VW Touareg 7P - 01-Engine -- Status: Cannot be reached 0100
sasha
Australia
C?ID=287611
Hi
It seems my engine ecu has had better days.
Could someone please advise how do I go about replacing it? Say I can find a second hand one form a wrecker, what do I do next? Plug it in and then what? How do I code it properly? What adaptation will be required?
Big thanks in advance!
Thursday,10,August,2017,16:45:45:15919
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 17.8.0.1 (x64)
Mileage: 134224km-83402mi   Repair Order:
Chassis Type: 7P6
Scan: 01 02 03 05 08 09 10 15 16 17 19 2E 42 46 52 53 56 62 72 77
          A7
   Mileage: 134224km-83402miles
A7-Infotain. Interface -- Status: Malfunction 0010
Address 01: Engine
   Part No SW: 0C8 927 750 AM    HW: 0C8 927 750 AM
   Component: AL1000 AISIN  001 1932
   Coding: 001568
   Shop #: WSC 05787 002 1048576
   ROD: EV_TCMAL991031_002.rod
   VCID: 77FC6EAACEF36BFEBB-8023
12809 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [039] - -
                    Reset counter: 0
                    Engine speed: 30.0 /min
                    Transmission input speed: 330 /min
                    Transmission output speed: 180 /min
                    Engine torque: -60 Nm
                    Transmission fluid temperature: 30 ∞C
                    Accelerator position: 0.0 %
                    Clutch status: closed
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    EOP failure status: Normalcy
                    EOP target revolution: 0 /min
                    EOP actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    EOP failure status with EOP without HV: Motor normal stop
                    EOP target current: 65278 mA
Address 03: ABS Brakes (J104)       Labels:| 7P0-907-379.clb
   Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
   Component: MK25A         H36 0418
   Revision: --------    Serial number: 419810010EC010
   Coding: 5B6B13C349252554DAF5C89992DBA4507700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: 4580D462C49FC96EF9-8011
336388 - Databus
          U1121 00 [137] - Missing Message
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:02
                    Standard Freeze  Frame Dynamic: 00 3D 03 57 28 00 00 00 05 00 03 20 02
   Part No SW: 4H0 907 064 BE    HW: 4H0 907 064 BE
   Component: BCM2 2.0      H31 0330
   Coding: 01B60000000000000000
   VCID: 6DD04CC2B4AFD12E51-8039
   Subsystem 1 - Part No SW: 7P6 959 754 L    HW: 7P6 959 754 L
   Component: FBSTOUAREGIDG  H05 0051
   Serial number: 0811000080748004
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000131620011
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:03
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Fault Frequency: 180
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 10:39:59
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BA    HW: 7P6 907 040 BA
   Component: Klima 2 Zonen H20 1203
   Coding: 3626200890
   VCID: 74E659A6DF8500E69E-8021
0331 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:03
                    Voltage terminal 30-Data: 12.2 V
                    Outside air temperature-Data: 10.00 ∞C
          U1101 00 [008] - Active
                    Reset counter: 77
                    Mileage: 130801 km
                    Date: 2017.03.18
                    Time: 04:42:29
                    Voltage terminal 30-Data: 8.3 V
                    Terminal 15 status: Terminal 15 on
                    Component protection-Data: 31
0247 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 134
                    Mileage: 131797 km
                    Date: 2017.04.04
                    Time: 11:17:57
                    Outside air temperature-Data: 21.50 ∞C
                    Engine speed-Data: 0 /min
0386 - Functional Limitation due to Energy Management
          B10CD 00 [008] -  -
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 09:00:04
                    Voltage terminal 30-Data: 11.3 V
                    Outside air temperature-Data: 6.00 ∞C
                    Interior temperature-Data: 4.90 ∞C
                    Energy management deactivation stage-Data: 1
   Part No SW: 4H0 907 063 BD    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0100
   Revision: 15012002    Serial number: 00000001162480
   Coding: 6900001181345D010005000300005F5F431D460807000241000000000000
   VCID: 6BD442DA8ABBDF1E4F-803F
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 955 120
   Component: WWS    100619  31  0020
   Serial number: 90243401100622035942
   Coding: 013F93
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10204511
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 B    HW: 7P6 941 431 B
   Component: E1 - LDS  H04 0031
   Serial number: 00000000003006110131
                    Fault Status: 01101100
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:13:00
                    Reset counter: 128
                    Mileage: 134226 km
                    Date: 2017.05.11
                    Time: 11:59:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0021
   Revision: --------    Serial number: 28291109466618
   Coding: 108501
   ASAM Dataset: EV_VW526ParkiAssis2 001011
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 428ACF7ED5B1FE56DC-8017
1111316 - Speaker for Front Parking Aid
          B10F5 14 [009] - Open or Short to Ground
                    Reset counter: 29
                    Mileage: 127869 km
                    Date: 2017.01.13
                    Time: 06:18:01
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
   Component: VW10Airbag00T H05 0023
   Revision: --------    Serial number: 003JX003HKEN
   Coding: 000000000000000000000000000000003054
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 408EC576DBBDEC46CA-8015
   Serial number: 3575LRB405T0ISD6996Y
   Serial number: 3585LRB405T0ISD6GGQQ
   Serial number: 3515RRB405N0LMIQNH4R
   Serial number: 3525RRB405R0LMIQGHL%
   Serial number: 3555NRB40530FAMEM98J
   Serial number: 3565NRB40530FAME31I3
12 Faults Found:
          B1000 1B [137] - Resistance Too High
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
9440273 - Driver side knee airbag igniter
          B100C 11 [136] - Short to Ground
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:27
9440283 - Driver side knee airbag igniter
          B100C 1B [137] - Resistance Too High
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
9442587 - Igniter for battery interrupt
          B1015 1B [137] - Resistance Too High
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:01
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 134224 km
                    Date: 2017.05.13
                    Time: 00:11:32
9437713 - Igniter for Passenger's Airbag
          B1002 11 [137] - Short to Ground
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
          B1006 1B [137] - Resistance Too High
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
          B1009 1B [137] - Resistance Too High
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
          B1008 1B [137] - Resistance Too High
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
9447424 - Front crash data stored
          B1028 00 [137] -  -
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:13:58
9466352 - Crash Data from Belt Tensioner Stored
          B1071 F0 [137] - Unknown Error Elaboration
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:13:58
   Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
   Revision: --------    Serial number: 90815KGR0008W
   Coding: 000015
   VCID: 3662A3AE817952F660-8063
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0095038
00889 - Horn (H)
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 19
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:59
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb
   Part No SW: 7P6 920 880 P    HW: 7P6 920 880 P
   Component: Kombi         H14 0248
   Revision: 12240064    Serial number: 658290113592021
   Coding: 3327310022000008000002
   Shop #: WSC 22040 959 00000
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526_VW52.rod
   VCID: 489EDD56F38DD40602-801D
13635840 - Supply voltage
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 15:42:37
16776971 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:02
   Part No SW: 7P6 907 530 B    HW: 7P6 907 530 B
   Component: Gateway-CAN-L H08 5202
