Disable start/stop and presense in A5 B9
   #21
hadez16
C?ID=289891
Disable Start-Stop for B9 platform:
Go to 08 Auto HVAC
Adaptation
Set channel
IDE03253 - A/C comfort parameter for start-stop function
to the value 0. (should be 5 before).
Done.
   #22
NVGeo
C?ID=2408
Sportmotor's post (#10) worked for my 2017 A6 3.0. Very straightforward using HEX+CAN adaptor and VCDS Release 17.8.0
   #23
automat
Canada
C?ID=153257
I see start/stop features everywhere! It's present in a lot of modules. I wonder if the answer to this problem would be to disable s/s in every possible locations all at once. the car seems to resync between modules upon turning ignition ON. if all modules except one say s/s enabled, it seems the disabled module will fall back to this enabled value instead.
I have a customer with an S5 who would love to see it GONE!
   #24
automat
Canada
C?ID=153257
not the same car, not the same architecture. those were easy.
   #25
hadez16
C?ID=289891
Did you read my post above?
   #26
automat
Canada
C?ID=153257
That's what we did to his car, but it's just a patch, if you turn the climate controls off altogether it will still stop (and apparently do funky things too)
   #27
autodoc
C?ID=411440
Hello Sportmotor,
I own Audi A4 B9 2017 model Engine Code CYMC. Would your instructions work on my car?
Thanks!
   #28
NostraJackAss
Disabling SS in the USA is illegal as an AECD.
Use the button that came with car each time........
