Engines codes after 2012 a7 3.0t water pump and thermostat replacement
cheng536
C?ID=242377
I just replaced this water pump and themostat on this 3.0t engine. I keep getting this codes after the repair. Please give me some suggestions. Thanks for all your time!!
Saturday,12,August,2017,16:06:03:60975
VCDS Version: 17.8.0.1  HEX-NET CB: 0.4401.4
Mileage: 167222km-103906mi   Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 28 36 3B 3C 42 44 46 47
          52 53 55 56 5F 62 6C 6D 72 8F 90
VIN: WAU2GAFC0CN0XXXXX   Mileage: 167222km-103906miles
3B-Sensor Elect. -- Status: Malfunction 0010
Address 01: Engine (J623-CGXB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551 A    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0010
   Revision: --H07---
   Coding: 1A2A0034052600060000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
   ROD: EV_ECM30TFS0214G0907551A_003.rod
   VCID: A71EAC22DE03BB7E6B-80F2
10 Faults Found:
6185 - EVAP Purge Valve (N80)
          P1425 00 [039] - Short to Ground
                    Mileage: 167222 km
                    Date: 2017.08.12
                    Time: 15:57:15
                    Engine speed: 698.00 /min
                    Normed load value: 13.3 %
                    Coolant temperature: 90 ∞C
                    Intake air temperature: 56 ∞C
                    Voltage terminal 30: 13.812 V
                    Engine speed: actual: 672 /min
                    MAF_ENVD: 136.17647 mg/stroke
                    Coolant temperature (unfiltered): 90.75 ∞C
                    Engine: operating status: IS
                    Engine load: 13.281250 %
                    Vehicle speed: actual: 0 km/h
6001 - Right Engine Mount Solenoid Valve (N145)
          P1576 00 [039] - Short to Ground
                    Mileage: 167222 km
                    Date: 2017.08.12
                    Time: 15:57:15
                    Engine speed: 689.00 /min
                    Normed load value: 13.7 %
                    Engine load: 13.671875 %
6004 - Left Engine Mount Solenoid Valve (N144)
          P1572 00 [039] - Short to Ground
                    Mileage: 167222 km
                    Date: 2017.08.12
                    Time: 15:57:15
7814 - Coolant Pump for Intercooler
          P190C 00 [039] - No Signal
                    Mileage: 167222 km
                    Date: 2017.08.12
                    Time: 15:57:16
                    Engine speed: 685.00 /min
                    Voltage terminal 30: 14.015 V
                    MAF_ENVD: 141.62353 mg/stroke
7105 - Oile Pressure Regulating Valve
          P164E 00 [039] - Electrical Malfunction
                    Mileage: 167222 km
                    Date: 2017.08.12
                    Time: 15:57:18
                    Engine speed: 704.00 /min
                    Normed load value: 12.9 %
                    Intake air temperature: 55 ∞C
                    Engine speed: actual: 704 /min
                    Coolant temperature: 90.75 ∞C
                    TQI_AV_ENVD: 52 Nm
                    Battery voltage: 13.914063 V
12875 - Thermostat for Cylinder Head
          P199D 00 [039] - Short to GND
                    Mileage: 167222 km
                    Date: 2017.08.12
                    Time: 15:57:14
                    Engine speed: 692.00 /min
                    Voltage terminal 30: 13.913 V
9497 - Secondary Air Injection System Valve (N112)
          P0414 00 [039] - Shorted
                    Mileage: 167222 km
                    Date: 2017.08.12
                    Time: 15:57:14
                    Engine speed: 686.00 /min
                    Battery voltage: 13.812500 V
                    STATE_LS_ENVD[1]: 4
9500 - Secondary Air Injection System Valve 2 (N320)
          P0417 00 [039] - Shorted
                    Mileage: 167222 km
                    Date: 2017.08.12
                    Time: 15:57:14
                    STATE_LS_ENVD[2]: 4
9494 - Secondary Air Injection Pump Relay (J299)
          P2257 00 [039] - Short to Ground
                    Mileage: 167222 km
                    Date: 2017.08.12
                    Time: 15:57:14
                    Engine speed: 696.00 /min
                    AMP_ENVD: 981.7285 hPa
18198 - Coolant pump
          P1B1C 00 [039] - Mechanical malfunction
                    Mileage: 167222 km
                    Date: 2017.08.12
                    Time: 15:57:15
Readiness: 1110 1101
   Part No SW: 4G0 927 158 P    HW: 0BK 927 156 R
   Component: 0BK 30TFSIUSA H08 0003
   Revision: --H08---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002017
   VCID: BB366052328B0F9E1F-80EE
   Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
   Component: ESP PREMIUM   H09 0250
   Coding: 44A70F0322E5F0C05B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004017
   VCID: B4244B6E1FD5C0E6DE-80E0
   Part No SW: 4H0 907 064 BR    HW: 4H0 907 064 BR
   Component: BCM2 2.0      H31 0330
   Coding: 0D8A2000000000000000
   VCID: FAB8A5567531F69644-80AE
   Component: J764 ELV MLB  H39 0046
   Serial number: 2311000154747012
   Part No SW: 4G0 820 043 L    HW: 4G0 820 043 L
   Component: KLIMA 4 ZONEN H11 0062
   Serial number: 09091100040096
   Coding: 668320BA48
   ASAM Dataset: EV_AirCondiComfoUDS 002033
   VCID: A81CAF1ED31DB40662-80FC
0247 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 141
