Power and G-meter B9 S4
James Cole
Mexico
C?ID=310965
Hello Guys,
I was able to add the power and g-meter on my VC screen but they dont move at all... is there an extra step for them to get the right "feed"
Thanks!
JC
Monday,31,July,2017,16:37:26:60947
VCDS Version: 17.7.0.4 (x64)  HEX-V2 CB: 0.4401.4
Data version: 20170721 DS276.1
VIN: WAUAGCF47HA176851   License Plate:
Mileage: 1241km-771mi   Repair Order:
Chassis Type: F4-AU49 (4M1)
Scan: 01 02 03 08 09 15 16 17 19 29 36 39 42 44 46 47 52 5F 6C 74
          81 A5 A9 BB BC CA D6 D7
VIN: WAUAGCF47HA176851   Mileage: 1241km-771miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CWGD)       Labels: None
   Part No SW: 8W0 907 559 G    HW: 06M 907 309 D
   Component: 3.0l V6 TFSI  H21 0008
   Revision: B2H21000
   Coding: 0A2A00322326050B34180000000000000000000000000000
   Shop #: WSC 06324 790 00001
   ASAM Dataset: EV_ECM30TFS0118W0907559G 001011
   ROD: EV_ECM30TFS0118W0907559G.rod
   VCID: 49CC54D07937E37FC65-801C
17138 - Oxygen (Lambda) Sensor B1 S2; Heating Circuit
          P0141 00 [096] - Malfunction
                    Fault Frequency: 14
                    Mileage: 790 km
                    Date: 2017.07.18
                    Time: 19:42:54
                    Engine speed: 846.00 /min
                    Normed load value: 16.9 %
                    Coolant temperature: 89 ∞C
                    Intake air temperature: 32 ∞C
                    Ambient air pressure: 810 mbar
                    Voltage terminal 30: 12.400 V
                    Dynamic environmental data: 20 96
                    Heated oxygen sensor bank 1: sensor 1: resistance: 148.1 Ohm
                    Heated oxygen sensor bank 1: sensor 1: activation: 30.679 %
                    Outside air temperature via CAN: 3.0 ∞C
                    Oxygen sensor 1 bank 1 ceramic temp: 719.29 ∞C
Readiness: 1000 0000
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 8W0 927 158 B    HW: 0D5 927 156 H
   Component: 0D5  30TSIRdW H05 1006
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011_AU49.rod
   VCID: 41DC4CF041072B3F1E5-8014
   Part No SW: 8W0 907 379 G    HW: 8W0 907 379 J
   Component: ESP9 Plus     H06 0719
   Coding: 1CAA149930A90A9C11A64896007E5292E6A5C238280C508812004A4967A543
   ASAM Dataset: EV_ESP9BOSCHCMP 001001
   ROD: EV_ESP9BOSCHCMP_001.rod
   Part No SW: 8W0 820 043 S    HW: 8W0 820 043 S
   Component: Klima Zone 3  H55 0205
   Coding: 1608058C5544000D10020100880000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 43D046F85B1B392F0C9-8016
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J216 FLuftV  H08 0003
   Serial number: 00000000000001509997
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: CFA946A880PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 CF    HW: 8W0 907 063 BF
   Component: BCM1 MLBevo   H13 0267
   Coding: 07500143C13900CD050C5119182D0CFB130B31040000000000000000600016810A4502A322B606
   Shop #: WSC 06325 790 00001
   ROD: EV_BCM1BOSCHAU736_018.rod
   VCID: 015C8CF00187EB3F5E5-8054
   Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 170328  043 0813
   Serial number: 89435300301708704330
   Coding: 5BC7F7
   Serial number: 20403208X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 02 03 2017  00808179
   Serial number: GX1CE104021723611779
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 AB    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B00348083
   Subsystem 6 - Part No SW: 8W0 925 301 BF    HW: 8W0 925 301 BF
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2617000008009003
   Valve Block 1 In Driver Side Front Seat:
   Subsystem 7 - Part No SW: 8W0 907 182     HW: 8W0 907 182
   Component: J873 MKS_FSv  H03 0033
   Serial number: 7008174235B171225243
   Coding: BF0500
   Valve Block 1 In Passenger Side Front Seat:
   Subsystem 8 - Part No SW: 8W0 907 182     HW: 8W0 907 182
   Component: J872 MKS_BFSv  H03 0033
   Serial number: 7008174235B171226086
   Coding: B30500
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
   Component: Airbag10.44   H03 0106
   Serial number: 003UP004H3B7
   Coding: AACCF00000800000580000F3D04C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006015
   ROD: EV_AirbaAU10BPAAU736_006.rod
   VCID: 4CC26DC47645F657FD3-8018
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 8W0857705F0118R01490
   Coding: 88001B
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 8W0857706G0122R00438
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 061 104 17
   Serial number: 3577Y00C72246103225G
   Subsystem 4 - Part No SW: -----------    HW: 442 061 104 17
   Serial number: 3587Y00C722CA58173DA
   Subsystem 5 - Part No SW: -----------    HW: 442 0B2 004 17
   Serial number: 3517700A522BE29112FB
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 104 17
   Serial number: 3527700B125CC371E36F
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 104 17
   Serial number: 35575009F22BF6F490C$
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 442 0C2 104 17
   Serial number: 35675009F22BF6F1B11T
   Part No SW: 4M0 907 129 HA    HW: 4M0 907 129 HA
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 76B6EF2C5849DC877B7-8022
Address 17: Instruments (J285)       Labels:* 8W5-920-xxx-17.clb
