- Dec 3, 2014
- 30
- 35
- Tartu, Estonia
- C?ID=238046
Here is scan from brand new VW Arteon from dealer from a test drive.
Saturday,15,July,2017,20:47:53:36026
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
VCDS Version 17.6.0.2 (x64) HEX-NET CB: 0.4346.4
Data version: 20170602 DS274
Dealer/Shop Name: LeVWFreaks.eu
VIN: WVWZZZ3HZJE****** License Plate:
Chassis Type: 3H (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 29 2B 39 42 44 4B 52 5F
6C 75 A5 BB BC D6 D7
VIN: WVWZZZ3HZJE****** Mileage: 141km-87miles
Address 01: Engine (J623-DFGA) Labels: None
Part No SW: 04L 906 026 KD HW: 04L 907 309 P
Component: R4 2.0l TDI H25 4798
Revision: B4H25---
Coding: 0125041203641D083000
Shop #: WSC 05311 115 00312
ASAM Dataset: EV_ECM20TDI01104L906026KD 005005
ROD: EV_ECM20TDI01104L906026KD.rod
VCID: 76A02D94C94B87F7EB-8023
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0GC 300 042 H HW: 0GC 927 711 G
Component: GSG DQ381 H06 1404
Revision: 00H06V07
ROD: EV_TCMDQ381061_VW48.rod
VCID: 2B16CCE042898A1F44-807F
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 61377000003369
Coding: 0DEC6A9434200B6C4780060240C849B0562CD0E2600292753862F078C222420000000012121212B835351919323200
Shop #: WSC 00015 115 08193
ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
VCID: 77BE2090CE41FEFFF0-8023
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0906
Revision: 00037000 Serial number: 0441733983
Coding: 1F20000723
VCID: 3E30F5B4A1FB0FB7F3-806B
Part No SW: 5G0 907 044 DP HW: 5G0 907 044 DP
Component: Climatronic H04 2001
Revision: 00001K10
Coding: 14020104202110011115500C00101922
ROD: EV_ACClimaBHBVW37X_006_VW27.rod
VCID: 78BC23ACC35FF187F9-802D
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 086 BL HW: 5Q0 937 086 BG
Component: BCM PQ37BOSCH 034 0242
Revision: -------- Serial number: 865819051700NQ
ROD: EV_BCMBOSCH_018.rod
VCID: 05425A5884AD9C6FF2-8051
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170414 042 0607
Serial number: 170508135327
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 20263364X81A955547A0
Coding: 00006E
Subsystem 3 - Part No SW: 3G8 941 633 HW: 3G8 941 633
Component: E1 - LDS MQB H01 0032
Serial number: 22 02 2017 10000409
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY171080RE9
Serial number: 00000000000069673730
U1101 00 [008] - Active
Reset counter: 41
Mileage: 16 km
Date: 2017.07.08
Time: 13:01:46
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418617146
Coding: 0471151811
Shop #: WSC 05311 115 00069
ROD: EV_EPHVA18AU3700000.rod
VCID: 4BD6AC60E249AA1F64-801F
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 32017F4251FFC728949C812481400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
ROD: EV_ACCBOSCHVW416.rod
201226 - Databus
Reset counter: 41
Mileage: 16 km
Date: 2017.07.12
Time: 11:11:58
Dynamic environmental data: 02 8D
Control Module temperature: 31 °C
Voltage terminal 15: 14.4 V
Velocity_vehicle_reference: 0.03 m/s
Longitudinal_acceleration_vehicle_reference: 0.12 m/s²
Part No SW: 3Q0 959 655 BR HW: 3Q0 959 655 BR
Component: Airbag VW21 006 0702
Revision: -------- Serial number: 003WEP54TUJW
Coding: 98CCC0C00C0000005C5400CF000840000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW21TS6VW48X_VW27.rod
VCID: 0F6E7870D6D1D63F48-805B
Subsystem 1 - Part No SW: ----------- HW: 454 000 905 17
Serial number: 3570000000060D7D252K
Subsystem 2 - Part No SW: ----------- HW: 454 001 205 17
Serial number: 35800000000CF1F0E42-
Subsystem 3 - Part No SW: ----------- HW: 454 802 105 17
Serial number: 3510061A983100000004
Subsystem 4 - Part No SW: ----------- HW: 454 802 305 17
Serial number: 352003E04EA10000000D
Subsystem 5 - Part No SW: ----------- HW: 454 801 504 17
Serial number: 355005E89FF0F0000008
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 454 801 605 17
Component: PedP_Sensor_D 304 0149
Serial number: 228000E58E810000000J
Subsystem 7 - Part No SW: ----------- HW: 454 801 605 17
Component: PedP_Sensor_P 304 0149
Serial number: 22900FE4FE810000000+
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 454 801 605 17
Component: PedP_Sensor_C 304 0149
Serial number: 23000899BC110000000D
Subsystem 9 - Part No SW: ----------- HW: 454 002 804 17
