Enable/Retrofit Adaptive Cruise Control Mk7 Golf Wolfsburg
dgoodell
C?ID=313782
I have a lot of traffic on my way to work so regular cruise control is basically useless for my commute. I bought a new 2017 Golf Wolfsburg a little a while ago and thought that it might be possible to enable ACC since the car already had the radar for the front braking assistance. I noticed that the car didn't have the ACC button on the steering wheel so I figured the 1st order of business was to get new steering wheel buttons and install them.
The original P/N was 5G0 959 442 P. I noticed that the 2017 Golf SEL Alltrack used 5G0 959 442 R. Unfortunately, I couldn't find that P/N used (new is way too expensive) so I found 5G0 959 442 K online. I installed the button relatively easily and started the car up. Unfortunately, none of the buttons seemed to work properly and it was not clear what I had to change.
I modified the coding of a few modules and ACC shows up as on option under the instrument cluster however the cruise control buttons still do nothing.
If I remember correctly I modified the coding in the Engine ECU to change from regular cruise control to adaptive with front assist and the adaptation channel on the CAN Gateway to change the multifunction steering wheel from GRA-High to ACC-High. There may have been a few other small things I changed but I can't recall them right now.
There are a few faults showing up currently:
01: Engine: No communications with cruise control front distance sensor
13: Auto Dist. Reg: Implausible message
17: Instruments: Missing message
Does anyone have any experience with this? Is the problem that I am using the wrong part number steering wheel buttons. Is what I'm trying to do even possible?
Would it be possible to get the regular cruise control with these buttons or do I have to change it back to the original buttons?
Thanks for any assistance anyone may be able to provide.
The original autoscan log of my car and adaptation channel maps for a few modules are here:
ftp://batdan.uk.to
Here is my current autoscan file:
Sunday,20,August,2017,13:39:31:62507
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
VIN:   License Plate:
Mileage: 2829km-1757mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 2B 3C 42 44 52 5F 75
VIN: 3VW217AU6HM050391   Mileage: 2829km-1757miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 K    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091A00122444042F1000
   Shop #: WSC 00066 790 00221
   ASAM Dataset: EV_ECM18TFS0208V0906264K 001004
   ROD: EV_ECM18TFS0208V0906264K.rod
   VCID: 44D244805E149D973F2-8010
22008 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
                    Mileage: 2829 km
                    Date: 2017.08.20
                    Time: 13:34:57
                    Engine speed: 0.00 /min
                    Coolant temperature: 66 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 12.128 V
                    Dynamic environmental data: 00
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 30.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 4 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    T_AST_SAE: 0 s
Readiness: 1110 1101
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 09G 927 158 AR    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3198
   Coding: 010200000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW25.rod
   VCID: 0350879C1B9A5AAF468-8056
Address 03: ABS Brakes (J104)       Labels:| 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 50027000000143
   Coding: 01FA6AA12425096C407A020980C42980562490024001943410405050C082430000000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036_VW37.rod
   VCID: 005A88900A8C41B75BA-8054
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0426439587
   Coding: 032C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3B203F7C23EAE26F4E8-806E
   Part No SW: 5GM 907 426 E    HW: 5GM 907 426 E
   Component: AC Manuell    H03 1801
   Revision: 00001K04
   Coding: 00020004200100000000000000000002
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 4ACE6AB87C304BE7C5E-801E
   Part No SW: 5Q0 937 087 AN    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: C86402021701R5
   Shop #: WSC 00066 790 00195
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017_VW27.rod
   VCID: 0748938C2FA2768F1A0-8052
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    161105  043 0551
   Serial number: 97022066161121064916
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  042 0105
   Serial number: S7Y16M12D23H05M07S57
   Coding: 06A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5GD 959 591 A    HW: 5GD 959 591 A
   Component: J245 PS60.006  H07 0170
   Serial number: 03691623530111161752
   Coding: 181803
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Coding: 3500000101FFC428949C810500301600000000000000000000
   ROD: EV_ACCBOSCHVW416.rod
   VCID: 3C223C6026E4E557472-8068
1116 - Databus
                    Reset counter: 88
                    Mileage: 2829 km
                    Date: 2017.08.20
                    Time: 13:34:55
                    Control Module temperature: 55 °C
                    Voltage terminal 15: 12.0 V
                    Longitudinal_acceleration_vehicle_reference: -0.00 m/s²
   Serial number: 003GCR070NY-
   VCID: 47C8538C6F22B68FDA0-8012
   Occupant Detection:
   Serial number: IBH000000000006MVJTO
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 001 712 16
   Serial number: 3570000000015DF48F1Y
   Subsystem 3 - Part No SW: -----------    HW: 480 001 712 16
   Serial number: 358000000002A83D3D1Q
   Subsystem 4 - Part No SW: -----------    HW: 480 402 012 16
   Serial number: 3510001C3237EE369625
   Subsystem 5 - Part No SW: -----------    HW: 480 402 012 16
   Serial number: 3520001AF237EE33A48I
   Subsystem 6 - Part No SW: -----------    HW: 480 403 101 17
   Serial number: 3550002AF23C4E427305
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 403 101 17
   Serial number: 3560002A5234FA3611F5
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 12011708490023
