Central electric module 9 not responding 2014 GTI
   #41
unfortunately no change even restoring all items to oem status.
ag13: so the storyline continues into yet another chapter!! When you say "restoring all items to oem status", do you mean restoring all items to the auto-scan that you posted on 21-aug-2014? Do you have any previous auto-scans (ideally, from before the RNS 510 retrofit)?
Of course, autos-cans can only ratify the coding values for control modules. To confirm that the adaptation channels are kosher, did you ever find the missing CodingLog.txt file (perhaps in the Beta RT directory) for changes made to the car after 24 September 2014?
Then there is Dana's suggestion about pulling the fuse and retesting the auto-scan. Was that done?
ag13
C?ID=223721
I only have in my system the new version of VCDS. I erased the other beta versions thinking that maybe that was the issue. Restored as in your breakdown as well as removing all lighting bulbs that I changed. Fuse(s) pulled no change.
   #43
ag13
C?ID=223721
Should I just replace the bcm and start again?
   #44
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I know that you intended to return everything to factory settings, but I think we should make sure that really happened/was accepted before you spend money on a BCM. Can you post for us:
1) A *current* Auto-Scan, as of now.
2) A *historical* Auto-Scan, from before you made any of these changes? Apparently RT Support/Dana have one from you if you don't have it anymore.
Jason
   #45
ag13
C?ID=223721
Thanks Jason will do.
I know that you intended to return everything to factory settings, but I think we hould make sure that really happened/was accepted before you spend money on a BCM. Can you post for us:
Jason
   #46
ag13
C?ID=223721
I cant run the autoscan since it hangs up on module 9. I did find this in the ross-tech program file. Ignore last adaptation done today, was trying to see if dip mirror would work. Thanks,
Address 17:5K6 920 973 C recoded (Long Coding) from 070901 to 270901  (01357/011/00200)  Saturday,01,November,2014,19:09:14:53396
Address 17:5K6 920 973 C recoded (ADP-indicator_celebration) from active  to active   Saturday,01,November,2014,19:10:26:53396
Address 17:5K6 920 973 C recoded (ADP-indicator_celebration) from active  to not active   Saturday,01,November,2014,19:17:18:53396
Address 17:5K6 920 973 C recoded (ADP-indicator_celebration) from not active  to active   Saturday,01,November,2014,19:19:18:53396
Address 19:7N0 907 530 AF recoded (Installation List) from ED807F064006120000 to ED807D064006120000  Sunday,02,November,2014,13:39:29:53396
Address 17:5K6 920 973 C recoded (Long Coding) from 270901 to 170901  (01357/011/00200)  Sunday,02,November,2014,13:41:36:53396
Address 17:5K6 920 973 C recoded (ADP-indicator_celebration) from active  to not active   Sunday,02,November,2014,13:43:13:53396
Address 37:1K0 035 274 K recoded (ADP-Developer mode) from blocked  to Enabled   Sunday,02,November,2014,13:43:56:53396
Address 37:1K0 035 274 K recoded (ADP-Developer mode (temporary)) from blocked  to Enabled   Sunday,02,November,2014,13:44:07:53396
Address 16:5K0 953 507 AH recoded (Long Coding) from 189A140000 to 1892140000  (46056/001/104857)  Sunday,02,November,2014,13:49:15:53396
Address 16:5K0 953 507 AH recoded (Long Coding) from 1892140000 to 189A140000  (46056/001/104857)  Sunday,02,November,2014,13:50:50:53396
Address 08:7N0 907 426 BH recoded (ADP-Retention of driver's seat heater level) from not active  to active   Sunday,02,November,2014,13:52:51:53396
Address 19:7N0 907 530 AF recoded (Installation List) from ED807D064006120000 to ED807F064006120000  Sunday,02,November,2014,13:55:26:53396
Address 2E:5N0 035 342 G recoded (Long Coding) from 010100 to 010000  (01357/011/00200)  Sunday,02,November,2014,14:03:01:53396
Address 08:7N0 907 426 BH recoded (Long Coding) from 0010001002 to 0010000002  (01357/011/00200)  Sunday,02,November,2014,14:04:05:53396
Address 37:1K0 035 274 K recoded (ADP-Maximum vehicle speed for destination entry) from 6 km/h to 250 km/h  Sunday,02,November,2014,14:08:09:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040004210400060000008000 to 040004210400060400008000  (01383/790/50316)  Sunday,02,November,2014,14:08:47:53396
Address 17:5K6 920 973 C recoded (ADP-indicator_celebration) from not active  to active   Sunday,02,November,2014,14:10:36:53396
