Retrofitting Active Info Display in Golf 7
   #81
kamold
Australia
C?ID=241363
So if there's a car in front of you, does the car display on the AID move in relation to the distance?
Mine just shows whether there's a car there or not - it doesn't move forwards and back as it's supposed to.
Has anyone found a solution for this issue?
   #82
IWMTom
C?ID=313572
There isn't one. For the ACC to display correctly, you need a newer ACC radar, but they have different SWaP/FeC codes. Without finding someone to hack the radar, it can't be done.
   #83
kamold
Australia
C?ID=241363
OK cool good to know thanks. Yes this car has older 5Q0 radar.
If it's an issue can look into 3q0 or 3qf radars
   #84
Johan1
C?ID=359010
5G1 920 891 A is for the NA spec Golf R. You want this one: 5G1 920 791 A. Bezel is 5G0 857 189 B AAH.
5G1 920 791 is for the regular Golf/Variant/Alltrack. I posted a write-up on how I retrofitted one onto my NA spec 2017 Golf Alltrack if it's of any help:
https://forums.ross-tech.com/showth...t-Guide-for-Golf-Alltrack&p=136017#post136017
ok guys i have a situation over here
i retrofit a 7,5 golf with a MIB2 Harman and a digital cluster PN(5G1920791B)
i did the online coding for the cluster all ok
i did remove the CP from harman online all ok
i diddo the hack for the harman to activate maps all ok
MOST cable is connected stright from MIB to cluster....(dont have AMP) so no Y cable but stright cable with 2 connectors
did follow all the coding of theVWVortex All ok only one Problem.....guess what?
No Maps on AID. dont get Navi Option on AID by View tab
Apreciate any help guys
   #85
Nuje
Canada
C?ID=120875
I had similar issue, following bbusato's adaptations. Another user here (I think downtime) suggested the following - which gave me maps in the AID.
Module 5F (Information Electr.) - ADAPTATIONS
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps; (make sure this is OFF; bbusato had this as adapting to ON, but with that setting, I had no maps in the AID; changing it back to OFF gave me maps in the AID)
   #86
Johan1
C?ID=359010
Ok mate i will give it a try thanks for the point and i will return with result
   #87
Johan1
C?ID=359010
do i have to enable navi on instrument 17 or in cangateway ????.................i didint did yet .....car originaly never had navi....
   #88
Johan1
C?ID=359010
this was my problem thanks to Nuje and all the comunity Great work guys!!!
   #89
braescuteo
Romania
C?ID=367488
Hello guys, I retroffited AID on my passat b8 2015.
Updated CAN to latest version with (AM). Updated ACC radar to latest version 3Q0 907 561 E.
But still.. the picture of the car moving in AID is stucked behind. What could be the problem? Can it be the camera that is still old in my windshield?
   #90
IWMTom
C?ID=313572
Only newer MRREvo radars support displaying to AID, which require different SWaP codes to your MRRPlus radar.
   #91
braescuteo
Romania
C?ID=367488
@IWMTom , my radar now is 3Q0 907 561 E, H05 01S 0196, MRRevo14F made in 14.09.19 so it's pretty new. So it's only about a SWaP code that I don't have?
   #92
kamold
Australia
C?ID=241363
I believe there is a coding option in 13 radar for 'FPW' however I don't think this is in the label file. And I don't have a suitable car to check. Maybe someone else can confirm/deny this?
   #93
IWMTom
C?ID=313572
How exactly have you installed the radar despite the SWaP code difference?
   #94
braescuteo
Romania
C?ID=367488
My initial radar was 3Q0 907 561 B, H04 03S 0130, MRRevo14F made in 29.04.15. So I looked on ETKA, see what is compatible and bought the latest one. Coded online with ODIS - it saw exactly what my car has from the factory and everything was set up pretty fast.
   #95
braescuteo
Romania
C?ID=367488
@kamold , after I saw your post I asked a colleague who had ACC and AID from factory to send the coding to me. I tried it and it works! Everything is ok now. So there is a coding in ACC for AID. I don't know which bit exactly but I will write the coding here for anyone who needs it in the future: Coding: 320467D25DFFC728949C8045 .
Thank you guys!
