2005 A8 D3
Devilz
C?ID=253973
I had Audi A8 D3 for some tweaks today. First thing first I did full scan which is as below:
Saturday,22,July,2017,17:59:56:25423
VCDS Version: 17.1.3.0
VIN: WAUZZZ4E36N001868   License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 13 15 16 17 18 19 1D 1E 25 28
          34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 69 72 76
          77
VIN: WAUZZZ4E36N001868   Mileage: 173890km-108050miles
1D-Driver Ident. -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
57-TV Tuner -- Status: Malfunction 0010
65-Tire Pressure -- Status: Not registered 0011
67-Voice Control -- Status: Malfunction 0010
   Part No SW: 4E0 910 409 H    HW: 4E0 907 409 C
   Component: 4.0L V8TDI  A000AGMª0010
   Revision: --H01---    Serial number: AUX3Z0E3362460
   Coding: 0010773
   Shop #: WSC 02313 785 00200
   VCID: 285FA89A9B90540181-807C
17861 - Exhaust Gas Temp Sensor 1 (G235)
            P1453 - 000 - Open or Short to Plus
                    Torque: 19.5 Nm
                    Duty Cycle: 0.4 %
                    Voltage: 8.59 V
                    Temperature: 690.2°C
                    Temperature: 110.2°C
                    Inj. Quantity: 0.0 mg/str
Readiness: 0 0 1 1 1
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E1 910 156 L    HW: 09E 927 156 A
   Component: AG6 09E 4,0LTDI RdW 0020
   Revision: --H01---    Serial number:        0056576
   Coding: 0000001
   VCID: 2C57548A8F68782165-8078
18265 - Load Signal
            P1857 - 000 - Error Message from ECU - Intermittent
                    Fault Status: 00110000
                    Reset counter: 22
                    Mileage: 173580 km
                    Date: 2017.07.13
                    Time: 10:12:52
                    RPM: 992 /min
                    RPM: 960 /min
                    RPM: 608 /min
                    (no units): 3.0
                    (no units): 48.0
                    Temperature: 55.0°C
                    T.B. Angle: 21.2°
18258 - Powertrain Data Bus
            P1850 - 000 - Missing Message from ECU - Intermittent
                    Reset counter: 22
                    Mileage: 173580 km
                    Date: 2017.07.13
                    Time: 10:12:52
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
   Component: ESP 5.7 allrad  H44 0510
   Coding: 0008557
   Shop #: WSC 02313 000 00000
   VCID: 224BBAB2FDACBE51DF-8076
            000 -  -
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 907 181 A
   Component:     FBS AUDID3  H12 0200
   Revision: 02005112    Serial number: AUX3Z0E3362460
   Coding: 0265216
   Shop #: WSC 01223 210 182671
   VCID: 58BFD85AEB702481F1-800C
                    Fault Frequency: 0
                    Reset counter: 114
                    Mileage: 173888 km
                    Date: 2017.07.22
                    Time: 00:04:28
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 C    HW: 4E0 959 760
   Component: Sitzmemory BFS H08  0060
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4063328
   VCID: 2345BFB6E2B6B759D4-8076
                    Reset counter: 114
                    Mileage: 173892 km
                    Date: 2017.07.22
                    Time: 00:00:55
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 730 F    HW: 4E0 035 729 A
   Component: Interfacebox    H43 1110
   Revision: 00000000    Serial number: 300D9057550044
   Coding: 0000002
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH01 0050
   Subsystem 2 - Serial number: 00000000095911
   Subsystem 3 - Serial number: 0128.03.120000000100010021ÿ
   Subsystem 4 - Serial number: 010021ÿ
                    Reset counter: 114
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:00:46
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 D
   Component: KLIMAAUTOMAT    016 0400
   Revision: 00000030    Serial number: 00000000064940
   Coding: 1136817
   Shop #: WSC 02311 785 00200
   VCID: 1C37844ADFC888A115-8048
00066 - Rear Right Footwell Heater (Z43)
                    Fault Status: 00101100
                    Reset counter: 110
                    Mileage: 170445 km
                    Date: 2017.03.29
                    Time: 15:33:26
                    Voltage: 13.30 V
                    Reset counter: 106
                    Mileage: 173648 km
                    Date: 2017.07.14
                    Time: 18:56:05
                    Voltage: 8.60 V
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 L    HW: 4E2 955 113 B
   Component: ILM Fahrer      H12 0210
   Coding: 0143121
   VCID: 316945FEA84A15C956-8064
   Subsystem 1 - Part No: 4E2 910 113 B
   Component: Wischer WWS D3  H50 0420
   Coding: 00000037
   Shop #: WSC 02313
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00139548
   Shop #: WSC 02313
                    Reset counter: 114
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:09:05
00908 - Control Module for Wiper Motor
                    Reset counter: 114
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:09:05
Address 11: Engine II        Labels: Redir Fail!
