Transporter T5 GP & BCM, problems with long code helper
mrjj
Finland
C?ID=32548
I have an interesting case where it really looks like long code helper does show wrong contents !
I did swapping of BCM to a newer one to allow CCS to be activated.
I noticed already with original box ...86D that there was some bits on eventhough they are nto shown on the screen (upper bits of few bytes)
Also some extra equipments not existing in my car where activated.
However after swapped to newer ...89D interior lights and rear lid lock stopped to work.
   Part No SW: 7H0 937 089 D    HW: 7H0 937 089
   Component: BCM T5GP Li4  H47 0230
   Revision: BS047001    Serial number: 0398 023110832
   Coding: A0A0393A0E212012002000003C2B8CD40080430F60040000300000000000
   Shop #: WSC 35110 377 08192
   VCID: 3776ADFA868213FE7B-8062
   Subsystem 1 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 2 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
03080 - Activation for interior lights
            006 - Short to Plus
                    Fault Status: 01100110
                    Reset counter: 234
                    Mileage: 233343 km
                    Date: 2011.12.29
                    Time: 00:03:14
...and status of rear lid lock...(sorry not pasted here)
I went thru several times all bits making sense but no help. Then I copy pasted original long code and then rear lid started to work but still interior lights were not working.
After swapping back original BCM both are fine.
   Part No SW: 7H0 937 086 D    HW: 7H0 937 086
   Component: BCM T5GP M++4 H47 0221
   Revision: BM047001    Serial number: 0346 247100984
   Coding: A0A0393A0E212012002000003C2B8CD40000430F60040000300000000000
   Shop #: WSC 02734 790 00000
   VCID: 346C9AF697F4F8E65E-8060
03304 - Response Closing Status of Rear Right Door
                    Fault Frequency: 15
                    Reset counter: 191
                    Mileage: 229861 km
                    Date: 2011.09.29
                    Time: 07:39:56
02660 - Radio Remote Control not Matched/Adapted
            000 -  -
                    Reset counter: 166
From my point of view it looks we are missing now some important bits for actual door combination and behave of interior lights.
The label file is the same though box swapped => Labels:. 7H0-937-08x-09.clb
Some of the bits not explained and/or bits with other meaning were affecting to rear lid.
Safelock feature were also activated during swap eventhough nothing controlling it according bits.
I even got 2 other BCM with same results.
My car is 2011 (VIN) and very basic with right slide door (manual), rear lid and basic halogen lights w/o fogs ie. coming /l eaving home is not available neither cornering lights.
VCDS is updated within couple of days to latest 17.8.
mrjj
Finland
C?ID=32548
Problem "solved"
Here I found updated description for BCM bits. I certainly hope these would be added to the label file of T5.
http://obdeleven.proboards.com/thread/86/coding-adaptations
(use the link to see added bits red coloured)
Byte 00 Bit 0 Selective Central Locking (Single Door Locking) active
Byte 00 Bit 1 Central Locking WITHOUT SAFE-Function (Zentralverriegelung OHNE SAFE-Funktion verbaut)
Byte 00 Bit 2 Central Locking 2-motor-locks installed (Zentralverriegelung 2-Motoren-Schlösser verbaut)
Byte 00 Bit 3 Auto-Unlock (Unlocking when Removing the Ignition Key)
Byte 00 Bit 4 Auto-Lock (Automatic Locking above 15 km/h)
Byte 00 Bit 5 Central Locking installed
Byte 00 Bit 6 Central Locking via cylinder lock active (Zentralverriegelung über Schliesszylinder aktiv)
Byte 00 Bit 7 Central Locking 1-motor-locks with SAFE Function installed (Zentralverriegelung 1-Motoren-Schlösser mit SAFE Funktion verbaut)
Byte 01 Bit 0 Activation Central Locking Rear Lid after 0.8s active (Aktivierung Zentralverriegelung Gepäckraum nach 0.8s aktiv)
Byte 01 Bit 1 Confirmation lock for right sliding door via CAN data bus (Rückmeldung Schloss für Schiebetür rechts über CAN-Datenbus)
Byte 01 Bit 2 ?
