Audi A4 2,0T FSI low oil pressure message flashing
Leadfoot
C?ID=94920
Hi just wondering if anyone has had problems with low oil pressure warning message lighting up when driving on this model. No particular set of circumstances cause the problem, one day owner can drive 100 miles without problem next day comes on after a mile. Does not stay on, maybe 5-10 seconds then turns off again. Engine rpm seems to have no influence on the problem.
I have tested with gauge and the pressure is within tolerances. I have changed the pressure sensor just as a precaution, no change. I'm 99% sure that it is not the blocked oil suction pipe problem that can occur with these engines as the oil pressure comes up instantly from start-up hot or cold. Suction pipe problem usually causes top end noise on start and a slow pressure build-up.
If I am understanding correctly the instrument panel does not respond to the sensor signal below 1500rpm and this checks out with vcds.
Thursday,14,August,2014,16:51:17:49214
VCDS Version: 12.12.2.0
Data version: 20140212
Dealer/Shop Name:
VIN: WAUZZZ8E25A473754   License Plate: WNO795-1
Mileage: 227440km-141324mi   Repair Order:
          67 69 75 76 77
VIN: WAUZZZ8E25A473754   Mileage: 227440km/141324miles
   Part No SW: 8E0 910 517 B    HW: 8E0 614 517 AT
   Component: ESP8 front      H04 0180
   Coding: 0004524
   Shop #: WSC 06325 000 00000
   VCID: 26480A869127332EC1B-8073
   Part No: 8E0 820 043 AK
   Component:   A4 Klimaautomat   2731
   Coding: 00000
   VCID: 6AD03EB616BFD74E253-5120
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  ECE 0304
   Coding: 10141
   Shop #: WSC 06325
   VCID: 3B7ECBF229A59EC68E5-4AE6
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H10 3230
   Revision: 91H10323    Serial number: 0036M0020785
   Coding: 0034622
   VCID: 3B7ECBF27AA59EC68E5-806E
   Subsystem 1 - Serial number: 6332DRB400BDC826Z
   Subsystem 2 - Serial number: 6342DRB400BD461DW
   Subsystem 3 - Serial number: 6352ARB400455B43E
   Subsystem 4 - Serial number: 6362ARB4004563045
   Subsystem 5 - Serial number: 63729RB400420000W
   Subsystem 6 - Serial number: 63829RB40041FCDE0
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0601
   Coding: 01022
   Shop #: WSC 06325
   VCID: 4182B91A4B49F416D49-4AE6
   Part No SW: 8E0 920 900 S    HW: 8E0 920 900 S
   Component: KOMBI+WFS 4     H12 0040
   Revision: 0040        Serial number: 00000000000000
   Coding: 0006141
   Shop #: WSC 40965 222 63542
   VCID: 346CE0CE54FB51BE4FF-5102
   Coding: 0006141
Regards
Colin
Gone But Not Forgotten
Yes sir that is it and the sludge which goes with it........
The whole basket with shafts and pump.
Also be sure to check the relief valve in pump and the oil filter control PSI valve housing.
Why is the engine controller missing from the scan?
DrPeter
16.4905° S, 151.7375° W
Just to add . . .
- Silly question, is the oil level and type correct, also OEM type filter? - just wanted to make sure... ;)
- So what were the readings? 1.2 to 1.6 bar is what the Factory Repair Manual says about the oil pressure switch activating when the engine starts and idles up...
and at 2,000 rpm, engine oil temp 80°C the pressure should read 2.7 to 4.5 bar.
- Have a look at the MVB group 001, field 3 in the 17-Instruruments, this is the result of the oil pressure switch, as seen by the controller.
- It is possible there is a wiring issue, from pressure switch to the cluster that could cause such a condition..
- Remember, this is a oil pressure switch, so it is off or on, it does not read varying pressure and it should switch at 1.4bar.
Hope this helps,
drpeter