   Component: 4.0L V8TDI  A000AGSª0010
   Coding: 0010773
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 4E0 910 561 F    HW: 4E0 907 561 F
   Component: ABSTANDSREGELUNGH03 0020
   Coding: 0011155
   VCID: 2541A1AEEC824969BA-8070
            013 - Check DTC Memory - Intermittent - MIL ON
                    Fault Status: 10111101
                    Reset counter: 114
                    Mileage: 173892 km
                    Date: 2017.07.22
                    Time: 00:02:00
                    Temperature: 28.0°C
                    Voltage: 8.45 V
                    Bin. Bits: 00100000
                    Fault Status: 11111101
                    Reset counter: 74
                    Mileage: 173892 km
                    Date: 2017.07.22
                    Time: 00:02:00
                    Temperature: 28.0°C
                    Voltage: 12.29 V
                    Bin. Bits: 00100000
            002 - Lower Limit Exceeded - Intermittent - MIL ON
                    Reset counter: 74
                    Mileage: 173892 km
                    Date: 2017.07.22
                    Time: 00:02:00
                    Fault Status: 10110010
                    Reset counter: 114
                    Mileage: 173892 km
                    Date: 2017.07.22
                    Time: 00:09:00
                    Temperature: 27.0°C
                    Voltage: 7.42 V
                    Bin. Bits: 00100000
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655     HW: 4E0 959 655 G
   Component: Airbag 8.4E+    H10 0940
   Coding: 0431707
   VCID: 63C5FFB6A236F75994-8036
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549
   Component: Lenksäulenmodul H13 0040
   Coding: 0112151
   VCID: 65C1E1AEAC0289697A-8030
   Component: Lenkradmodul    H07 0080
                    Reset counter: 114
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:09:09
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 980 N    HW: 4E0 920 980 N
   Component: KOMBIINSTR. VDO H70 0400
   Revision: D01         Serial number: AUDID3E3000186
   Coding: 0016413
   Shop #: WSC 39809 067 57207
   VCID: 326B4AF2AD4C2ED12F-8066
                    Reset counter: 114
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:03:55
Address 18: Aux. Heat        Labels: None
   Part No SW: 4E0 910 105 A    HW: 4E0 815 069 E
   Component: Heizgeraet      H07 0100
   Revision: 0000000B    Serial number: 00000009006406
   Coding: 0000001
   VCID: 1A3B8252D5FCF69107-804E
Address 19: CAN Gateway        Labels: 4E0-910-468.clb
   Part No SW: 4E0 910 468 B    HW: 4E0 907 468 F
   Component: Gateway         H10 0080
   Revision: 10          Serial number: 1800405322004E
   Coding: FFFFFFDE2B7504
   VCID: 275DABA6968E5B7988-8072
                    Fault Status: 01100010
                    Reset counter: 74
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:10:55
            000 -  -
                    Reset counter: 74
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:10:55
Address 1D: Driver Ident.        Labels: 4E0-910-218.lbl
   Part No SW: 4E0 910 218 A    HW: 4E2 905 218 B
   Component: FPI_1           H01 0010
   Revision: 01000101    Serial number: 31012005175649
   VCID: 1F4DB346CEDE93B9F0-804A
                    Fault Frequency: 0
                    Reset counter: 114
                    Mileage: 173888 km
                    Date: 2017.07.22
                    Time: 00:03:38
                    Fault Frequency: 0
                    Reset counter: 114
                    Mileage: 173888 km
                    Date: 2017.07.22
                    Time: 00:11:20
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0430
   Revision: 00000000    Serial number: AUZ5ZBE7145383
   VCID: 1B358756DAC68F991C-804E
                    Reset counter: 114
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:10:04
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0265216
   XXXXXXXXXXX ELV                 XXXX
                    Fault Frequency: 0
                    Reset counter: 114
                    Mileage: 173888 km
                    Date: 2017.07.22
                    Time: 00:04:28
   Part No SW: 4E0 910 158     HW: 4E0 919 158 A
