No response from controlier
GJC
C?ID=53683
Hi everyone,here's the problem.
Plug Hex-Net into 2001 audi tt 1.8t
Lights are green led3 flashing.
Open VCDS 14.2 and click options.
Select net and click test.
Port Test Status ok,Interface found,type Hex-Net,shows my serial #,K1&K2 ok,Bat & Ign volts 12.5.
Click save.
Click select,click engine or any other controller.
After a few seconds Vcds:Init Controller opens and says No Response from controller.
I have tried three different car same thing. ( all cars work fine with cable VCDS)
What should i check next.
14.2... what's the next digit? Also, is your HEX-NET up-to-date?
GJC
C?ID=53683
How do I check for updates
14.2.1
GJC
C?ID=53683
Ok little more info.Everything is working fine when i use my Samsung Galaxy tab 3 using the same wireless connection
That indeed checks for updates to VCDS.
But to check for updates to VCDS-Mobile and the HEX-NET, you have to access VCDS-Mobile via a browser and click [Options] -> [Check for Updates] while the HEX-NET is in infrastructure mode and has access to the internet.
(posted for GJC's benefit, I'm confident Jake knows this)
Sounds like VCDS-Mobile is working, but VCDS isn't. We've seen a couple of instances of that. Seems to be a timeout that shouldn't... Hopefully we'll have a fix for that soon.
GJC
C?ID=53683
I have checked for updates and there are none needed.
Just tried it again on an 08 r32 and it worked!!!!Went back to try a 01 jetta no response again?,went back to
the R32 and now no response? VCDS cloud works great
We think we know what's causing this and we're working on it, but it may be next week before there's a fix.