   Revision: --------    Serial number: 00000000210829
   Coding: 000D077500
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 377CAEAA8E73ABFE7B-8063
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650926403
   Voltage stabilizer:
6657 - Generator
          U1052 00 [009] - No Communication
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:02
                    Voltage terminal 30: 12.1 V
                    Voltage terminal 15: 12.2 V
                    Control Module temperature: 16 ∞C
                    System status: Terminal 15 on
                    IN ESP_standstill flag: no standstill detected
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
5712 - Radio
          U1066 00 [008] - No Communication
                    Reset counter: 168
                    Mileage: 116443 km
                    Date: 2016.09.02
                    Time: 13:36:00
                    Voltage terminal 30: 13.1 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 12 ∞C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [009] - -
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:01
                    Voltage terminal 30: 12.2 V
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0017 - Supply voltage
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:22:11
                    Voltage terminal 30: 8.3 V
                    Control Module temperature: 17 ∞C
                    System status: K-/Dash-CAN_MOST_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 136
                    Mileage: 128861 km
                    Date: 2017.02.04
                    Time: 16:58:02
                    Voltage terminal 30: 12.5 V
                    Control Module temperature: 47 ∞C
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
                    Fault Frequency: 15
                    Reset counter: 168
                    Mileage: 129945 km
                    Date: 2017.03.03
                    Time: 01:54:45
                    Voltage terminal 30: 12.4 V
                    Control Module temperature: 23 ∞C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
Address 2E: Media Player 3 (J650)       Labels: None
   Part No SW: 7P6 035 342 C    HW: 7P6 035 342 C
   Revision: A1001003    Serial number: 7669620744
   VCID: 316890B2681775CE35-8065
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 14:49:05
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:21:08
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000117815978
   Coding: 011D0620D001451005080000
   VCID: 4486C966C7A5F066EE-8011
   Revision: 00002001    Serial number: 0155131862
   Coding: 0100162028B9009480200624000000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P0 959 591     HW: 7P0 959 591
   Component: J245 PS30.050  H07 0006
   Serial number:     WOO12778313
   Coding: 191100
   Subsystem 2 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
   Component: J394 PS30.050  H07 0006
   Serial number:     WOO12726653
   Coding: 191100
00985 - Right Tail Light (M2)
                    Fault Status: 00101100
                    Reset counter: 136
                    Mileage: 132062 km
                    Date: 2017.04.05
                    Time: 09:48:07
00984 - Left Tail Light (M4)
                    Fault Frequency: 12
                    Reset counter: 168
                    Mileage: 133210 km
                    Date: 2017.04.24
                    Time: 07:26:26
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:03
00230 - Transmission Park Selector Switch (F305)
                    Fault Status: 01101000
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:15:07
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:25:56
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000117798379
   VCID: 3B74B29ABA5B8F9E9F-806F
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: A117060011F
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 3662A3AE897952F660-8063
   Slave 3:
12652544 - Supply voltage
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 17:05:12
                    Voltage: 7.4 V
0018 - Switch for Electric Parking Brake
          C100C 01 [009] - Electrical Failure
                    Voltage: 12.4 V
12656642 - Databus
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:02
                    Voltage: 12.2 V
12656770 - Databus
                    Reset counter: 128
                    Mileage: 134226 km
                    Date: 2017.05.11
                    Time: 11:59:11
                    Voltage: 11.4 V
Address 56: Radio
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000118463983
   Coding: 011C06200001251005080000
   VCID: 3A7AB79EB561B69684-806F
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000118426845
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 B    HW: 3C8 035 730 B
   Component: Telefon       011 0723
   Revision: --------    Serial number: 35909603189691
   Coding: 020000000100010000000000
   ASAM Dataset: EV_UHVPremi A02003
   ROD: EV_UHVPremi_A02.rod
   VCID: 224A6FFE35F1DE56BC-8077
          U1400 00 [008] - -
                    Fault Frequency: 31
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 13:39:44
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:05:23
Address A7: Infotain. Interface (J885)       Labels:* None
   Part No SW: 7P6 907 540 A    HW: 1K0 907 951
   Component: IF CAN Infot. H27 0012
   Serial number: 100711F6000022
   Coding: 04052602000000001003
   ASAM Dataset: EV_InfotInterConti 001002
   ROD: EV_InfotInterConti.rod
0017 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:01:10
4098 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:03
End-------------------------(Elapsed Time: 04:38)--------------------------
What does the inside of the ECU look like? If it's only the pins and mating connector that have this corrosion, I think it could be cleaned up.
In order to get a new ECU working, you'll need a GeKo session. IIRC, there are no provisions for independent garages to have access to that facility in Australia, meaning a dealer would have to do it. Alternatively, you might be able to send both ECUs to someone for an identity transfer. In any case, VCDS can't do it.
NostraJackAss
I would try cleaning it up first as Uwe stated above.
You will need to send the ECU out for a data transfer or buy a new ECU and have an SVM session done at the dealer.
If you want we can help with a data transfer, to a used unit you supply of identical part # or reman unit for sale.
sasha
Australia
C?ID=287611
@uwe the terminals were cleaned however still no go. I haven't touched inside of the ECU. To make it more interesting one of the pins have broken off too... (I guess because of corrosion)
@jack i'll email you, thanks for the offer!
Sasha, I'm curious: How did you get this kind of corrosion on the ECU pins? Was this vehicle exposed to salt water at some point?
NostraJackAss
Hey Uwe
All 0x01 Master locations for the TOW-RIG since first production........leak water directly on the ECU vent port and down to the plug which eventually allows water through heat transition to take on water around the crummy orange seal too.
That corrosion is not from salt water & pretty standard at this location.
This is why I recommend adding a snorkel tube to the vent port and bagging the ECU with a proper rain shield.
To prove the theory I present that usually I sell mostly 0x01 Master units and that if you do a search or observation of the condition of the cases on 0x01 versus 0x11 you will see a difference in external corrosion.
Sasha,
I replied to your email with request for VIN # please & to JPPSG this for part #?
sasha
Australia
C?ID=287611
@jack thank you very much for the info however I did managed to find a local shop that would do the clone for me so was on the hunt for a second hand ECU.
Sadly I did indeed find the ECU in Germany and bought it. While the ECU was in transit I obviously kept thinking about why the original would just be dead (as you probably were wondering also @uwe) and then I remembered about this DTC
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:01
Fair enough I find this fella under the left front seat which has been 'deployed' and nothing coming through it as reported by my multimeter.
So yesterday I temporary connected the two terminals directly (where the interrupter was connected), connect the original ECU, ignition on and scan - ECU is working!
