Hi all,
My first post on this VCDS forum.... I have a Touareg 7L6, model year 2008.
I recently got a hit from a rock on my windshield and while replacing the windshield through insurance to the one with a factory-equipped rain sensor / auto-dimming mirror holder, I retrofitted the rain sensor according to the wiring schema available through VW's erWin online service. I have also swapped my original light switch with otherwise similar OEM original part with the addition of "Auto" position.
The rain sensor and wipers are working just as described in the owner's manual. However, the automatic headlight functionality is not.
Is it so that the automatic headlight functionality needs to be enabled via VCDS? I don't see any options related to it in the central electronics control module. I only see coming/leaving home, high beam with assistance driving light and garage/cinema light bits in the long coding section. What are those options for?
Byte 00 Bit 7 High Beam with Assistance Driving Light
Byte 04 Bit 0 Assistance Driving Light
Byte 04 Bit 1 Coming-Home
Byte 04 Bit 2 Garage/Cinema Light
I also tried to enable bit 1 Coming/leaving home in VCDS, and after that I can see the related options in the instrument cluster's MFD (off/10s/20s adjustment), but after setting some other value than "off", the headlights anyway remain inactive when the car is locked/unlocked.
Any advice on how to get automatic ("tunnel") headlights and CH/LH enabled?
I have tried CH/LH coding and activation when it should have been dark enough ambient light level outside (night time).
Please find the VCDS scan below.
-Turik08
-Turik08
Wednesday,12,July,2017,21:27:27:41242
VCDS Version: 17.1.3.0 (x64)
VIN: WVGZZZ7LZ8D0XXXXX License Plate: NNNNN
Mileage: XXXkm-YYYmi Repair Order: 12_07_2017_DTC
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 22 32 37 46 47 55 56 68 69
6C 76 77
VIN: WVGZZZ7LZ8D0XXXXX Mileage: XXXkm-YYYmiles
32-Differential Locks -- Status: Malfunction 0010
68-Wiper Electr. -- Status: Sporadic communication error 1000
Address 01: Engine (CAS) Labels: 059-907-401-CAT1.clb
Part No SW: 7L0 907 401 N HW: 7L0 907 401 H
Component: 3.0TDI EDC17G104AG 0040
Revision: --H02--- Serial number: VWX3Z0H1726703
Coding: 04210023591F0968
Shop #: WSC 39721 123 79935
VCID: 36635AB442E667F103-5124
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 FT HW: 09D 927 750 FT
Component: AL 750 6A 1168
Revision: 00H75000 Serial number:
Coding: 0004456
Shop #: WSC 31414 790 00001
VCID: 0501ED784F803C69DA-5140
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 L HW: 7L0 907 379 L
Component: ESP ALLRAD MK25E1 0303
Revision: 00H53001
Coding: 0004354
VCID: 428B3664192ECB51BF-8016
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 139 B HW: 5WK 485 04
Component: Kessy 6840
Revision: 68406620 Serial number: VWX3Z0H1726703
Coding: 0000232
VCID: 285F84CC9F52010181-807C
Component: ELV XXXX
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 AF
Component: CLIMAtronic R/L 4331
VCID: 74E7A0BC131A35E1FD-8020
Address 09: Cent. Elect. Labels: 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2000
Revision: -0004--- Serial number: --------------
Coding: 6000040038021C000000000000000000
VCID: 000FFC6C57A21941E9-8054
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 HW: 7L0 959 655
Component: J234__37 VW8T 0250
Revision: 92012025 Serial number: 0039P0048ZTR
Coding: 0013111
VCID: 7AFB8E84317E4391A7-802E
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 F
Component: J527 3601
Coding: 0010011
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 885 R HW: 7L6 920 885 R
Component: J285 KOMBI-INST. 7520
Revision: KHH06V02
Coding: 0005111
Shop #: WSC 00011 888 96745
VCID: 4B951B402A640A194C-801E
Address 18: Aux. Heat Labels: 7L6-819-008.lbl
Part No: 7L6 815 071 G
Component: Standheizung E1MAC 0425
Coding: 0000000
VCID: 36635AB441E667F103-8062
Address 19: CAN Gateway Labels: 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 885 R
Component: J533 GW-K-CAN TP20 7520
Coding: 77EAE7CBCA056002
VCID: 70EFACAC630209C119-8024
Address 22: AWD Labels: None
Part No: 0AD 927 755 BG
Component: TRANSFERCASE 0126
VCID: 0109F9685BA81049E6-5140
Address 32: Differential Locks Labels: None
Part No: 0AC 927 771 D
Component: SG-Quersperre 5023
VCID: 3979518873F88889EE-5140
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 7L6 035 680 B HW: 7L6 035 680 A
Component: RNS-MID H04 1102
Revision: AB001001 Serial number: VWZ6Z7H9056135
Coding: 000100400100002200
Shop #: WSC 39713 123 79375
VCID: 316969A8688840C956-8064
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L6 959 933 A
Component: 4N HSG 0601
Coding: 0000069
Shop #: WSC 38550 001 1048576
VCID: 408F3C6C1022D941A9-4B00
Subsystem 1 - Part No: 7L0 959 701 N
Component: Tuersteuergeraet FS 6303
Subsystem 2 - Part No: 7L0 959 702 N
Component: Tuersteuergeraet BF 6302
Subsystem 3 - Part No: 7L6 959 703
Component: Tuersteuergeraet HL 0202
Subsystem 4 - Part No: 7L6 959 704
Component: Tuersteuergeraet HR 0202
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No SW: 7L6 035 456 C HW: 7L6 035 456 C
Component: 08K Audioverst. 0001
Revision: 00001000 Serial number: 00000000170951
VCID: 336563A0529472D924-8066
Address 55: Headlight Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 A HW: 7L6 907 357 A
Component: AFS-Steuergeraet 0001
Revision: H02 Serial number:
Coding: 1286275
Shop #: WSC 00136 935 101092
VCID: 3979518874F88889EE-806C
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Coding: 00000019
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Coding: 00000019
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L6 955 119 B
Component: J400__ Front Wiper 5301
Coding: 0001392
VCID: 3979518870F88889EE-806C
Component: RLS 141111 054 0403
Coding: 00209069
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 L HW: 7L0 907 383 L
Component: J345 Anhaenger 0080
Revision: 4A014001 Serial number: 00000109595999
Coding: 0000001
VCID: 3D71459860D0B4A9C2-8068
Address 6C: Back-up Cam.
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
Address 77: Telephone Labels: 3C0-035-730.lbl
Part No SW: 7L6 035 730 C HW: 7L6 035 730
Component: Telefon 1910
Revision: 00011000 Serial number: 0000000061562
Coding: 0020041
VCID: 2E5372D4B9B65F314B-807A
End-------------------------(Elapsed Time: 04:18)--------------------------
