Please forgive posting errors!
The Car: 06 A6 3.2
The symptom: Rough idle/even vibration, think old rabbit running well, really bad engine mount. Only 1 code, listed below.
The History: 140Kish miles, deferred maintenance, they finally decided to step up. We did plugs/filters at first visit. We resealed 'cam ladders', replaced Bank 2 Timing chain adjuster(broken plastic running surface), intake port carbon clean(they were really bad on this one), and #6 injector due to misfire code and 000632/ P0278 Injector #6; contribution/balance fault. The car ran poorly from the outset, so I'm not clear if this was a pre-existing condition, but I believe it may not have been.
What I've checked, and learned so far: After delivery, and a few days of driving, it set
-- 004409/P1139 Fuel Trim Bank 2 (Add), system too rich. Sorry I only have a printed version right now. RPM 672, Temp, 90C. On initial checking, I had worked out Bank 2 was running too rich, and this DTC confirmed it, but did not return after sending the car for a week, I believe the issue is borderline at the threshold for setting it. I removed B2 plugs hoping to see a fouled one, thinking leaking/bad injector. No dice there. I proceeded to remove B1 plugs, and do a compression test. Fuel pump disabled B1 is 175-180, B2 is 155-160. I moved all plugs/coils to their opposite banks, as well as the leading O2's just to rule them out.
What I'm thinking now: The B2 timing is incorrect. Based on lower compression and the work done, and the fact that no single plug is a standout for running rich, causing the control unit to compensate, and lean the Bank...
And my question!! Wouldn't I get a correlation code if this was the case? Is it possible to be out of time one link and not code?
Here's the data I know you want...
AND MVB 032
AND MVB 093 at idle
This Autoscan was done warm, but shortly after clearing codes from the compression test.
Thanks for any input, let the berating begin!!!
Scott
The Car: 06 A6 3.2
Wednesday,09,August,2017,15:43:23:55556
VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4401.4
VIN: WAUDH74F36N128663 License Plate: CHUNG
Mileage: 227630km-141442mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 65 67 72 76 77
VIN: WAUDH74F36N128663 Mileage: 227630km-141442miles
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F2 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0030
Revision: --H15--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 26153 444 54017
VCID: AB1666C90ADCB41E8F-80FE
Readiness: 0110 0101
Part No SW: 4F2 910 156 D HW: 09L 927 156 A
Component: AG6 09L 3,2 FSI USA 0010
Revision: --H01--- Serial number: 4125447
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: A60097FD113E897650-80F2
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H04 0090
Coding: 0020895
VCID: AD1268D134C8BA2E91-80F8
Fault Status: 00101101
Reset counter: 25
Mileage: 227037 km
Date: 2017.07.27
Time: 17:49:39
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0025
Hex Value: 0x01A7
Hex Value: 0x00FF
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0180
Revision: 30070501 Serial number: 10604000317777
Coding: 0000015
Shop #: WSC 26153 444 84168
VCID: E386CEE9228C3C5E77-80B6
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0070
Component: FBSAUDIC6 KSG H27 0080
Component: FBSAUDIC6 IDG H01 0060
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 731 B HW: 4E0 035 729
Component: Interfacebox H43 1190
Revision: 00000000 Serial number: 303L.057513989
Coding: 0000003
Shop #: WSC 02335 785 00200
VCID: A10A84E178106E4E25-80F4
Component: Bedienteil MMIC6H08 0050
Subsystem 2 - Serial number: 00000000300877
Subsystem 3 - Serial number: 0113.12.050000000100010197ÿ
Subsystem 4 - Serial number: 010197ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0170
Revision: 00000030 Serial number: 00000000215150
Coding: 0532518
VCID: DBF6F6091AFC049E3F-808E
Reset counter: 26
Mileage: 227037 km
Date: 2017.07.27
Time: 15:43:06
00739 - Coolant Circulation Pump (V50)
Fault Status: 00100001
Reset counter: 27
Mileage: 227037 km
Date: 2017.07.27
Time: 17:54:14
Temperature: 31.0°C
Part No SW: 4F0 910 279 D HW: 4F0 907 279
Component: ILM Fahrer H15 0190
Coding: 0014123
VCID: AA1863CD0526AD1674-80FE
