No response from controller 5F after retrofitted MIB2 for MK7 GTI 14
Golfmania
Saudi Arabia
C?ID=313413
I own golf gti mk7 2014 ROW with engine code:CHHB
and today I just upgraded my infotainment system from MIB1 unit with 6.5 inch screen to a MIB2 unit with 8 inch screen, and this is the part No. 3G0035043
(All equipments are OEM)
But when I try connecting to vcds 5F controller, it's says (no response from controller) BTW all other controllers work fine.
What should I do to fix this??
See the AutoScan:
https://drive.google.com/open?id=0B9KBeTrlWpjJT0dJSmNTNm9LSjA
iichel
Eindhoven, NB, NL
C?ID=284912
Does the infotainment itself work?
Tuesday,25,July,2017,01:49:00:05443
VCDS Version: 17.1.3.0 (x64)
VIN: WVWFK2AU5EW053492 License Plate: MYGTI
Mileage: 115294km-71640mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A9
VIN: WVWFK2AU5EW053492 Mileage: 115294km-71640miles
Address 01: Engine (J623-CHHB) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0009
Revision: --H13---
Coding: 091D1032442404083000
ASAM Dataset: EV_ECM20TFS0215G0906259 001013
ROD: EV_ECM20TFS0215G0906259.rod
VCID: 6BD598AF8290B3192C-803E
17178 - Databus
Mileage: 115158 km
Date: 2017.07.22
Time: 00:01:44
Engine speed: 839.50 /min
Normed load value: 5.5 %
Coolant temperature: 74 °C
Intake air temperature: 57 °C
Voltage terminal 30: 12.304 V
Unlearning counter according OBD: 36
Drivetrain coordinator: ACC fault status-ACC: Not active: although TSK passive
Drivetrain coordinator: ACC fault status-Start and stop request: Set at stopping
speed
Drivetrain coordinator: ACC fault status-Bit 2: Not transmitted simultaneously
Drivetrain coordinator: ACC fault status-Bit 3: Does not reactivate after
DTC-induced shutdown
Drivetrain coordinator: ACC fault status-Bit 4: Not active when limiter active
Drivetrain coordinator: ACC fault status-Bit 5: Transmits no undefined signals
Drivetrain coordinator: ACC fault status-Bit 6: Not active when main switch off
Drivetrain coordinator: ACC fault status-Bit 7: Not active when driver braking
Drivetrain coordinator: ACC fault status-Bit 8: Not active during the EPB emer.
braking
Drivetrain coordinator: brake fault status-ESP: no error
Drivetrain coordinator: brake fault status-Deceleration controller: Available
Drivetrain coordinator: brake fault status-TSK/ESP handshake: no error
Drivetrain coordinator: brake fault status-Bit 1: no error
Drivetrain coordinator: brake fault status-Bit 3: Not malfunction due to inaccurate
engine torque
Drivetrain coordinator: brake fault status-Bit 4: No indication of TSK message
consistency error
Drivetrain coordinator: brake fault status-Bit 6: Automatic engagement OK
Drivetrain coordinator: brake fault status: 4
Drivetrain coordinator: brake function status-Parking Brake: not active
Drivetrain coordinator: brake function status-ACC: Not braking
Drivetrain coordinator: brake function status-ESP: Not invoking TSK braking
Drivetrain coordinator: brake function status-Driver: Not braking
Drivetrain coordinator: brake function status-Hill descent control: passive
Drivetrain coordinator: brake function status-ASR: no intervention
Drivetrain coordinator: brake function status-MSR: no intervention
Drivetrain coordinator: brake function status-ADS: no intervention
Drivetrain coordinator: brake function status-ABS: no intervention
Drivetrain coordinator: brake function status-EDL: no intervention
Drivetrain coordinator: brake function status-ASP: no intervention
Drivetrain coordinator: brake function status-AWV2: No warning pressure
Drivetrain coordinator: brake function status-Bit 4: no intervention
Drivetrain coordinator: brake function status-Bit 11: not passively cycled
Drivetrain coordinator: brake function status-Bit 12: not passively cycled
Drivetrain coordinator: brake function status-Bit 13: Standstill not detected
Part No SW: 0D9 300 040 L HW: 02E 927 770 AN
Component: DQ250-6F MQB H52 4025
Revision: 05652104 Serial number: TFK01305221548
ROD: EV_TCMDQ250021.rod
VCID: 204FBF833BD6A041C9-8074
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 61713000000B52
Coding: 01FA6BA13425096F037B0609C1C5A980D62C90C0608395B70040503AC109
VCID: 7BF5A8EFF2F02399BC-802E
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 237
Mileage: 115158 km
Date: 2017.07.22
Time: 00:01:43
4214 - Auto-Hold Switch
C10CE 29 [008] - Signal Implausible
Reset counter: 198
Mileage: 115204 km
Date: 2017.07.23
Time: 14:10:32
C1146 02 [008] - Signal Failure
Reset counter: 237
Mileage: 115158 km
Date: 2017.07.22
Time: 00:01:54
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0193829980
Coding: 030C1C
Shop #: WSC 12345 123 61029
