VCDS Mobile stops during AUTO-SCAN search
Peter / Logic
Ireland
C?ID=57059
Hi,
Using the HEX-NET in Infrastructure Mode the programme seems to stop or hang when it comes to a Control Unit with Label: none or ReDir: Fail
I have tried it many many times and it always only gets to 7% but after switching to AP Mode and doing the same AUTO-SCAN I can get the full list but I can see the problem seems to be when it gets to the " Labels: None " Control Unit , please see and compare the AUTO-SCAN details below..
VCDS-Mobile
Auto-Scan
Progress: 7% 	Trying address 03...
Chassis Type:7H
Scan:
	 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
	 57 6E 76 77 78 7D
Address 02: Auto Trans	Labels:09G-927-750.lbl
	Part Number SW: 09K-927-750-K	HW: 09K927750K
	Component: AQ 250 6F            1044
	Revision: 00H67000	Serial Number:
	Coding: 0000072
	Shop #: WSC 02756 790 00000
	VCID: 3D3DAAF7340FBFF7DD9FE
No fault codes found.
Please note the 7% and that the next Control Unit has a Labels: None when using HEX-NET in AP Mode below---->
          57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ7H123509   Mileage: 374240km/232541miles
Address 01: Engine        Labels: 070-906-016-BPC.clb
   Part No SW: 070 997 016 M    HW: 070 997 016 M
   Component: R5 2,5L EDC  000AG  0860
   Revision: --H05---    Serial number: VWZ7Z0G5236470
   Coding: 0001075
   VCID: 24042D2DE44D4914C3-5184
Address 02: Auto Trans        Labels: 09G-927-750.lbl
   Part No SW: 09K 927 750 K    HW: 09K 927 750 K
   Revision: 00H67000    Serial number:
   Coding: 0000072
   VCID: 3D32F84967E718DCAC-5184
   VCID: 55E240E9BF97E09C84-5160
No Faults Found
   Part No: 1C0 909 605 A
   Component: 3C AIRBAG VW51      0010
   Coding: 13123
   Shop #: WSC 02756
   VCID: 22082B35AE594724B1-5160
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 851 S
   Coding: 00113
   Shop #: WSC 00740
   VCID: 3B36F65129F316EC92-5160
   WV2ZZZ7HZ7H123509     VWZ7Z0G5236470
Address 18: Aux. Heat        Labels:
   VCID: 55E240E9AC97E09C84-FFFF
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02756
   VCID: F0AC917DB03525B4F7-5160
Address 56: Radio        Labels: None
No Faults Found
OK, this clearly isn't VCDS-Mobile. That's VCDS 14.2.1 running on a PC, talking to the HEX-NET via WiFi, right? ;)
We're looking at some issues like that right now.
Peter / Logic
Ireland
C?ID=57059
Hi Uwe,
The top Scan is the 7% AutoScan that I got using VCDS Mobile in Infrastructure mode with Wifi .
The Second AutoScan is using the HEX-NET in AP Mode Connected to the same Laptop using the usb cable and using VCDS 14.2.1, but the problem is only when using VCDS Mobile.
Ah.. Thanks! Let me see about fixing up the original post to make it more obvious what's going on.
[time passes]
OK, CODE tags applied.
What had me confused was:
It's not "the same" when you do it with VCDS vs. doing it with VCDS-Mobile. ;)
What we need to know here is whether the problem is truly AP vs. Infrastructure, or VCDS vs. VCDS Mobile. Both VCDS and VCDS Mobile can be used with the HEX-NET in AP mode or in Infrastructure mode. My guess is that both will exhibit the same behavior no matter which networking mode you're using them in?
Peter / Logic
Ireland
C?ID=57059
I don't think the issue is AP vs. Infrastructure mode as these modes do exactly as they are intended ( I hope I am correct here ) , in other words they both work perfect.
Because VCDS Mobile is a different platform ( if I can call it that ) from VCDS I just wanted to use the same interface ( HEX-NET ) and compare AutoScan procedure VCDS Mobile vs. VCDS to see what the issue could be, but I guess the issue is a VCDS Mobile issue as VCDS works perfect.
I did not know I could use VCDS in Infrastructure Mode so that is something I can try on Monday,
Have a good weekend,
P.S I might drop into your bar at some point for a chat and a couple of beers !
