MK7 NAR Golf Wagon Kencha Tails V2 recode?
quailallstar
Ormond Beach, FL
C?ID=53119
My tails are currently coded to have both the outer/inner flash together when turn signals or braking is applied (Thanks to Don a few months back). I'll add that I have 7740 red LED bulbs installed inside the NAR incandescent housings from SuperBrightLeds.com which are a fraction of the cost found via other online re-sellers + Euro spec rear fog housing w/incandescent factory bulb.
Found the below tweak in the MK7GTI forums and curious if anyone here has done this on their wagon with success? I use and have both VCDS and OBDEleven.
@Davedough
Rear lights by Davedough:
So I did a thing tonight. The video is crappy because it was very late and my cell phone washed out with the brightness of my LEDs.
So I wanted both the inner and outer brake lights to illuminate as well as have directional indicators that cycled from the inner to the outer to show motion of direction. I also had one other stipulation and that was to have the lights go completely out when they indicated so there was a better visual display when the turn signals were on.
https://youtu.be/IS2OwRBF2B4
For the coding, Everything is done under Central Electrics with access code 31347 and Adaptation. From that menu, verify all the following settings:
Left outer Tail Function Value Notes
(1)-Leuchte20BR LA71-Lasttyp 20 35 - kombinierte LED Blink-Bremsleuchten Recommended setting if you are running LED bulbs
(2)-Leuchte20BR LA71-Lampendefektbitposition 20 13
(3)-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 3D
(4)-Leuchte20BR LA71-Lichtfunktion A 20 Bremslicht
(5)-Leuchte20BR LA71-Lichtfunktion B 20 Blinken links Dunkelphase
(6)-Leuchte20BR LA71-Dimmwert AB 20 100
(7)-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always
(8)-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(9)-Leuchte20BR LA71-Lichtfunktion D 20 not active
(10)-Leuchte20BR LA71-Dimmwert CD 20 36 Value 47 if standard LED bulbs
(11)-Leuchte20BR LA71-Dimming Direction CD 20 maximize
(12)-Leuchte20BR LA71-Lichtfunktion E 20 Blinken links Hellphase
(13)-Leuchte20BR LA71-Lichtfunktion F 20 not active
(14)-Leuchte20BR LA71-Dimmwert EF 20 0
(15)-Leuchte20BR LA71-Dimming Direction EF 20 minimize
(16)-Leuchte20BR LA71-Lichtfunktion G 20 not active
(17)-Leuchte20BR LA71-Lichtfunktion H 20 not active
(18)-Leuchte20BR LA71-Dimmwert GH 20 0
(19)-Leuchte20BR LA71-Dimming Direction GH 20 maximize
Right Outer Function Value Notes
(1)-Leuchte21BR RC8-Lasttyp 21 35 - kombinierte LED Blink-Bremsleuchten Recommended setting if you are running LED bulbs
(2)-Leuchte21BR RC8-Lampendefektbitposition 21 23
(3)-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3E
(4)-Leuchte21BR RC8-Lichtfunktion A 21 Bremslicht
(5)-Leuchte21BR RC8-Lichtfunktion B 21 Blinken rechts Dunkelphase
(6)-Leuchte21BR RC8-Dimmwert AB 21 100
(7)-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always
(8)-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(9)-Leuchte21BR RC8-Lichtfunktion D 21 not active
(10)-Leuchte21BR RC8-Dimmwert CD 21 36 Value 47 if standard LED bulbs
(11)-Leuchte21BR RC8-Dimming Direction CD 21 maximize
(12)-Leuchte21BR RC8-Lichtfunktion E 21 Blinken rechts Hellphase
(13)-Leuchte21BR RC8-Lichtfunktion F 21 not active
(14)-Leuchte21BR RC8-Dimmwert EF 21 0
(15)-Leuchte21BR RC8-Dimming Direction EF 21 minimize
(16)-Leuchte21BR RC8-Lichtfunktion G 21 not active
(17)-Leuchte21BR RC8-Lichtfunktion H 21 not active
(18)-Leuchte21BR RC8-Dimmwert GH 21 0
(19)-Leuchte21BR RC8-Dimming Direction GH 21 maximize
Left Inner Function Notes
(1)-Leuchte23SL HLC10-Lasttyp 23 35 - kombinierte LED Blink-Bremsleuchten Recommended setting if you are running LED bulbs
(2)-Leuchte23SL HLC10-Lampendefektbitposition 23 0A