                    Mileage: 167222 km
                    Date: 2017.08.12
                    Time: 15:32:49
                    Outside air temperature: 32.5 ∞C
                    Engine speed: 175 /min
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0100
   Revision: 11012002    Serial number: 00000001044821
   Coding: 02002091163C9FE0C1008884A0003928CF9CD208A2080125800008402000
   VCID: EE9099063979AA36E8-80BA
   Component: WWS57X 110731  H35 0051
   Serial number:         110805110850
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11665408
   Coding: 02562B
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 05 09 2011  00000660
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R0LDT02
   Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0024271048
   Coding: 0F3000
   Subsystem 6 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Serial number: WA102069000000410884
   Coding: 020300
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: BF18C5C5000000000001
Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
   Part No SW: 8X0 035 110 B    HW: 8X0 035 110
   Component: CDC-MP3-Pana  H41 0480
   Revision: 00000007
   VCID: AC14530ECFE5982686-80F8
   Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0050
   Revision: 11001001    Serial number: 55901125101203
   Coding: 280104
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   VCID: BD326E4A2C9F01AE21-80E8
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H31 0032
   Revision: --------    Serial number: 003D8001CD3A
   Coding: 303145313131303030314A55304C34473853
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: B32648721ADBC7DEC7-80E6
   Serial number: 6940000Y150001FEDZ08
   Serial number: 3575HRB404V0OPI250M
   Serial number: 3585HRB405D0NI366OV.
   Serial number: 3515JRB404R0M5SQ886.
   Serial number: 3525JRB405L0N49O9177
   Serial number: 3554VRB404V0NI3IKHIR
   Serial number: 3564VRB40530NI3I216+
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372KI9000II
   Coding: 000414
   VCID: B83C7F5E0BBD2486F2-80EC
   Subsystem 1 - Part No SW: 4G0 951 528 F    HW: 4G0 951 528 F
   Component: E221 - MFL  H09 0009
   Serial number: 24 07 2011  33108987
Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 982     HW: 4G8 920 982
   Component: TBenUsa       H71 0375
   Revision: 26181114    Serial number: 658050911593014
   Coding: 0BE601060B03D705020100
   ASAM Dataset: EV_RBD4K 004040
   ROD: EV_RBD4K.rod
   VCID: F1AA827A2047B5CEF5-80A4
   Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000249279
   Coding: 00C1033000
   ROD: EV_GatewUDS_AU57.rod
   VCID: B2284D76E5C1CED6CC-80E6
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650411549
   Part No SW: 4G0 919 158 D    HW: 4G0 919 158 D
   Component: KLIMA FOND    H07 0062
   Serial number: 26081100041017
   Coding: 00
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002015
   VCID: B02C477EEBCDFCC6BA-80E4
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Component: MEM-FS        H03 0153
   Revision: AA000000    Serial number: 00000011476684
   Coding: C0581B008F002001000001010101102030303232203232
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA4201UBTS0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: AD125E0AFCFF912E91-80F8
2097156 - Internal Control Module Memory Check Sum Error
          B2000 00 [109] -  -
                    Fault Frequency: 0
                    Mileage: 163961 km
                    Date: 2017.06.16
                    Time: 13:55:35
                    DCU Temperature: 0 ∞C
                    Voltage Clamp 15: 14.0 V
                    Voltage Clamp 30: 13.5 V
                    Ignition Cycle Count: 21686
                    Voltage UBDZ: 13.5 V
                    Voltage VDD1: 1.5 V
                    Voltage VDD3: 3.3 V
                    Voltage VDD3_STUCK: 1.9 V
                    Voltage VDD5: 5.0 V
                    Voltage VBG2: 2.5 V
                    Voltage GNDA: 0.0 V
2117632 - Internal Control Module Memory Check Sum Error
          B2000 00 [109] -  -
                    Fault Frequency: 0
                    Mileage: 163961 km
                    Date: 2017.06.16
                    Time: 13:55:35
                    Voltage VDD1: 1.5 V
                    Voltage VDD3: 3.3 V
                    Voltage VDD5: 5.0 V
                    Voltage VBG2: 2.5 V
                    Voltage GNDA: 0.0 V
   Part No SW: 4G0 907 566 J    HW: 4G0 907 566
   Component: J769  SWA MasterH01 0030
   Revision: 00H01000    Serial number: 6PZ 010 287-08
   Coding: 0000007
   VCID: B6207166C1A9D2F6E0-80E2
   Subsystem 1 - Part No: 4G0 907 568 J
   Component: J770  SWA Slave H01 0030
   Subsystem 2 - Serial number: 6PZ 010 287-28
   Subsystem 3 - Serial number: 5F16.08.1100H010003CZ21944ˇ
   Subsystem 4 - Serial number: Z21944ˇ
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   Coding: 011F57225E00628002000412
   Shop #: WSC 02312 785 00200
   VCID: C2C81DB65D617E565C-8096
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0020146212
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0158289811
   Coding: 0126023A20FAF48580B00A80020100000000000000000000000000000000
   Component: GTO BF  H01 0070
   Serial number: 00000000000000048040
   Subsystem 3 - Part No SW: 7P5 959 591     HW: 4H0 959 591
   Component: J245 PS40.033  H07 0006
   Serial number:     WOO1320725.
