ABS code fault
mohamed
Egypt
C?ID=211960
Could you help me with the ABS code
Monday,24,July,2017,05:45:01:43156
VCDS Version: 16.8.4.2
Dealer/Shop Name: Harisa car service
VIN: TMBDA11Z662186254   License Plate:
Mileage: 155490km-96617mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: TMBDA11Z662186254   Mileage: 155490km-96617miles
Address 01: Engine        Labels: 06A-906-033-BGU.lbl
   Part No: 06A 906 033 FE
   Component: SIMOS71 1.6l 2V     7006
   Revision: --H01---    Serial number: SKZ7Z0E3276437
   Coding: 0000075
   Shop #: WSC 73430 790 00000
   VCID: 67D95C4E56C5407A68-8032
16414 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
            P0030 - 009 - Malfunction / Open Circuit
                    Bin. Bits: 00001000
                    Resistance: 16.38 kOhm
                    Voltage: 2.100 V
                    Load: 8.6 %
17837 - Circuit for Brake Vacuum Pump
            P1429 - 009 - Open Circuit - Intermittent
                    RPM: 736 /min
                    Mass Air / Rev.: 152.6 mg/str
                    Bin. Bits: 00000011
                    Bin. Bits: 00000100
                    RPM: 832 /min
                    Mass Air / Rev.: 119.9 mg/str
                    Bin. Bits: 00000000
                    Bin. Bits: 00000100
16500 - Engine Coolant Temp. Sensor (G62)
            P0116 - 008 - Implausible Signal - Intermittent - MIL ON
                    RPM: 640 /min
                    Voltage: 0.620 V
                    Temperature: 76.5°C
                    Hex Value: 0x0004
                    RPM: 1184 /min
                    Voltage: 0.380 V
                    Temperature: 94.5°C
                    Hex Value: 0x0008
Readiness: 0110 0101
   Part No: 09G 927 750 DK
   Component: AQ 250 6F           0646
   Coding: 0000008
   VCID: 7DF51E262459FAAAA2-8028
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AF    HW: 1K0 907 379 AF
   Component: MABS MK70M          0103
   Revision: 00H32001
   Coding: 0020737
   Shop #: WSC 73430 790 00999
   VCID: 76E7010A016FA9F2E3-8022
            003 - Mechanical Failure
   Part No: 1Z0 820 047 D
   Component: Climatic PQ35   010 0301
   VCID: 3463FB025793FBE21D-8060
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000003674431
   Coding: A0040E030004140000110D000000000000087B075C
   VCID: 2A5FE57A8557BD12B7-807E
   Subsystem 1 - Part No: 1Z1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 73430
                    Fault Status: 00101100
                    Reset counter: 63
                    Mileage: 152245 km
                    Voltage: 11.90 V
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 06 AIRBAG VW52  023 2400
   Revision: 04023000    Serial number: 0037TD08B6D4
   Coding: 0012342
   Part No SW: 1K0 953 549 AK    HW: 1K0 953 549 AK
   Coding: 0010042
   Shop #: WSC 43102 431 55164
   VCID: 7BF1103E3A4DF49A9C-802E
00895 - Cruise Control Switch (E45)
            014 - Defective
   Part No: 1Z0 920 820 B
   Component: KOMBIINSTRUMENT VD1 3562
   Coding: 0002701
   VCID: 326FFD1AAD87F5D20F-8066
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105A20865D
   Coding: 3F0F0340071302
   Shop #: WSC 12345 007 183346
            000 -  -  - Intermittent
                    Reset counter: 72
                    Mileage: 149927 km
                    Time: 18:56:04
   Component: IMMO                3562
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2345
   Coding: 0000180
   VCID: 3667C10A41EFE9F223-8062
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 3361F81E529DFCDA04-8066
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Coding: 02D002407F2D8505484B861004CC
   Shop #: WSC 08224 211 56823
   VCID: 79FD0A363071C68A8E-802C
   Subsystem 3 - Component:      IRUE No Answer
   Part No: 1T0 959 702 B
   Coding: 0000180
   VCID: 3779CC0E46E510FA38-8062
   Part No SW: 1Z0 035 152 B    HW: 1Z0 035 152 B
   Component: Radio YD5           0004
   Revision: 00000000    Serial number: SKZAZ1E4001686
   Coding: 0000200
   VCID: 2D55EE66B4B9AA2A52-8078
End-------------------------(Elapsed Time: 01:53)--------------------------
mohamed
Egypt
C?ID=211960
Is there is anything about the code of abs ?