Byte 01 Bit 3 Central Locking/Rear Lid: Speed depending locking over 5 km/h (Zentralverriegelung/Heckklappe: Geschwindigkeits basierte Verriegelung (ab 5 km/h))
Byte 01 Bit 4 Central Locking/Rear Lid: Direct opening with Switch & Remote control (Zentralverriegelung/Heckklappe: Direkter Auswurf Heckklappe über Taster & Funkfernbedienung)
Byte 01 Bit 5 Central Locking/Rear Lid: Contact controlled on detent (Zentralverriegelung/Heckklappe: Kontaktgesteuert auf Raste(n))
Byte 01 Bit 7 Central Locking/Rear Lid: Rear Lid Locking/Unlocking via Central Locking
Byte 02 Bit 0 Central Locking/Rear Lid: Soft-Touch
Byte 02 Bit 1 4 doors version (excl. Sliding doors and rear lid) (Ausführung Viertürer (exkl. Schiebetüren & Heckklappe))
Byte 02 Bit 3 Central Locking/Rear Lid: Spring motor (unidirectional) installed (Zentralverriegelung/Heckklappe: Federstellmotor (unidirektional) verbaut)
Byte 02 Bit 4 Actuation for central locking via MOST data bus blocked (Ansteuerung für Zentralverriegelung via MOST-Datenbus gesperrt)
Byte 02 Bit 5 Central Locking/Rear Lid: Lock with pre-lock and electrical feedback (Zentralverriegelung/Heckklappe: Schloss mit Vorraste und elektrischer Rückmeldung verbaut)
Byte 02 Bit 6 Central Locking/Rear Lid: Release button inside (Zentralverriegelung/Heckklappe: Entriegelungstaster innen verbaut)
Byte 03 Bit 0 Comfort Opening for Sun Roof active
Byte 03 Bit 1 Comfort Closing for Sun Roof active
Byte 03 Bit 2 Comfort Function for Sun Roof active (Schiebe-/Aufstelldach (SAD) bei Komfortöffnung nur aufstellen (statt komplett öffnen))
Byte 03 Bit 3 Comfort Function for Power Windows via Lock Cylinder active
Byte 03 Bit 4 Comfort Function for Power Windows via Drivers Interior Switch active
Byte 03 Bit 5 Comfort Function for Power Windows via Remote Control active
Byte 03 Bit 6 Mirror folding blocked when exceeding 40 km/h (Spiegelanklappung bei Überschreitung 40 km/h gesperrt)
Byte 03 Bit 7 Comfort Function active (Ausgabe Freigabesignal während Komfortbedienung über LIN-Datenbus (Dach) aktiv)
Byte 04 Bit 0 SECRET Alarm function (send a pm if you want more information (Funktion, welche die Diebstahlwarnanlage betrifft! Schreibt eine PN wenn Ihr mehr Infos wollt)
Byte 04 Bit 1 Activation of control activation disabled for lock error (Ansteuerungswiederholung bei Schlossfehler deaktiviert)
Byte 04 Bit 2 Internally lock over lock release driver's door (Intern verriegeln über Schlossrückmeldung Fahrertür)
Byte 04 Bit 3 Release after-run Electric window lifter or sliding roof on ignition OFF (Freigabenachlauf elektrische Fensterheber (eFH) bzw. Schiebe-/Ausstelldach (SAD) bei Zündung AUS)
Byte 04 Bit 4 ?
Byte 04 Bit 5 Central Locking Re-Locking (after 30 Seconds) active
Byte 04 Bit 6 Rain Closing active
Byte 05 Bit 0 Locking/Unlocking Optical Confirmation (Turn Signal) active
Byte 05 Bit 1 Acoustical Locking Confirmation (Horn) active (Verriegelung akustische (Sirene/Sounder) bestätigen
Byte 05 Bit 2 ?