Address 17:5K6 920 973 C recoded (ADP-indicator_celebration) from active  to not active   Sunday,02,November,2014,14:11:51:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040004210400060400008000 to 040100210100060400008000  (01383/790/50316)  Thursday,06,November,2014,17:40:08:53396
Address 37:1K0 035 274 K recoded (ADP-Developer mode (temporary)) from blocked  to Enabled   Thursday,06,November,2014,17:41:46:53396
Address 17:5K6 920 973 C recoded (Long Coding) from 170901 to 070903  (01357/011/00200)  Thursday,06,November,2014,17:46:50:53396
Address 17:5K6 920 973 C recoded (ADP-indicator_celebration) from not active  to active   Thursday,06,November,2014,17:47:37:53396
Address 08:7N0 907 426 BH recoded (Long Coding) from 0010000002 to 0010001002  (01357/011/00200)  Thursday,06,November,2014,17:52:14:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040100210100060400008000 to 040600210100060400008000  (01383/790/50316)  Friday,07,November,2014,20:17:58:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040600210100060400008000 to 040000210100060400008000  (01383/790/50316)  Friday,07,November,2014,20:18:19:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040000210100060400008000 to 040100210100060400008000  (01383/790/50316)  Friday,07,November,2014,20:18:51:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040100210100060400008000 to 040600210100060400008000  (01383/790/50316)  Friday,07,November,2014,20:19:06:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040600210100060400008000 to 040000210400060400008000  (01383/790/50316)  Friday,07,November,2014,20:19:39:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040000210400060400008000 to 040004210400060400008000  (01383/790/50316)  Friday,07,November,2014,20:20:18:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040004210400060400008000 to 040000210400060400008000  (01383/790/50316)  Friday,07,November,2014,20:20:38:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040000210400060400008000 to 040004210400060400008000  (01383/790/50316)  Friday,07,November,2014,20:21:02:53396
Address 08:7N0 907 426 BH recoded (Long Coding) from 0010001002 to 0010000002  (01357/011/00200)  Tuesday,11,November,2014,17:16:20:53396
Address 01:1K0 907 115 AT recoded (Long Coding) from 040301081C070160 to 040301081C070360  (01357/011/00200)  Tuesday,11,November,2014,17:19:52:53396
Address 52:5K0 959 702 H recoded (Short coding) from 0001204 to 0001460  (01357/011/00200)  Friday,21,November,2014,09:46:36:53396
Address 42:5K0 959 701 H recoded (Short coding) from 0001204 to 0001460  (01357/011/00200)  Friday,21,November,2014,09:46:59:53396
Address 37:1K0 035 274 K recoded (ADP-Developer mode (temporary)) from blocked  to Enabled   Friday,21,November,2014,09:48:41:53396
Address 17:5K6 920 973 C recoded (Long Coding) from 070901 to 170901  (01357/011/00200)  Monday,24,November,2014,21:05:49:53396
Address 17:5K6 920 973 C recoded (Long Coding) from 070901 to 170901  (01357/011/00200)  Monday,24,November,2014,21:05:54:53396
Address 17:5K6 920 973 C recoded (Long Coding) from 070901 to 170901  (01357/011/00200)  Monday,24,November,2014,21:06:27:53396
Address 52:5K0 959 702 H recoded (Short coding) from 0001460 to 0001460  (01204/011/00200)  Monday,24,November,2014,21:06:50:53396
Address 42:5K0 959 701 H recoded (Short coding) from 0001460 to 0001460  (01204/011/00200)  Monday,24,November,2014,21:07:08:53396
Address 08:7N0 907 426 BH recoded (Long Coding) from 0010000002 to 0010001002  (01357/011/00200)  Monday,24,November,2014,21:08:28:53396
Address 09:5Q0 937 085 S recoded (Long Coding) from 04141A42C041227541C04004510007000000000000000000000000000000 to 04141A46C041227541C04004510007000000000000000000000000000000  (06385/790/00016)  Monday,24,November,2014,21:16:41:53396
Address 19:5Q0 907 530 Q recoded (Installation List) from 01503C0000000000400C1000 to 01503C0000000000400C1000  Monday,24,November,2014,21:20:36:53396
Address 19:5Q0 907 530 Q recoded (ADP-Increase idle speed request) from Mode not active  to Stage 1   Monday,24,November,2014,21:21:33:53396
Address 19:5Q0 907 530 Q recoded (ADP-Increase idle speed request) from Mode not active  to Stage 2   Monday,24,November,2014,21:21:41:53396