   Component: KLIMA-STG. FOND 015 0220
   Revision: 00000018    Serial number: 00000000026399
   Coding: 0000000
   VCID: 61C9F5BEB82AE54986-8034
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 6310
   Coding: 0015520
   Shop #: WSC 00011 888 06946
   VCID: 2A5B5292859C661197-807E
01598 - Drive Battery Voltage
                    Reset counter: 114
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:05:02
   Component: Sitzmemory FS  H08  0060
   Coding: 4063342
                    Reset counter: 114
                    Mileage: 173892 km
                    Date: 2017.07.22
                    Time: 00:00:55
   Part No SW: 4E0 910 887 L    HW: 4E0 919 887 C
   Component: MNS ECE         H44 0690
   Revision: 00000000    Serial number: 305DM057583037
   VCID: 366376E2412432F103-8062
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 0
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:15:56
                    Bin. Bits:     0100
                    Reset counter: 0
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:15:56
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H02 0090
   Serial number: 00000504700025
   Coding: 0036038
   VCID: 1D31894EC4D281A9E2-8048
00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
            000 -  -  - Intermittent
                    Reset counter: 114
                    Mileage: 173892 km
                    Date: 2017.07.22
                    Time: 00:05:00
                    Reset counter: 114
                    Mileage: 173892 km
                    Date: 2017.07.22
                    Time: 00:09:00
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 802 B
   Component: Türsteuer.FS BRM003 0060
   Coding: 0028462
   VCID: 204FB0BAF3A0AC41C9-8074
02111 - Motor for Window Regulator
                    Fault Frequency: 0
                    Reset counter: 114
                    Mileage: 173888 km
                    Date: 2017.07.22
                    Time: 00:06:06
                    Fault Frequency: 0
                    Reset counter: 114
                    Mileage: 173888 km
                    Date: 2017.07.22
                    Time: 00:06:06
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H04 0040
   Revision: 00400004    Serial number:  W040504050026
   Coding: 0004317
   Subsystem 1 - Part No: 4E0 907 719
   Component: Neigungssensor  H03 0020
                    Reset counter: 114
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:12:40
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 K    HW: 4E0 035 223 A
   Component: DSP-Amp.-High   H13 0440
   Revision: PROD_01     Serial number: 00000000013092
   Coding: 0000011
                    Reset counter: 114
                    Mileage: 173772 km
                    Date: 2017.07.18
                    Time: 00:00:58
                    Reset counter: 114
                    Mileage: 173772 km
                    Date: 2017.07.18
                    Time: 00:00:58
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H09 0040
   Revision:             Serial number: 00000000059086
   Coding: 0010101
   VCID: 1E338E42C9D49AB1FB-804A
                    Fault Status: 00110010
                    Reset counter: 114
                    Mileage: 173892 km
                    Date: 2017.07.22
                    Time: 00:07:00
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 801 B
   Component: Türsteuer.BF BRM003 0060
   Coding: 0028462
                    Fault Frequency: 0
                    Reset counter: 114
                    Mileage: 173888 km
                    Date: 2017.07.22
                    Time: 00:07:62
                    Fault Frequency: 0
                    Reset counter: 114
                    Mileage: 173888 km
                    Date: 2017.07.22
                    Time: 00:07:62
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 A    HW: 4E0 907 801
   Component: EPB  AV1C1010   H01 1010
   Revision: AV1C1010
   Coding: 0000431
   Shop #: WSC 00383 210 80878
                    Reset counter: 114
                    Mileage: 173888 km
                    Date: 2017.07.22
                    Time: 00:09:17
