Retrofitting Active Info Display in Golf 7
   #41
bbusato
Phoenix, AZ
C?ID=290995
I’m planning on doing this retrofit in my MK7 Golf R and now have most of the parts. However the part numbers on the Active Info Displays have me confused. Is anyone able to help explain the difference between 5G1 920 891 and 5G1 920 891 A? Thanks!!
5G1 920 891 A is for the NA spec Golf R. You want this one: 5G1 920 791 A. Bezel is 5G0 857 189 B AAH.
5G1 920 791 is for the regular Golf/Variant/Alltrack. I posted a write-up on how I retrofitted one onto my NA spec 2017 Golf Alltrack if it's of any help:
https://forums.ross-tech.com/showth...t-Guide-for-Golf-Alltrack&p=136017#post136017
   #42
deutsch
C?ID=68604
i have just retrofit the active info display / virtual cockpit to a 1.6tdi golf 7, now all seems ok but i have one small fault, i get "Error: range calculation" warning on the display when i start the car. the cluster came from a golf a petrol i think. as this has been mentioned on other retrofits has anyone found a fix yet??
regards
   #43
DakotaUwe
C?ID=312050
hey folks,
whats 5G1 920 790 for ?
   #45
Blade3562
C?ID=310127
virtual cluster but not supporting map display
Edit: After a little looking the 5G1920891A is much easier to source, but I'm curious what the advantage of the 790 unit is.
kamold
Australia
C?ID=241363
regards
I think this is because the CANbus gateway software is too old. What is the PN and software version of your gateway?
   #49
Spacewalker
Poland
C?ID=159607
no, I also swap to Virtual cluster in my 2014 Golf 1.4 TFSI and keep factory gateway
   #50
kamold
Australia
C?ID=241363
I saw this last week in a Golf R. Had the same error on startup after retrofitting MIB2.5 and Active Info - range calculation error.
Upgraded the GW software to rev AJ 1244 and the fault was gone.
It was previously rev Q sw 1164.
   #51
Spacewalker
Poland
C?ID=159607
this is my factory GW
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 F
Component: GW MQB High 128 1204
Revision: -------- Serial number: 0002818375
Coding: 030100042F085700EF000048080F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011020
ROD: EV_GatewLear.rod
VCID: 72E1D85BA5CEFAD37D-8026
   #52
kamold
Australia
C?ID=241363
Ok cool so it already had newer software than what was on this one:
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001387300
Coding: 030100042B085900EF00027E9C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010_VW37.rod
Seems like maybe yours has the minimum required software to properly support AID.
   #53
offpist
Norway
C?ID=321041
Does my Gateway have the required SW?
Control Module Part Number: 5QE 907 530 B
  Component and/or Version: GW MQB EV     312 3186
           Software Coding: 0201001746F81000EF001210081E00000001050100030000000000000000
            Work Shop Code: WSC 01357
                      VCID: 45D7AFDB1527912F022-8010
Advanced Identification/FAZIT
     Serial number: 09071410800025
     Identification: SJ8-FST
     Revision: --------
     Date: 09.07.14
     Manufacturer number: 1080
     Test stand number: 0025
Flash Status
     Programming Attempts(application): 0/0
     Programming Attempts(data): 1
     Successful Attempts(data): 1
     Flash Date: 00.00.00
     Flash Tool Code(data): 00200 011 01357
Misc.
     Hardware number: 5QE 907 530 A
     Workshop System Name: J533
     Equipment/PR Code: FFFFFFFFFFFFFFFF
     Dataset Number: 5GE067v____
     Dataset Version: 1815
     ASAM Dataset: EV_GatewEVConti
     ASAM Dataset Revision: 011017
BTW I test fitted an Active info display in my golf, and then put back the original display.
And now i see that was not so smart, as now i get all kinds of error messages from brake controller and light controller .