Address 42:5Q0 959 393 B recoded (Long Coding) from 00100F204100048000000002 to 00100F204D00048000000002  (06385/790/00016)  Monday,24,November,2014,21:24:53:53396
Address 5F:8V0 035 844  recoded (ADP-Developer mode) from not activated  to activated   Monday,24,November,2014,21:25:55:53396
Address 03:5Q0 907 379 AA recoded (ADP-Brake booster) from 4  to 3   Monday,24,November,2014,21:27:38:53396
Address 03:5Q0 907 379 AA recoded (ADP-Brake disk drying) from Weak  to not activated   Monday,24,November,2014,21:27:53:53396
Address 17:8V0 920 960 B recoded (Long Coding) from 07F519092B80A7050208AA00180000 to 07F519092B80A7000100EA00180000  (06385/790/00016)  Monday,24,November,2014,21:33:30:53396
Address 09:5Q0 937 085 S recoded (Long Coding) from 04141A46C041227541C04004510007000000000000000000000000000000 to 04141A42C041227541C04004510007000000000000000000000000000000  (06385/790/00016)  Monday,24,November,2014,21:36:15:53396
Address 19:5Q0 907 530 Q recoded (Installation List) from 01503C0000000000400C1000 to 01503C0000000000400C1000  Monday,24,November,2014,21:37:43:53396
Address 17:8V0 920 960 B recoded (Long Coding) from 07F519092B80A7000100EA00180000 to 07F519092B80A7000100AA00180000  (06385/790/00016)  Monday,24,November,2014,21:39:22:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040004210400060400008000 to 040104210400060400008000  (01383/790/50316)  Monday,01,December,2014,16:24:11:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040104210400060400008000 to 040604210400060400008000  (01383/790/50316)  Monday,01,December,2014,16:24:53:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040604210400060400008000 to 040604210100060400008000  (01383/790/50316)  Monday,01,December,2014,16:25:16:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040604210100060400008000 to 040504210100060400008000  (01383/790/50316)  Monday,01,December,2014,16:25:43:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040504210100060400008000 to 040904210100060400008000  (01383/790/50316)  Monday,01,December,2014,16:26:08:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040904210100060400008000 to 040004210100060400008000  (01383/790/50316)  Monday,01,December,2014,16:26:35:53396
Address 37:1K0 035 274 K recoded (Long Coding) from 040004210100060400008000 to 040004210400060400008000  (01383/790/50316)  Monday,01,December,2014,16:43:09:53396
Address 42:5K0 959 701 H recoded (Short coding) from 0001460 to 0001460  (01204/011/00200)  Sunday,07,December,2014,17:12:52:53396
Address 52:5K0 959 702 H recoded (Short coding) from 0001460 to 0001460  (01204/011/00200)  Sunday,07,December,2014,17:13:18:53396
Address 62:5K0 959 703 D recoded (Short coding) from 0001168 to 0001168  (01357/011/1012552)  Sunday,07,December,2014,17:13:38:53396
Address 72:5K0 959 704 D recoded (Short coding) from 0001168 to 0001168  (01357/011/1012552)  Sunday,07,December,2014,17:13:57:53396
Address 19:7N0 907 530 AF recoded (Installation List) from ED807F064006120000 to ED8007064006120000  Sunday,07,December,2014,17:23:49:53396
Address 19:7N0 907 530 AF recoded (Installation List) from ED8007064006120000 to ED807F064006120000  Sunday,07,December,2014,17:27:04:53396
Address 17:5K6 920 973 C recoded (ADP-Activating and deactivating all development messages) from not active  to active   Sunday,07,December,2014,17:32:51:53396
Address 17:5K6 920 973 C recoded (ADP-Automatic door locking) from Yes  to No   Sunday,07,December,2014,17:33:12:53396
Address 17:5K6 920 973 C recoded (ADP-Automatic door locking) from No  to Yes   Sunday,07,December,2014,17:34:24:53396
Address 17:5K6 920 973 C recoded (ADP-Activating and deactivating all development messages) from active  to not active   Sunday,07,December,2014,17:34:39:53396
Address 17:5K6 920 973 C recoded (Long Coding) from 070901 to 270B01  (01357/011/00200)  Sunday,07,December,2014,17:36:04:53396
Address 17:5K6 920 973 C recoded (Long Coding) from 270B01 to 170901  (01357/011/00200)  Sunday,07,December,2014,17:39:32:53396
Address 52:5K0 959 702 H recoded (Short coding) from 0001460 to 0001716  (01204/011/00200)  Wednesday,17,December,2014,08:02:17:53396
Address 19:7N0 907 530 AF recoded (Installation List) from ED807F064006120000 to ED807F864006120000  Wednesday,17,December,2014,08:03:17:53396
ag13
C?ID=223721
If I am looking at this correctly, it appears that all mods I did to module 9 are not showing?