Byte 05 Bit 3 Acoustical Locking Confirmation (Horn) duration from 40 ms to 20 ms (Akustische (Sirene/Sounder) Bestätigung von 40 ms auf 20 ms verkürzt)
Byte 05 Bit 4 Acoustical Unlocking Confirmation (Horn) active (Entriegelung akustisch (Sirene/Sounder) bestätigen)
Byte 05 Bit 5 Comfort Closing Optical Confirmation (Turn Signal) active (Komfortschliessen optisch (Blinklicht) bestätigen
Byte 05 Bit 6 Anti-Theft-System Sounder/Sirenen Port active (0 = Simple-Horn installed / 1 = Backup-Siren (LIN) installed)
Byte 05 Bit 7 Anti-Theft-System Activation Acoustical Confirmation (Horn) active
Byte 06 Bit 0 Siren Tone Type (0 = frequency modulated / 1 = discontinuoud)
Byte 06 Bit 1 Siren Alarm Type (0 = 10 Alarms (GB/Irland) / 1 = 1 Alarm (RoW))
Byte 06 Bit 2 Anti-Theft-System installed
Byte 06 Bit 3 Anti-Theft-System Deactivation via Ignition Lock active
Byte 06 Bit 5 Anti-Theft-System Delay Start (0 = with Door Opening / 1 = with Unlocking)
Byte 07 Bit 0 Central Locking/Rear: Slidung Door Left installed
Byte 07 Bit 1 Central Locking/Rear: Slidung Door Right installed
Byte 07 Bit 3 Remote Control inactive
Byte 07 Bit 4 Direct ejection for rear lid blocked (Direkter Auswurf für Heckklappe blockiert)
Byte 07 Bit 5 Central Locking/Rear Lid: One-Motor-Lock installed (Zentralverriegelung/Heckklappe: Ein-Motoren-Schloss verbaut)
Byte 08 Bit 0 Rain/Light Sensor (RLS) installed
Byte 08 Bit 1 Inclination Sensor for Anti-Theft System installed
Byte 08 Bit 2 ?
Byte 08 Bit 3 Sliding roof (external control/ installed (Schiebe-/Ausstelldach (externe Steuerung) verbaut
Byte 08 Bit 4 Interior Monitoring for Anti-Theft System installed
Byte 08 Bit 5 ?
Byte 08 Bit 6 Cable winch installed (Seilwinde verbaut)
Byte 08 Bit 7 Sounder/Siren for Anti-Theft System (via LIN) installed
Byte 09 Bit 0 ?
Byte 09 Bit 1 ?
Byte 09 Bit 2 Selective short stroke function (with terminal S OFF) active (Selektive Kurzhubfunktion (bei Klemme S AUS) aktiv
Byte 09 Bit 3 Multi-Function-Steering-Wheel (MFSW) installed
Byte 09 Bit 4 Rear Power Windows installed
Byte 09 Bit 5 Front Power Windows installed
Byte 09 Bit 6 ?
Byte 09 Bit 7 Short stroke active (Kurzhubfunktion aktiv)
Byte 10 Bit 0 Body control module (BCM) with external start / stop control (Body-Control-Module (BCM) mit externer Start/Stopp-Regelung)
Byte 10 Bit 1 Leaving-Home (LH) active
Byte 10 Bit 2 Coming-Home (CH) active
Byte 10 Bit 3 Active display of "Safelock" in den Multi Function Display (Anzeige Safelock im Schalttafeleinsatz aktiv)
Byte 10 Bit 4 ?
Byte 10 Bit 5 ?
Byte 10 Bit 6 Reversed rotary contacts for rear sliding doors (Drehfallenkontakte für hintere Schiebetüren reversiert)
Byte 11 Bit 0 High beam via shutter (xenon) active/installed (Fernlicht über Shutter (Xenon) aktiv/verbaut)
Byte 11 Bit 1 Lamp failure detection for additional position lights active (Lampenausfallerkennung für zusätzliche Positionsleuchten aktiv)
Byte 11 Bit 2 Activation of additional position lights via pulse width modulation (PWM) active (Ansteuerung zusätzliche Positionsleuchten über Pulsweitenmodulation (PWM) aktiv)
Byte 11 Bit 3 Additional position lights installed (Zusätzliche Positionsleuchten verbaut)
Byte 11 Bit 4 Activation of Back-Up Light via pulse width modulation (PWM) active (Ansteuerung Rückfahrleuchte über Pulsweitenmodulation (PWM) aktiv)
Byte 11 Bit 5 Activation of license plate light via pulse width modulation (PWM) active (Ansteuerung Kennzeichenbeleuchtung über Pulsweitenmodulation (PWM) aktiv)
Byte 11 Bit 6 Lamp Diagnostics for Back-Up Light active
Byte 11 Bit 7 Lamp Diagnostics for License Plate Light active
Byte 12 Bit 0 Parking Lights ON with "Terminal 15 ON" (Standlicht EIN bei Zündung/Klemme 15 EIN) Anmerkung: Aktive Heckbeleuchtung bei Tagfahrlicht!!