   Coding: 0410
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   Part No SW: 5G1 920 840 B    HW: 5G1 920 840 B
   Component: KOMBI         244 8311
   Coding: 0BA4191AA588CF0502886A295000000000000000
   VCID: 2616FE08C8684F87016-8072
16776996 - Databus
                    Reset counter: 88
                    Mileage: 2829 km
                    Date: 2017.08.20
                    Time: 13:34:54
   Component: GW MQB High   515 5286
   Serial number: 17021700840178
   Coding: 0101000870085900FA0000181C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00215
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F381B2CE7920ECFF20-807A
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29170001392130067255
   Coding: 2C0000
   Revision: 00000000    Serial number: 16000226222007
   Coding: 5D00000000000000
   VCID: 343214400EB42D178F2-8060
Address 3C: Lane Change (J1086)       Labels:* None
   Serial number: 0414373429
   Coding: 01011103
   ROD: EV_HREntryHella_VW32.rod
   Lane Change Assistant 2:
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 2301170605015S
   Coding: 003013200000020000000000
   VCID: 41DC4D94410688BF144-8014
   Serial number: 00000000000005476759
   Coding: 011000
   Part No SW: 5QM 909 144 A    HW: 5QM 909 144 A
   Component: EPS_MQB_ZFLS  171 1072
   Coding: 0102
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 4FF87BAC87526ECF920-801A
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 1701170605037F
   VCID: 40DA48904A0C81B71BA-8014
   Serial number: 00000000000005235870
   Coding: 091000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0751
   Coding: 02730000FF00000051220001001808009F0100D40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2D040124ED9E7CDFC0C-8078
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9TJW025JE
   ROD: EV_OCULowMQB_VW37.rod
   VCID: 43D0479C5B1A9AAF068-8016
End----------(Elapsed Time: 01:28, VBatt start/end: 12.1V/12.1V)-----------
Have you checked whether the radar sensor is really the same one as used in cars that have ACC?
I wouldn't put it past VW to do something different, even if it's only different software in the sensor, to prevent a "premium" feature like ACC from being enabled.
jimmyq
C?ID=139879
needs enabling via geko online
hmm............... your autoscan doesn't appear to have a module @ address A5 - Frt Sens. Drv. Assist. I had thought that ACC needed one of these.
kamold
Australia
C?ID=241363
ACC uses the auto distance radar at address 13 which is present.
A5 is the front camera module which is used for lane keeping assist and sign recognition.
dgoodell
C?ID=313782
It's the same part number as the one that is in cars that have ACC. I would think that if there was anything permanently different they would give it a different part number. I am sure it's possible but I don't know how I would be able to tell that or if it is something that the dealer can do online.
Here's the scan for address 13 from a 2017 Alltrack SEL & my car. There are some coding differences, I'll have to check and see if those are related or not later.
2017 Alltrack SEL:
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
  Coding: 350000C141FFC428949C810520301600000000000000000000
   Shop #: WSC 00066 790 00218
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3C59E5AAB7652BA1F5-8068
My 2017 Golf Wolfsburg:
dgoodell
C?ID=313782
I kinda suspected this. Is this something a dealer might do if asked? I would assume that they wouldn't, it doesn't seem like there is any benefit to them at all to do this.
golfi_vend
Tartu, Estonia
C?ID=195131
No easy way at moment.
Hardware is same, but FEC codes for SWAP functions are different. Without correct FEC codes the feature is useless.
MQB is totally a platform wherd You need to order the features You want and can't retrofit them.
At least for now.
If i look how VCDS has planned their business, and for legal reasons also, this wont be ever possible with VCDS.
dgoodell
C?ID=313782
At least for now.
That is unfortunate. For 2017 in the U.S. the regular Volkswagen Golf doesn't come with ACC as an option or I would have gotten it. The GTI, Sportwagon, and Alltrack all have it available as an option but that doesn't do me any good. Oh well.
ASR
C?ID=270252
You will have to get an ABS module/pump that is compatible with ACC, (pr. code 8T8 if you have an automatic or DSG, and 8T5 if its a manual, ABS module 3Q0907379AB, new 46 pin connector, plus new wire pins, new ACC compatible rear ABS sensors, steering wheel button for ACC). and that's probably why you're not getting communications between controllers. I'm referencing from 15'-16 models, for 17's it's a different story (I think).
downtime
Finland
C?ID=280813
I'm pretty sure you have messed the pr codes there.
My understanding is that 8T3 is for manual + acc, 8T5 is automatic as it incorporates stop&go and 8T8 is for newer generation acc and is for both manual and automatic.
I've done quite a bit of research on the matter and this is my understanding of ABS pr codes.
Earlier MQB cars did not have 46pin ABS. And they still support 8T3 and 8T5.
ASR
C?ID=270252
I have done extensive research on this with the documentation provided by XaGiCo and ErWin, 8T5 is for manual trans, 8T3/8T8 is for auto/DSG. On my 15' GTI my cluster/speedo is only compatible with 8T5 (manual) or 8T8 (Auto/DSG) only, so in my case my 38 pin ABS unit is only compatible with 8T0, 8T2, 8T6, 8T7, thus the need to change mine to the 46 pin ABS.
downtime
Finland
C?ID=280813
That information is contradicting on my car then.
I have 38pin ABS unit which according to Etka is compatible with 8T0, 8T2 and 8T5.
But yes, I'm also in a process of doing this same thing to my 2013 Seat Leon. I've gotten almost all the parts already except new stalk with distance setting for acc. I also have to update my ABS controller to the new 46pin one.
By the way, have you found out the part number for the 46pin abs controller connector? Seems to be a bit tedious to find it. My best guess according to ETKA is : 4M0998046. I would like to get definitive confirmation for this though :D
