I had similar issue, following bbusato's adaptations. Another user here (I think downtime) suggested the following - which gave me maps in the .
Module 5F (Information Electr.) - ADAPTATIONS
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps; (make sure this is OFF; bbusato had this as adapting to ON, but with that setting, I had no maps in the ; changing it back to OFF gave me maps in the )
Greetings!
I finally pulled the trigger on purchasing the VW MK7 Active Info Virtual Cockpit retrofit kit (, black trim, wiring harness) from EuroZone Tuning for $1400 USD and had it installed at Bill Jacobs VW in Naperville, IL ($650) . . . I was getting the recall on my sunroof drains at the same time so I'm not sure how many hours it took the technician to install.
I hopped in the car and marveled at my $2k investment - I love it!!! It was only after I left the dealership that I realized I didn't have music on; I went to play some music and . . . nothing! No phone calls, no SD card, no Apple CarPlay. I brought it back and the technician spent some time going through stuff. He believed the fiber optic splitter cable was wired improperly so he swapped the In/Out around and everything worked! The only thing that he couldn't get was the Navigation to show in the cluster. I was heading out of town on a long trip so, although disappointing, I decided I could live with it. I love my GSW, especially now with the ! I no longer pine over getting a Volvo v60, mostly because there's none to be found in the US!
I've attempted to follow others in getting this to work but I receive the following error for
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps, under
Stored value: ERROR: Channel Not Available.
I'm not sure if its related but I did upgrade my to an 8" glass display.
Any insight would be much appreciated!
Here is my most-recent scan:
Wednesday,11,August,2021,14:41:19:06278
VCDS Version: 21.3.0.0 (x64) HEX-NET CB: 0.4543.4
VIN: 3VWC17AU4GM501532 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 47 52 55 5F
75 A5
VIN: 3VWC17AU4GM501532 Mileage: 92956km-57760miles
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 F HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0003
Revision: --H13---
Coding: 091A00322464002F1000
Shop #: WSC 00066 790 00221
ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
ROD: EV_ECM18TFS0208V0906264F.rod
VCID: 3FCE8369A6653A73FA-806A
Readiness: 0000 0100
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 749 AP HW: 09G 927 749 AP
Component: AISIN AG6 G3 129 2943
Coding: 010200000C000000000000000000000000000000
ASAM Dataset: EV_TCMAQ250031 002009
ROD: EV_TCMAQ250031_002_VW23.rod
VCID: 075E5B89BE35B2B382-8052
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 61255000000354
Coding: 04FA6AA12420096D007C020381C5292056249000408194B416435052C082
Shop #: WSC 01383 790 50316
VCID: 7AB8327DFDC7DF5B8D-802E
Revision: 00021000 Serial number: 0367374266
Coding: 030C0C
VCID: 3A38F27DBD471F5BCD-806E
Part No SW: 5GM 907 044 A HW: 5GM 907 044 A
Component: Climatronic H03 1001
Revision: 00001K01
Coding: 02020024200100000105000012111402
VCID: 42C88A9DD597579B95-8016
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 86581605150679
Coding: 00511B464041A2E969E44000001407001800000000000000000000000000
Shop #: WSC 12345 123 61029
ROD: EV_BCMBOSCH_015.rod
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150430 043 0581
Serial number: 150628095715
Component: RLHS 037 0059
Serial number: S5Y15M05D11H20M57S08
Coding: 90A8DD
Sunroof control module:
Subsystem 3 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST0009CPKU00000
Coding: 191800
Roof shade control module:
Subsystem 4 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST0009CQ2D00000
Coding: 191800
Humidity sensor: interior:
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39431513200575
Coding: 0031165011
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 47DE9B89FEB572B342-8012
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0400
Serial number: 13031503210237
Coding: 01045400FE0739
Shop #: WSC 00066 790 00211
ASAM Dataset: EV_ACCMRRBoschVW372 001016
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 009 0825
Serial number: 003GCR01Y1DL
Component: BF-Gewichtss. H11 0021
Serial number: IBH0000J1500031ZIL0K
Coding: 303137
Subsystem 2 - Part No SW: ----------- HW: 480 002 305 15
Serial number: 357000000000A560A418
Subsystem 3 - Part No SW: ----------- HW: 480 002 205 15
Serial number: 358000000000D0B06418
Subsystem 4 - Part No SW: ----------- HW: 480 402 704 15
Serial number: 3510002C91A91E714070
Subsystem 5 - Part No SW: ----------- HW: 480 402 804 15
Serial number: 35200029B1A87872711+
Subsystem 6 - Part No SW: ----------- HW: 480 400 505 15
Serial number: 3550002AF1A8787292DL
Subsystem 7 - Part No SW: ----------- HW: 480 400 505 15
Component: FrontSensor_P 001 6149
Serial number: 3560002B31A878729376
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150328500718
Coding: 0C10
ROD: EV_SMLSVALEOMQB.rod
VCID: 73A61F59DAADAE13CE-8026
Part No SW: 5G1 920 791 B HW: 5G1 920 791 B
Component: KOMBI 403 4191
Coding: 0BA4511AED98CF0502886A0B5400000000000000
VCID: 2B16C739421DB6D346-807E
U1110 00 [008] - -
[BAP_TEL_0x28 keine Kommunikation]
Reset counter: 134
Mileage: 92930 km
Date: 2021.08.10
Time: 11:47:35
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2223
Revision: -------- Serial number: 22051510000845
Coding: 0901000830085900FB00021A1C0F00000001050000000000000000000000
Shop #: WSC 00066 790 00194
ROD: EV_GatewConti_013.rod
VCID: 75A22141D4D9B023E0-8020
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 R HW: 5G0 959 442 R Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0040
Serial number: 29150000641010105136
Coding: 35FFFF
Inverter for electrical outlet:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0071941
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000127554002
Coding: 5D00000000000000
Shop #: WSC 00066 790 07025
ROD: EV_ELVMarquMQB.rod
VCID: 3424DC459F23E92B17-8060
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0368374670
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3C34F465B773216BDF-8068
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H11 0071
Serial number: 0368977758
Coding: 020111
Component: TSG FS 020 0041
Serial number: 0506150605043U
Coding: 003A13200000040000000000
VCID: 43C68F99CA8D5E939E-8016
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001360106
Coding: 011000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 1302
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0110
Revision: 00000001 Serial number: VWZ8Z1FBA00BE4Z
Coding: 2200000000AAAAAA000000000000
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 6D920921BC8978E318-8038
Component: TSG BFS 020 0041
Serial number: 170615060504TQ
Coding: 003A13200C00040000000000
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001369331
Coding: 091000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 061A00010B000400
VCID: 40CC8095DB9B458B83-8014
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Part No SW: 3Q0 035 876 HW: 3Q0 035 876
Component: MU-S-NS-US H25 0241
Serial number: VWZAZ2R0154122
Coding: 027302020000000051220002001808001F0100F401200105C6
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 71AA1551A0B19C033C-8024
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZHV0841226
Subsystem 2 - Part No SW: 3G0 919 866 B HW: -----------
Component: NAR 2015/16 --- 0220
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Coding: 02730202C2823A017F1E06000000
Shop #: WSC 00066 790 00323
ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000355732
Coding: 0100010000020306000400010100000100
ROD: EV_MFKBoschAU370.rod
End----------(Elapsed Time: 01:52, VBatt start/end: 13.6V/13.5V)-----------