Byte 12 Bit 1 Daytime Running Light (DRL) adjustable (Manually AND/OR Instrument Cluster)
Byte 12 Bit 2 Interior Light after Ignition Key removal active
Byte 12 Bit 3 Emergency Flashing (Turn Signals) active
Byte 12 Bit 4 Emergency Brake Flashing (Brake Light) active
Byte 12 Bit 5 Comfort Turn Signals active
Byte 12 Bit 6 Turn/Cornering Lights installed/active
Byte 13 Bit 0 Parking Lights ON only w/o Ignition ON possible
Byte 13 Bit 1 Parking Lights Function active
Byte 13 Bit 2 Brake Lights OFF while Terminal 15 OFF
Byte 13 Bit 3 Brake Light Activation via Body Control Module (BCM)
Byte 13 Bit 5 Interior Light Enabling via Rear Lid
Byte 13 Bit 6 Coming-Home (CH) / Leaving-Home (LH) Variant (0 = Fog Lights / 1 = Low Beam)
Byte 13 Bit 7 Light Sensor Function active
Byte 14 Bit 0 Headlight Wishers installed
Byte 14 Bit 1 Rain Sensor Function active
Byte 14 Bit 2 Service Position for Front Wiper active
Byte 14 Bit 3 Comfort Function for Rear Wiper active
Byte 14 Bit 4 Tear Wiping active
Byte 14 Bit 7 Speed dependent Wiper Stage Activation active
Byte 15 Bit 0 Push-to-Talk Function via Multi-Function-Steering-Wheel (MFSW) active
Byte 15 Bit 2 Rear Window Heater Activation (via) CAN active
Byte 15 Bit 3 Mirror Heating ON while Rear Window Heater ON
Byte 15 Bit 4 Intervention / deactivation for heated seats (by energy management) deactivated (Eingriff/Abschaltung für beheizbare Sitze (durch Energiemanagement) deaktiviert)
Byte 15 Bit 5 Heated Front Window installed
Byte 15 Bit 6 Heated Outside Mirrors installed
Byte 15 Bit 7 Heated Rear Window installed
Byte 16 Bit 0 Activation low beam via pulse width modulation (PWM) active (Ansteuerung Abblendlicht über Pulsweitenmodulation (PWM) aktiv)
Byte 16 Bit 1 Activation of fog light via pulse width modulation (PWM) active (Ansteuerung Nebelschlusslicht über Pulsweitenmodulation (PWM) aktiv)
Byte 16 Bit 2 Activation of Daytime running lights via pulse width modulation (PWM) active (Ansteuerung Tagfahrlicht über Pulsweitenmodulation (PWM) aktiv)
Byte 16 Bit 3 Activation of High Beam via pulse width modulation (PWM) active (Ansteuerung Fernlicht über Pulsweitenmodulation (PWM) aktiv)
Byte 16 Bit 4 Lamp Diagnostics for Low Beam active
Byte 16 Bit 5 Lamp Diagnostics for Rear Fog Light(s) active
Byte 16 Bit 6 Lamp Diagnostics for (Separate) Daytime Running Lights (DRL) active
Byte 16 Bit 7 Lamp Diagnostics for High Beam active
Byte 17 Bit 3 Horn with "Terminal 15 OFF" inactive
Byte 17 Bit 4 Battery Seperating Relay active
Byte 17 Bit 5 Enable for special functions I active / multifunctional control (MFG) (Freigabe für Sonderfunktionen I aktiv / Multifunktionssteuerung (MFG) verbaut)
Byte 17 Bit 6 Control of electric fuel pump (EKP) via driver door opening (Ansteuerung elektrische Kraftstoffpumpe (EKP) über Fahrertüröffnung)
Byte 17 Bit 7 Cruise Control System (CCS) installed
Byte 18 Bit 0~7 00 Light Setup: Standard/Parameter Settings (EEPROM)
Byte 18 Bit 0-1 01 Model parking light: 5W + 5W (Ausführung Standlicht: 5W+5W)
Byte 18 Bit 3-4 00 Indicator lights: 21W/21W/5W (Ausführung Blinkleuchten: 21W/21W/5W)
Byte 18 Bit 5 Output high beam active (Ausgang Fernlicht aktiv)
Byte 18 Bit 6-7 40 Brake lights: 21W/21W/5W (Ausführung Bremsleuchten: 21W/21W/5W)
Byte 19 Bit 0 Control of fog/cornering light via pulse width modulation (PWM) active (Ansteuerung Nebel-/Abbiegelicht über Pulsweitenmodulation (PWM) aktiv)
Byte 19 Bit 1 Control of rear lights via pulse width modulation (PWM) active (Ansteuerung Begrenzung-/Schlusslicht über Pulsweitenmodulation (PWM) aktiv)