   Part No SW: 8W5 920 790 C    HW: 8W5 920 790 C
   Component: FBenRDW       H17 0313
   Coding: 04AD59C8789000080523ED401800001000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   ROD: EV_DashBoardAU736.rod
   VCID: 42DE43FC4401302707F-8016
   Part No SW: 4M1 907 468 D    HW: 4M1 907 468 A
   Component: Gateway       H16 0108
   Revision: 4V020004    Serial number: 0444V030B17408
   Coding: 03010001000006405407000000590012EC900000100000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002040
   ROD: EV_GatewCONTIAU736_002.rod
   VCID: 382A211412DD6AF7A9B-806C
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20170425015302 20195
   Serial number: 0049413804
   Part No SW: 4M0 907 397 AD    HW: 4M0 907 397 D
   Component: LCM_MLBevoH05 0024
   VCID: 79ACE4106957B3FF165-802C
   Part No SW: 4M1 959 760     HW: 4M1 959 760
   Component: MEM-FS        008 0031
   Serial number: 00000254580988
   Coding: 00581B000000B0010000010101010000000000000000000000000000000000
   ROD: EV_SCMDriveSideCONTIAU736_AU37.rod
   Part No SW: 8W0 959 593 E    HW: 8W0 959 593
   Component: TSG FS        005 0057
   Serial number: 0000254009736
   Coding: 005D9A205E00008000001082
   Part No SW: 8W0 909 144 G    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0409
   Coding: 09888380008000
   ASAM Dataset: EV_EPSZFAU49X 003018
   ROD: EV_EPSZFAU49X_003.rod
   Part No SW: 8W0 907 064 CC    HW: 8W0 907 064 C
   Component: BCM2 MLBevo   018 0344
   Coding: 013400004F100000638D80002E00000033004000004B02502F0400000104803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012.rod
   VCID: 7F580A0877739DCF281-802A
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY170900FCU
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000069478807
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0904
   Serial number: >1084600
   Part No SW: 8W0 035 465     HW: 8W0 035 465
   Component: MIB2_amp_P_B9 H11 0420
   Revision: 00000001    Serial number: AUZ8ZAHJA01S9GD
   Coding: 0194010800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
0512 - Front Left Midrange Speaker
          B1060 13 [008] - Open Circuit
                    Reset counter: 101
                    Mileage: 1191 km
                    Voltage terminal 30: 12.6 V
0517 - Front Right Midrange Speaker
          B1063 13 [008] - Open Circuit
                    Reset counter: 101
                    Mileage: 1191 km
   Part No SW: 8W0 959 592 E    HW: 8W0 959 592
   Component: TSG BFS       005 0057
   Serial number: 0000254809767
   Coding: 005D9A205E00008000001080
   VCID: 4BC06ED8734BF16FF49-801E
   Part No SW: 8W5 035 893     HW: 8W5 035 893
   Component: MU-P-N-MX     033 0918
   Serial number: A797D0HB001192
   Coding: 019451020000000013220002041A00002F000AE401700104FE
   VCID: 55F488A0A58FB79F52D-8000
   Subsystem 1 - Part No SW: V03 959 801 GG    HW: -----------
   Component: NAR 2017  --- 0057
   Subsystem 2 - Part No SW: 8W1 919 605     HW: 8W1 919 605
   Component: DU High AU49x  H32 0160
   Serial number: TPO00118031700821118
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK128031700020537
Address 6C: Back-up Cam. (J772)       Labels:* None
   Component: RVC Compact   H12 0240
   Coding: 0294010102002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_VW53.rod
   VCID: 333016380BBB89AF9C9-8066
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 8W0 907 777 H    HW: 8W0 907 777 C
   Component: Fahrwerk-SG   H35 1214
   Serial number: 0505170476
   Coding: 1050484158
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426_VW53.rod
   Part No SW: 8W1 713 041 K    HW: 4M1 713 041 F
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20170418004996
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 3B203E1823EB41EF449-806E
   Part No SW: 8W0 907 217 C    HW: 8W0 907 217 C
   Component: BVS           H16 0050
   Coding: 0404090100000404022023A0CD00000080000020C280
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 3C223D0426E546D74D3-8068
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 8W0 907 159 E    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0007
   Serial number: 170408201436
   Part No SW: 8W0 959 595 E    HW: 8W0 959 595
   Component: TSG HFS       005 0057
   Serial number: 0000253976143
   Coding: 000D98200000008000001080
   VCID: 4EC667CC8059C447937-801A
   Component: TSG HBFS      005 0057
   Serial number: 0000253976092
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
Address CA: Sunroof (J245)       Labels:* None
   Part No SW: 4M0 907 594 A    HW: 4M0 907 594
   Component: SAD_STG_1     012 0003
   Coding: 608000049100
   ROD: EV_SunRoofCONTIAU736_004_VW37.rod
   VCID: 343215240EB58E97853-8060
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 7PP 941 571 BC    HW: 7PP 941 571 B
   ROD: EV_LEDModLeftMELCOAU736_AU49.rod
   VCID: 1768C2A87F03458F801-8042
Address D7: Light Ctrl Right 2 (A27)       Labels: None
End-------------------------(Elapsed Time: 02:02)--------------------------
hadez16
C?ID=289891
Nothing new to have them activated :)
But yet not known if it is possible somehow to get them moving...
phydaux
Australia
C?ID=93953
I think you need to add the sensor that the RS cars have for the gauges to work.