The display now has error:
                Address 17: Instruments       Labels: NONE-SRI3
Control Module Part Number: 5GE 920 755     HW: 5GE 920 755
  Component and/or Version: KOMBI         301 4280
           Software Coding: 072518182F900008008868011600000000000000
            Work Shop Code: WSC 01357 011 00200
              ASAM Dataset: EV_DashBoardVDDMQBAB 009037 (VW37)
                      VCID: 7DA7073B3D7719EF1A2-8028
16776967 - Databus
          [EPB_02 keine Kommunikation]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 20:15:08
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 20:15:08
Brake:
11 Faults Found:
0195 - Control module not coded
          U1013 00 [175] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Mileage: 5878 km
                    Date: 2018.09.03
                    Time: 00:00:02
          C1017 54 [175] - Missing Calibration / Basic Setting
                    Mileage: 5878 km
                    Date: 2018.09.03
                    Time: 00:00:02
          C1079 54 [175] - Missing Calibration / Basic Setting
                    Mileage: 5878 km
                    Date: 2018.09.03
                    Time: 00:00:02
0279 - Brake Pressure Sensor 1
          C107A 54 [175] - Missing Calibration / Basic Setting
                    Mileage: 5878 km
                    Date: 2018.09.03
                    Time: 00:00:02
0295 - Steering angle sensor
          B1168 54 [175] - Missing Calibration / Basic Setting
                    Mileage: 5878 km
                    Date: 2018.09.03
                    Time: 00:00:02
4163 - Control module not coded
          U1013 00 [096] - -
          [Vin_mismatch]
                    Mileage: 5878 km
                    Date: 2018.09.03
                    Time: 00:00:02
8290 - Coding Not Possible
          U10BC 00 [175] - -
          [FCAN: Unplausible VIN number]
                    Mileage: 91988 km
                    Date: 2018.10.12
                    Time: 14:37:04
8306 - Databus
          U1122 00 [175] - Implausible Message
                    Mileage: 91988 km
                    Date: 2018.10.12
                    Time: 14:37:04
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [047] - -
          [FCAN: Coding of ESP and TSK does not fit together]
                    Mileage: 91988 km
                    Date: 2018.10.12
                    Time: 14:37:01
16401 - Tire Pressure Warning
          C102D 00 [108] -  -
                    Mileage: 91776 km
                    Date: 2018.10.09
                    Time: 18:47:39
32848 - Control Module for Electric Parking Brake
          C10E2 F1 [175] - Switches/Motors Detected
                    Mileage: 5878 km
                    Date: 2018.09.03
                    Time: 00:00:02
I will have to get the new display programmed in at an VW dealer but that may take some days to get an appointment..
Is there any way to quickly get the different control units back to normal function?
MasterTommy
Amsterdam
C?ID=295586
Please post a complete autoscan.
   #55
offpist
Norway
C?ID=321041
Here you go:
Friday,12,October,2018,21:29:41:26480
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4417.4
Data version: 20180518 DS287.2
VIN: WVWZZZAUZFW901533   License Plate:
Chassis Type: AU-VW37 (5QE)
Scan: 01 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 47 51 52 55 5F
          75 8C BD C6
VIN: WVWZZZAUZFW901533   Mileage: 91992km-57161miles
51-Electric Drive -- Status: Malfunction 0010
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
Address 01: Engine (J623-EAGA)       Labels:. 0EA-907-309-V1.clb
   Part No SW: 0EA 906 016 A    HW: 0EA 907 309 A
   Component: E-Vehicle     H22 8343
   Revision: WMH22---
   Coding: 000D0012006404003000
   Shop #: WSC 51729 001 1048576
   ASAM Dataset: EV_VCU00XXX0110EA906016A 002015
   ROD: EV_VCU00XXX0110EA906016A_002.rod
   VCID: 2D07F77BAD97496FEA2-8078
24175 - Please Check Fault Codes in Control Module for ESP
          U102C 00 [039] - -
          [ESPRead out DTC]
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:34
                    Engine speed: 16383.75 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Voltage terminal 30: 14.559 V
          U0428 00 [039] - -
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:32
                    Voltage terminal 30: 14.536 V
4716 - No Communications with Parking Brake Control Module
          U0128 00 [039] - -
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:31