Byte 19 Bit 2 Control of brake lights via pulse width modulation (PWM) active (Ansteuerung Bremsleuchten über Pulsweitenmodulation (PWM) aktiv)
Byte 19 Bit 3 Control of indicator/turn lights via pulse width modulation (PWM) active (Ansteuerung Blinkleuchten über Pulsweitenmodulation (PWM) aktiv)
Byte 19 Bit 4 Lamp Diagnostics for Turn Lights active
Byte 19 Bit 5 Lamp Diagnostics for Fog Lights and/or Cornering/Turn Lights active
Byte 19 Bit 6 Lamp Diagnostics for Tail Lights active
Byte 19 Bit 7 Lamp Diagnostics for Brake Lights active
Byte 20 Bit 1 Recuperation active / installed (Rekuperation aktiv/verbaut)
Byte 20 Bit 2 Battery module (BDM) indstalled (Batteriedatenmodul (BDM) verbaut)
Byte 20 Bit 3 Generator connection via LIN data bus (Generator-Anbindung über LIN-Datenbus verbaut)
Byte 20 Bit 4 Start / stop function active / installed (Start/Stopp-Funktion aktiv/verbaut)
Byte 20 Bit 5 Energy Management active (Batterie-/Energiemanagement aktiv)
Byte 20 Bit 6 Function Tension indicator active with active transport mode (TRA) active (Funktion Ruhespannungsanzeige bei aktivem Transportmodus (TRA) aktiv)
Byte 21 Bit 0 Daytime running light in LED version (Tagfahrlicht in LED-Ausführung verbaut)
Byte 21 Bit 1 Dimming Switch lighting via fixed value (see APK 045) active (Dimmung Schalterbeleuchtung über Festwert (siehe APK 045) aktiv)
Byte 21 Bit 2 Cornering/Turn Lights via Turn Signal active
Byte 21 Bit 3 Cornering light on both sides when reversing (Abbiegelicht beidseitig bei Rückwärtsfahrt)
Byte 21 Bit 4 Roof flashing lights installed (Dachblinkleuchten verbaut)
Byte 21 Bit 5 Fog Lights inactive with High Beams active
Byte 21 Bit 6 Two-sided parking light active / side marker lights installed (Beidseitiges Parklicht aktiv / Seitenmarkierungsleuchten verbaut)
Byte 21 Bit 7 Front Fog Lights (with Turn Lights) installed
Byte 22 Bit 0 Light reduction / evaluation Light switch (LDS) Position 0 (at 'ZV CLOSE'?) (Standlichtreduzierung / Auswertung Lichtdrehschalter (LDS) Stellung 0 (bei 'ZV ZU'?))
Byte 22 Bit 1 ?
Byte 22 Bit 2 Low beam inactive with main beam active(Abblendlicht inaktiv bei Fernlicht aktiv)
Byte 22 Bit 3 Display daytime running light active / installed (Anzeige Tagfahrlicht aktiv/verbaut)
Byte 22 Bit 4 Shut-off of rear fog lights (NSL) with luggage compartment open (Abschaltung Nebelschlussleuchten (NSL) bei geöffnetem Kofferraum)
Byte 22 Bit 5 Assistent Driving Light (ADL) active
Byte 22 Bit 6 Interlock Display (Clutch Message) in Instrument Cluster active (Funktion Automatikstart aktiv)
Byte 23 Bit 0 Alternative Voltage Supply for High Beam and Terminal 58d
Byte 23 Bit 1 Rear fog light (NSL) in high beam (FL) inactive (Nebelschlusslicht (NSL) bei Fernlicht (FL) inaktiv)
Byte 23 Bit 2-3 00 Daytime running lights (TFL) via exit for daytime running lights (TFL) (Tagfahrlicht (TFL) über Ausgang für Tagfahrlicht (TFL))
Byte 23 Bit 4 Daytime running light (TFL) is switched off when the handbrake is pulled (Abschaltung Tagfahrlicht (TFL) bei gezogener Handbremse)
Byte 23 Bit 5 Daytime running lights with parking light (Tagfahrlicht bei Standlicht)
Byte 23 Bit 6 Function "Daytime Running Light (DRL)" active
Byte 23 Bit 7 Switch off the daytime running lights when the turning lights active (Tagfahrlicht beim Blinken abschalten)
Byte 24 Bit 0 Parking light OFF with low beam and S-contact OFF (Standlicht AUS bei Abblendlicht und S-Kontakt AUS)
Byte 24 Bit 1 Display for limiting light active / installed (Anzeige für Begrenzungslicht aktiv/verbaut)
Byte 24 Bit 2 Delay light switch (LDS) always active (Verzögerung Lichtdrehschalter (LDS) immer aktiv)
Byte 24 Bit 3 ?
