Volkswagen Up! TPMS fault - Won't calibrate?
racerfiftynine
C?ID=301708
Hello All, new to the forum and new to using VCDS.
We've got a 2015 Volkswagen Up! with TPMS fault.
Do the usual reset button, drive it 2-3 days and warning light comes on.
Scan as below:
Monday,31,July,2017,13:27:14:60494
VCDS Version: 17.8.0.1 HEX-NET CB: 0.4401.4
VIN: WVWZZZAAZFD074596 License Plate: NJ15 ZVY
Address 03: ABS Brakes Labels: 1S0-614-517.clb
Control Module Part Number: 1S0 614 517 F HW: 1S0 614 517 F
Component and/or Version: EBC 460 ESP H16 0022
Software Coding: 11BF247129B402F588FF24FE94AF40805F0100
Work Shop Code: WSC 31414 790 00001
ASAM Dataset: EV_Brake1ESPEBC460TRW 002004 (VW12)
ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
VCID: 3228C7AE65C32FD64C-8066
0460 - TPMS Display
C1146 F0 [009] - Not Available
Reset counter: 187
Mileage: 12704 km
Date: 2017.07.31
Time: 13:28:51
DTC: 00 01 CC
Any ideas? I thought they are not driving it for long enough to allow calibration to complete (old couple). I have just driven it 15 miles and given it back for them to try.
Otherwise, we have reset this fault code 3 times now and keeps coming back on.
South Molton, UK
Any ideas?
This TPMS is based on ABS wheel speed sensors, so have you checked that all 4 wheels/tyres are correctly inflated, are identical and have similar tyre tread depth?
simon oleary
C?ID=273239
I worked for Skoda around this time and I recall there being a software update on citigo model which is the same as the up unsure what was changed in the s/ware update
racerfiftynine
C?ID=301708
Checked tyre pressures each time and them reset system with button in car. Then cleared fault code with VCDS. Fault comes back approx 2-3 days later.
Car only done 8,000 miles. Still has original tyres on, all with good even, matched, tread.
I'll post full scan when I'm on the laptop (apologies)
I was thinking software, but getting any sense out of the dealer these days is impossible. Younger generation not interested in helping and getting past reception is a mission.
We had an UP! with poor radio reception. Common fault and car under warranty.
Had to wait 2 weeks for booking and they had car for 8 days to replace aerial cable and base.
Out of interested, scanned car with snap-on modis edge and code: C1146FO - tire pressure indicator, calibration incomplete.
Polofan
Denmark
C?ID=270984
On the Vw polo 2015 TPM is calibrated this way :
Drive Max 20 km/H Press reset, car gives gong Sound When calibrated.
?? Dont know if its the same procedure with Vw Up :-)
racerfiftynine
C?ID=301708
Hello All, thank you for your replies.
Just to clear up this thread. Since Resetting and driving the car 10 miles before returning to customer, there has been no problems or light issues.
So if you have a customer who only drives 1 mile each way to the shops, a couple of times a week. You may need to drive the car to calibrate it after resetting TPMS.
Keithuk
Stoke on Trent, England
C?ID=122432
On my Golf you if you change the tyre pressures or swap wheels. You turn the ignition on and press the SET button in the glovebox it beeps, no need to drive the car.
I thought later VW's didn't have a SET button for indirect TPMS you have to go to a dealer to have it re-calibrated. This is a totally stupid idea. Or use VCDS.
vagtuning
VCDS Super-User
C?ID=57100
Known Problem : TSB 2039142 - Update to Index L (SW 0023)
