Replacing BCM in VW T5 GP
bluetone
Sweden
C?ID=303067
Hello all,
I have retrofitted genuine VW xenons to my VW T5 van from 2012.
Now, everything is working fine...(then why are you posting on this forum?!?)
..exept that I have a error on the dashboard saying that there is a broken bulb.
Now, scanning reveals that this is the daytime running light that is being detected as broken and I strongly suspect this is because I have LEDs now instead of a bulb as DRL.
Now from reading all over the net, I belive this is due to a BCM that is just a little to old for being able to cope with LEDs as DRL.
I have the 7h0937089F BCM with software version 0251 (according to internet you need software version 0254 at least to be able to cope with LED DRLs
And I am trying to install the 7h0937090D with software version 0725, but when I do that, I cannot reach the engine, auto trans and several other things with VCDS.
Also, it seems that VCDS recognizes this as a completely new VIN number as well. (However, I have been able to program my two keys for the car to work with the new BCM.)
How can I program the new BCM to work in the car? Is it possible with VCDS? Can the dealers do it (if it cant be done via VCDS?
All and any replies on this topic are more than welcome.
Thank you!
/Mattias
iichel
Eindhoven, NB, NL
C?ID=284912
Autoscan please! If possible with both bcms
089F should be capable of bi-xenons too.
bluetone
Sweden
C?ID=303067
Ok, here comes the autoscan.
Unfortunately, I dont know how to put it in a nice text window like the pros, as I am new poster in this forum.
The scan is of the factory fitted BCM, the new one, I cant even get an autoscan off, as some modules impossible for VCDS to contact when it is connected.
Here goes:
Tuesday,22,August,2017,06:09:19:09285
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
VIN: WV1ZZZ7HZCH004972   License Plate: LWK240
Mileage: 182010km-113095mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 18 19 22 25 2E 37 55 56 69 6E 77
          0B
VIN: WV1ZZZ7HZCH004972   Mileage: 182010km-113095miles
6E-Ctrl Head Roof -- Status: Malfunction 0010
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 022 JE    HW: 03L 907 309 H
   Component: R4 2,0L EDC   H35 9970
   Revision: 22H35---    Serial number: 00000000000000
   Coding: 0125401A233600080000
   Shop #: WSC 40330 222 00000
   ASAM Dataset: EV_ECM20BTD01103L906022JE 002009
   ROD: EV_ECM20BTD01103L906022JD_002.rod
   VCID: 71BCDCEE212B5EDFA44-8024
   Part No SW: 0BT 300 011 L    HW: 0BH 927 711 C
   Component: DSG DQ500-7A  H05 1711
   Revision: 00H05V01
   VCID: 372822F60FCFC0EFAA0-8062
Address 03: ABS Brakes (-----)       Labels:. 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 H    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0107
   Coding: 708764AD91A40E9926AB8978696010
   Shop #: WSC 02736 790 49152
   VCID: 372822F60F4FC0EFAA0-8062
No Faults Found
   Part No SW: 7E5 907 047 BG    HW: 7E5 907 047 BG
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 75B4E8FE554372FF78C-8020
   Part No SW: 7H0 937 089 F    HW: 7H0 937 089
   Component: BCM T5GP Li4  H50 0251
   Revision: BS050001    Serial number: 0465 150110614
   Coding: B8A030B80E61242293284E716DEF8F548290670F60857D41300000000000
   Shop #: WSC 02734 790 12345
   VCID: 392C24CE395BD69F5C4-806C
   Component: RLS 230511 05  54  0403
   Coding: 02302E
   Subsystem 2 - Part No SW: 7E0 959 801 J    HW: 7E0 959 801 J  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8653
   Serial number: KU0KU018111443228101
   Coding: 0000A3
   Subsystem 3 - Part No SW: 7E0 959 802 J    HW: 7E0 959 802 J  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8653
   Serial number: KU0KU010021550411113
   Coding: 1000A3
   Subsystem 4 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 1K0 951 605 C
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Serial number: 70000000000000153511
   Coding: E20000
                    Fault Status: 00101010
                    Reset counter: 22
                    Mileage: 181789 km
                    Date: 2012.01.11
                    Time: 21:38:34
