2010 audi a3 2.0ltr common rail, CFFB engine. fuel pressure fault.
Pinpointdiag
Scotland
C?ID=90374
Hi I have a problem with an A3 that belongs to a motor trade customer, The previous history is unknown and it was bought at auction with this
fault.
The car starts and runs every time although it cranks a little longer than i think is normal. It has a rev limit when stationary and produces no fault codes
untill driven. At which point it drops in to limited performance mode and logs faults for fuel pressure.
The fuel pressure is to low, when over 2500rpm under load the actual and desired pressures are way off.
I have so far tried the following.
Replaced fuel filter, Checked for any sign of air in fuel. Confirmed that there is plenty of good fuel in the tank.
Checked that both low pressure pumps are running, Then tested the low fuel pessure and found it to be 4 bar at all times, when driving and
under load low pressure is still 4 bar. My info says 3.8 so i'm fairly confident the low pressure system is ok.
I'v also done an injector back leakage test in the workshop and also driving when the fault happens using a pressure transducer and scope.
The injector back leakege does not suddenly increase when fault happens.
I have looked at duty cycle and current with a scope of both the inlet metering valve and the desiel regulating valve. but i dont have good data to compair with.
The fuel system is I believe EDC17 with a cp4.1 single piston pump. I have read that they are becoming common failures and that swarf can sometimes be found in the pump under the inlet metring valve. which i'v removed but found it to be clean.
There are a very large amount of data blocks in vcds and i wonder if any one has any advice on which ones if any may help.
I have alldata euro access to the workshop manuel which i'm not so sure is as good as erwin.
Any advice as to where to go next would be much appreciated
The trade customer is however as tight as a drum and is all ready talking about punting it back through the auction if i think its the pump.
Cheers Alan
Tuesday,15,August,2017,06:31:32:05279
VCDS Version: 17.1.3.0
VIN: WAUZZZ8P0AB020805   License Plate:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61 62 72
VIN: WAUZZZ8P0AB020805   Mileage: 156060km-96971miles
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 AB    HW: 03L 906 018 AG
   Component: R4 2,0L EDC   X20 6744
   Revision: 41X20---    Serial number: AUX7Z0J1FN30PB
   Coding: 00190012040501080000
   Shop #: WSC 02069 000 90108
   ASAM Dataset: EV_ECM20TDI01103L906018AB 003006
   ROD: EV_ECM20TDI01103L906018AB.rod
   VCID: 6ADF9A4C8D6B761157-803E
5211 - Fuel Rail/System Pressure
          P0087 00 [101] - Too Low
                    Mileage: 156066 km
                    Date: 2017.08.17
                    Time: 01:39:30
                    Engine speed: 2783.00 /min
                    Normed load value: 99.6 %
                    Vehicle speed: 74 km/h
                    Coolant temperature: 78 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 14.360 V
                    Unlearning counter according OBD: 77
                    Fuel temperature: 35.3 °C
                    Mean injection quantity: 66.86 mg/stroke
                    Rail pressure regulation: status-Bit 0: 00000101
                    Fuel high pressure: actual value: 583400 hPa
                    High fuel pressure: specified value: 1.4e+006 hPa
                    Pressure control valve adaptation factor: 1.0463
                    Fuel level: 18.00 l
5227 - Fuel Rail/System Pressure
          P0087 00 [172] - Too Low
                    Mileage: 156068 km
                    Date: 2017.08.17
                    Time: 01:40:47
                    Engine speed: 1473.00 /min
                    Normed load value: 55.3 %
                    Vehicle speed: 39 km/h
                    Coolant temperature: 79 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 14.380 V
                    Fuel temperature: 36.8 °C
                    Mean injection quantity: 26.83 mg/stroke
                    Rail pressure regulation: status-Bit 0: 00000100
                    Fuel high pressure: actual value: 683600 hPa
                    High fuel pressure: specified value: 937300 hPa
                    Pressure control valve adaptation factor: 1.0106
                    Fuel level: 18.00 l
5175 - Fuel Pressure Regulation
          P1065 00 [101] - Regulation Discrepancy
                    Mileage: 156068 km
                    Date: 2017.08.17