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00000371286
   Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H09 0027
   Serial number: WA102073000000463265
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
            000 -  -  - Intermittent
                    Reset counter: 141
                    Mileage: 167222 km
                    Date: 2017.08.12
                    Time: 15:25:10
   Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
   Component: BOSE G3 C7    H07 0130
   Revision: CJ007000    Serial number: 00000000020665
   Coding: 030000
   VCID: 9C7483CE9F4568A6F6-80C8
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   Coding: 011F57225E00628002000402
   VCID: C1CA12BA5867654E45-8094
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000125015
   ROD: EV_ParkiBrake_AU57.rod
   VCID: AA185516CD11861674-80FE
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0012
   Serial number: 110913-0004-016
   Coding: 1223A633701AA400
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
H01 0020
   Coding: 3A0000
H01 0020
   Coding: 3A0000
   Part No SW: 4G0 035 082 B    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0076
   Revision: AB001007    Serial number: 156I+0B7550772
   Coding: 020007010000000001
   VCID: 9F0EB4C28E5373BE13-80CA
   Part No SW: 4G0 035 746 C    HW: 4G0 035 746
   Component: H-BNT-NA      H48 0423
   Revision: --------    Serial number: 031IS0B7514812
   Coding: 090200040003E1EF55128B0E00000003100001000000000000
   VCID: A71EAC22D603BB7E6B-80F2
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB1301FWK%
   Subsystem 3 - Part No SW: 4G1 919 610 A    HW: 4G1 919 610 A
   Component: E380 BDT C7  H08 0203
   Serial number: 90349KI50003W
   Component: CD-Database  3371
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F17224000628002000002
   VCID: C4C41BAE477570666E-8090
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H04---    Serial number: 525 PA8J14G0TK
   Coding: 1080013
   VCID: A600A1261109A27650-80F2
   Part No SW: 4G8 959 107 P    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0039
   Revision: 12013001    Serial number: 237100321
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001014
   ROD: EV_HDSGAu571.rod
   VCID: C2C81DB655617E565C-8096
   Component: TSG HR        H04 0212
Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 0006E008031F0300070308014244CA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: EFAE84023673A33EE3-80BA
Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: F0AC877E2B4DBCC6FA-80A4
End----------(Elapsed Time: 02:38, VBatt start/end: 14.2V/14.2V)----------
NostraJackAss
Hello and welcome to the VCDS forum OP.
Sounds like you should unplug your thermostat and electric water pump for inspection & since work was just aforementioned in this work detail. You might have bent a pin causing a short on the sensor bus.
Please review WD for shared tracks and check fuses plus all terminals and ground connectivity.
Isolate to test and verify.
You could benefit from the JPPSG in this forums sticky.
cheng536
C?ID=242377
Thanks for your reply!! The thing that confuse me the most is it is saying the themostat itself is short to gound, which doesn't really have any electrical part. :(
"Thermostat for Cylinder Head" is not the main thermostat.
cheng536
C?ID=242377
NostraJackAss
You must observe the WD and trace by isolation.
Maybe you plugged something in a incorrect location or damaged something while in there.
Did you have or what codes did you have before the work detail?
Why did you perform this aforementioned work?
cheng536
C?ID=242377
Originally was a coolant leak complain. It was a broken coolant pipe under the supercharger between the heater cord and the themostat. The car was due for a water pump and themostat. So they were all replaced after that. The engine light came on with the coolant warning still remained after the repair. I am going to take a look at the WD and see if i did anything wrong when putting those 7 connectors back near the supercharger. :)
Keithuk
Stoke on Trent, England
C?ID=122432
I've read in a SSP a long time ago they show and electrical thermostat. I shall have to search through the thousands I have.
UPDATE:
I've found Map-Controlled Engine Cooling Thermostat (F265) in SSP 252 1.4 L 77 kW Engine with Petrol Direct Injection System in the Lupo FSI
http://www.volkspage.net/technik/ssp/ssp/SSP_252.pdf
SSP 222 Electronically Mapped Cooling System
http://www.volkspage.net/technik/ssp/ssp/SSP_222.pdf
I'm sure there was another engine with electrical thermostat.