Address 01: Engine (J623-CJMA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 311 C    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0002
   Revision: 53H37---
   Coding: 292A4012232601020000
   Shop #: WSC 22040 959 99908
   ASAM Dataset: EV_ECM30TDI0117P0907311C 001002
   ROD: EV_ECM30TDI0117P0907311C.rod
   VCID: 2F6C96CA7623633E23-807B
5568 - Sensor for Ambient Air Temperature (G17)
          P0073 00 [039] - Signal too High
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:01:37
                    Engine speed: 0.00 /min
                    Coolant temperature: 22 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 12.120 V
                    Mean injection quantity: 0.00 mg/stroke
                    Control Module temperature: 24.0 °C
                    EGR_governor_deviation: 375.7 mg/stroke
                    Inj Ctl q Curr: 0.00 mg/stroke
                    Standardised airflow ratio: 3.9999
                    Air_Flow_Rate_from_Mass_Air_Flow_Sensor_kg_h: 0.0 kg/h
                    Actual charge pressure: 1005 hPa
5290 - Throttle Actuator Control Circuit
          P2100 00 [039] - Open Circuit
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:01:47
                    Voltage terminal 30: 11.980 V
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
                    Throttle valve adapter: specified value: 100.00 %
                    Throttle valve adapter: actual value: 105.00 %
                    Throttle valve adapter: offset closed: 0.04 %
                    Throttle valve adapter: status-Bit 0: 0
                    Throttle valve adapter: status-Bit 16: 11
                    Throttle valve adapter: status-Bit 24: 55
                    Throttle valve adapter: status-Bit 8: 2
                    Throttle valve adapter: uncond voltage actual value: 4384.0 mV
5595 - Crash Shut-Down Activated
          P1609 00 [039] - -
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:01:36
4629 - ECM Power Relay Load Circuit
          P068A 00 [032] - Opens Too Early
Now the only issue I have is that there is a broken pin on the original ECU. I've searched the web and ELSA WIN trying to find what that pin is 'responsible' for however haven't been successful yet. Pin 67.
If anyone knows where this information can be found please let me know. (or if easier tell me what that pin is used by/for).
Thanks in advance!
sasha
Australia
C?ID=287611
Ohh sorry @jack when ECU was out of action the VIN didn't come up.
New scan done yesterday:
Wednesday,13,September,2017,18:03:50:15919
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
VIN: WVGZZZ7PZCD011169   License Plate: TOUAREG
Chassis Type: 7P-VW52 (7P6)
          A7
VIN: WVGZZZ7PZCD011169   Mileage: 134224km-83402miles
   Revision: 53H37---
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:01:37
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:01:47
          P1609 00 [039] - -
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:01:36
   Coding: 001568
          U0100 00 [039] - -
                    Reset counter: 0
                    Transmission fluid temperature: 30 °C
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
336388 - Databus
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:02
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:03
                    Fault Frequency: 185
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 10:39:59
02823 - Requirements for Locking the Steering Column Lock not met
            000 -  -  - Intermittent
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.13
                    Time: 00:41:53
   Coding: 3626200890
0239 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:00:02
                    Voltage terminal 30-Data: 12.9 V
                    Outside air temperature-Data: 77.00 °C
          U1111 00 [008] - -
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:03
                    Outside air temperature-Data: 10.00 °C
                    Reset counter: 77
                    Mileage: 130801 km
                    Date: 2017.03.18
                    Time: 04:42:29
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.22
                    Time: 20:05:04
                    Voltage terminal 30-Data: 12.1 V
                    Outside air temperature-Data: 77.50 °C
          U1113 00 [008] - -
                    Reset counter: 134
                    Mileage: 131797 km
                    Date: 2017.04.04
                    Time: 11:17:57
                    Outside air temperature-Data: 21.50 °C
          B10CD 00 [008] -  -
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 09:00:04
                    Outside air temperature-Data: 6.00 °C
                    Interior temperature-Data: 4.90 °C
   Coding: 013F93
   Coding: 025223
9 Faults Found:
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:13:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 06:27:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.22
                    Time: 20:05:00
                    Reset counter: 128
                    Mileage: 134226 km
                    Date: 2017.05.11
                    Time: 11:59:00
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
   Coding: 108501
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [009] - Open Circuit
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.22
                    Time: 20:05:02