Byte 24 Bit 4 Transport Protocol für CAN-Databus Powertrain (0 = TP 1.6 / 1 = TP 2.0)
Byte 24 Bit 5 CAN-Powertrain "Loop" active
Byte 25 Bit 0 ?
Byte 26 Bit 0 Rotary signal for sliding door on the left via CAN data bus (Drehfallensignal für Schiebetür links über CAN-Datenbus)
Byte 26 Bit 1 Rotary signal for sliding door on the right via CAN data bus (Drehfallensignal für Schiebetür rechts über CAN-Datenbus)
Byte 26 Bit 2 Control 2-motor locks active (special solution Beetle / Beetle Cabrio (Ansteuerung 2-Motoren-Schlösser aktiv (Sonderlösung Beetle/Beetle Cabrio)
Byte 26 Bit 3 ?
Byte 26 Bit 4 Radio remote control (FFB) active in transport mode (Funkfernbedienung (FFB) im Transportmodus aktiv)
Byte 27 Bit 0 License plate light in LED design (Kennzeichenbeleuchtung in LED Ausführung)
Byte 27 Bit 1 Activation terminal 58d active via Body Control Module (BCM) with pulse width modulation (PWM) (Ansteuerung Klemme 58d über Body Control Module (BCM) mit Pulsweitenmodulation (PWM) aktiv)
Byte 28 Bit 0 ?
Byte 29 Bit 0 ?
Sadly adding comfortline/highline BCM, requires changes to interior light voltage supply hence requiring new wires from fuse box to BCM.
On the other words, if there is original BCM with part number 86x or below you can only swap to 87x. Any higher BCM will not work as it is.
iichel
Eindhoven, NB, NL
C?ID=284912
Some of the functions of the BCM are unique for a BCM type (i.e. 089/090). But most of them I agree with.
mrjj
Finland
C?ID=32548
Indeed, all of them are found only with highest model but when recoding such a BCM for to be used in basic car you need to take those into account too.
With label file in latest release you were not able to interpret central locking so in addition to new bits some regular old bits were missing.
iichel
Eindhoven, NB, NL
C?ID=284912
usually i recode my BCM with my own excel sheet and copy/past long code into the coding box of vcds :-)
mrjj
Finland
C?ID=32548
The story goes on still...
Just got yet another BCM with ...87 code on it.
Interior lights fine BUT rear lid not working. Unbelievable.
While looking more carefully coding bits I found few strange details, maybe somebody can help me ?
Byte 01 Bit 2 ?
---what happens to bit 6 ?---
Something does not match here...
1010 0000 = A0 This original coding do not set keyfob rear lid opening at all, but it worked wit original bcm (a0 byte)
1001 0000 = 90 accepted not working (middle key in key fob)
---what happens to bit 2 ?---
This BCM for this byte won´t accept the hex 39 as it used to be with original 86D BCM
010 0000 = 20 accepted, not working
010 0001 = 21 accepted, not working
010 1001 = 29 accepted, not working
011 0001 = 31=REJECTED
011 1001 = 39=REJECTED
iichel
Eindhoven, NB, NL
C?ID=284912
byte 1 bit 6: i don't know
byte 2 bit 2: remote active with ignition on
mrjj
Finland
C?ID=32548
Thanks, iichel !
Now I got it to work finally, I need to tweak also byte 7. Do you happen to know anything about that bytes missing bits too ?
Lock versions seems to vary, in this case it has to be set to one motor, spring loaded :)
mrjj
Finland
C?ID=32548
Do you iichel or anyone happen to have got info for aux heater testing on a T5.1 ? Went to look in Basic setting and couldn´t find any place.
Testing functions works and no fault codes found. It is still so warm out that it doesn´t come on itself.
amigokola
Poland
C?ID=281040
Hi..
I didnt want to make new thread so I ask here...
Somebody knows what to rewire/add after BCM upgrade in VW T5 (no interior lights)??
Old BCM 7H0937086D, new one 7H0937089D.
Rgs.
