- May 12, 2014
- 52
- 13
- Palestine Gaza
- C?ID=11756
Hi
I have skoda 2012 pcr2,1 1,6 diesel , it has battery light on at the dashboard , customer think its Alternator issue , he replaced it with a good used one , problem still exist , he thik the the new used one is defect , he replaced it again with another used , but the same problem , he also has issue with rpm , it is rising to reach 1000 rpm, its not regeneration , cause fan didnt work when rpm is rising ,
any help friend , customer replaced new brand battery with new alternator . but battery light still exist at the dash , help me please
thank you all
thank you all
Saturday,05,August,2017,16:52:12:25282
VCDS Version: 17.8.0.1 (x64)
Dealer/Shop Name: Gaza Automotive Solutions
Workshop Code: 116 27465 022987
VIN: TMBHT61Z7D2097847 License Plate:
Chassis Type: 1Z-SK35 (7N0)
VIN: TMBHT61Z7D2097847 Mileage: 193110km-119992miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 LP HW: 03L 906 023 JH
Component: 1,6l R4 CR td H43 9972
Revision: --H43--- Serial number:
Coding: 00114016032400080000
Shop #: WSC 73430 031 00061
ASAM Dataset: EV_ECM16TDI02103L906023LP 003010
ROD: EV_ECM16TDI02103L997557.rod
VCID: 7F0767BEE69FBEBEF3-802A
6082 - Steering Column Control Module
U0212 00 [039] - No Communications
Mileage: 193111 km
Date: 2017.08.05
Time: 00:41:00
Engine speed: 0.00 /min
Coolant temperature: 92 °C
Intake air temperature: 56 °C
Voltage terminal 30: 12.198 V
Driver request torque-TQI_DRIV_SUB: 0.00 Nm
Control Module temperature-TECU: 52 °C
Readiness: 1110 1000
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: 113B201C0A2B0001881304E850200041310000
Shop #: WSC 73430 790 00061
VCID: 7DFB9DB6E493ACAEE1-8028
Part No SW: 3T0 820 047 AH HW: 3T0 820 047 AH
Component: AC Manuell H20 0607
Revision: 00001012
Coding: 0010000002
ROD: EV_ACManueBHBVW36X_SK35.rod
VCID: 75EB8596D4A3F4EEA9-8020
Part No SW: 1K0 937 085 P HW: 1K0 937 085 P
Component: BCM PQ35 B+ 111 0709
Revision: AC111709
Coding: 40000AB8A005089040100080510000A4430000AE724D85605CC440000040
VCID: 3C7D50B2BF0965A696-8068
Subsystem 1 - Part No: 1Z1 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 10111 26 0601
Coding: 00D7B7
Component: Q6 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PC2DB1F4
Coding: 0020790
VCID: 3D7B5DB664136CAEA1-8068
Subsystem 1 - Serial number: 6332MSME7253504B8
Subsystem 2 - Serial number: 6342MSME725164221
Subsystem 3 - Serial number: 6351HSME2E661D09I
Subsystem 4 - Serial number: 6361HSME2E660B70E
Part No SW: 5K0 953 507 AC HW: 5K0 953 549
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90440LKD000IK
Coding: 5880040000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 71E3B186A0CBD8CE75-8024
0516 - Databus
Reset counter: 180
Mileage: 193111 km
Date: 2017.08.05
Time: 00:41:00
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 803 S HW: 1Z0 920 803 S
Component: KOMBI H06 0608
Coding: 110E00
ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
VCID: 448D2852CFF91D66EE-8010
Part No SW: 7N0 907 530 AF HW: 7N0 907 530 AF
Component: J533 Gateway H52 1634
Revision: H52 Serial number: 101112F2000093
Coding: 352302
VCID: 74EDB892D7D9EDE69E-8020
Component: IMMO H06 0608
VCID: 6AD1A6EA8D1D2B1634-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2119
Coding: 0000116
VCID: 48953C623BD1390602-801C
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 69 3305
Revision: 00H22000
VCID: 37774F9E462F46FE7B-8062
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000116
VCID: 47973F5E36CF367E0B-8012
Part No SW: 1Z0 035 161 M HW: 1Z0 035 161 M
Component: Radio-SWING 003 0003
Revision: -----05S Serial number: SKZ4Z2M1396603
Coding: 000002000001
VCID: 38754CA28B31498672-806C
End-------------------------(Elapsed Time: 01:43)--------------------------