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 907 379 N    HW: 5Q0 907 379 H
   Component: ESC           H31 0807
   Revision: 00000000    Serial number: 61954000000541
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
   ROD: EV_Brake1UDSContiMK100OMG_001_VW37.rod
   VCID: 47CBA5D32F2B833FF0E-8012
10 Faults Found:
          U1013 00 [167] - -
                    Date: 2018.10.12
                    Time: 21:26:33
          C1017 54 [167] - Missing Calibration / Basic Setting
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:31
          C1079 54 [167] - Missing Calibration / Basic Setting
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:31
          C107A 54 [167] - Missing Calibration / Basic Setting
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:31
          B1168 54 [167] - Missing Calibration / Basic Setting
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:31
          U10BC 00 [167] - -
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:31
8306 - Databus
          U1122 00 [167] - Implausible Message
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:31
          P1647 00 [047] - -
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:31
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:33
33000 - Longitudinal Acceleration
          C10B1 29 [047] - Signal Implausible
          [IPB-Sensor: Longitudinal acceleration sensor failure]
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:33
   Revision: 00021000    Serial number: 0341198814
   Coding: 030C0C
   VCID: 3A2DCC276CD9EED77F0-806E
   Part No SW: 5GE 907 044 S    HW: 5GE 907 044 S
   Component: Climatronic   H02 1101
   Revision: 00001K07
   Coding: 00022200200100010005000200101000
   ASAM Dataset: EV_ACClimaBHBVW37X 003022
   VCID: 4CC19AFF364D6067DDC-8018
   Subsystem 3 - Part No SW: 12E 963 231 E    HW: 12E 963 231 E
   Component: J848 HV-PTC  H09 0205
   Serial number:  T141913003805000080
   Air quality sensor:
   Air Conditioning Compressor Sub:
   Subsystem 5 - Part No: 12E 820 803 E
H01
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011419901942
   Coding: 00051A66C34102F36BE44000001407201800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 00597ECF4A857407714-8054
   Component: WWS    140711  043 0551
   Serial number:         140715202043
   Component: RLHS  037 0059
   Serial number: S4Y14M07D23H17M41S53
   Coding: 00A8DD
   Part No SW: 5Q0 919 298 F    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0047
   Revision: --------    Serial number: 39431419800012
   Coding: 2031161011
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003_VW37.rod
   VCID: 42DDB4C70409A617270-8016
12658704 - Databus
          [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:29
13697024 - Control Module
          U110F 00 [009] - I'm sorry Dave; I'm afraid I can't do that!
          [Steuergerät für Bremse - ESP_02.ESP_Status_ESP_PLA - PLA-Codierung in Bremse prüfen]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:29
13637426 - Databus
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:29
   Part No SW: 5Q0 907 572 K    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0402
   Serial number: 19071476510229
   Coding: 001C2300FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3FDBBD3377FBCBFF48E-806A
1071 - Databus
          [FAULT_CIS_AXV_INVALID]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:30
                    Control Module temperature: 22 °C
                    Voltage terminal 15: 14.6 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:30
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:30
1078 - Databus
          [FAULT_CIS_SAS_INIT]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:30
0261 - Databus
          [FAULT_CIM_TIMEOUT_EPB_01]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:30
1043 - Automatic Distance Control
          B10E7 F0 [009] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:30
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    009 0870
   Serial number: 003MFR003E42
   Coding: 98FCC0C0002000005C5400CF004800000065
   VCID: 50F98E8FDA654487A14-8004
   Belt Pretensioner left:
   Serial number: 34169667B18071470211
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169668B22071440835
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 107 14
   Serial number: 35700000000290C0B017
   Subsystem 4 - Part No SW: -----------    HW: 480 001 807 14
   Serial number: 3580000000042A7C0019
   Subsystem 5 - Part No SW: -----------    HW: 480 401 707 14