(3)-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 29
(4)-Leuchte23SL HLC10-Lichtfunktion A 23 Bremslicht
(5)-Leuchte23SL HLC10-Lichtfunktion B 23 Blinken links Hellphase
(6)-Leuchte23SL HLC10-Dimmwert AB 23 100
(7)-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always
(8)-Leuchte23SL HLC10-Lichtfunktion C 23 Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(9)-Leuchte23SL HLC10-Lichtfunktion D 23 not active
(10)-Leuchte23SL HLC10-Dimmwert CD 23 36 Value 47 if standard LED bulbs
(11)-Leuchte23SL HLC10-Dimming Direction CD 23 maximize
(12)-Leuchte23SL HLC10-Lichtfunktion E 23 Blinken links Dunkelphase
(13)-Leuchte23SL HLC10-Lichtfunktion F 23 not active
(14)-Leuchte23SL HLC10-Dimmwert EF 23 0
(15)-Leuchte23SL HLC10-Dimming Direction EF 23 minimize
(16)-Leuchte23SL HLC10-Lichtfunktion G 23 not active
(17)-Leuchte23SL HLC10-Lichtfunktion H 23 not active
(18)-Leuchte23SL HLC10-Dimmwert GH 23 0
(19)-Leuchte23SL HLC10-Dimming Direction GH 23 maximize
Right Inner Function Value Notes
(1)-Leuchte24SL HRA65-Lasttyp 24 35 - kombinierte LED Blink-Bremsleuchten Recommended setting if you are running LED bulbs
(2)-Leuchte24SL HRA65-Lampendefektbitposition 24 1A
(3)-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 2A
(4)-Leuchte24SL HRA65-Lichtfunktion A 24 Bremslicht
(5)-Leuchte24SL HRA65-Lichtfunktion B 24 Blinken rechts Hellphase
(6)-Leuchte24SL HRA65-Dimmwert AB 24 100
(7)-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always
(8)-Leuchte24SL HRA65-Lichtfunktion C 24 Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(9)-Leuchte24SL HRA65-Lichtfunktion D 24 not active
(10)-Leuchte24SL HRA65-Dimmwert CD 24 36 Value 47 if standard LED bulbs
(11)-Leuchte24SL HRA65-Dimming Direction CD 24 maximize
(12)-Leuchte24SL HRA65-Lichtfunktion E 24 Blinken rechts Dunkelphase
(13)-Leuchte24SL HRA65-Lichtfunktion F 24 not active
(14)-Leuchte24SL HRA65-Dimmwert EF 24 0
(15)-Leuchte24SL HRA65-Dimming Direction EF 24 minimize
(16)-Leuchte24SL HRA65-Lichtfunktion G 24 not active
(17)-Leuchte24SL HRA65-Lichtfunktion H 24 not active
(18)-Leuchte24SL HRA65-Dimmwert GH 24 10
(19)-Leuchte24SL HRA65-Dimming Direction GH 24 maximize
Source: http://forums.vwvortex.com/showthre...ure-Thread&p=94665090&viewfull=1#post94665090
TBAx
C?ID=287144
Why don't you try it. Coding looks correct so far, the effect looks terrible imho.
quailallstar
Ormond Beach, FL
C?ID=53119
Did this mod and it works well! Only issue is I've lost my outer tail Parking light function via left steering wheel stalk and my out tails no longer light up when the boot is open :( Is there a way to get those two features back while keeping the coding mod?
Single sided parking light
(9)-Leuchte20BR LA71-Lichtfunktion D 20 >Parklicht links (beidseitiges Parklicht aktiviert li & re)
(9)-Leuchte21BR RC8-Lichtfunktion D 21 >Parking light right
Boot operated lights
(16)-Leuchte20BR LA71-Lichtfunktion G 20> Heckdeckel offen
(18)-Leuchte20BR LA71-Dimmwert GH 20 > 127
(16)-Leuchte21BR RC8-Lichtfunktion G 21 > Heckdeckel offen
(18)-Leuchte21BR RC8-Dimmwert GH 21 >127
quailallstar
Ormond Beach, FL
C?ID=53119
Thanks for this info! Made some minor modifications and got the parking and boot open lights to work. Just installed the OEM Euro MK7.5 facelift variant LED's (amber turn signals).
Install took me about 1.5 hours total
(no shots of the amber in action, sorry)
1. Outer brake light illumination when you open the boot.
2. Left and Right rear parking lights via turn stalk (I previously had the front coded and didn't touch that coding). Now how can I dim these down maybe to at least 75% bright?
(9)-Leuchte20BR LA71-Lichtfunktion H 20 >Parklicht links (beidseitiges Parklicht aktiviert li & re)
(9)-Leuchte21BR RC8-Lichtfunktion H 21 >Parking light right