                    Reset counter: 29
                    Mileage: 127869 km
                    Date: 2017.01.13
                    Time: 06:18:01
12 Faults Found:
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:27
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:01
                    Mileage: 134224 km
                    Date: 2017.05.13
                    Time: 00:11:32
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
          B1028 00 [137] -  -
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:13:58
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:13:58
   Coding: 000015
00889 - Horn (H)
                    Fault Status: 00100111
                    Fault Frequency: 21
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:59
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:00:02
                    Reset counter: 168
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 15:42:37
          U1111 00 [008] - -
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:02
16776976 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.22
                    Time: 20:05:04
   Coding: 000D077500
   Voltage stabilizer:
6657 - Generator
          U1052 00 [008] - No Communication
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:02
                    Control Module temperature: 16 °C
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5712 - Radio
                    Reset counter: 168
                    Mileage: 116443 km
                    Date: 2016.09.02
                    Time: 13:36:00
                    Control Module temperature: 12 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U0100 00 [008] - -
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:01
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:22:11
                    Control Module temperature: 17 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
                    Reset counter: 136
                    Mileage: 128861 km
                    Date: 2017.02.04
                    Time: 16:58:02
                    Control Module temperature: 47 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
                    Fault Frequency: 16
                    Reset counter: 168
                    Mileage: 129945 km
                    Date: 2017.03.03
                    Time: 01:54:45
                    Control Module temperature: 23 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 14:49:05
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:21:08
   Coding: 191100
   Coding: 191100
                    Reset counter: 136
                    Mileage: 132062 km
                    Date: 2017.04.05
                    Time: 09:48:07
                    Fault Frequency: 12
                    Reset counter: 168
                    Mileage: 133210 km
                    Date: 2017.04.24
                    Time: 07:26:26
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:03
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:15:07
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:25:56
                    Fault Frequency: 67
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.22
                    Time: 17:39:08
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 06:26:16
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   Slave 3:
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 17:05:12
                    Voltage: 7.4 V
0016 - Indicator Lamp in Controls
          C1014 14 [008] - Open or Short to Ground
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.13
                    Time: 00:17:11
                    Voltage: 11.8 V
12656642 - Databus
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:02
                    Voltage: 12.2 V
12656770 - Databus
                    Reset counter: 168
                    Mileage: 134226 km
                    Date: 2017.05.11
                    Time: 11:59:11
                    Voltage: 11.4 V
                    Voltage: 12.4 V
12656790 - Databus
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.22
                    Time: 20:05:08
                    Voltage: 12.0 V
Address 56: Radio
          U1400 00 [008] - -
                    Fault Frequency: 32
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 13:39:44
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:05:23
          U1400 00 [008] - -
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:01:10
          U1111 00 [009] - -
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:03
End-------------------------(Elapsed Time: 04:29)--------------------------
NostraJackAss
[TABLE="class: vinInfoTable"]
[TR]
[TH]"Multimedia", video/DVD/notebook connection
[/TH]
[TD="class: prCode"]9WL
[/TD]
[TD]Multimedia socket for external audio
source
[/TD]
[/TR]
[TR]
[TH]Activated carbon canister
[/TH]
[TD="class: prCode"]1E0
[/TD]
[TD]Without activated charcoal canister
[/TD]
[/TR]
[TR]
[TH]Additional body covers, side
[/TH]
[TD="class: prCode"]6EA
[/TD]
[TD]Without additional side body covers
(stone guard)
[/TD]
[/TR]
[TR]
[TH]Additional tires (winter tires)
[/TH]
[TD="class: prCode"]2WA
[/TD]
[TD]Without additional tires
[/TD]
[/TR]
[TR]
[TH]Additional warning lights
[/TH]
[TD="class: prCode"]9TB
[/TD]
[TD]Additional warning lights (door area)
[/TD]
[/TR]
[TR]
[TH]Air bag
[/TH]
[TD="class: prCode"]4UH
[/TD]
[TD]Air bag for driver and front passenger
