC 05314 000 00000
   VCID: 6FE6C9F97E68BA3E63-803A
Readiness: N/A
   Part No SW: 3C0 614 109 C    HW: 3C0 614 109 C
   Component: J104    C4 440 V1   0003
   Revision: --020---    Serial number: 00000775972812
   Coding: 0004369
   Shop #: WSC 05311 000 00000
   VCID: 1E38C43DC94263B698-804A
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 CC    HW: 3C0 907 044 CC
   Component: ClimatronicPQ46 122 0707
   Revision: 00122021    Serial number: 00000000000000
   VCID: 64CCB6D5A7AE09660E-8030
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 99
                    Mileage: 276393 km
                    Date: 2017.01.11
                    Time: 18:37:02
            000 -  -  - Intermittent
                    Reset counter: 139
                    Mileage: 276393 km
                    Date: 2017.01.11
                    Time: 19:41:00
00710 - Defroster Flap Positioning Motor (V107)
            000 -  -
                    Reset counter: 99
                    Mileage: 288674 km
                    Date: 2017.06.13
                    Time: 19:14:59
01810 - Actuating Motor for Temperature Flap; Right (V159)
                    Fault Frequency: 44
                    Reset counter: 139
                    Mileage: 288530 km
                    Date: 2017.06.11
                    Time: 21:20:14
   Part No SW: 3C0 937 049 AL    HW: 3C0 937 049 AL
   Revision: 00H54000    Serial number: 01000007416873
   Coding: 098A8F0700041A00470A00000F000000000C5D435C000100000000000000
   Shop #: WSC 05124 000 00000
   VCID: 73EEC58912409EDE87-8026
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 130707 003  0205
   Coding: 00046997
   Shop #: WSC 05124
01517 - Control Module for Trailer/Towing Sensor (J345)
                    Reset counter: 100
                    Mileage: 276393 km
                    Date: 2017.01.11
                    Voltage: 12.40 V
                    Reset counter: 100
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.50 V
   Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
   Component: 0B AIRBAG VW8   032 2522
   Revision: 12032000    Serial number: 003B1PH1C21U
   Coding: 0012354
   VCID: 30640A85A3D6E5C63A-8064
   Subsystem 1 - Serial number: 6332MSME1627672D
   Subsystem 2 - Serial number: 6342MSME0D46136E
   Subsystem 3 - Serial number: 6351HTS61CG0T577
   Subsystem 4 - Serial number: 6361HTS618L07LB6
   Part No SW: 3C0 953 549 M    HW: 3C0 953 549 M
   Component: J0527               0015
   Revision: 00006000    Serial number: 3C9953507BJ
   Coding: 0000112
   VCID: 36683C9D41B2CBF660-8062
   Part No SW: 3C0 920 871 E    HW: 3C0 920 871 E
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 67000 205 21643
   VCID: 2648ECDD9112BB76D0-8072
Address 18: Aux. Heat
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P078280669
   Coding: F9827F4E000A022002
   Shop #: WSC 67000 205 84137
   VCID: 234EF5C9E2204E5EB7-8076
                    Reset counter: 10
                    Mileage: 276393 km
                    Date: 2017.01.11
                    Time: 18:37:03
                    Reset counter: 10
                    Mileage: 276393 km
                    Date: 2017.01.11
                    Time: 00:00:05
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 K
   Component: Haldex 4Motion      1118
   Coding: 0000001
   VCID: 356A3B915CB4C0EE69-8060
            013 - Check DTC Memory
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Shop #: WSC 61204 205 85339
   VCID: 397237A170AC248E8D-806C
   Component: J386  TUER-SG FT    1131
   Revision: 32008001    Serial number: 00000572178824
   Coding: 0000181
   VCID: 3B7E2DA97A90169E9F-806E
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.136 H08 1901
   Shop #: WSC 02069 000 90108
   Component:    KSG PQ46 ELV 042 0472
   Coding: 0091020051030E763004941570084F0B607C00
                    Fault Frequency: 11
                    Reset counter: 254
                    Mileage: 276393 km
                    Date: 2017.01.11
                    Time: 00:00:01
   Component: J387  TUER-SG BT    1131
   Revision: 32008001    Serial number: 00000106978714
   Coding: 0000180
   Shop #: WSC 00028 028 00001
   VCID: 3C7C2EB57F9E11A696-8068
   Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-09393 0009
   Revision:   008       Serial number: 00000000180793
   Coding: 0000056
   VCID: 2952E7E1800C940EFD-807C
                    Fault Status: 11110101
                    Reset counter: 254
                    Mileage: 290093 km
                    Date: 2017.07.17
                    Time: 00:00:41
                    Voltage: 11.60 V
                    Count: 101
                    Hex Value: 0x1250
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No: 1K0 035 186 AD
   Component: Radio GR0       033 0033
   Revision: 0003303S    Serial number: VWZ2Z2G2339818
   Coding: 0040400