                    Voltage: 7.04 V
                    Count: 200
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Coding: 0000018
   VCID: 2643A6A291844271B3-8072
   Subsystem 1 - Part No: 4F0 941 329 A
   Component: AFS-Modul links H05 0010
   Subsystem 2 - Part No: 4F0 941 329 A
   Component: AFS-Modul rechtsH01 0010
                    Mileage: 173896 km
                    Date: 2017.07.22
                    Time: 00:07:57
02233 - Left Headlight Power Output Stage (J667)
                    Mileage: 173896 km
                    Date: 2017.07.22
                    Time: 00:07:57
02234 - Right Headlight Power Output Stage (J668)
                    Mileage: 173896 km
                    Date: 2017.07.22
                    Time: 00:07:57
   Part No SW: 4E0 910 541 F    HW: 4E0 035 541 E
   Component: TUNER EU/US/RDW H42 0480
   Revision: 00000000    Serial number: 396DR057507702
   Coding: 0000001
                    Reset counter: 114
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:01:39
                    Reset counter: 114
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:01:39
Address 57: TV Tuner        Labels: 4E0-910-146.clb
   Part No SW: 4E0 910 146 E    HW: 4E0 919 146 B
   Component: TV analog TUNER H13 0270
   Revision: 00000010    Serial number: 00000000001317
   Coding: 0001003
                    Reset counter: 114
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:08:42
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: ENERGIEMANAGER  H12 0480
   Revision: 00000000    Serial number: 00000000005469
   Shop #: WSC 00958 210 51185
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  300410A23L
   Coding: 34453039313531303541205641303330303431304132334C
   Shop #: WSC 00383 210 83674
02276 - Quiescent Current Stage 5
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:09:51
02274 - Quiescent Current Stage 3
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:09:51
02277 - Quiescent Current Stage 6
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:09:51
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
   Component: Türsteuer.HL BRM003 0060
   Coding: 0028462
                    Fault Frequency: 0
                    Reset counter: 114
                    Mileage: 173888 km
                    Date: 2017.07.22
                    Time: 00:09:44
                    Fault Frequency: 0
                    Reset counter: 114
                    Mileage: 173888 km
                    Date: 2017.07.22
                    Time: 00:09:44
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273     HW: 4E0 907 273
   Component: Reifendruck 2   H01
   Revision: 00010028    Serial number: 00000700031509
   Coding: 0202328
   VCID: 5FCDF3468E5ED3B9B0-800A
                    Fault Status: 10100010
                    Reset counter: 114
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:10:43
                    Voltage: 8.20 V
                    (no units): 42.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01477 - System Switched Off
            000 -  -
                    Reset counter: 114
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:10:43
   Part No SW: 4E0 910 754 D    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H45 0560
   Revision: 00000000    Serial number: 00000503300059
   Shop #: WSC 12336 024 394758
                    Reset counter: 114
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:09:31
Address 69: Trailer        Labels: 4E0-910-383.lbl
   Part No SW: 4E0 910 383 B    HW: 4E0 907 383 B
   Component: ANHAENGERELEKTR 003 0040
   Coding: 0000001
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 C
   Component: Türsteuer.HR BRM003 0060
   Coding: 0028462
                    Fault Frequency: 0
                    Reset counter: 114
                    Mileage: 173888 km
                    Date: 2017.07.22
                    Time: 00:10:58
                    Fault Frequency: 0
                    Reset counter: 114
                    Mileage: 173888 km
                    Date: 2017.07.22
                    Time: 00:10:58
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
   Component: Parkhilfe 8-Kan H12 0020