VCID: 3A7B6DEBBD4ADA91E7-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 AA HW: 5G0 907 044 AA
Component: Climatronic H02 0705
Revision: 00001K06
Coding: 00020014100100000005004012101800
VCID: 66C3E99B99728E7173-8032
Air quality sensor:
459025 - Databus
Reset counter: 237
Mileage: 115098 km
Date: 2017.07.22
Time: 02:38:51
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0137
Serial number: 00011317901358
Coding: 00151A46C04122FB4BE44000000C07001800000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 000FDF039B164041E9-8054
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels:
5QX-955-119-V1.CLB
Component: WWS 130619 042 0551
Serial number: 130621030704
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M07D03H03M09S36S1
Coding: 06A8DD
Sun Roof:
Subsystem 3 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.013 H02 0007
Serial number: WOO2265142$
Coding: 181801
B1263 01 [009] - Electrical Failure
Reset counter: 198
Mileage: 115211 km
Date: 2017.07.23
Time: 16:59:52
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 A HW: 5Q0 919 298
Component: PARKHILFE PLA 011 0029
Revision: -------- Serial number: 61131317700833
Coding: 0031161011
ASAM Dataset: EV_EPHVA2CAU3700000 003014
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: 3D7166F7AC64EDA9C2-8068
13637426 - Databus
Reset counter: 237
Mileage: 115158 km
Date: 2017.07.22
Time: 00:01:44
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Component: AirbagVW20 011 0361
Serial number: 003F5R063YKR
VCID: 408F1F03DB968041A9-8014
Subsystem 1 - Part No SW: ----------- HW: 480 002 406 13
Serial number: 357670000007C1705D0U
Subsystem 2 - Part No SW: ----------- HW: 480 002 406 13
Serial number: 35867000000551705D0M
Subsystem 3 - Part No SW: ----------- HW: 480 402 006 13
Serial number: 3516502AF107446482C9
Subsystem 4 - Part No SW: ----------- HW: 480 402 106 13
Serial number: 3526502C110CBDD240BH
Subsystem 5 - Part No SW: ----------- HW: 480 401 806 13
Serial number: 35565029B106FA4130FF
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 BK HW: 5Q0 953 549
Revision: -------- Serial number: 27061304221015
Coding: 0400
Shop #: WSC 40195 333 37120
ROD: EV_SMLSKLOMQB_VW37.rod
Part No SW: 5G6 920 870 HW: 5G6 920 870
Component: KOMBI 314 2210
Coding: 07AD09182B90000801087E00040000
VCID: 6CD79BB3879EB42125-8038
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Reset counter: 237
Mileage: 115098 km
Date: 2017.07.22
Time: 02:38:45
U1110 00 [008] - -
Reset counter: 237
Mileage: 115098 km
Date: 2017.07.22
Time: 02:38:45
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000693654
Coding: 0101000820085900FF00022A1C0F00000001000000000000000000000000
ROD: EV_GatewLear_009.rod
VCID: 3B7568EFB270E399FC-806E
Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H06 0101
Serial number: 27130000649500103245
Coding: 29FFFF
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [008] - Performance
Reset counter: 238
Mileage: 115098 km
Date: 2017.07.22
Time: 01:15:38
Supply voltage: Terminal 30: 12.6 V
Terminal 15: OFF
U1101 00 [009] - Active
Reset counter: 200
Mileage: 115158 km
Date: 2017.07.22
Time: 00:01:45
Supply voltage: Terminal 30: 12.1 V
Terminal 15: On
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 5Q0 905 861 HW: 5Q0 905 861
Component: ELV-MQBA H06 0010
Revision: 00000000 Serial number: 13000124237003
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMQB 003008
ROD: EV_ELVMarquMQB_003.rod
VCID: 73E580CFDAA06BD9E4-8026
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 19061301101050
Coding: 001F13205C00040000001000
VCID: 3F8D1CFFA668FFB9D0-806A
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels:
5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001876174
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 0302
Shop #: WSC 21627 002 1048576
VCID: 397972E7B84CD189EE-806C
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 23061304080633
Coding: 001F11205C00040000801000
VCID: 3E7361FBA162F6B1DB-806A
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels:
5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001863768
Coding: 090000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 021A01000B000200
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 2E0000
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0011
Serial number: 130514202066
End-------------------------(Elapsed Time: 04:02)--------------------------
South Molton, UK
This is an upgrade that is usually fraught with problems, most people give up, why? Because the infotainment is locked to the vehicle, so a change of infotainment needs unlocking usually by a dealer .
