7L Touareg Rain sensor
HCAE
New Zealand
C?ID=213797
Hi all
Have a mate with a 7L Touareg wipers don't work on intermittent. We suspect a faulty rain sensor but can't find any measuring blocks with the data in it. Can someone point me in the right direction please?
From what I can tell it has rain sensor enabled in the coding...
Auto Scan
Thursday,21,August,2014,16:56:17:55685
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVGZZZ7LZ5D065348   License Plate:
Mileage: 141190km-87731mi   Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ5D065348   Mileage: 141190km/87731miles
Address 01: Engine        Labels: 077-907-560-AXQ.lbl
   Part No SW: 4D0 907 560 BQ    HW: 8E0 907 560
   Component: 4.2L V8/5V      G   0070
   Coding: 0011875
   Shop #: WSC 31414 000 00000
   VCID: 76E3F4A3021EB8AEB1B-5140
Address 02: Auto Trans        Labels: 09D-927-750.lbl
   Part No: 09D 927 750 BQ
   Component: AL 750 6A           0577
   Coding: 0012330
   VCID: 7EF3EC832A2EF0EEE9B-5140
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0014594
   VCID: 3D712B8F67A82BF6B01-5140
   Part No SW: 3D0 909 135 P    HW: 5WK 470 25
   Component:    Kessy            6610
   Revision: 66105312    Serial number: VWZ3Z0E5311932
   Coding: 0008424
   VCID: 326B08B3AEF6E48E5D3-5140
00172 - Key 2 not learned
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 H
   Component: CLIMAtronic R/L   X 3716
   Coding: 0000030
   VCID: 356133AF5F98F3B6781-5140
Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 M
   Component:                     3001
   Coding: 0236796
   VCID: 46834463327E682EE1B-5140
   Part No: 3D0 909 601 E
   Component: 0B Airbag 8.4E+ H10 0951
   Coding: 0012354
   VCID: 2541E3EFEF388336C81-5140
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 D
   Component: Lenksäulenmodul     3301
   Coding: 0000031
   VCID: 408F527B105A461EDB7-5140
   Subsystem 1 - Part No: 7L6 953 549 D
No Faults Found
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 881
   Component: KOMBIINSTRUMENT RB8 3135
   Coding: 0007511
   Shop #: WSC 87300 981 60639
   VCID: F5E173AF9F1833B6381-5140
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: F0EF42BBE07A169EEB7-5140
   Part No: 0AD 927 755 AJ
   Component: TRANSFERCASE        0100
   VCID: 83051D77C1CC1D06065-5140
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Coding: 0000003
   VCID: E6C324E3D2BEC82E81B-515E
01344 - HID (Xenon) Headlight
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   VCID: 366334A3429EF8AE71B-5140
Address 39: Right Light        Labels: 3D0-909-158.lbl
   Part No: 3D0 909 158
   Component: EVG GDL+AutoLWR(r)  0001
   Coding: 0000017
   VCID: E7DD29E7D5B4D126BAD-5124
00003 - Control Module
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L0 959 933 E
   Component: 2L HSG              0201
   Coding: 0000069
   VCID: 3E732C836AAE30EEA9B-4B00
   Subsystem 1 - Part No: 7L0 959 701 K
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 K
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 C
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 C
   Component: Tuersteuergeraet HR 0201
   Subsystem 5 - Part No: 7L0 907 719
   Subsystem 6 - Part No: 7L6 951 171
   Component: A  Innenraumsensor  0019
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 L
   Component: Front Wiper         4027
   Coding: 0000855
   Shop #: WSC 31414 000 376832
   Component: RLS     240208 046  0204
   Coding: 00733221
   Shop #: WSC 31414
Address 76: Park Assist        Labels: 3D0-919-283.lbl
   Part No: 7L0 919 283 F
   Component: 0D Einparkhilfe     1107
   VCID: 39793F9F738017D69C9-515E
The first thing I'd do is check status of wiper switch 68: Wiper Electr, MVB 001.
HCAE
New Zealand
C?ID=213797
Forgot to mention that, we have checked the switch operation and it all seems to be fine.
NEtech
Denmark
C?ID=56995
Have you checked engine hood (or whatever it is called) contact, [46-Central comfort], MWB 014 ?
In addition to the Hood/Bonnet suggestion I wonder if vehicle speed is required for the Intermittent operation? My Tiguan with RLS (which is a completely different animal diagnostically) for example stops wiping until I begin to accelerate based on the factory speed dependent settings. I have no idea if that's possible on a T'reg but hopefully someone can chime in and correct me.
Gone But Not Forgotten
Just out of curiosity has anyone tried coding out the rain sensor, so the wipers just work when you hit the switch.
My favorite is the hood switch personally.
Don't rule out that wipers may also be effected by the DTC either cluttering traffic on CAN in addition to other DTC's or could possibly be required for wipers on since its a law/rule in most places to have lights on when wipers are on........
Lgibson
C?ID=41716
The 7L with "rain sensor automatically either shortens or lengthens the intervals between wipes depending on how hard it is raining." Not directly under your control.
There is an upgraded sensor you might like better: 1K0 955 559 AH.
You might also check Byte 2 of your coding. Should be 2D For Touareg with the AH version. Not sure about AF tho.