   VCID: 68D4A2E55B866D0622-803C
            000 -  -
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1119
   Revision: 11006001    Serial number: 00000002250768
   Coding: 0000144
   VCID: 3D7A23B1648418AEA1-8068
Address 69: Trailer
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1119
   Revision: 11006001    Serial number: 00000002269791
   Coding: 0000144
   VCID: 3E7824BD698203B6B8-806A
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 C    HW: 3C0 919 283 C
   Component: Parkhilfe 8-Kan 004 0013
   Revision: 00004000    Serial number: 90630723204296
   Coding: 0000024
End-------------------------(Elapsed Time: 02:04)--------------------------
Auto-Scan before (when I bought the car)
Tuesday,10,November,2015,20:00:09:62902
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
Mileage: 236780km-147128mi   Repair Order: 20151110-1959
          76
VIN: WVWZZZ3CZ8E067771   Mileage: 236780km-147128miles
62-Door, Rear Left -- Status: Sporadic communication error 1000
   Coding: 0000172
   VCID: 6FE6C9F97E68BA46B4-803A
Readiness: N/A
   Coding: 0004369
   VCID: 1E38C43DC94263CE4F-804A
   VCID: 64CCB6D5A7AE091ED9-8030
            014 - Defective
                    Fault Status: 01111110
                    Reset counter: 134
                    Mileage: 191745 km
                    Date: 2014.07.09
                    Time: 15:14:54
                    Reset counter: 174
                    Mileage: 212025 km
                    Date: 2015.02.20
                    Time: 12:03:18
                    Fault Frequency: 76
                    Reset counter: 170
                    Mileage: 229836 km
                    Date: 2015.09.06
                    Time: 13:21:30
   VCID: 73EEC58912409EA650-8026
   Coding: 00046997
   Shop #: WSC 05124
                    Reset counter: 136
                    Mileage: 235648 km
                    Date: 2015.10.29
                    Time: 20:05:00
                    Voltage: 12.50 V
                    Reset counter: 134
                    Mileage: 191745 km
                    Date: 2014.07.09
                    Time: 15:13:00
                    Voltage: 13.80 V
   Coding: 0012354
   VCID: 30640A85A3D6E5BEED-8064
   Coding: 0000112
   VCID: 36683C9D41B2CB8EB7-8062
   Coding: 0007105
   VCID: 2648ECDD9112BB0E07-8072
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   VCID: 234EF5C9E2204E2660-8076
                    Reset counter: 236
                    Mileage: 191745 km
                    Date: 2014.07.09
                    Time: 14:59:43
                    Reset counter: 136
                    Mileage: 235648 km
                    Date: 2015.10.29
                    Time: 20:05:01
   Coding: 0000001
   VCID: 356A3B915CB4C096BE-8060
   VCID: 397237A170AC24F65A-806C
01176 - Key
                    Fault Status: 01101000
                    Reset counter: 112
                    Mileage: 204874 km
                    Date: 2014.11.29
                    Time: 13:05:58
   Coding: 0000181
   VCID: 3B7E2DA97A9016E648-806E
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
                    Fault Frequency: 26
                    Reset counter: 236
                    Mileage: 191745 km
                    Date: 2014.07.09
                    Time: 15:13:49
   Coding: 0000180
   VCID: 3C7C2EB57F9E11DE41-8068
   Revision:   008       Serial number: 00000000145226
   Coding: 0000056
   VCID: 2952E7E1800C94762A-807C
   Coding: 0040400
   VCID: 68D4A2E55B866D7EF5-803C
   Coding: 0000144
   VCID: 3D7A23B1648418D676-8068
Address 69: Trailer
   Coding: 0000144
   VCID: 3E7824BD698203CE6F-806A
   Coding: 0000024
End-------------------------(Elapsed Time: 02:14)--------------------------
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
When you go to Basic settings for Lateral Acceleration Sensor (G200), after Security Access 40168,
Enter 063 and wait till it says OK, DO NOT CLICK on On/Off/NEXT
Then go to 53-prrking brake and do same for Longitudinal Acceleration Sensor (G251).
Jef
HQ
Moi!
http://wiki.ross-tech.com/wiki/index.php/VW_Tiguan_(5N)_Brake_Electronics
Scroll down to the Lateral/Longitudinal Acceleration & Yaw Rate Sensor (G200/G202/G251) section.
Note that a lot of ABS systems will give you some sort of "OK" message after you click [Go!] but then an "error" message after you click the [On/Off/Next] button. This seems to be a normal thing, nothing to worry about.
Tinqe
Finland
C?ID=111265
Thank You!
Had to use Basic setting Group 061 and it just did the trick. Error lights are off, parking brake is working right and there is no errors about this in Auto-Scan.
Using Basic Setting Group 063 or 068 was not possible, because it did give me this "Not available" -error right after I clicked [Go!].
Jetta 97
C?ID=81680
Like Jef said , If is available ,always use drop down Box instead direct Group.