   Serial number: 3510002AF15F3C34D0AG
   Subsystem 6 - Part No SW: -----------    HW: 480 401 707 14
   Serial number: 3520002BF15F3C310282
   Subsystem 7 - Part No SW: -----------    HW: 480 401 707 14
   Serial number: 3550002B915F3C33F208
          B13BC F2 [137] - No function
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:29
1049093 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Querbeschleunigung]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:29
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:29
1049094 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:29
1049095 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Gierrate]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:29
   Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 24071408491097
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 7BA30923236317DF246-802E
   Part No SW: 5GE 920 755     HW: 5GE 920 755
   Component: KOMBI         301 4280
16776967 - Databus
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:29
16776973 - Databus
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:29
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 5QE 907 530 B    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3186
   Revision: --------    Serial number: 09071410800025
   ASAM Dataset: EV_GatewEVConti 011017
   ROD: EV_GatewEVConti_011.rod
   Subsystem 1 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0038
   Serial number: 27140001774830054294
   Coding: 2CFFFF
   Subsystem 2 - Part No SW: 5GE 915 181     HW: 5GE 915 181
   Component: J367-BDMHella  H03 8050
   Serial number: 5063663003
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 A    HW: 5QE 909 059 A
   Component: EBKV          H12 0160
   Serial number:   085430010022
   Coding: 01720100321900030002000500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 002014
   ROD: EV_BrakeBoostBoschMQBOMG_002_VW37.rod
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 A    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0140
   Serial number: 05802861100714065147
163584 - No Communications with Parking Brake Control Module
          U0128 00 [047] - -
          [iBoVAG_ComScl_EPB_01_Timeout]
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:32
   Revision: 00000000    Serial number: 14000187914004
   Coding: 7900000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431E21F4EBD18A7A5C-8060
   Serial number: 13071403110632
   Coding: 00311320D000048000001000
   VCID: 40D9BECF0A05B407314-8014
   Serial number: 00000000000003346201
   Component: EPS_MQB_ZFLS  123 1043
   Coding: C302
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DFBBCB010FBD0F3EA-8014
15873 - Steering angle sensor
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:29
                    Motor status: 00
                    System status: Driving mode
                    Supply voltage: 14.50 V
                    Temperature: 24.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 14.52 V
                    uAdSensI_SwitchedKl30_xdu16: 14.51 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:29
                    Motor status: 00
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 7F
                    uioUdNotFilt_xdu16: 14.67 V
                    uAdSensI_SwitchedKl30_xdu16: 14.68 V
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0060
   Serial number: VWZ8Z1EC401FJ4$
   Coding: 120000008AAA8A0000
   ASAM Dataset: EV_AMPMst12C1ALPI 001005
   ROD: EV_AMPMst12C1ALPI.rod
   VCID: 63935143BBD3CF1F0C6-8036
   Part No SW: 5QE 907 080 C    HW: 5QE 907 080 B
   Component: VW370E2615010 H05 2461
   Revision: 00H05000
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM09550115QE907080C 001020
   ROD: EV_DMCM09550115QE907080C.rod
   VCID: 46D5A8D728219A370B8-8012
27161 - No Communication with ESP (Vehicle Dynamics) Control Module
          U0122 00 [039] - -
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:31
                    Voltage terminal 30: 14.550 V
                    Drive control condition: Standby
                    Drive control condition-Test_Program_Enum ACI st Drv Ctrl UBYTE: 3
   Serial number: 11071406071419
   Coding: 00311120DE00048000001000
   Serial number: 00000000000003324042
   Coding: 190000
   Coding: 051A000001010000
   Shop #: WSC 37781 001 1048576
   VCID: 75B71F1B054741AF522-8020
13705992 - Databus
          [LWI_01: Fehlerwert im Signal LWI_Lenkradwinkel]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:30