with knee air bag
[/TD]
[/TR]
[TR]
[TH]Air cleaner (engine)
[/TH]
[TD="class: prCode"]1L1
[/TD]
[TD]Air cleaner for dusty regions
[/TD]
[/TR]
[TR]
[TH]Alternative drive module
[/TH]
[TD="class: prCode"]0K0
[/TD]
[TD]Without alternative drive module
[/TD]
[/TR]
[TR]
[TH]Antennas
[/TH]
[TD="class: prCode"]8ZH
[/TD]
[TD]Antenna for AM/FM reception, "diversity"
[/TD]
[/TR]
[TR]
[TH]Anti-theft protection system
[/TH]
[TD="class: prCode"]7AA
[/TD]
[TD]Electronic vehicle immobilization device
[/TD]
[/TR]
[TR]
[TH]Auxiliary heating
[/TH]
[TD="class: prCode"]9M0
[/TD]
[TD]Without auxiliary/parking heater
[/TD]
[/TR]
[TR]
[TH]Base engine
[/TH]
[TD="class: prCode"]TF1
[/TD]
[TD]6-cylinder diesel engine 3.0 l
unit 059.H
[/TD]
[/TR]
[TR]
[TH]Batteries
[/TH]
[TD="class: prCode"]J0B
[/TD]
[TD]520 A (92 Ah) battery
[/TD]
[/TR]
[TR]
[TH]Battery/alternator capacity
[/TH]
[TD="class: prCode"]NY0
[/TD]
[TD]Standard battery/alternator capacity
[/TD]
[/TR]
[TR]
[TH]Body measures
[/TH]
[TD="class: prCode"]5C0
[/TD]
[TD]Without special body measures
[/TD]
[/TR]
[TR]
[TH]Body style
[/TH]
[TD="class: prCode"]K8G
[/TD]
[TD]Hatchback
[/TD]
[/TR]
[TR]
[TH]Bolt-on kit
[/TH]
[TD="class: prCode"]6GA
[/TD]
[TD]Without add-on kit
[/TD]
[/TR]
[TR]
[TH]Brake type, front
[/TH]
[TD="class: prCode"]1LC
[/TD]
[TD]Disc brakes, front
[/TD]
[/TR]
[TR]
[TH]Brake type, rear
[/TH]
[TD="class: prCode"]2EG
[/TD]
[TD]Disc brakes, rear
[/TD]
[/TR]
[TR]
[TH]Braking systems
[/TH]
[TD="class: prCode"]1AT
[/TD]
[TD]Electronic stabilization program (ESP)
[/TD]
[/TR]
[TR]
[TH]Breakaway interior mirror
[/TH]
[TD="class: prCode"]4L6
[/TD]
[TD]Breakaway interior rear view mirror,
automatically dimming
[/TD]
[/TR]
[TR]
[TH]Bumper
[/TH]
[TD="class: prCode"]2JC
[/TD]
[TD]Comfort bumpers
[/TD]
[/TR]
[TR]
[TH]Call feature
[/TH]
[TD="class: prCode"]NZ0
[/TD]
[TD]Without emergency call control unit
[/TD]
[/TR]
[TR]
[TH]Carrier frequency for radio remote control
[/TH]
[TD="class: prCode"]5D1
[/TD]
[TD]Carrier frequency 433.92 MHz-434.42 Mhz
[/TD]
[/TR]
[TR]
[TH]CD changer/CD player
[/TH]
[TD="class: prCode"]7A0
[/TD]
[TD]Without CD changer/CD player
[/TD]
[/TR]
[TR]
[TH]Center armrest
[/TH]
[TD="class: prCode"]6E3
[/TD]
[TD]Front center armrest
[/TD]
[/TR]
[TR]
[TH]Center armrest rear
[/TH]
[TD="class: prCode"]6D1
[/TD]
[TD]Center armrest rear
[/TD]
[/TR]
[TR]
[TH]Center console
[/TH]
[TD="class: prCode"]3D1
[/TD]
[TD]Center console
[/TD]
[/TR]
[TR]
[TH]Child lock
[/TH]
[TD="class: prCode"]4H5
[/TD]
[TD]Electrically operated child lock
[/TD]
[/TR]
[TR]
[TH]Chrome work package
[/TH]
[TD="class: prCode"]QJ1
[/TD]
[TD]Chrome work package
[/TD]
[/TR]
[TR]
[TH]Climatic zones
[/TH]
[TD="class: prCode"]0Y2
[/TD]
[TD]Tropical zones
[/TD]
[/TR]
[TR]
[TH]Compass/traffic sign display
[/TH]
[TD="class: prCode"]QR0
[/TD]
[TD]Without compass/traffic sign display/
traffic signs recognition
[/TD]
[/TR]
[TR]
[TH]Component part sets with country-specific design requirements
[/TH]
[TD="class: prCode"]B0R
[/TD]
[TD]Component parts set, complying with
vehicle type for Australia, various
parts
[/TD]
[/TR]
[TR]
[TH]Country codes
[/TH]
[TD="class: prCode"]FE0
[/TD]
[TD]Without country code (no DVD player in
vehicle)
[/TD]
[/TR]
[TR]
[TH]Cruise control
[/TH]
[TD="class: prCode"]8T1
[/TD]
[TD]Cruise control system (CCS)
[/TD]
[/TR]
[TR]
[TH]Cup holder
[/TH]
[TD="class: prCode"]4M3
[/TD]
[TD]Cup holder
[/TD]
[/TR]
[TR]
[TH]Customized installation
[/TH]
[TD="class: prCode"]FC0
[/TD]
[TD]Without customized installation
[/TD]
[/TR]
[TR]
[TH]Decorative films / emblems
[/TH]
[TD="class: prCode"]6F0
[/TD]
[TD]Without decorative films / emblems
[/TD]
[/TR]
[TR]
[TH]Delivery equipment
[/TH]
[TD="class: prCode"]2A0
[/TD]
[TD]Without delivery equipment
[/TD]
[/TR]
[TR]
[TH]Differential lock
[/TH]
[TD="class: prCode"]1Y0
[/TD]
[TD]Without differential lock
[/TD]
[/TR]
[TR]
[TH]Door and lid locking system
[/TH]
[TD="class: prCode"]4K3
[/TD]
[TD]Radio remote controlled central locking
operated from inside and safe securing
[/TD]
[/TR]
[TR]
[TH]Door and side trim panels
[/TH]
[TD="class: prCode"]4AP
[/TD]
[TD]Door and side trim panel
[/TD]
[/TR]
[TR]
[TH]Driving on the left/on the right
[/TH]
[TD="class: prCode"]AV0
[/TD]
[TD]Driving on the left
[/TD]
[/TR]
[TR]
[TH]Electric interface for external use
[/TH]
[TD="class: prCode"]UF6
[/TD]
[TD]Electric interface for external use
(MDI)
[/TD]
[/TR]
[TR]
[TH]Emission standard
[/TH]
[TD="class: prCode"]7MQ
[/TD]
[TD]Emissions standard, EU5 mod
[/TD]
[/TR]
[TR]
[TH]Engine cooling system
[/TH]
[TD="class: prCode"]8Z6
[/TD]
[TD]Hot country
[/TD]
[/TR]
[TR]
[TH]Engine specifications
[/TH]
[TD="class: prCode"]D1Q
[/TD]
[TD]6-cyl. turbo dies. eng. 3.0 l/150 kW
(24V), base engine is T41/TF1/TH1
[/TD]
[/TR]
[TR]
[TH]Entry grab handle (A/B-pillar)
[/TH]
[TD="class: prCode"]6X0
[/TD]
[TD]Without entry grab handle
[/TD]
[/TR]
[TR]
[TH]Equipment levels
[/TH]
[TD="class: prCode"]A8B
[/TD]
[TD]Basic equipment
[/TD]
[/TR]
[TR]
[TH]Exhaust tailpipe
[/TH]
[TD="class: prCode"]0P3
[/TD]
[TD]Sports tailpipe of polished stainless
steel
[/TD]
[/TR]
[TR]
[TH]Exterior mirror setting
[/TH]
[TD="class: prCode"]6XW
[/TD]
[TD]Exterior mirrors: automatically dimming,
electrically foldable/adjustable,
separately heated
[/TD]
[/TR]
[TR]
[TH]Fire extinguisher
[/TH]
[TD="class: prCode"]6A0
[/TD]
[TD]Without fire extinguisher
[/TD]
[/TR]
[TR]
[TH]First aid kit / warning triangle
