Retrofitting Cruise control in 2008 MK5 Golf
NitrousOxide
Jamaica
C?ID=269481
I bought a cruise control stalk online with part number 1K0-953-513G to install in my 2008 MK5 Golf later today. I haven't bought any additional wiring or modules. I want to know if I need to buy any additional modules or wiring to make this work in my car.
My coding is shown below:
Tuesday,13,June,2017,07:40:37:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.5.1.1 (x64)
Data version: 20170602 DS272.1
Dealer/Shop Name: Matthew Taylor
VIN: WVWZZZ1KZ8W111078   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 77
VIN: WVWZZZ1KZ8W111078   Mileage: 163970km-101886miles
77-Telephone -- Status: Not registered 0001
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0G83NA8OV
   Coding: 040300101C070060
   Shop #: WSC 66565 257 00032
   VCID: 354FD8585CDD5EEF87-8060
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0036 - 004 - Malfunction / Open Circuit
                    Mileage: 163909 km
                    Time: 07:30:55
                    RPM: 1637 /min
                    Load: 53.3 %
                    Speed: 21.0 km/h
                    Temperature: 77.0°C
                    Temperature: 31.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.224 V
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow
                    Fault Status: 01100010
                    Mileage: 163909 km
                    Time: 07:31:26
                    RPM: 763 /min
                    Load: 20.0 %
                    Temperature: 90.0°C
                    Temperature: 34.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.843 V
Readiness: 0110 0001
   Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1407
   Revision: 04808020    Serial number: 00000907050136
   Shop #: WSC 09537 809 89632
   VCID: 1C192DFCDF37EFA798-8048
   Revision: 00H11001
   Coding: 0004738
   VCID: 73CB2640122900DF69-8026
   Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   VCID: 79D7146830457A8F23-802C
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Revision: 00H54000    Serial number: 01000007456322
   Coding: E70E8F0F0004150A4F140AFF1400FFE48019FF07FF10010D000000000000
   VCID: 71C72C48683532CF9B-8024
   Component: Wischer 300807 021  0501
   Coding: 00038837
   Shop #: WSC 12345
   Component: RLS     130907 046  0204
   Coding: 00208933
   Shop #: WSC 12345
02499 - Right Low Beam Reflector Motor (V295)
                    Fault Status: 00111100
                    Reset counter: 115
                    Mileage: 163941 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.15 V
                    Fault Status: 01101100
                    Reset counter: 77
                    Mileage: 163909 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.85 V
   Component: 3A AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1FKU0T
   Coding: 0013121
   Shop #: WSC 01269 785 00200
   VCID: 3D5FC07864ED86AF4F-8068
   Subsystem 1 - Serial number: 6332MSME2C406B29H
   Subsystem 2 - Serial number: 6342MSME2C42223ED
   Subsystem 3 - Serial number: 6352QSME3D213635D
   Subsystem 4 - Serial number: 6362QSME3C0B0C41L
7 Faults Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
            007 - Short to Ground - Intermittent - MIL ON
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
00589 - Airbag Igniter 1; Passenger Side (N131)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Coding: 0012102
   VCID: 01277C885895224F6B-8054
   Part No SW: 1K6 920 974     HW: 1K6 920 974
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0G83NA8OV
   Coding: 0004103
   Revision:   H07 01    Serial number: 040907F1000254
   Coding: ED811F060002020001
   VCID: 3041E94CA3BF7BC7D4-8064
            000 -  -
                    Mileage: 163909 km
                    Time: 07:30:32
   Component: IMMO            VDD 1216
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
   Component: Tuer-SG         006 120B
   Coding: 0000564
   Shop #: WSC 00000 785 00200
   VCID: 3851D16C4BCFA3879C-806C
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 69     2901
   Revision: 00H15000
   VCID: 2F43EA30BE81643FCD-807A
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 9890020851030C7F42CC0F0FF0085A2670B840
   VCID: 032B76804289305F79-8056
                    Reset counter: 74
                    Mileage: 163909 km
                    Time: 07:30:33
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
   Coding: 0000564
   VCID: 3957D46870C5BA8F63-806C
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74C9255C172707E770-8020
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7L3180243
   Coding: 01000401000000
   VCID: 63EB560062C9905F19-8036
                    Reset counter: 74
                    Mileage: 163909 km
                    Time: 07:30:35
02633 - Antenna for Satellite Tuner
                    Reset counter: 74
                    Mileage: 163909 km
                    Time: 07:30:35
            000 -  -
                    Reset counter: 74
                    Mileage: 163909 km
                    Time: 07:30:35
Address 77: Telephone
End-------------------------(Elapsed Time: 01:10)--------------------------
NitrousOxide
Jamaica
C?ID=269481
I was hoping that since my car is a 2008 model, I wouldn't need to buy any additional modules or wiring, so the process could be as simple as swapping the replacement stalk and wiring. I'd then just play around with the coding to get the desired results. I'm just trying to avoid removing the steering wheel twice to get the job done.
Been here?
NitrousOxide
Jamaica
C?ID=269481
I had looked at that page already, but I still can't conclude based on the part number for my module that it would work for my module without additional wiring. I only see where I should take a gamble based on my 2008 model being newer than 2007 where the wiring was required.
m87a
Bosnia and Herzegovina
C?ID=156900
your module support, check connector coming to module if it has pin 13 (black/white wire) if you have it just replace stalk and code it, if not you need to route wire from steering wheel module to ECU.
NitrousOxide
Jamaica
C?ID=269481
I pulled off the steering wheel and replaced the stalk today, I did coding to only Module #01 and Module #16 to say Cruise control without the board.
I haven't test driven the vehicle as yet, but I'll be doing so shortly to see if it works. I forgot to look for the wiring to see if my car came pre-wired. I may have to look at the MVB to be sure, since I've sealed everything up.
Spacewalker
Poland
C?ID=159607
simple switch ON/ OFF CCS, RES/SEt and you will see if ECu get error .
if no ERROR - and all is code correct , should be ok
NitrousOxide
Jamaica
C?ID=269481
Indeed the retrofit worked perfectly. In the MK5 I get no visual indication that the system is on, other than the cruise control LED. I was expecting something in my multifunction display to tell me what the set cruise control speed is when I resume the cruise control operation.
Spacewalker
Poland
C?ID=159607
this is only in UDS cluster and also depend of ECU
your cluster can be "adjust" to enable GREEN CCS Indicator when you switch ON CCS toggle ( but CCS is still not enable)
it was like that in older clusters till 2006