   Part No SW: 7E0 919 475 D    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47301112700641
   Coding: 118101
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_VW75XParkAssis4K A01006
   ROD: EV_VW75XParkAssis4K_A01.rod
   VCID: 333016E61BB72CCF968-8066
   Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
   Component: VW10Airbag007 H06 0013
   Revision: --------    Serial number: 003HM0014KP6
   Coding: 000000000000000000000000000000003037
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 36362FF208C539E7B16-8062
   Serial number: 3495ZRB405T0891IJGTH
   Serial number: 3505ZRB405L08IF868IP
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 7E0 920 870 E    HW: 7E0 920 870 E
   Component: KOMBI         H03 0305
   Coding: 160F00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_004_VN35.rod
   VCID: 2B000E86C387740FDE8-807E
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 819 008 D
   Component: J737__Standheizung  0605
   Revision: 00084000    Serial number: 09019169F00000
   Coding: 0001322
   Shop #: WSC 02757 790 00000
   VCID: 2A0E0B82C0FD6D0725E-807E
00625 - Vehicle Speed Signal
                    Date: 2012.01.11
                    Time: 00:00:01
                    Temperature: 31.0°C
                    Voltage: 12.72 V
                    Temperature: 77.5°C
00667 - Ambient Temperature Signal
                    Date: 2012.01.11
                    Time: 00:00:01
                    Temperature: 31.0°C
                    Voltage: 12.72 V
                    Temperature: 77.5°C
                    Fault Frequency: 30
                    Date: 2012.01.11
                    Time: 00:00:01
                    Temperature: 57.0°C
                    Voltage: 12.72 V
                    Temperature: 24.5°C
02650 - Crash Signal on CAN
            000 -  -
                    Mileage: 181759 km
                    Date: 2012.01.11
                    Time: 13:16:36
                    Temperature: 56.0°C
                    Voltage: 12.72 V
                    Temperature: 24.5°C
02251 - Heater Unit Locked
            000 -  -
                    Mileage: 181759 km
                    Date: 2012.01.11
                    Time: 13:16:36
                    Temperature: 56.0°C
                    Voltage: 12.72 V
                    Temperature: 24.5°C
   Part No SW: 6N0 909 901     HW: 7H0 937 089
   Component: GW-K-CAN TP20 H50 0251
   Revision: BS050001
   Coding: 042200
   VCID: 70BAD9EA2AA157D7ABA-8024
   Part No SW: 09N 907 554 A    HW: 09N 907 554 A
   Component: Haldex 4Motion      6007
   Coding: 0000009
   Shop #: WSC 02736 790 00000
   VCID: 36362FF2044539E7B16-8062
   Component: IMMO          H03 0305
   VCID: 6A8ECB820CFDAD07E5E-803E
   Revision: A1001003    Serial number: 7660082171
   VCID: 290CF48EC9FB661F2C4-807C
   Part No SW: 1T0 035 686 C    HW: 1T0 035 686 C
   Component: RNS-MID       H10 5274
   Revision: AB001001    Serial number: VWZ6Z7M7324176
   Coding: 00010200000000800014
   VCID: 343215FA1E392BF78F2-8060
   Component: EU West V14  8477
00859 - Line-Output; Front Right
                    Fault Status: 00101011
                    Fault Frequency: 9
                    Reset counter: 28
                    Mileage: 181776 km
00823 - Line-Output; Front Left
                    Fault Frequency: 9
                    Reset counter: 28
                    Mileage: 181776 km
00869 - Line Output; Rear Right
                    Fault Frequency: 9
                    Reset counter: 28
                    Mileage: 181776 km
00860 - Line-Output; Rear Left
                    Fault Frequency: 9
                    Reset counter: 28
                    Mileage: 181776 km
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357     HW: 6R0 907 357
   Component: LWR-ECU       H02 0070
   Coding: 0202000001000000
   ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
   ROD: EV_HeadlRegulVWLWRPt_VW25.rod
   VCID: 77A8E2F64F4F00EF6A0-8022
                    Fault Frequency: 9
                    Reset counter: 28
                    Mileage: 181776 km
