Central electric module 9 not responding 2014 GTI
ag13
C?ID=223721
Still could use some help with this. Everything on the car is running as it such but I still have no access to this module. I have done the door lock, battery, car on/off, disconnected battery, all doors open/ closed tricks and still no access. Any help would be greatly appreciated.
Do you folks think I should unplug the module and let it sit for a few minutes without power to reset it?
ag13: I've been watching your thread unfold with academic interest (but alas without the ability to help). The only contribution that I can make to solving your problem (and it's a very small contribution) is by way of reference to your CodingLog File. I have parsed the data from this file below and I have stripped-out the control modules that don't relate to your auto-scan report. I'm not sure what Dana had in mind when she (I'm assuming that Dana is a "she") requested the file, but I'm guessing that she wanted to look at the changes that you have made to the coding/adaptation channels. Without seeking to steal any of Dana's thunder (and she wields a considerable amount of thunder!) do the changes in the table look correct?
Since discussion thus far has cantered on the BCM, I note that the only alteration in the codinglog file to your BCM is a change to Byte 12 from Hex70 to Hex30. Was this change correct?
ag13
C?ID=223721
Thanks for posting. I actually made several changes to that module that don't seem to appear on the list. Running lights to fog, led tag light no warning I'm sure this was more technically labeled, mirror dip, etc. this has been quite mind blogging as to why I can't get back in. I even tried using a security but it stated some sort of seed issue.
   #24
ag13: Again, my apology if my reply regarding your issue is less-than-helpful, but I note that there are no entries in the file that you posted after 24 September 2014 (for your car). The missing line entries that you mention could be explained if (like me) you are using Mr Ross's Beta SW ver concurrently with the full release SW ver. If this is so, there is a separate CodingLog.txt file in the Ross-Tech \Beta directory.
ag13
C?ID=223721
As if this couldnt get any stranger. Dealer did a reset of the system this past week during scheduled maintainance. I no longer get an error code, gateway scan now states central electronics is status ok, but I still have no communication with it. Same box pops up unable to communicate. I would be happy to pay for additional help on this from Ross tech of its available.
   #26
I'm scratching my head. Can you please post a current Auto-Scan from your car?
ag13
C?ID=223721
Now am worried even more with you scratching your head: Uwe I have to hit done on module 9 because it hangs up on it, had it hung there for up to 30 mins when I finally hit done go back and then it continues scanning other modules. I appears it communicating but when I try to access it I get the unable to communicate with module. I have tried every trick from battery disconnect to opening all doors unlocking locking etc.
VCDS Version: Release 14.10.0 (x64)
Data version: 20141022
Monday,24,November,2014,20:58:14:53396
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
VIN: WVWHD7AJ2EW000948   Mileage: 16660km-10352miles
Address 01: Engine (CBF)       Labels: 06J-907-115-CBF.clb
   Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
   Revision: E3H26---    Serial number:
   Coding: 040301081C070160
   VCID: 78D107C10B03DFE157B-802D
   Part No SW: 02E 300 058 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 3513
   Revision: 05652104    Serial number: 00001307120742
   VCID: 277314BD963D80190E1-8072
   Revision: 00H31001
   Coding: 114B600C492200FA881406E892210041B70800
   VCID: 7DDF16D5E421FAC904D-8028
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
   Component: AC Manuell    H20 0505
   Revision: 00001019
   Coding: 0010000002
   ROD: EV_ACManueBHBVW36X_SE36.rod
   VCID: 7BDB18CDF235F4F93A9-802E
Address 09: Cent. Elect.        Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086 T    HW: 1K0 937 086 T
   Component: BCM PQ35  M   111 0709
   Coding: 6F180A3898232BC4008800C1200083A448810386435D8D604B8020200040
   VCID: 41A7AA25D8595E29205-8014
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 09071  26  0512
   Coding: 009F95
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R02ADUO
   Coding: 00004737
   ROD: EV_AirbaVW10SMEVW360_SK35.rod
   VCID: 3C59DBD1B7BB33C1733-8069
   Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00008FM400
   Serial number: 3572MSME0A311578ZZZS
   Serial number: 3582MSME0070617BZZZQ
   Serial number: 3512QSME480B3049ZZZU
   Serial number: 3522QSME5A183232ZZZQ
   Serial number: 35527SME625E732FZZZU
   Serial number: 35627SME1E54732FZZZS
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90422MH2000W8
   Coding: 189A140000
   Shop #: WSC 46056 001 104857
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 76CD09F9C917A991457-8023
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0036
   Serial number: 0089279
   Coding: 830000
   Part No SW: 5K6 920 973 C    HW: 5K6 920 973 C
   Component: KOMBI         H05 0705
   Coding: 070901
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 3753C4FD8E9D10999E1-8062
   Coding: 070901
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 020713F1001299
   Coding: 350002
   VCID: 74C933F1D76BBB817B3-8021
   Component: IMMO          H05 0705
   VCID: 6AF52D898DAF7D71D1F-803F
   Revision: A1001003    Serial number: 7665038284
   Coding: 010100
   VCID: 2B7BE88D4AD5A479EA9-807E
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 1K0 035 274 K    HW: 1K0 035 274 K
   Component: RNS315-NAR    H76 0410
   Serial number: VWZAZ2P0026729
   Coding: 040004210400060400008000
   Shop #: WSC 01383 790 50316
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 2C79EB9147DBA341E33-8079
   Component: NAR_V5N  0046
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2105
   Coding: 0001460
   VCID: 3753C4FD469D10999E1-8062
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 74     3501
   Revision: 00H22000
   VCID: 3957C2C5708906E9685-806C
   Part No SW: 5K0 959 702 H    HW: 5K0 959 702 H
   Coding: 0001460
   VCID: 3851C7C14B831FE197B-806D
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 354FCEF55C91E2898CD-8060
   Coding: 0001168
   VCID: 364DC9F94197E991857-8063
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007665094725
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3A55DDC9BD8F0DF161F-806F
End-------------------------(Elapsed Time: 02:33)--------------------------
There's never a reason to wait for more than (I'm going to say this somewhat arbitrarily) 1 minute in VCDS unless there's something obvious going on. If it sits there longer than that doing nothing and hasn't told you it's going to be a while, something is, uh, not functioning nominally. In other words, don't bother waiting 30 minutes. ;)
Anyway, it seems your 09 module is back to talking. Sometimes. When it feels like it. For a while. The question now becomes: Is the module wonky? Or is the scan tool (which consists of VCDS, your Micro-CAN interface, and the PC it's running on) the problem? Let's see what we can see. With it all hooked up, go to [Options], set Debug Level to 1024, then click [Apply]. Then [Select] and [09-Cent.Elect]. If you get in, [Fault Codes-02]. If you don't get in, try it a few times (and you never need to wait more than one minute tops). When you're done, there should be a file named DEBUG-09.DLM in your Debug sub-folder, typically C:\Ross-Tech\VCDS\ Send that file to Support@... along with a link to this thread please.