   Revision: 06.00.57    Serial number: 00067808720509
   Coding: 0111108
   VCID: 2149B5BEF8AAA549C6-8074
                    Reset counter: 114
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:10:23
   Part No SW: 4E0 910 336 C    HW: 4E0 862 335
   Component: Handyvorb2      H10 0120
   Revision: 00000000    Serial number: 00000007548564
   Coding: 0010900
                    Reset counter: 114
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:12:02
End-------------------------(Elapsed Time: 04:00)--------------------------
The battery died half way through when I was trying to clear the faults. Had to jump start the vehicle and did the scan today and clear the faults. Kept the engine running this time and on MMI battery meter was like 0% which eventally showed 100%
Saturday,22,July,2017,18:15:32:25423
          77
1D-Driver Ident. -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
65-Tire Pressure -- Status: Not registered 0001
   Coding: 0010773
                    RPM: 651 /min
                    Torque: 89.7 Nm
                    Duty Cycle: 0.4 %
                    Voltage: 13.53 V
                    Temperature: 145.0°C
                    Inj. Quantity: 8.2 mg/str
   Coding: 0000001
   Coding: 0008557
            000 -  -
   Coding: 0265216
   Coding: 4063328
   Coding: 0000002
   Coding: 1136817
   Part No SW: 4E0 910 279 L    HW: 4E0 907 279 L
   Coding: 0143121
   Coding: 00000037
   Shop #: WSC 02313
   Coding: 00139548
   Shop #: WSC 02313
   Coding: 0010773
   Coding: 0011155
                    Reset counter: 74
                    Mileage: 173892 km
                    Date: 2017.07.22
                    Time: 00:34:00
                    Temperature: 30.0°C
                    Voltage: 13.95 V
                    Bin. Bits: 00100100
   Coding: 0431707
   Coding: 0112151
   Coding: 0016413
   Coding: 0000001
            000 -  -
                    Reset counter: 74
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:26:15
   Coding: 0265216
   Coding: 0000000
   Coding: 0015520
   Coding: 4063342
   Coding: 0036038
   Coding: 0028462
   Coding: 0004317
   Coding: 0000011
   Coding: 0010101
   Coding: 0028462
   Revision: AV1C1010
   Coding: 0000431
   Coding: 0000018
   Coding: 0000001
   Coding: 0001003
   Coding: 0028462
   Coding: 0202328
            000 -  -
                    Reset counter: 74
                    Mileage: 173894 km
                    Date: 2017.07.22
                    Time: 00:32:21
                    Temperature: 19.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0000001
   Coding: 0028462
   Coding: 0111108
   Coding: 0010900
End-------------------------(Elapsed Time: 03:46)--------------------------
need advise what could be the cause of battery drain, also I couldn't do any changes for some reason.
JulianHicks
Kent, UK
C?ID=265735
Sounds like this is someone else's car! Not sure what battery drain you see unless you ran the scans with the ignition on, no engine running and with no battery charger attached to the BEM in the boot!
As Uwe may well quickly add later, these cars are HUGE drains on the battery; and you need the ignition ON to runs VCDS scans. Either run the engine or attach a 25Amp charger to the battery red terminal [+] and the external charging post on the BEM [-] when you're doing scans.
Suggest you clear DTCs individually by going to each ECU and clearing the codes; the run the car 'round the block' and then re scan with an Autoscan.
BTW this car has really old MMI software; the control head indicates MMI level 11.1.0 [1110] which dates from Jan 2005. Best advice is to update these cars to 5570 level which is the latest/last level of code for this car dating from Oct 2008. [It's really irritating seing all the cars on forums that are purchased in 2017 with no MMI updates since the car was new].:banghead:
Julian
JulianHicks
Kent, UK
C?ID=265735
BTW, I note, too, that this car has a BEM with a 'bad' level - 0480
   Component: ENERGIEMANAGER  H12 [COLOR="#FF0000"]0480[/COLOR]
This BEM firmware level has been identified by Audi as producing unspecified bad info. for which they supplied replacement firmware back in 2009.
Julian