                    Fault Frequency: 9
                    Reset counter: 28
                    Mileage: 181776 km
                    Fault Frequency: 9
                    Reset counter: 28
                    Mileage: 181776 km
                    Fault Frequency: 9
                    Reset counter: 28
                    Mileage: 181776 km
   Revision: 3A001001    Serial number: 00000147675604
   Coding: 410D000100000000
   VCID: 303A19EAEA2117D7EBA-8064
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
   Part No SW: 7E5 919 037 G    HW: 7E5 919 037 G
   Component: Dachdisplay   H15 0175
   Revision: 10100010    Serial number: 205358
   Coding: 000203
   VCID: 353428FE154332FFB8C-8060
16347 - Control Module - EEPROM Error
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 141152 km
                    Date: 2015.11.11
                    Time: 06:45:19
                    Fault Status: 01101000
                    Fault Priority: 8
                    Fault Frequency: 13
                    Reset counter: 242
                    Mileage: 181759 km
                    Date: 2017.08.24
                    Time: 00:25:37
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105236324
   Coding: 020000010100000000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 2514F8BEA563427F08C-8070
End----------(Elapsed Time: 02:52, VBatt start/end: 14.2V/14.2V)-----------
Spacewalker
Poland
C?ID=159607
Did you try close and open driver door few time and keep door open while autoscan ?
iichel
Eindhoven, NB, NL
C?ID=284912
You have to write [/code] at the end and
 at the start.
So it looks like [code]
Blabla[/c ode]
The autoscan, is this with the xenon's installed and wired?
Did you try to clear errors and make new scan? I'm a bit confused by your scan, some errors that don't make sense and there are some modules missing.
Did you also install AFS system?
And do you have an autoscan with the 090D BCM?
bluetone
Sweden
C?ID=303067
I have tried autscanning with both open and closed doors. At the time of this scan, doors where closed and engine running.
bluetone
Sweden
C?ID=303067
 at the start.
Blabla[/c ode]
And do you have an autoscan with the 090D BCM?[/QUOTE]
Many thanks for the tip, will do that next time.
At the time of scanning, the xenons are installed and wired. AFS system is also wired and installed.
I will make a new attempt on getting an autoscan with the 090D BCM, but I dont think it will succeed, as last time it was connected, VCDS could not connect to engine, auto trans. etc. modules and certanly no autoscan.
bluetone
Sweden
C?ID=303067
Heres a new scan with fault codes freshly erased with the 089F module installed
Tuesday,22,August,2017,11:37:37:09285
Mileage: 182050km-113120mi   Repair Order:
          0B
VIN: WV1ZZZ7HZCH004972   Mileage: 182050km-113120miles
   Revision: 00H05V01
   Revision: 00H43001
   Revision: 00001010
   Coding: 0000000002
   Coding: 02302E
   Coding: 0000A3
   Coding: 1000A3
   Coding: E20000
   Coding: 118101
   Coding: 160F00
   Coding: 0001322
                    Date: 2012.01.11
                    Time: 00:00:01
                    Temperature: 31.0°C
                    Voltage: 12.72 V
                    Temperature: 77.5°C
                    Date: 2012.01.11
                    Time: 00:00:01
                    Temperature: 31.0°C
                    Voltage: 12.72 V
                    Temperature: 77.5°C
                    Fault Frequency: 30
                    Date: 2012.01.11
                    Time: 00:00:01
                    Temperature: 57.0°C
                    Voltage: 12.72 V
                    Temperature: 24.5°C
            000 -  -
                    Mileage: 181759 km
                    Date: 2012.01.11
                    Time: 13:16:36
                    Temperature: 56.0°C
                    Voltage: 12.72 V
                    Temperature: 24.5°C
            000 -  -
                    Mileage: 181759 km
                    Date: 2012.01.11
                    Time: 13:16:36
                    Temperature: 56.0°C
                    Voltage: 12.72 V