[/TH]
[TD="class: prCode"]1T0
[/TD]
[TD]Without first aid kit and warning
triangle
[/TD]
[/TR]
[TR]
[TH]Floor mats
[/TH]
[TD="class: prCode"]0TD
[/TD]
[TD]Front and rear floor mats
[/TD]
[/TR]
[TR]
[TH]Front fog light/additional headlight
[/TH]
[TD="class: prCode"]8WH
[/TD]
[TD]Front fog lamp and cornering lamp
[/TD]
[/TR]
[TR]
[TH]Front license plate bracket
[/TH]
[TD="class: prCode"]6W1
[/TD]
[TD]License plate bracket front (large)
[/TD]
[/TR]
[TR]
[TH]Front seats
[/TH]
[TD="class: prCode"]Q1A
[/TD]
[TD]Standard front seats
[/TD]
[/TR]
[TR]
[TH]Front underbody guard
[/TH]
[TD="class: prCode"]1SA
[/TD]
[TD]Without additional front underbody guard
[/TD]
[/TR]
[TR]
[TH]Fuel quantity for initial filling
[/TH]
[TD="class: prCode"]1Z0
[/TD]
[TD]Initial standard fuel filling
[/TD]
[/TR]
[TR]
[TH]Fuel systems
[/TH]
[TD="class: prCode"]0F5
[/TD]
[TD]Fuel system for diesel engine
[/TD]
[/TR]
[TR]
[TH]Fuel tank capacity
[/TH]
[TD="class: prCode"]0M0
[/TD]
[TD]Fuel tank
[/TD]
[/TR]
[TR]
[TH]Fuse box (for industrial engine only)
[/TH]
[TD="class: prCode"]KE2
[/TD]
[TD]Additional fuse
[/TD]
[/TR]
[TR]
[TH]Gearshift knob/handle
[/TH]
[TD="class: prCode"]6Q2
[/TD]
[TD]Leather gearshift knob/handle
[/TD]
[/TR]
[TR]
[TH]General operating permit, alterations
[/TH]
[TD="class: prCode"]C04
[/TD]
[TD]Operating permit, alteration
[/TD]
[/TR]
[TR]
[TH]Generators
[/TH]
[TD="class: prCode"]9G1
[/TD]
[TD]Alternator 220 A
[/TD]
[/TR]
[TR]
[TH]Headlight
[/TH]
[TD="class: prCode"]8ID
[/TD]
[TD]Halogen twin headlights
[/TD]
[/TR]
[TR]
[TH]Headlight activation
[/TH]
[TD="class: prCode"]8K3
[/TD]
[TD]Separate daytime running lights with
low beam assistant and "Coming Home"
feature
[/TD]
[/TR]
[TR]
[TH]Headlight washer system
[/TH]
[TD="class: prCode"]8X0
[/TD]
[TD]Without headlight washer system
[/TD]
[/TR]
[TR]
[TH]Headlight-range adjustment
[/TH]
[TD="class: prCode"]8Q1
[/TD]
[TD]Headlight-range adjustment
[/TD]
[/TR]
[TR]
[TH]Headrests
[/TH]
[TD="class: prCode"]5ZF
[/TD]
[TD]Front headrests
[/TD]
[/TR]
[TR]
[TH]Heat accumulator system/additional heater
[/TH]
[TD="class: prCode"]7E0
[/TD]
[TD]W/o heat accumulator/auxiliary heating
[/TD]
[/TR]
[TR]
[TH]Heated washer nozzles
[/TH]
[TD="class: prCode"]9T1
[/TD]
[TD]Heated washer nozzles, front
[/TD]
[/TR]
[TR]
[TH]Heating and air conditioning system
[/TH]
[TD="class: prCode"]9AD
[/TD]
[TD]Climatronic, free of cfc
[/TD]
[/TR]
[TR]
[TH]Identification plates
[/TH]
[TD="class: prCode"]1EJ
[/TD]
[TD]Special identification plate
[/TD]
[/TR]
[TR]
[TH]Insert for the filling up of unleaded fuel/fuel type
[/TH]
[TD="class: prCode"]2G0
[/TD]
[TD]Without insert for the filling up of
fuel
[/TD]
[/TR]
[TR]
[TH]Inserts
[/TH]
[TD="class: prCode"]5MA
[/TD]
[TD]Decorative inserts
[/TD]
[/TR]
[TR]
[TH]Instrument inserts
[/TH]
[TD="class: prCode"]U5A
[/TD]
[TD]Instrument insert, km/h speedometer
[/TD]
[/TR]
[TR]
[TH]Interior lighting
[/TH]
[TD="class: prCode"]9MA
[/TD]
[TD]Interior lighting for basic equipment
[/TD]
[/TR]
[TR]
[TH]Interior noise suppression measures
[/TH]
[TD="class: prCode"]3W7
[/TD]
[TD]Acoustics package "Extra"
[/TD]
[/TR]
[TR]
[TH]Left exterior mirror
[/TH]
[TD="class: prCode"]5SJ
[/TD]
[TD]Left exterior mirror: convex
[/TD]
[/TR]
[TR]
[TH]License plate lighting
[/TH]
[TD="class: prCode"]KL0
[/TD]
[TD]Standard license plate lighting
[/TD]
[/TR]
[TR]
[TH]Light assistance system
[/TH]
[TD="class: prCode"]8G0
[/TD]
[TD]Without light assistant
[/TD]
[/TR]
[TR]
[TH]Lock operation for tailgate/trunk lid
[/TH]
[TD="class: prCode"]4E2
[/TD]
[TD]Tailgate/trunk lid release
from inside (electrically)
[/TD]
[/TR]
[TR]
[TH]Luggage compartment cover
[/TH]
[TD="class: prCode"]3U4
[/TD]
[TD]Luggage compartment cover
[/TD]
[/TR]
[TR]
[TH]Luggage compartment floor covering
[/TH]
[TD="class: prCode"]6SJ
[/TD]
[TD]Trunk floor covering, reversible mat
(rubber/fabric)
[/TD]
[/TR]
[TR]
[TH]Lumbar support
[/TH]
[TD="class: prCode"]7P0
[/TD]
[TD]Without lumbar support
in seat backrests
[/TD]
[/TR]
[TR]
[TH]Mass damper for steering wheels
[/TH]
[TD="class: prCode"]1Q3
[/TD]
[TD]Mass damper for steering wheel, XXHz
[/TD]
[/TR]
[TR]
[TH]Molding roof liner
[/TH]
[TD="class: prCode"]6NJ
[/TD]
[TD]Standard molded headlining
[/TD]
[/TR]
[TR]
[TH]Multi-function display/trip computer
[/TH]
[TD="class: prCode"]9Q2
[/TD]
[TD]Multi-function display/on-board computer
with check control
[/TD]
[/TR]
[TR]
[TH]Nameplate set
[/TH]
[TD="class: prCode"]0PP
[/TD]
[TD]Nameplate set "BlueMotion"
[/TD]
[/TR]
[TR]
[TH]Navigation device
[/TH]
[TD="class: prCode"]7Q0
[/TD]
[TD]Without navigation device
[/TD]
[/TR]
[TR]
[TH]Operating voltage
[/TH]
[TD="class: prCode"]9Z0
[/TD]
[TD]Operating voltage 12V
[/TD]
[/TR]
[TR]
[TH]Outer rear seat belts
[/TH]
[TD="class: prCode"]3ZU
[/TD]
[TD]3-point seat belts, outer rear with ECE
label
[/TD]
[/TR]
[TR]
[TH]Owner's manuals
[/TH]
[TD="class: prCode"]0VF
[/TD]
[TD]Information kit in English
[/TD]
[/TR]
[TR]
[TH]Paint coating
[/TH]
[TD="class: prCode"]FB0
[/TD]
[TD]Standard paint coating
[/TD]
[/TR]
[TR]
[TH]Paint preservative/transit coating
[/TH]
[TD="class: prCode"]5K5
[/TD]
[TD]Transit coating film with additional
transport protection measures
[/TD]
[/TR]
[TR]
[TH]Park distance control
[/TH]
[TD="class: prCode"]7X2
[/TD]
[TD]Park distance control, front and rear
[/TD]
[/TR]
[TR]
[TH]Parking brake
[/TH]
[TD="class: prCode"]UH2
[/TD]
[TD]Parking brake
[/TD]
[/TR]
[TR]
[TH]Partition
