I bought a cruise control stalk online with part number 1K0-953-513G to install in my 2008 MK5 Golf later today. I haven't bought any additional wiring or modules. I want to know if I need to buy any additional modules or wiring to make this work in my car.
My coding is shown below:
Tuesday,13,June,2017,07:40:37:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.5.1.1 (x64)
Data version: 20170602 DS272.1
Dealer/Shop Name: Matthew Taylor
VIN: WVWZZZ1KZ8W111078 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 77
VIN: WVWZZZ1KZ8W111078 Mileage: 163970km-101886miles
77-Telephone -- Status: Not registered 0001
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 R HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0G83NA8OV
Coding: 040300101C070060
Shop #: WSC 66565 257 00032
VCID: 354FD8585CDD5EEF87-8060
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 - 004 - Malfunction / Open Circuit
Mileage: 163909 km
Time: 07:30:55
RPM: 1637 /min
Load: 53.3 %
Speed: 21.0 km/h
Temperature: 77.0°C
Temperature: 31.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow
Fault Status: 01100010
Mileage: 163909 km
Time: 07:31:26
RPM: 763 /min
Load: 20.0 %
Temperature: 90.0°C
Temperature: 34.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.843 V
Readiness: 0110 0001
Part No SW: 02E 300 044 J HW: 02E 927 770 AD
Component: GSG DSG 082 1407
Revision: 04808020 Serial number: 00000907050136
Shop #: WSC 09537 809 89632
VCID: 1C192DFCDF37EFA798-8048
Revision: 00H11001
Coding: 0004738
Shop #: WSC 12345 123 12345
VCID: 73CB2640122900DF69-8026
Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
VCID: 79D7146830457A8F23-802C
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Revision: 00H54000 Serial number: 01000007456322
Coding: E70E8F0F0004150A4F140AFF1400FFE48019FF07FF10010D000000000000
VCID: 71C72C48683532CF9B-8024
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 300807 021 0501
Coding: 00038837
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 130907 046 0204
Coding: 00208933
Shop #: WSC 12345
02499 - Right Low Beam Reflector Motor (V295)
Fault Status: 00111100
Reset counter: 115
Mileage: 163941 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.15 V
Fault Status: 01101100
Reset counter: 77
Mileage: 163909 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.85 V
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 3A AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1FKU0T
Coding: 0013121
Shop #: WSC 01269 785 00200
VCID: 3D5FC07864ED86AF4F-8068
Subsystem 1 - Serial number: 6332MSME2C406B29H
Subsystem 2 - Serial number: 6342MSME2C42223ED
Subsystem 3 - Serial number: 6352QSME3D213635D
Subsystem 4 - Serial number: 6362QSME3C0B0C41L
7 Faults Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
007 - Short to Ground - Intermittent - MIL ON
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 036 0070
Coding: 0012102
VCID: 01277C885895224F6B-8054
Component: E0221 002 0010
Part No SW: 1K6 920 974 HW: 1K6 920 974
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0G83NA8OV
Coding: 0004103
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 040907F1000254
Coding: ED811F060002020001
VCID: 3041E94CA3BF7BC7D4-8064
Fault Frequency: 7
Mileage: 163909 km
Time: 07:30:32
Component: IMMO VDD 1216
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.clb
Component: Tuer-SG 006 120B
Coding: 0000564
Shop #: WSC 00000 785 00200
VCID: 3851D16C4BCFA3879C-806C
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 69 2901
Revision: 00H15000
VCID: 2F43EA30BE81643FCD-807A
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Coding: 9890020851030C7F42CC0F0FF0085A2670B840
VCID: 032B76804289305F79-8056
Subsystem 1 - Component: Sounder No Answer
01134 - Alarm Horn (H12)
Reset counter: 74
Mileage: 163909 km
Time: 07:30:33
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.clb
Coding: 0000564
VCID: 3957D46870C5BA8F63-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74C9255C172707E770-8020
01539 - Headlights Not Adjusted
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7L3180243
Coding: 01000401000000
VCID: 63EB560062C9905F19-8036
Reset counter: 74
Mileage: 163909 km
Time: 07:30:35
02633 - Antenna for Satellite Tuner
Fault Status: 01101011
Reset counter: 74
Mileage: 163909 km
Time: 07:30:35
Reset counter: 74
Mileage: 163909 km
Time: 07:30:35
Address 77: Telephone
End-------------------------(Elapsed Time: 01:10)--------------------------