                    Temperature: 24.5°C
   Revision: BS050001
   Coding: 042200
   Coding: 0000009
   Coding: 000203
            014 - Defective
                    Mileage: 141152 km
                    Date: 2015.11.11
                    Time: 06:45:19
                    Fault Priority: 8
                    Reset counter: 244
                    Mileage: 182051 km
                    Date: 2017.08.22
                    Time: 11:33:03
End----------(Elapsed Time: 02:27, VBatt start/end: 14.1V/14.1V)-----------
And here is one with the 090 bcm connected. VCDS took a really long time to connect to engine, auto trans and some other modules, and the dashboard was glowing like a christmas tree on the 24th of december
Tuesday,22,August,2017,11:47:52:09285
VIN: WV1ZZZ7HZCZZZ7HZC   License Plate: LWK240
Mileage: new bcm1   Repair Order:
          0B
   ASAM Dataset: EV_bñžEV_ECM20BTECM20BTD0 Unknown
   ROD: N/A
   VCID: 55F4887EB58312FF58C-8000
No ASAM data for: "EV_bñžEV_ECM20BTECM20BTD0" (VN75)
Readiness: N/A
Address 02: Auto Trans        Labels: None
No ASAM data for: "Unknown" (VN75)
Address 08: Auto HVAC        Labels:. 7E5-907-047.clb
   Revision: 00001010
13701456 - ROD - Unknown Error Code
          - 00 [008]
   Part No SW: 7H0 937 090 D    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H78 0725
   Revision: B9078001    Serial number: 0671 029150383
   Coding: B8A030BA4E61262293284EF17FEF9F54F29066FF60A57D41300000000000
   Shop #: WSC 02739 790 12345
   VCID: 2F381A96F71F082FF20-807A
   Coding: 02302E
   Coding: 0000A3
   Coding: 1000A3
   Coding: E20000
Address 10: Park/Steer Assist        Labels:
   VCID: 55F4887EBC0312FF58C-FFFE
Address 15: Airbags
Address 17: Instruments        Labels: None
   Coding: 0001322
                    Date: 2003.14.09
                    Time: 00:00:01
                    Temperature: 31.0°C
                    Voltage: 12.72 V
                    Temperature: 77.5°C
                    Date: 2003.14.09
                    Time: 00:00:01
                    Temperature: 31.0°C
                    Voltage: 12.72 V
                    Temperature: 77.5°C
                    Fault Frequency: 30
                    Date: 2003.14.09
                    Time: 00:00:01
                    Temperature: 57.0°C
                    Voltage: 12.72 V
                    Temperature: 24.5°C
            000 -  -
                    Mileage: 181759 km
                    Date: 2003.14.09
                    Time: 13:16:36
                    Temperature: 56.0°C
                    Voltage: 12.72 V
                    Temperature: 24.5°C
            000 -  -
                    Mileage: 181759 km
                    Date: 2003.14.09
                    Time: 13:16:36
                    Temperature: 56.0°C
                    Voltage: 12.72 V
                    Temperature: 24.5°C
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H78 0725
   Revision: B9078001
   Coding: 042200
                    Fault Frequency: 39
                    Reset counter: 241
                    Mileage: 181759 km
                    Date: 2003.14.09
                    Time: 00:04:38
   Coding: 0000009
Address 25: Immobilizer        Labels:
   Coding: 000203
            014 - Defective
                    Mileage: 141152 km
                    Date: 2015.11.11
                    Time: 06:45:19
                    Fault Frequency: 14
                    Reset counter: 241
                    Mileage: 182051 km
                    Date: 2017.08.22
                    Time: 11:39:39
                    Fault Priority: 8
                    Reset counter: 244
                    Mileage: 182051 km
                    Date: 2017.08.22
                    Time: 11:33:03
Address 77: Telephone        Labels:. 3C8-035-730-A.clb
   Part No: 3C8 035 730 E
   Coding: 54656C65666F6E202020202020
End----------(Elapsed Time: 07:22, VBatt start/end: 14.1V/14.1V)-----------
bluetone
Sweden
C?ID=303067
Short movie of my dashboard with the new bcm connected. (no buttons are being pressed at the time of filming this).