[/TH]
[TD="class: prCode"]3CX
[/TD]
[TD]Net partition
[/TD]
[/TR]
[TR]
[TH]Pedal cluster
[/TH]
[TD="class: prCode"]VF0
[/TD]
[TD]Standard pedal cluster
[/TD]
[/TR]
[TR]
[TH]Pedestrian protection
[/TH]
[TD="class: prCode"]VL1
[/TD]
[TD]Extended pedestrian protection measures
[/TD]
[/TR]
[TR]
[TH]Power latching for tailgate
[/TH]
[TD="class: prCode"]GY0
[/TD]
[TD]Without power latching for tailgate
[/TD]
[/TR]
[TR]
[TH]Radiator grille
[/TH]
[TD="class: prCode"]6KA
[/TD]
[TD]Radiator grille
[/TD]
[/TR]
[TR]
[TH]Radios
[/TH]
[TD="class: prCode"]8AI
[/TD]
[TD]Radio "RCD510 MP3"
[/TD]
[/TR]
[TR]
[TH]Rear cargo area
[/TH]
[TD="class: prCode"]3GD
[/TD]
[TD]Plane rear cargo area
[/TD]
[/TR]
[TR]
[TH]Rear fog light
[/TH]
[TD="class: prCode"]8TD
[/TD]
[TD]Rear fog light for driving on the left
[/TD]
[/TR]
[TR]
[TH]Rear license plate bracket
[/TH]
[TD="class: prCode"]6P1
[/TD]
[TD]License plate bracket rear (ECE)
[/TD]
[/TR]
[TR]
[TH]Rear seat catch
[/TH]
[TD="class: prCode"]UK1
[/TD]
[TD]Standard rear seat release
[/TD]
[/TR]
[TR]
[TH]Rear seats
[/TH]
[TD="class: prCode"]3NW
[/TD]
[TD]Rear seat bench/backrest, split folding
with center armrest
[/TD]
[/TR]
[TR]
[TH]Refrigerator
[/TH]
[TD="class: prCode"]1W2
[/TD]
[TD]Glove compartment cooling system
[/TD]
[/TR]
[TR]
[TH]Remote-controlled garage door opener
[/TH]
[TD="class: prCode"]VC0
[/TD]
[TD]W/o remote-controlled garage door opener
[/TD]
[/TR]
[TR]
[TH]Restraint systems, front
[/TH]
[TD="class: prCode"]3QT
[/TD]
[TD]3-point seat belts with tensioner and
height adjustment, front
[/TD]
[/TR]
[TR]
[TH]Right exterior mirror
[/TH]
[TD="class: prCode"]5RV
[/TD]
[TD]Right exterior mirror: aspherical
[/TD]
[/TR]
[TR]
[TH]Roll-up sun screen for rear and side windows
[/TH]
[TD="class: prCode"]3Y0
[/TD]
[TD]Without roll-up sun screen
[/TD]
[/TR]
[TR]
[TH]Roof insert/convertible top
[/TH]
[TD="class: prCode"]3FU
[/TD]
[TD]Big roof system
[/TD]
[/TR]
[TR]
[TH]Roof rails/roof load rack
[/TH]
[TD="class: prCode"]3S1
[/TD]
[TD]Bright roof rails
[/TD]
[/TR]
[TR]
[TH]Scuff plates
[/TH]
[TD="class: prCode"]7M0
[/TD]
[TD]Plastic scuff plates in door apertures
[/TD]
[/TR]
[TR]
[TH]Seat adjustment
[/TH]
[TD="class: prCode"]3L3
[/TD]
[TD]Manual height adjustment for front seats
[/TD]
[/TR]
[TR]
[TH]Seat belt check
[/TH]
[TD="class: prCode"]9P3
[/TD]
[TD]Seat belt reminder, electric contact in
buckle
[/TD]
[/TR]
[TR]
[TH]Seat covering
[/TH]
[TD="class: prCode"]N4M
[/TD]
[TD]Partially leather seat covering
[/TD]
[/TR]
[TR]
[TH]Seat heater
[/TH]
[TD="class: prCode"]4A3
[/TD]
[TD]Seat heater for front seats
separately controlled
[/TD]
[/TR]
[TR]
[TH]Seat ventilation/massage seat
[/TH]
[TD="class: prCode"]4D0
[/TD]
[TD]Without seat ventilation/massage seat
[/TD]
[/TR]
[TR]
[TH]Service interval prolongation
[/TH]
[TD="class: prCode"]QG1
[/TD]
[TD]Service interval prolongation
[/TD]
[/TR]
[TR]
[TH]Shock absorption/suspension, chassis
[/TH]
[TD="class: prCode"]1BA
[/TD]
[TD]Standard suspension/shock absorption
[/TD]
[/TR]
[TR]
[TH]Side air bag
[/TH]
[TD="class: prCode"]4X4
[/TD]
[TD]Side air bag, front and rear
with curtain air bag
[/TD]
[/TR]
[TR]
[TH]Side and rear windows
[/TH]
[TD="class: prCode"]4KC
[/TD]
[TD]Side and rear windows in heat-insulating
glass
[/TD]
[/TR]
[TR]
[TH]Side assist/lane departure warning
[/TH]
[TD="class: prCode"]7Y0
[/TD]
[TD]Without lane change assistant
[/TD]
[/TR]
[TR]
[TH]Smoking/non-smoking package
[/TH]
[TD="class: prCode"]9JA
[/TD]
[TD]Non-smoking package
[/TD]
[/TR]
[TR]
[TH]Socket
[/TH]
[TD="class: prCode"]7B3
[/TD]
[TD]12-volt socket(s)
[/TD]
[/TR]
[TR]
[TH]Spare wheel/breakdown set
[/TH]
[TD="class: prCode"]1G1
[/TD]
[TD]Space-saving spare wheel
[/TD]
[/TR]
[TR]
[TH]Speaker installation
[/TH]
[TD="class: prCode"]8RM
[/TD]
[TD]8 speakers (passive)
[/TD]
[/TR]
[TR]
[TH]Special editions
[/TH]
[TD="class: prCode"]E0A
[/TD]
[TD]No special edition
[/TD]
[/TR]
[TR]
[TH]Special labels/plates
[/TH]
[TD="class: prCode"]0SC
[/TD]
[TD]Labels/plates in English
[/TD]
[/TR]
[TR]
[TH]Special registration measures
[/TH]
[TD="class: prCode"]3M0
[/TD]
[TD]Without special measures
[/TD]
[/TR]
[TR]
[TH]Start/stop system/regenerative braking
[/TH]
[TD="class: prCode"]7L8
[/TD]
[TD]Start/stop system with regenerative
braking
[/TD]
[/TR]
[TR]
[TH]Steering
[/TH]
[TD="class: prCode"]1N3
[/TD]
[TD]Speed-related variable steering assist
(Servotronic)
[/TD]
[/TR]
[TR]
[TH]Steering column systems
[/TH]
[TD="class: prCode"]2C5
[/TD]
[TD]Axial and vertical adjustable steering
column
[/TD]
[/TR]
[TR]
[TH]Steering system arrangement
[/TH]
[TD="class: prCode"]L0R
[/TD]
[TD]Right-hand drive vehicle
[/TD]
[/TR]
[TR]
[TH]Steering wheels
[/TH]
[TD="class: prCode"]1MH
[/TD]
[TD]Leather steering wheel
[/TD]
[/TR]
[TR]
[TH]Sticker (customized or special edition)
[/TH]
[TD="class: prCode"]0KA
[/TD]
[TD]Without stickers and badges
[/TD]
[/TR]
[TR]
[TH]Subsequent guarantee
[/TH]
[TD="class: prCode"]EA0
[/TD]
[TD]Without subsequent warranty
[/TD]
[/TR]
[TR]
[TH]Sun visors
[/TH]
[TD="class: prCode"]5XH
[/TD]
[TD]Sun visors with illuminated vanity
mirror on driver's and front seat
passenger's side
[/TD]
[/TR]
[TR]
[TH]Tachograph/logbook
[/TH]
[TD="class: prCode"]9NX
[/TD]
[TD]Without electronic logbook
[/TD]
[/TR]
[TR]
[TH]Taillight assemblies
[/TH]
[TD="class: prCode"]8SA
[/TD]
[TD]Taillight assemblies, standard design
[/TD]
[/TR]
[TR]
[TH]Telephone/telematics
[/TH]
[TD="class: prCode"]9W4
