how can i change the "shop name" in my vag-com
stowburb
Garner/Clayton NC
C?ID=77250
Hey Guys, I used to work at another shop and while I was there I bought myself a Vag-com Cable from Ross-Tech, and when I set it up I put the shops name in my vag-com so when I print off the auto scan codes it would have their name on top of the page. I no longer work for them and I would like to remove their name, but when I go into options that part is greyed out and I cant change or erase it.
Is there anything I can do, or am I just stuck with that shop's name on my Vag-com auto scan printout?
It's in VCDS.CFG. Just delete that file, then do [Options] -> [Test] -> [Save] and you'll have a nice new clean one.
stowburb
Garner/Clayton NC
C?ID=77250
cool, are you saying basically just delete the VCDS software from my laptop and reinstall it?
No, I'm saying just delete that one little file.
stowburb
Garner/Clayton NC
C?ID=77250
hmmmm, where will I find that file?
In the folder that you have VCDS installed in.
stowburb
Garner/Clayton NC
C?ID=77250
ok, cool, hate to keep bugging you, can you tell me how that file is labeled? and you say just delete it and the basically reset my options up and i'll be good,right?
Santos
The File in the VCDS folder is called VCDS.CFG. Delete the file. Then open VCDS and plug into a car. Then click [Options] [Test]. This will generate a new VCDS.CFG without the shop name.
stowburb
Garner/Clayton NC
C?ID=77250
wonderful! thank you guys so much!!
NEtech
Denmark
C?ID=56995
Or just click vcds car icon at the top / left corner of vcds window, click [Delete config file and close].