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH11 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels:
VCID: D5EC6BDA2C0C46EFD8C-FFFE
Address 0F: Digital Radio Labels: None
VCID: D5E2E0313CD8D2EE09-8080
No Faults Found
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 66 AIRBAG AUDI8RH29 0300
Revision: 14H29000 Serial number: 00359D0B1D5H
Coding: 0013878
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME0E3E215AA
Subsystem 3 - Serial number: 6342CSME0D5D31287
Subsystem 4 - Serial number: 6352QSME03343001Y
Subsystem 5 - Serial number: 6362QSME0803784BJ
Subsystem 6 - Serial number: 63734SME0747104BZ
Subsystem 7 - Serial number: 63834SME032E2C798
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026053240275
Coding: 0002041
Shop #: WSC 02323 785 00200
VCID: E680D7FDD1BE497690-80B2
Component: Lenkradmodul H07 0090
Part No SW: 4F0 910 930 A HW: 4F0 920 980 N
Component: KOMBIINSTR. M73 H16 0630
Revision: 00200000 Serial number: 4PY34P5D5
Coding: 2129263
Shop #: WSC 26153 444 14546
Fault Status: 00101010
Reset counter: 25
Mileage: 227037 km
Date: 2017.07.27
Time: 15:43:56
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300805C120186
Coding: ECFE73CD1B7904
Shop #: WSC 02334 785 00200
VCID: A71E9AF91634907E6B-80F2
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: E18AC4E138902E4E65-80B4
Part No SW: 4E0 910 888 F HW: 4E0 919 887 C
Component: MNS US H45 0990
Revision: 00000000 Serial number: 355L$057559461
Shop #: WSC 00000 785 00200
VCID: B12A74A128F0DECEB5-80E4
02927 - DVD Read Error
Reset counter: 56
Mileage: 227596 km
Date: 2017.08.08
Time: 16:02:50
Hex Value: 0x5989
Hex Value: 0xE0E6
Hex Value: 0x0401
Hex Value: 0x0000
Address 42: Door Elect, Driver Labels:
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01009453810000
Coding: 4619325
VCID: AE106FDD39CEC136A8-80FA
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 A HW: 4F0 035 223 A
Component: DSP-High C6 H09 0140
Revision: PROD_01 Serial number: 00000000201691
Coding: 0000026
VCID: 9C74B5155F7243A6F6-80C8
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000013333
Coding: 0002114
VCID: DEF0FF1D09EE11B658-808A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0080
Revision: 00-00000
Coding: 0051947
Shop #: WSC 02327 785 00200
VCID: AC1465D50FD2B32686-80F8
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
VCID: DDF2F81104E80AAE41-8088
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Coding: 0000016
VCID: A81C99C51B2A9F0662-80FC
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Part No SW: 4E0 910 541 F HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 394L2057633579
Coding: 0000002
VCID: A3068EE9620C7C5E37-80F6
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000175629
Shop #: WSC 26153 444 66633
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 1512010407
Coding: 344630393135313035432056413031353132303130343037
Shop #: WSC 00000 384 00290
02256 - Quiescent Current
Reset counter: 28
Mileage: 227037 km
Date: 2017.07.28
Time: 00:35:54
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0051754
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900015201
Coding: 0062221
VCID: A2088BED7D1675563C-80F6
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 J HW: 4E0 035 753 A
Component: SDS 3501 US H45 0600
Revision: 00000000 Serial number: 00000512060322
Shop #: WSC 12336 024 394758
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0051754
Part No SW: 4F0 910 283 B HW: 4F0 919 283 B
Component: Parkhilfe 4-Kan H09 0030
Revision: 00H09000 Serial number: 11720533918804
Coding: 0001206
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 B HW: 4E0 862 335
Component: Handyvorb2 H11 0440
Revision: 00000000 Serial number: 00000007526210
Coding: 0010900
End----------(Elapsed Time: 04:36, VBatt start/end: 13.7V/13.8V)-----------
Address 01: Engine (4F2 910 559 B)
15:37:21 Group 032: Lambda Control (Mixture Adaptation)
-2.1 % Adaptation (Idle) Bank 1 Sensor 1
0.0 % Adaptation (Partial) Bank 1 Sensor 1
-15.5 % Adaptation (Idle) Bank 2 Sensor 1
0.0 % Adaptation (Partial) Bank 2 Sensor 1
15:36:18 Group 093: Camshaft Adjustment (Adaption Values)
2.3°KW Phase Position Intake Bank 1
14.3°KW Phase Position Intake Bank 2
2.3°KW Phase Position Exhaust Bank 1
12.4°KW Phase Position Exhaust Bank 2
Scott