I would love to change the MIB1 Amundsen in my Skoda Octavia to a MIB2, but having done the research and consulted several experts have given up on the idea.
Golfmania
Saudi Arabia
C?ID=313413
Revision: --H13---
17178 - Databus
Mileage: 115158 km
Date: 2017.07.22
Time: 00:01:44
speed
braking
engine torque
consistency error
Reset counter: 237
Mileage: 115158 km
Date: 2017.07.22
Time: 00:01:43
Reset counter: 198
Mileage: 115204 km
Date: 2017.07.23
Time: 14:10:32
Reset counter: 237
Mileage: 115158 km
Date: 2017.07.22
Time: 00:01:54
Coding: 030C1C
Revision: 00001K06
Air quality sensor:
459025 - Databus
Reset counter: 237
Mileage: 115098 km
Date: 2017.07.22
Time: 02:38:51
5QX-955-119-V1.CLB
Coding: 06A8DD
Sun Roof:
Coding: 181801
Reset counter: 198
Mileage: 115211 km
Date: 2017.07.23
Time: 16:59:52
Coding: 0031161011
13637426 - Databus
Reset counter: 237
Mileage: 115158 km
Date: 2017.07.22
Time: 00:01:44
Coding: 0400
U1110 00 [008] - -
Reset counter: 237
Mileage: 115098 km
Date: 2017.07.22
Time: 02:38:45
U1110 00 [008] - -
Reset counter: 237
Mileage: 115098 km
Date: 2017.07.22
Time: 02:38:45
Coding: 29FFFF
Reset counter: 238
Mileage: 115098 km
Date: 2017.07.22
Time: 01:15:38
Terminal 15: OFF
Reset counter: 200
Mileage: 115158 km
Date: 2017.07.22
Time: 00:01:45
Terminal 15: On
5QX-959-81X-V1.CLB
Coding: 0302
5QX-959-81X-V1.CLB
Coding: 090000
Coding: 2E0000
Coding: 2E0000
Yes the infotainment itself does work including the car-play & performance monitor
Golfmania
Saudi Arabia
C?ID=313413
When I bought it they asked me to give them my VIN in order to unlock it I guess
Sounds like this is one of those eastern-European hacked-up MIB-IIs that deliberately has diagnostics disabled. Ask the supplier please.
kamold
Australia
C?ID=241363
You need to go into green engineering mode on the MIB unit and disable DAB, and enable diagnostics for next 5 reboots, then it will be contactable at address 5F
Golfmania
Saudi Arabia
C?ID=313413
Not it's not hacked they confirmed to me it's not. (^^,)
Golfmania
Saudi Arabia
C?ID=313413
what should I choose after I entered green engineering mode?
this is what it looks from inside (see the picture)
kamold
Australia
C?ID=241363
Nope, don't see the picture...
In that case, I'm pretty sure it would have had to go to the dealer to get Component Protection matched to the car. If that wasn't necessary, it's hacked.
kamold
Australia
C?ID=241363
Enable diagnostics for next 10 bootups.
Then you will see the unit in VCDS once it starts.
Spacewalker
Poland
C?ID=159607
not exactly
Depend of unit , after CP remove via ODIS you might lost all activations (BT, Satnav etc) . And most of the time VW will not enable it , because you car not have it
Sebastian
Magdeburg, Germany
HN0-nnnnnn
CP and SWaP are seperate functions. As far as my experience goes, the removal/deactivation of SWaP functions only happens if the dealer does more than just deactivate CP. SWaP functions are tight to a car/VIN and not the device, so the deactivation in a car which isn't "authorized" to have them is just logical. From a consumers point of view that's obviously not so cool, yet if we're truly honest - they didn't pay for it in the first place. Sort of like buying a used computer, which has Windows and Office installed on it. Sure, you can buy it, yet that doesn't make you a legal owner of a Windows or Office license.
Spacewalker
Poland
C?ID=159607
On my example , bought MIB Gen 1 for Golf 7 with all futures , guy told me - just remove CP in a dealer , dont do any adaptation / matches , all working, proper VIN , I did myself coding and adaption , working over a year now
GEN2 can not be do like that any longer
also all MIB units for PQ platform - this same, after CP remove is just a radio, nothing available.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
If you get your hands on an ODIS session log from such a case, I would bet my tushy that there is actually more than just CP happening. The only other thing I can think of, the unit looses all SWaP activations once CP is active.
m87a
Bosnia and Herzegovina
C?ID=156900
i can confirm same with MIB1 a friend just did CP remove and kept all swap codes and correct VIN, but PQ loses all same with MIB2. Since 5-6 months dealer refuses all CP removal for used parts :(