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
   Part No SW: 5G0 035 020 D    HW: 5G0 035 020 D
   Component: MU-H-ND-EU    H43 0362
   Serial number: A310G0EB003812
   Coding: 027370010000000011111202000800001F0105B401000100D7
   ASAM Dataset: EV_MUHig6C3HBAS 001041
   ROD: EV_MUHig6C3HBAS_VW37.rod
   VCID: 1A6D2CA7CC19CED79F0-804E
   Component: ABT_High  H60 0030
   Serial number: VWZ8Z9PS1007T3
   Subsystem 2 - Part No SW: V03 959 801 BG    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Compact Disc Database:
   Component: Gracenote  --- 1010
          U1111 00 [009] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:35
                    Voltage terminal 30: 14.8 V
                    BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 102
                    Mileage: 91992 km
                    Date: 2018.10.12
                    Time: 21:26:35
   Part No SW: 5QE 035 284     HW: 5QE 035 284
   Component: OCULowMQBEU   007 0535
   Coding: 0273700110829A01007800000000
   ROD: EV_OCULowMQB.rod
   VCID: 015F7BCB418F7D0F7EA-8054
Address 8C: Hybrid Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 5QE 915 227 M    HW: 5QE 915 227 H
   Component: K8C           H13 0731
   Serial number: VWADEGU005
   ASAM Dataset: EV_BECM08820215QE915227M 003016
   ROD: EV_BECM08820215QE915227H.rod
   VCID: 52FD8487D4693697970-8006
Address BD: Hi Volt. Batt. Charg. (J966)       Labels:| 5QE-915-022-V1.clb
   Part No SW: 5QE 915 022 G    HW: 12E 915 022 C
   Component: LMSG          H08 1075
   Serial number: 00920042830331
   Coding: CA0903
   ASAM Dataset: EV_HVChargManagVWMQB 001001
   ROD: EV_HVChargManagVWMQB_001.rod
Address C6: Batt. Chrg. (JAX4)       Labels: 5QE-915-681.clb
   Part No SW: 12E 915 682 G    HW: 12E 915 682 G
   Component: OBC KOSTAL    H42 0142
   Revision: --------    Serial number: 1807140GH000CL
   ASAM Dataset: EV_OBCSinglPhaseKLOVW3707 002001
   ROD: EV_OBCSinglPhaseKLOVW3707_002.rod
   VCID: 2E05F077A0913277D38-807A
End----------(Elapsed Time: 02:25, VBatt start/end: 14.6V/14.7V)-----------
offpist
Norway
C?ID=321041
Nobody has any clue how to solve this?
Any help would be appreciated.
I have an appointment at the dealer but that is over 4 weeks from now.
   #57
Spacewalker
Poland
C?ID=159607
Your ABS loct coding and calibration due to new VIN recognize (new cluster)
this is typical as ABS have in coding part of VIN number
If you have Autoscan backup from past, you can easy restore coding and then do a adaptation sensors what need
if you not have any backup, scan, only dealer can code this
as far as I know there is no long coding helper for Mk100
   #58
offpist
Norway
C?ID=321041
Thanks for the help.
Yes I do have an autoscan backup from the past.
Like the coding for ABS was previously: 01FA40A12C20316D037C060341C6298002348CC0608294B3F881507AC242
I will try to redo coding tonight.
   #59
Spacewalker
Poland
C?ID=159607
yep,
CODE abs first
then do sensor calibrations
Chrisfz
South Africa
C?ID=329808
Hi does your car have kessy.
ive got a cluster with 458kms on but i cant get into vcds due to the ignition stays off due to car not picking up the car ?
retrofitted the virtual cluster but cant get the car on to code it in .
and idea why?
Tuesday,23,October,2018,17:30:06:40674
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
Dealer/Shop Name: Retrofitters Kzn
VIN: WVWZZZAUZEW154658 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 20 2B 42 44 52 55 5F A9
VIN: WVWZZZAUZEW154658 Mileage: 172506km-107190miles
Address 01: Engine (J623-CHHB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0007
Revision: --H13---
Coding: 091D00324424050B3000
ASAM Dataset: EV_ECM20TFS0215G0906259 001011
ROD: EV_ECM20TFS0215G0906259_VW37.rod
VCID: 6B823067E30C1E7F5B7-803E
17178 - Databus
U1123 00 [039] - Received Error Message
Mileage: 172506 km
Date: 2018.10.23
Time: 00:04:32
Engine speed: 0.00 /min
Coolant temperature: 110 °C
Intake air temperature: 57 °C
Ambient air pressure: 840 mbar
Voltage terminal 30: 12.324 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-ESP system error: No
Readiness: 1010 0001
Part No SW: 0D9 300 040 L HW: 02E 927 770 AN
Component: DQ250-6F MQB H52 4025
Revision: 05652104 Serial number: TFK01309201983
ROD: EV_TCMDQ250021.rod
VCID: 2018174B5A4A0D27BE5-8074
P1734 00 [002] - -
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 6264300000053C
Coding: 01FA93A134252970037D0605C1CBA980C92C94C0608395F700 4250BAC109
Shop #: WSC 47649 001 1048576
VCID: 7BA20027936C8EFFCB7-802E
