I had changed the module of parking brake , and the code of abs had been changed , so i want the code , i have tried abs code of 0046469 and it is not worked , could you tell me the abs code
Wednesday,26,July,2017,07:05:09:43156
VCDS Version: 16.8.4.2
Dealer/Shop Name: Harisa car service
VIN: WVWZZZ3CZ7P094709 License Plate:
Mileage: 63760km-39618mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ7P094709 Mileage: 63760km-39618miles
53-Parking Brake -- Status: Malfunction 1010
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 EC
Component: SIMOS72 1.6l 2VG 9601
Revision: --H03--- Serial number: VWZCZ000000000
Coding: 0000071
Shop #: WSC 00028 028 00001
VCID: 64C34B42A7F32B624D-8030
28793 - No Communication with ABS Brake Control Module
U0121 - 009 - - Intermittent
RPM: 992 /min
Mass Air / Rev.: 163.5 mg/str
Bin. Bits: 00000100
Hex Value: 0x0000
Mass Air / Rev.: 0.0 mg/str
Bin. Bits: 00000001
Hex Value: 0x0000
28800 - No Communications with Parking Brake Control Module
U0128 - 009 - - Intermittent
RPM: 992 /min
Bin. Bits: 00000100
Hex Value: 0x0000
Bin. Bits: 00000001
Hex Value: 0x0000
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Bin. Bits: 00000000
Bin. Bits: 00000000
Readiness: 0010 0001
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 109 HW: 3C0 614 109
Component: ESP 440 C4 H018 0001
Revision: H018 Serial number: 0668155317
Coding: 0001922
VCID: 5BB170BE9A8D149AFC-800E
7 Faults Found:
Mileage: 63766 km
Time: 20:29:18
Mileage: 63766 km
Time: 20:29:18
Mileage: 63766 km
Time: 20:29:18
Mileage: 63766 km
Time: 20:29:18
Mileage: 63766 km
Time: 20:29:18
Mileage: 63766 km
Time: 20:29:18
Mileage: 63766 km
Time: 20:29:18
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AF HW: 3C0 907 044 AF
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
VCID: 65C55646ACC9526A5A-8030
01316 - ABS Control Module
Reset counter: 101
Mileage: 63766 km
Time: 16:29:59
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 H HW: 3C0 937 049 H
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000004499281
Coding: 00840F0700041A00000A00000F000000000959435C0000
VCID: 2E57E96AB9BFD1326B-807A
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 140906 003 0205
Coding: 00046997
Shop #: WSC 00028
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 0B AIRBAG VW8 031 2522
Revision: 11031000 Serial number: 003B1PNMX4D6
Coding: 0012354
VCID: 306BF712A38BC7C279-8064
Subsystem 1 - Serial number: 6332MSME14453608
Subsystem 2 - Serial number: 6342MSME14474F54
Subsystem 3 - Serial number: 6351HTS66HB07R07
Subsystem 4 - Serial number: 6361HTS66HBKU2C6
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 J HW: 3C0 953 549 J
Component: Lenksäulenmodul 006 0010
Revision: 00006000 Serial number: 3C5953507AB
Coding: 0000011
VCID: 3361F81E529DFCDA04-8066
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 852 G HW: 3C0 920 852 G
Component: KOMBIINSTRUMENT VD1 1614
Revision: V0007000 Serial number: 00000000000000
Coding: 0006105
Shop #: WSC 36000 360 21868
VCID: 27591C4E9645807AA8-8072
Reset counter: 89
Fault Frequency: 53
Reset counter: 101
Mileage: 63443 km
Time: 01:50:22
Fault Frequency: 53
Reset counter: 101
Mileage: 63443 km
Time: 01:50:22
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C06A310316
Coding: 3DFD0C04C21002
VCID: 214D0256F8617E4AE6-8074
Fault Frequency: 73
Reset counter: 101
Mileage: 63443 km
Time: 02:36:02
Fault Frequency: 73
Reset counter: 101
Mileage: 63443 km
Time: 02:36:02
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
VCID: 397DCA3670F1068ACE-806C
Component: ELV 027 0380
3C0905861G ELV 027 0380
02823 - Requirements for Locking the Steering Column Lock not met
Fault Frequency: 7
Reset counter: 101
Mileage: 63699 km
Time: 14:27:52
02827 - Wake-Up request via ESP
007 - Short to Ground
Fault Status: 01100111
Reset counter: 52
Mileage: 63673 km
Time: 15:04:09
Fault Frequency: 6
Reset counter: 101
Mileage: 63699 km
Time: 14:27:53
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1123
Revision: 32008001 Serial number: 00000078969106
Coding: 0000181
VCID: 3B71D03E7ACD349ADC-806E
Fault Status: 00100101
Reset counter: 89
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.132 H07 1806
VCID: 3463FB025793FBE21D-8060
00625 - Vehicle Speed Signal
Mileage: 63660 km
Temperature: 36.0°C
Voltage: 12.20 V
Voltage: 12.00 V
02546 - Steering Limit Stop
Mileage: 63760 km
Temperature: 33.0°C
Voltage: 12.50 V
Voltage: 12.30 V
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 042 0472
Coding: 00910A0001860E763004941570084F0B607CA0
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1123
Revision: 32008001 Serial number: 00000580069110
Coding: 0000180
VCID: 3C73D3227FC333A2D5-8068
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000012
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 61
Mileage: 63760 km
Time: 20:27:41
Voltage: 12.32 V
Count: 170
Fault Status: 11101101
Reset counter: 61
Mileage: 63760 km
Time: 20:27:41
Voltage: 12.32 V
Count: 236
02779 - Databus for Electric Parking Brake
Reset counter: 101
Voltage: 10.04 V
Count: 221
02839 - Wake-Up Line from Control Module for Electrical Parking Brake
Fault Status: 00101001
Reset counter: 101
Mileage: 63760 km
Time: 20:15:31
Voltage: 12.01 V
Count: 51
Part No: 1K0 035 186 T
Component: Radio GR0 020 0023
Revision: 0002006S Serial number: VWZ2Z2F1231442
Coding: 0040400
VCID: 3779CC0E46E510FA38-8062
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1113
Revision: 11005001 Serial number: 00000000882671
Coding: 0000144
VCID: 3D75DE2664D93AAAE2-8068
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1113
Revision: 11005001 Serial number: 00000000884392
Coding: 0000144
VCID: 3E77D92A69DF21B2FB-806A
End-------------------------(Elapsed Time: 02:11)--------------------------