   #48
NEtech
Denmark
C?ID=56995
I would try this:
Change Coding of [42] / [52] back to: 0001204
Change Coding of [17] back to: 070901 (probably not necessary, but anyway)
Correct changes in [19] Gateway Installation list, check value in above file, becomes this: ED807F064006120000 (as you did dec. 7)
After this, take battery ground connection off, for about 30 minutes.
   #49
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
The coding and adaptation logs are good to have, but in your case, they don't have history before November 1st. They also don't show whether the attempt to change coding was actually successful. You started the thread about this problem back in August. I think we should firmly establish the state of the car before the changes that might be causing problems, and the state of the car as it is now, and figure out how to get back. The data you've shared isn't really enough to do that.
For a current Auto-Scan, you've said earlier you can press Done while it's hung on 09 and it continues. Can you do that to get a current scan?
For your historical Auto-Scan, can you dig up one that worked before your changes, or give Dana permission to share the one you sent to Ross-Tech support?
Niels just shared some coding stuff he'd like you to try. He has access to research resources that I don't, so it's worth trying. If it doesn't work, we're back to trying to figure out how to roll back your changes to restore 09 functionality, and for that we need data.
Jason
   #50
Ag13: I posted a copy of a more user friendly version of your CodeLog.txt file here . It might be better to download the spreadsheet (some odd formatting when viewed on dropbox). NEtech has probably done the same thing (my apology Mr NEtech)
Anyhow, there is only two changes to the BCM, both happened on 24 November 2014. You changed byte 03 and then rolled back to the original setting (looks pretty innocuous)
The real problem is that your 2nd CodeLog.txt file is AFTER the previous version that you posted (i.e. the 1st file had dates in Aug/Sept 2014 and the one above has activities in Nov/Dec 2014). From your description of events, I assume that your problems were encountered BEFORE the first CodeLog.txt file date.
PS: You appear to have been fairly persistent in trying to change the coding string for address 37! It's not related to your problem, but just out of interest, why?
ag13
C?ID=223721
DV trying everything I can think off. Here is the latest scan.
VCDS Version: Release 14.10.0 (x64)
Data version: 20141022
Monday,29,December,2014,20:09:37:53396
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
VIN: WVWHD7AJ2EW000948   Mileage: 18970km-11787miles
Address 01: Engine (CBF)       Labels: 06J-907-115-CBF.clb
   Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
   Revision: E3H26---    Serial number:
   Coding: 040301081C070160
   VCID: 78D107C10B03DFE157B-802D
   Part No SW: 02E 300 058 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 3513
   Revision: 05652104    Serial number: 00001307120742
   VCID: 277314BD963D80190E1-8072
   Revision: 00H31001
   Coding: 114B600C492200FA881406E892210041B70800
   VCID: 7DDF16D5E421FAC904D-8028
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
   Component: AC Manuell    H20 0505
   Revision: 00001019
   Coding: 0010001002
   ROD: EV_ACManueBHBVW36X_SE36.rod
   VCID: 7BDB18CDF235F4F93A9-802E
Address 09: Cent. Elect.        Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086 T    HW: 1K0 937 086 T
   Component: BCM PQ35  M   111 0709
   Coding: 6F180A3898232BC4008800C1200083A448810386435D8D604B8020200040
   VCID: 41A7AA25D8595E29205-8014
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 09071  26  0512
   Coding: 009F95
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R02ADUO
   Coding: 00004737
   ROD: EV_AirbaVW10SMEVW360_SK35.rod
   VCID: 3C59DBD1B7BB33C1733-8069
   Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00008FM400
   Serial number: 3572MSME0A311578ZZZS
   Serial number: 3582MSME0070617BZZZQ
   Serial number: 3512QSME480B3049ZZZU
   Serial number: 3522QSME5A183232ZZZQ
   Serial number: 35527SME625E732FZZZU
   Serial number: 35627SME1E54732FZZZS
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90422MH2000W8
   Coding: 189A140000
   Shop #: WSC 46056 001 104857
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 76CD09F9C917A991457-8023