Component: PedP_Sens_D_2 008 0887
Serial number: I0M00000000B1290842Y
Subsystem 10 - Part No SW: ----------- HW: 454 002 804 17
Component: PedP_Sens_P_2 008 0887
Serial number: I0N0000000011290842P
Part No SW: 5Q0 953 521 FE HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0225
Revision: FF034034 Serial number: 20170514500870
Coding: 0810
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
ROD: EV_SMLSVALEOMQBLRH_VW37.rod
VCID: 7AB839A4FD53E3978F-802F
291104 - Temperature Sensor for Heated Steering Wheel
B1455 01 [008] - Electrical Failure
Fault Frequency: 221
Reset counter: 43
Mileage: 15 km
Date: 2017.07.04
Time: 15:07:46
Ubat 30 Voltage: 12.40 V
Internal error state: 0
LIN_Temp: 254
Isense: 0
Max.Leistung: 110
PWM: 0
Offset: 238
Slope: 134
kp: 13
OUT: 50
Temperatur Statisch: 30
Tsoll Wert 0: 39.00 °C
Tsoll Wert 1: 43.00 °C
Tsoll Wert 2: 47.00 °C
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 3G0 920 741 C HW: 3G0 920 741 C
Component: KOMBI 202 0310
Coding: 07A4111B6F84000801806B031001000800000000
VCID: 240427DC2F57456785-8071
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 15051710522741
Coding: 0B0300045F087300FB00025A1C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 3326D4809AB9D2DF0C-8067
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 46170001360160097205
Coding: 2FFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75886000001705112486
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: U13DCAC H26 0780
Serial number: 0049388
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 0202201700010069
Address 29: Left Light (J1018) Labels: None
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH08 0014
VCID: 45C29A58C42D5C6FB2-8011
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000133492008
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 71AA1E88A025A0CF3E-8025
Address 39: Right Light (J1023) Labels: None
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 0000258277673
Coding: 00355A02D000020000001000
VCID: 47DE9050FE214E7F40-8013
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 1107
Shop #: WSC 00015 115 00312
ROD: EV_SteerAssisMQB_013_VW37.rod
VCID: 3A38F9A4BDD32397CF-806F
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 19051710800843
Coding: 000000050100044A01102F01020000000000000000000000000000000000
Shop #: WSC 05311 000 08193
ROD: EV_MultiModulContiVW48X_VW27.rod
VCID: 72A81184A5239BD7C7-8027
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 0000258747227
Coding: 00355002DE00020000001000
VCID: 46C09D54F92B5777BB-8013
Part No SW: 3Q0 035 846 B HW: 3Q0 035 846 B
Component: MU-S-N-ER 851 0842
Coding: 02840301FF0000005111000100080A001F0500C4012001008E
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 302CDB8C6BAFE9C771-8065
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8120
Serial number: VWZ6ZHT1171242
Subsystem 2 - Part No SW: 3G0 919 866 BC HW: -----------
Component: ECE1 2017/18 --- 0820
Component: RVC Compact H12 0231
Coding: 0184030162002017000040
VCID: 393AE6A8B8D5288FC6-806D
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 B HW: 5NA 035 284 B
Component: OCULowMQBLGE H17 0717
Revision: --------
Coding: 02840301EA42180D3F1CBE000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004044
ROD: EV_OCULowMQBLGE_004_VW25.rod
VCID: 3C34FFBCB7E71DA7DD-8069
Part No SW: 3Q0 980 654 J HW: 3Q0 980 654 A
Component: MQB_B_MFK H07 0273
Serial number: 11051712K20051
Coding: 0004080400000401002213448140A90094000E300000
ROD: EV_MFKBoschMQBB_VW36.rod
Part No SW: 5Q4 959 595 E HW: 5Q4 959 595 B
Component: TSG HFS 012 0032
Serial number: 0000259453978
Coding: 000050020100020000001000
ASAM Dataset: EV_DCURearDriveMAXCONT 006001
ROD: EV_DCURearDriveMAXCONT_VW37.rod
VCID: 49DA9668E835B80F56-801D
Component: TSG HBFS 012 0032
Serial number: 0000259453975
ASAM Dataset: EV_DCURearPasseMAXCONT 006001
ROD: EV_DCURearPasseMAXCONT_VW37.rod
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
ROD: N/A
VCID: 16600D14E90B27F70B-8043
No ASAM data for: "EV_LEDModLeftMELCOAU736" (VW52)
Component: LED1R H09 0003
ROD: N/A
No ASAM data for: "EV_LEDModRightMELCOAU736" (VW52)
End----------(Elapsed Time: 02:08, VBatt start/end: 12.3V/12.3V)-----------