                    Time: 01:41:02
                    Engine speed: 1683.00 /min
                    Normed load value: 98.8 %
                    Vehicle speed: 44 km/h
                    Coolant temperature: 80 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 14.680 V
                    Engine status: COENG_RUNNING
                    Fuel temperature: 37.0 °C
                    Mean injection quantity: 24.18 mg/stroke
                    Pressure control valve adaptation factor: 0.7000
                    Fuel pressure regulator valve: specified value rail pressure: 1.5122e+006 hPa
                    High fuel pressure: specified value: 1.0579e+006 hPa
                    Fuel high pressure: actual value: 878900 hPa
Readiness: 1 1 0 0 0
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 13424012092400FAC81302E4901E0092380800
   Shop #: WSC 00046 412 00000
   VCID: 7AFFAA0CF5CBC691A7-802E
   Part No SW: 8P0 820 047 D    HW: 8P0 820 047 D
   Component: J255  Klima Man H08 0060
   Revision: 00H08004    Serial number: 00000000000000
   VCID: 316D4D20A83DC5C956-8064
Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
   Part No SW: 8P0 907 063 A    HW: 8P0 907 063 A
   Component: BCM PQ35  M   105 0575
   Revision: 00105 AK
   Coding: 0E000A2FB005F0C0207041E00000015C431A29AA004DC122E4008F800041
   VCID: 326F422C6D3BFED12F-8066
   Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H10 0040
   Coding: 00DD13
   Subsystem 2 - Part No: 8P0 951 177
   Component: Innenraumuebe  H04 0020
   Subsystem 3 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
   Subsystem 4 - Part No: 1K0 907 719 C
   Component: Neigungssenso  005 0003
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 150
                    Mileage: 156062 km
                    Date: 2017.08.16
                    Time: 23:38:30
                    Voltage: 14.65 V
                        Term 50 On
Address 15: Airbags (J234)       Labels: 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
   Component: Airbag AU1042 H06 0160
   Revision: --------    Serial number: 003FB004YWV1
   Coding: 30314238303830303037554A305238503053
   ROD: EV_Airba10AURB4.rod
   VCID: 4FA92BD816C9B33920-801A
   Serial number: 3572DRB40000A58CF24%
   Serial number: 3582DRB40000A4D5010K
   Serial number: 35128RB4000054342261
   Serial number: 35228RB4000054A53014
   Serial number: 35547RB40000552F285M
   Serial number: 35647RB40000552F21DO
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0002012
   VCID: 46870EFC31B3727193-8012
   Component: E0221           H02 0100
   Part No SW: 8P0 920 982 J    HW: 8P0 920 982 J
   Component: KOMBIINSTR. VDO H03 0990
   Revision: D0H03005    Serial number: 2241J005018539
   Coding: 0004428
   Shop #: WSC 00028 001 00001
   VCID: 408B18E413975C41A9-8014
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AF    HW: 1K0 907 951
   Component: J533  Gateway   H17 0233
   Revision:   H17       Serial number: 1521J101150291
   Coding: E9807F06000202042103
   VCID: 6BD19F484A916F192C-803E
   Revision: D0H03005    Serial number: AUX7Z0J1FN30PB
   Part No SW: 8P0 959 801 N    HW: 8P0 959 801 N
   Component: Tuer-SG         H04 0100
   Coding: 0131764
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 232    3001
   Revision: 00H17000
   Shop #: WSC 00046 000 90108
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
   Part No SW: 8P0 959 802 N    HW: 8P0 959 802 N
   Coding: 0131764
   VCID: 479903F836B96B7968-8012
   Part No SW: 8P0 035 152 E    HW: 8P0 035 152 E
   Component: R Chorus2+      H03 0280
   Revision: 00H03000    Serial number: AUZ1Z2K6131210
   Coding: 0200021
   VCID: 2D555150B405A12972-8078
   Part No SW: 1K0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H17 0233
   Revision: --------    Serial number: 1521J101150291
   Coding: 0303085A
   VCID: 68DBE0449B67440141-803C
   Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790901689
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0131216
   Shop #: WSC 00046 412 1012544
   VCID: 428F12EC1D9B4E51BF-8016
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0131216
   VCID: 438117E802814759B4-8016
End-------------------------(Elapsed Time: 02:26)--------------------------
NostraJackAss
It is not...........might as well be no data.
Might be the HPP failing or the regulation piston being stuck & due to lubricity issues.
You can try to clean the control PSI regulation unit within the HPP pump or replace the HPP so you meet the required fuel PSI and volume targets.