ag13
C?ID=223721
Email sent, no access
   #30
Eric
HC800000
One of the slaves of module 09 is causing module 09 to make the scan tool wait indefinitely when we request identification. VCDS is trying to break out of that wait, but the module refuses any further request since it's still (presumably) waiting on that slave. Not sure where you go from there, could be an actual slave malfunctioning, the wiring to it, or any coding/adaptation change you made...
   #31
OK now that we know the 09 issue is slave related, and this car only has one slave (unless a RLS is installed, but I doubt that), I have to wonder if it is faulty. You mentioned replacement sylvania silver stars .. and even though those bulbs are NOT noted for causing problems (I run them in my Halogen cars) I have to wonder if the headlight bulbs or some combination of pulling and reinstalling fuses spiked the BCM and/or connected slave wiper motor.
I think we should locate and remove the fuse for the wiper motor so you can Auto-Scan it again and see if my theory is correct. I'll edit this post after I locate a wiring diagram.
Edit:
Vehicle Identification No. WVWHD7AJ2EW000948
2013 (5K19W3) GTI | Production date 16.08.2013
Engine code CBFA
Transmission code PBH
Per the Standard equipment (Canada, Mexico, USA) from November 2011 wiring diagram # 121, J400 (Wiper motor control module) is powered from one of two possible fuses - depending on the installed fuse box:
SB31 (E-Box High)
SB19 (E-Box Low)
If you have parking spots/slots for 2 total relays in the box under the hood I would consider that the Low system.
If you have parking spots/slots for 4 total relays in the box under the hood I would consider that the High system.
Either way, the fuse should be a 30A and that is Terminal 30 (constant battery power) power source.
ag13
C?ID=223721
Ok pulled the fuse and confirmed by trying wipers which didn't go on. That said still no access to module and now I do show an error but no code on the gateway list which I can not erase. Help! That said I do remember changing the wiper settings in module 9 to one sweep after using the windshield washer, when I did have access.
   #33
ag13: I know that it's little solace, but the aberrant behaviour of your BCM is an intriguing mystery (that seems to have captured the interest of lots of folk here). Your thread reads like the unfolding story to a good book - every new post adds yet another dimension to the development of the plot.
Whilst I don't want to interrupt the flow of Dana's hypothesis, just for my own edification can you confirm my suspicion from a previous post - please?
   #34
Did pulling that fuse for the test resolve the Auto-Scan problem?
   #35
Eric
HC800000
I don't have a fresh enough version of Sebastian's work (hello! :o ) to comment about 08, but Dana did mention this car is a RNS 510 retrofit. Nothing wrong with that, however I see 42 had its coding changed to reflect Seat Memory installed. Seeing how the door modules being locked interfere with comms to 09, I'd urge a revert to the original coding of both 42 and 52 if Seat Memory is not actually installed. Very good point DV52 :)
   #36
Eric: I removed my post after I re-read the thread (about RNS 510 retrofit). Guess I got so interested in the plot of AG13's unfolding story, that I forget about the storyline detail (always a risk with a good book!).
Can you provide more information about the interaction between the door control modules and comms with 09? Why does this happen?
Eric
HC800000
Well, I didn't write the firmware in those controllers, but our guess is that locking the doors sends some sort of a sleep signal to the central electrics or the gateway. Is it far fetched that the door modules could make 09 misbehave if they were told to interact with seat memory functionality when there is none? I think reverting the coding is worth a try :)
Eric: Thanks for the explanation which makes sense. And yes, I agree that rolling back the codes is an easy-try.
Ag13: Here's the rest of the compare between the two Auto-scans (first line in each address is the earlier auto-scan)
   #39
ag13
C?ID=223721
I hope in the end the story doesn't have a bum ending, lol. Ok auto scan still hangs on module 9. I did put back in the oem bulbs, no change. Eric when I get home this evening I will recode back to oem per your breakdown and retry. Just so you all know I REALLY appreciate your help on this. It seriously is a brain teaser.
   #40
ag13
C?ID=223721
unfortunately no change even restoring all items to oem status.
