Audi A3 8V 2013 swap central electronic MID for HIGH
XPepino
Czech Republic
C?ID=91614
Hello
is there any way to copy via VCDS or VAG CAN PRO adaption settings from old MID unit to HIGH ?
I have to swap unit due heated seats.
But nothing about lights work now :-/ In this new High units was installed Xenon Headlights and I have only halogen.
My old unit:
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
   Component: BCM MQBAB M   H14 0106
   Serial number: 00011229201261
   Coding: 04001842C20100DD03044000001407A80000000000000000000000000000
   Shop #: WSC 45343 001 1048576
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_010.rod
   VCID: 4381293DCA10A259B4-8016
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 120916  041 0580
   Serial number:         120928192046
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8V0 941 531 N    HW: 8V0 941 531 N
   Serial number: 07 08 2012  00000364
   Subsystem 3 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 20188473
My new unit have lot of errors, i post later.
You can run Adaptation function control module maps with VCDS, and I would do that with the factory original and then the newly retrofitted one for comparison, and that results in files like this:
http://forums.ross-tech.com/showthread.php?8917-2017-NAR-Golf-Alltrack
VCDS cannot upload all Adp settings from a module map into a module. You would have to do that manually.
VCDS cannot upload parameters or resolve CP DTCs so that MQB BCM retrofit will require additional tools. If you need more specific answers please post the Adp map and Auto-Scan before any modifications in addition to the same info after the new BCM is installed so someone with experience can comment.
Pepino (what an gorgeous name!): Hi. In addition to Dana's excellent advice, a tad more additional information might be useful for the retrofit mentioned above - because how the Leuchte-sets in your new BCM should be programmed is dependent on how the new Xenon fittings were installed. Did you run any additional wires back to the new BCM for the Xenon units, or did you use a cross wiring loom on the 10 x pin existing halogen connector?
XPepino
Czech Republic
C?ID=91614
Hello Don!
I did not retrofit Xenon light, there is an original Halogen. I am on business trip now, so i cant post scan.
But there are lot of errors about lights not working high beam etc.
XPepino
Czech Republic
C?ID=91614
Dana, thank you, i try do it on weekend.
Hello, i tried make list of old one unit and new one unit.
CSV are in link...
Do you have any metod to automated compare these 2 files and make result ?
Old one is
adpmap-09-5Q0-937-084-N.zip
New one is
adpmap-09-5Q0-937-084-AJ.zip
Pepino: Your BCM Compare file is HERE
Some explanations follow:
  1. There are a total of 2,026 x Adaptation Channels in the New BCM
  2. There are 1,789 Adaptation Channels in the Old BCM
  3. The New BCM has 259 x Adaptation Channels that aren't present in the Old BCM
  4. The Old BCM has 22 x Adaptation channels that aren't in the New BCM
  5. In the "Pepino BCM compare" worksheet, I've used the New BCM as a reference source. Please note that this worksheet makes a literal comparison of settings - if ANY part of the setting value is different between the 2 x BCM s, the comparison "Same?" will return a negative result. In some channels, the setting differences are purely cosmetic, but the "Same?" value will still be No in these instances. The second worksheet are those channels that are present in the Old BCM, but are not present in the New BCM (the new channels in the New BCM are embedded in the BCM Compare worksheet)
XPepino
Czech Republic
C?ID=91614
Wow :-)
You are :thumbs:
If there is no automated import of adaption channels, i think i spend night in car :-)
Thank you