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0036
   Serial number: 0089279
   Coding: 830000
   Part No SW: 5K6 920 973 C    HW: 5K6 920 973 C
   Component: KOMBI         H05 0705
   Coding: 170901
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 3753C4FD8E9D10999E1-8062
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 020713F1001299
   Coding: 350002
   VCID: 74C933F1D76BBB817B3-8021
   Component: IMMO          H05 0705
   VCID: 6AF52D898DAF7D71D1F-803F
   Revision: A1001003    Serial number: 7665038284
   Coding: 010100
   VCID: 2B7BE88D4AD5A479EA9-807E
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 1K0 035 274 K    HW: 1K0 035 274 K
   Component: RNS315-NAR    H76 0410
   Serial number: VWZAZ2P0026729
   Coding: 040500210100060400008000
   Shop #: WSC 01383 790 50316
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 2C79EB9147DBA341E33-8079
   Component: NAR_V5N  0046
1048613 - Front Left Audio Signal Output
          B1105 13 [009] - Open Circuit
                    Reset counter: 168
                    Mileage: 18977 km
                    Date: 2014.12.29
                    Time: 20:01:20
1048614 - Front Right Audio Signal Output
          B1106 13 [009] - Open Circuit
                    Reset counter: 168
                    Mileage: 18977 km
                    Date: 2014.12.29
                    Time: 20:01:20
1048615 - Rear Left Audio Signal Output
          B1108 13 [009] - Open Circuit
                    Reset counter: 168
                    Mileage: 18977 km
                    Date: 2014.12.29
                    Time: 20:01:20
1048628 - Rear Right Audio Signal Output
          B1107 F0 [009] - Short Circuit Between Poles
                    Reset counter: 168
                    Mileage: 18977 km
                    Date: 2014.12.29
                    Time: 20:01:20
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2105
   Coding: 0001204
   Shop #: WSC 01204 011 00200
   VCID: 3753C4FD469D10999E1-8062
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 74     3501
   Revision: 00H22000
   VCID: 3957C2C5708906E9685-806C
   Part No SW: 5K0 959 702 H    HW: 5K0 959 702 H
   Coding: 0001204
   VCID: 3851C7C14B831FE197B-806D
   Coding: 0001168
   Shop #: WSC 01357 011 1012551
   VCID: 354FCEF55C91E2898CD-8060
   Coding: 0001168
   VCID: 364DC9F94197E991857-8063
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007665094725
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3A55DDC9BD8F0DF161F-806F
End-------------------------(Elapsed Time: 02:17)--------------------------
ag13
C?ID=223721
I recently added ab alpine 445 u amp with enfig cable. All is working well but as you can see I do have error codes showing up.
   #53
ag13: How did you get the L/R, front/Rear audio signals for the new amp? If you disconnected them from any part of the native audio circuits, then it could explain the open-circuit errors (although Rear Right Audio Signal Output- Short Circuit Between Poles looks odd).
Wiser and more knowledgeable VCDS brains than mine can advise how the auto-scan helps.
   #54
ag13
C?ID=223721
The harness gave me the option of taking the two front channels via RCA jack of cutting off the RCA jacks and connecting all four channels. I connected all four channels from hu to harness.
ag13: yep, that explains the audio errors! Though the Rear-Right channel fault is still a mystery - are you absolutely sure that when you spliced this cable and reconnected it to the amp, that it wasn't shorted?
Anyway, we are "straining gnats and passing elephants" by concentrating on this matter - you have much bigger issues with your BCM problem. Hope one of the VCDS gurus here can help you
ag13
C?ID=223721
Thanks DV52, at this point I think I just need to replace the bcm. Anyone know my best purchase option on this besides the dealer? Thanks!
   #58
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I wouldn't buy anything yet. There are now several other Micro-CAN interface users reporting similar comms trouble on 09-Central Electronics. Ross-Tech is actively looking into it.
Jason
   #59
Eric
HC800000
Trying the upcoming beta and generating debugs certainly won't hurt, but I'm afraid (having looked at debugs of this particular issue earlier in the thread) that the problem really sits module-side in this case.
   #60
Enriquez
Poland
C?ID=72075
Agree wit You. I've u-CAN as well, and never meet that issue.