8299 - Databus
[FCAN: Anhaenger_01_alt veraltet bit is set]
Reset counter: 70
Date: 2018.10.23
Time: 00:04:33
Revision: 00021000 Serial number: 0194515140
Coding: 030C0C
VCID: 3A2CC523DCD677F7901-806E
Part No SW: 5G0 907 044 AA HW: 5G0 907 044 AA
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 00120014200100001005000012101800
VCID: 66944153F8EE2317049-8032
Air quality sensor:
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011328201012
Coding: 03111B46C24122FB0BA44080B10C0728180A00000000000000 0000000000
ROD: EV_BCMBOSCH_011.rod
VCID: 77AA1C17AF44AA9FAFF-8022
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130915 042 0551
Serial number: 130926083906
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M10D09H08M13S21S1
Coding: 00A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1324116QY
Serial number: 00000000000027889966
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.013 H02 0007
Serial number: WOO24389415
Coding: 181801
Part No SW: 5Q0 919 298 A HW: 5Q0 919 298
Component: PARKHILFE PLA 011 0029
Revision: -------- Serial number: 61131325501051
Coding: 0131061051
ASAM Dataset: EV_EPHVA2CAU3700000 003014
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 3D26CE3FCDF840CFB53-8068
13637426 - Databus
Reset counter: 110
Mileage: 172506 km
Date: 2018.10.23
Time: 00:04:32
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 HW: 5Q0 907 376
Component: DAEMPFUNGS-SG H15 0115
Serial number: 09091341356708
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 76B41113A84ED397B49-8022
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R01908Q
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 41DEB2CFB100242FD1B-8014
Subsystem 1 - Part No SW: ----------- HW: 480 001 909 13
Serial number: 357670000003C649CD01
Subsystem 2 - Part No SW: ----------- HW: 480 001 909 13
Serial number: 3586700000002A2CFD0/
Subsystem 3 - Part No SW: ----------- HW: 480 400 910 13
Serial number: 3516502B71171FE170FG
Subsystem 4 - Part No SW: ----------- HW: 480 400 910 13
Serial number: 3526502C51171FE51087
Subsystem 5 - Part No SW: ----------- HW: 480 400 110 13
Serial number: 3556502BD1171FE2B20I
Part No SW: 5Q0 953 507 BK HW: 5Q0 953 549
Revision: -------- Serial number: 04101304220218
Coding: 0400
ROD: EV_SMLSKLOMQB_012_AU37.rod
VCID: 005877CBFA8AED279E5-8054
Part No SW: 5G6 920 870 HW: 5G6 920 870
Component: KOMBI 314 2210
Coding: 27AD09183B90000800082A00040000
VCID: 6C80337BE602194752D-8038
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0001103306
Coding: 030100042B085900EF00026A9C0F0001000100000000000000 0000000000
ROD: EV_GatewLear_009.rod
VCID: 3B22C027D3EC4EFF8B7-806E
Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H06 0101
Serial number: 27130001506550063384
Coding: 29FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 2093481403
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511 D
Component: FLA H05 0002
Revision: AA001001
Coding: 02028864727264565625393E01
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 2B02F067238CDE7F1B7-807E
Part No SW: 5Q0 905 861 HW: 5Q0 905 861
Component: ELV-MQBA H06 0010
Revision: 00000000 Serial number: 13000219904002
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMQB 003008
ROD: EV_ELVMarquMQB_003.rod
VCID: 73B22807BB3CC6BF937-8026
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 21091304080223
Coding: 003E12208001040000001000
VCID: 3FDAB437C7F452DFA7F-806A
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000002842756
Coding: 0D0000
Part No SW: 3Q0 909 144 D HW: 3Q0 909 144 E
Component: EPS_MQB_ZFLS 502 5011
Coding: 8301
ASAM Dataset: EV_SteerAssisMQB 009026
ROD: EV_SteerAssisMQB_009_VW37.rod
VCID: 3332E807FBBC86BF537-8066
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 07101303110325
Coding: 003E10208E01040000801000
VCID: 3E24C933C0FE5BD7AC9-806A
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000002880350
Coding: 050000
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 029603000B000200
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 819 A HW: 5G0 035 819 A
Component: MU-S--ER 040 0421
Serial number: V1C00610131815
Coding: 02730000FF00000011110001000900001F0203860100010001
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 270A0C573F64FA1FFFF-8072
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H51 0022
Serial number: VWZ8Z9NJ7021US
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0011
Serial number: 130918202216
End----------(Elapsed Time: 01:36, VBatt start/end: 12.4V/12.4V)-----------
