- Sep 5, 2016
- 1,165
- 1,244
- Riga, Latvia
- C?ID=268515
Hi, haven't been here for some months - I was running out of free time at summer...
This Audi was towed to me from another workshop. I don't know why, but someone tried to do something with ECU and I suspect, flash and eeprom files are partially damaged after that.
Bad thing is, I can't find needed files anywhere..
ECU is Bosch ME7.5, 8D1906018A/0261204966.
Sometimes ECU starts up with ignition on, then I can scan it:
Sunday,06,August,2017,01:22:59:32442
VCDS Version: 17.8.0.1
VIN: XXXXXXXXXXXXXXXXX License Plate:
Chassis Type: XX (8L - Audi A3/S3 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: XXXXXXXXXXXXXXXXX Mileage: 237140km-147351miles
Address 01: Engine Labels: None
Part No: 8D1 906 018 A
Component: 1.8L R4/5VS MOTR 0002
Coding: 10430
VCID: 26439CA7C299B776D0-5140
16985 - Internal Control Module
P0601 - 35-00 - Memory Check Sum Error
16989 - Internal Control Module
P0605 - 35-10 - ROM Error - Intermittent
18010 - Power Supply Terminal 30
P1602 - 35-00 - Voltage too Low
16497 - Intake Air Temp. Sensor (G42)
P0113 - 35-00 - Signal too High
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 GS
Component: AG4 Getriebe 01M 4627
Coding: 00000
VCID: 071DF12325538E7ECB-095E
00777 - Accelerator Position Sensor (G79)
00660 - Kickdown Switch or Throttle Position Sensor
00529 - Engine Speed Signal Missing
35-10 - - - Intermittent
00545 - Engine-Transmission Electrical Connection
31-10 - Open or Short to Ground - Intermittent
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13504
Shop #: WSC 06435
VCID: 3F8D29C33D0306BEB3-4B1A
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 M
Component: A3 KLIMAVOLLAUTOMAT_D77
Coding: 03140
Shop #: WSC 06435
VCID: 326B70F7FE51DBD64C-2592
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 G
Component: Airbag Front+Seite 1008
Coding: 00104
Shop #: WSC 06435
VCID: 428B20374EF16B56DC-515E
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 931 F
Component: KOMBI+WEGFAHRS. M73 D56
Coding: 00042
Shop #: WSC 21121
VCID: 326B70F7FE51DBD64C-4AE8
XXXXXXXXXXXXXXXXX AUZ5Z0GD188052
37-10 - Faulty - Intermittent
Address 35: Centr. Locks Labels:. 8D0-862-257.lbl
Part No: 8L0 862 257 L
Component: ZV-Pumpe D10
Coding: 00000
Shop #: WSC 06435
VCID: 3E7354C73A090FB6B8-4EEA
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186 B
VCID: 1F4D89439DC366BE93-4B00
07-00 - Signal too Low
00855 - Connection to CD changer
49-00 - No Communications
00856 - Radio Antenna
36-00 - Open Circuit
End-------------------------(Elapsed Time: 04:34)--------------------------