[/TD]
[TD]Car phone preparation
[/TD]
[/TR]
[TR]
[TH]Tie down straps/net/pocket
[/TH]
[TD="class: prCode"]6M3
[/TD]
[TD]Trunk net
[/TD]
[/TR]
[TR]
[TH]Tire pressure warning light
[/TH]
[TD="class: prCode"]7K0
[/TD]
[TD]Without tire pressure warning light
[/TD]
[/TR]
[TR]
[TH]Tire suppliers
[/TH]
[TD="class: prCode"]V0A
[/TD]
[TD]Tires w/o specification of tire brand
[/TD]
[/TR]
[TR]
[TH]Tires
[/TH]
[TD="class: prCode"]H8Y
[/TD]
[TD]Tires 255/60 R17 106V
[/TD]
[/TR]
[TR]
[TH]Tool kit and jack
[/TH]
[TD="class: prCode"]1S1
[/TD]
[TD]Tool kit and jack
[/TD]
[/TR]
[TR]
[TH]Trailer hitch
[/TH]
[TD="class: prCode"]1M5
[/TD]
[TD]Trailer hitch preparation
[/TD]
[/TR]
[TR]
[TH]Transit coating
[/TH]
[TD="class: prCode"]NT0
[/TD]
[TD]Transit coating (type 1)
[/TD]
[/TR]
[TR]
[TH]Transmission specifications
[/TH]
[TD="class: prCode"]G1G
[/TD]
[TD]8-speed automatic transmission for
four-wheel drive vehicle
[/TD]
[/TR]
[TR]
[TH]Tray areas package
[/TH]
[TD="class: prCode"]QE4
[/TD]
[TD]Tray areas package 2
[/TD]
[/TR]
[TR]
[TH]Trunk sill protection
[/TH]
[TD="class: prCode"]2P2
[/TD]
[TD]Trunk sill protection in stainless steel
[/TD]
[/TR]
[TR]
[TH]TV reception/digital radio reception
[/TH]
[TD="class: prCode"]QV0
[/TD]
[TD]W/o TV reception/digital radio reception
[/TD]
[/TR]
[TR]
[TH]Type approval countries/countries with special requirements
[/TH]
[TD="class: prCode"]B30
[/TD]
[TD]Type approval Australia
[/TD]
[/TR]
[TR]
[TH]Vehicle class differentiation units/platform components
[/TH]
[TD="class: prCode"]7KJ
[/TD]
[TD]Vehicle class differentiation 7P0
[/TD]
[/TR]
[TR]
[TH]Vehicle tracking system
[/TH]
[TD="class: prCode"]7G0
[/TD]
[TD]Without preparation for VTS
(vehicle tracking system)
[/TD]
[/TR]
[TR]
[TH]Versions
[/TH]
[TD="class: prCode"]FM0
[/TD]
[TD]Basic equipment variant
[/TD]
[/TR]
[TR]
[TH]Weight category front axle
[/TH]
[TD="class: prCode"]0JB
[/TD]
[TD]Weight category front axle
weight range 2
[/TD]
[/TR]
[TR]
[TH]Weight category rear axle
[/TH]
[TD="class: prCode"]0YA
[/TD]
[TD]Weight range 1
installation control only, no
requirement forecast
[/TD]
[/TR]
[TR]
[TH]Wheel covers
[/TH]
[TD="class: prCode"]1NS
[/TD]
[TD]Covers for wheel hubs/wheel bolts
[/TD]
[/TR]
[TR]
[TH]Wheels
[/TH]
[TD="class: prCode"]CH7
[/TD]
[TD]Alloy wheels 7.5J x 17
[/TD]
[/TR]
[TR]
[TH]Windshield glass type
[/TH]
[TD="class: prCode"]4GF
[/TD]
[TD]Windshield in heat-insulating glass
[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]PAA
[/TD]
[TD]Side air bags for outer rear seats
[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]PCA
[/TD]
[TD]Design package "Chrome & Style"
[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]PGN
[/TD]
[TD]Net partition, reversible luggage
compartment mat and luggage net
[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]PJ0
[/TD]
[TD]"Atacama" painted in sterling silver - 4
 alloy wheels 7.5J x 17 - tires 255/60
R17
[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]PTC
[/TD]
[TD]"Lights & Vision" package
[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]WLA
[/TD]
[TD]"Cricket" leather trim
[/TD]
[/TR]
[/TABLE]
[TR]
[TH]Vehicle Identification No.
[/TH]
[TD="colspan: 2"]WVGZZZ7PZCD011169
[/TD]
[/TR]
[TR]
[TH]Model
[/TH]
[TD="colspan: 2"]Touareg Blue Motion
TOUA
[/TD]
[/TR]
[TR]
[TH]Date of production
[/TH]
[TD="colspan: 2"]07.08.2011
[/TD]
[/TR]
[TR]
[TH]Year
[/TH]
[TD="colspan: 2"]2012
[/TD]
[/TR]
[TR]
[TH]Sales type
[/TH]
[TD="colspan: 2"]7P52GJ
[/TD]
[/TR]
[TR]
[TH]Engine Code
[/TH]
[TD="colspan: 2"]CJMA
[/TD]
[/TR]
[TR]
[TH]Transmission Code
[/TH]
[TD="colspan: 2"]MYX
[/TD]
[/TR]
[TR]
[TH]Axle drive
[/TH]
[TD="colspan: 2"]8A
[/TD]
[/TR]
[TR]
[TH]Equipment
[/TH]
[TD="colspan: 2"] JJ
[/TD]
[/TR]
[TR]
[TH]Roof color
[/TH]
[TD="colspan: 2"]2T
[/TD]
[/TR]
[TR]
[TH]Exterior color / Paint Code
[/TH]
[TD="colspan: 2"]2T / C9X
[/TD]
[/TR]
[/TABLE]
Part No SW: 7P0 907 311 C HW: 4G0 907 401 <<<<<<<<<<<<<<<<<<<<<<<<<< Confirmed identity config!
Working!
sasha
Australia
C?ID=287611
Thanks @jack
Do you know about pin 67 on the ECU, what is it used for?
The One
Australia
C?ID=277442
Thanks @jack
T105/67 is negative for the J338 throttle valve module.
sasha
Australia
C?ID=287611
:facepalm: looks like i missed your post @jack - thank you for that :thumbs:
that would explain this DTC then
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:01:47
The One
Australia
C?ID=277442
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:01:47
Yes it does Sasha. I don't think you'll be able to re-pin this TBH, and as you probably are aware, secondhand ECU's are hard to come by in Aus for the 7P Touareg haha
sasha
Australia
C?ID=287611
Second hand ECU is not a problem as I already got it. I'll see if the pin can be soldered on, if not, cloning will be done.
:popcorn:
The One
Australia
C?ID=277442
:popcorn:
Clearly I didn't read that ahaa. I would probably just clone it TBH, less stuffing around with pin soldering etc..
sasha
Australia
C?ID=287611
edc17cp44 is actually quite popular, all these have them - A5, A6, A7, A8, Q5, Q7, Cayenne, Macan
The One
Australia
C?ID=277442
Didn't even think ahaha - I got schooled today :facepalm:
sasha
Australia
C?ID=287611
Thought I'd finish up this thread on a good note. I ended up soldering the broken pin onto the original ECU and all is working fine, no issues in the last 6 months.
As I got it - kangaroo fur was in the front bumper..
All complete