Idle RPMs go up, feels like the engine goes into limp mode.
iichel
Eindhoven, NB, NL
C?ID=284912
Looks like your CAN powertrain is partially offline or seriously limping.
I know, in some cases, the cluster (and high beam assist and TPMS) needs to be on a new can instrument network (2 new wires), with some PQ25 090x BCMs.
In your case, it seems not the case.
With your 089F BCM, what I can see, the coding is OK for bi-xenon. The DRL and parking lights are now not in the separate bulbs anymore but are done by the LEDs.
Can you verify whether the lights are working well? (low beam, high beam, high beam flash, DRL, indicator and parking lights).
Did you wire the static cornering lights to the xenon headlights as well?
Spacewalker
Poland
C?ID=159607
Leave CAN network alone . Try new BCM at first ,
Within 15 years VW retrofit , I neve swap any CAN wires in a modyfication like that
In a fact , both BCM can be swap toogether and main wires like CAN / Power / always in this same place.
bluetone
Sweden
C?ID=303067
I read in a post on a forum, that new can high and can low wires where needed from the instrument cluster to the bcm. I had can h and can l (pins 28 and 29) coming out from the cluster, but not into pins 54 and 57 of the BCM. So I put in a new can bus wire. from these pins.
Before, when I put in the BCM, door windows where not working, no illumination on the cluster and only screen showing on the instrument cluster was distance till empty.
All the lights are working just fine.
Headlight were bought used online, but the AFS and all the connectors in between where bought from Kufatec "new" (I am not sure these things are new, even though they claim they are) and installed according to their instructions.
Static cornering lights are not connected (if you mean the fog lights) are not connected to the xenons (if memory serves me right). I must have missed that unless that connection is covered by the kufatec instructions.
bluetone
Sweden
C?ID=303067
YOu have a point. I always try to avoid this as far a possible. BUT, I dont want that light on the dashboard warning me of a broken bulb, when no bulb is broken.
I have tried to just connect the new BCM, without doing anything with the wires. When I did that, power windows stopped working and illumination on the instrument cluster stopped working, along with several functions on the cluster like trip computer etc , right pair of buttons on steering wheel (volume and changing of station where working though)
Spacewalker
Poland
C?ID=159607
for me - BCM faulty
bluetone
Sweden
C?ID=303067
for me - BCM faulty
I dont know how often these BCM:s get faulty. Keys where able to be coded. It was working well before I connected the two cables (with the exeption for some instrument functions and power windows). And VCDS was saying that the instrument cluster was giving a "data signal missing" error.
iichel
Eindhoven, NB, NL
C?ID=284912
It sounds like the Linbus and canbus databuses are not communicating very well. The can gateway is integrated into the BCM.
The BCM seems to be rather recent (HW 78; latest is 82, SW is also ok). BCM coding looks ok too (same as old coding).
So then either the wiring is not OK or, as spacewalker says, BCM not ok. I tend to agree with him.
Could you connect the cluster back to power train can to see what happens?
Spacewalker
Poland
C?ID=159607
thinking about this same
remove all wires you did last time and try new BCM with genuine configuration (plugs / loom etc)
iichel
Eindhoven, NB, NL
C?ID=284912
just as a small side note, the extra can lines do make some sense.
Polo 6R BlueGT 2014 (BCM 7H0 937 090, PR-7L6, 1.4TSI CPTA)
IC connector T32/28 and /29 to powertrain CAN:
Transporter T5 GP 2015 (BCM 7H0 937 089x or BCM 7H0 937 090, CAAC 2.0 TDI engine)
T32/28 and /29 to separate CAN on T73b/54 and /57
bluetone
Sweden
C?ID=303067
OK, got it working.
Turns out this was a programming issue after all. Original, factory fitted BCM is installed in the car and the broken bulb warning light in the car is gone.
I have left the cable pin 28-29 in instrument cluster to BCM T73B 54 and 57 as is, with the extra wire, but as it is not being used it does not matter.
I would like to thank everybody here who has taken their time to answer my posts, comment and offer hints, tips, suggestions.
Matt
iichel
Eindhoven, NB, NL
C?ID=284912
Could you tell us a bit more about the programming issue (which bits and bytes)?
