This repair started out as a fairly straight forward wheel bearing replacement. My drivers-side rear wheel bearing has been making noise for about a month, so it was time to replace it... I arranged time over at my friends house who is a 20 year VW / Audi trained mechanic. Purchased the wheel bearing, pulled the wheel and all the bits to allow us access to pull the hub and pull the bearing out and replace it... all seemed good. However, along the way we noticed that the rear brake pads seemed very low and we should probably replace them since we had to have all of this apart anyways. However, it never occurred to us that we needed to put the computer in brake-pad replacement mode and retract the electronic parking brake... as per the Ross-Tech procedure until after we had the brakes off and pads pulled out. Our mistake was probably somewhere around this point, that we started the car with the drivers side parking brake electrical connector disconnected. We reconnected the parking brake connector and thought that we could put the parking brake system into that retracted mode now... but all we got was flashing lights on the dash and the parking brake button flashing as well.
We found that no matter what steps we tried on the computer (we followed the Ross-Tech wiki on how to open and close the parking brake for pad replacement), we could not get it to co-operate and clear itself up. However, we continued to work the problem, we removed the electric motor and turned the piston out to open it wide enough to get the new pads in. This seemed to work well enough to get the pads in and we put it all back together. And were able to run the Adaptation to set the new pad thickness. But from this point, we could not get the computer to recognize that everything was back together and seemingly working properly... all of the brake related lights on the dash are flashing and the buzzer is buzzing continuously... yet the brakes are functioning properly, even the parking brake seems to work... yet the red light on the parking brake button is flashing! Not exactly sure how to get this back to normal?
It was a very long day yesterday and got home very late, after midnight... so I ran a fresh full scan on the VCDS this morning (my mechanic friend uses some different diagnostic tool... so I didn't have my VCDS with me yesterday). Here is the pertinent bits from that log:
Thursday,13,July,2017,07:40:58:08168
VCDS Version: 17.1.3.0 HEX-V2 CB: 0.4334.4
Ross-Tech: Home
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E8774746
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2E0604104C16BBF78F5-807A
10 Faults Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Fault Status: 01101000
Mileage: 217891 km
Temperature: 91.0°C
Temperature: 42.0°C
Absolute Pres.: 0.0 mbar
Voltage: 11.938 V
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Mileage: 217891 km
RPM: 137 /min
Load: 78.8 %
Temperature: 91.0°C
Temperature: 42.0°C
Voltage: 10.287 V
17833 - EVAP Purge Valve (N80)
P1425 - 002 - Short to Ground
Fault Status: 01100010
Mileage: 217891 km
RPM: 137 /min
Load: 78.8 %
Temperature: 91.0°C
Temperature: 42.0°C
Voltage: 10.287 V
17984 - Right Engine Mount Solenoid Valve (N145)
P1576 - 002 - Short to Ground
Mileage: 217891 km
RPM: 137 /min
Load: 78.8 %
Temperature: 91.0°C
Temperature: 42.0°C
Voltage: 10.287 V
17880 - EVAP Leak Detection Pump
P1472 - 002 - Short to Ground
Mileage: 217891 km
RPM: 137 /min
Load: 78.8 %
Temperature: 91.0°C
Temperature: 42.0°C
Voltage: 10.287 V
17843 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground
Mileage: 217891 km
RPM: 137 /min
Load: 78.8 %
Temperature: 91.0°C
Temperature: 42.0°C
Voltage: 10.287 V
17829 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 002 - Short to Ground
Mileage: 217891 km
RPM: 137 /min
Load: 78.8 %
Temperature: 91.0°C
Temperature: 42.0°C
Voltage: 10.287 V
17876 - EVAP Canister Solenoid Valve 2 (N115)
P1468 - 002 - Short to Ground
Mileage: 217891 km
RPM: 137 /min
Load: 78.8 %
Temperature: 91.0°C
Temperature: 42.0°C
Voltage: 10.287 V
16486 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low
Mileage: 217891 km
RPM: 1325 /min
Load: 40.0 %
Temperature: 91.0°C
Temperature: 42.0°C
Voltage: 11.684 V
17475 - Intake Air Switch-Over Valve (N335)
P1067 - 002 - Short to Ground
Mileage: 217891 km
RPM: 921 /min
Load: 35.3 %
Temperature: 91.0°C
Temperature: 39.0°C
Voltage: 12.827 V
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 N
Component: ESP 5.7 allrad H44 0500
Coding: 0007597
Shop #: WSC 12345 000 00000
VCID: 221EE02008CE0F971BD-8076
18265 - Load Signal
P1857 - 000 - Error Message from ECU
00003 - Control Module
014 - Defective
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000532
Shop #: WSC 02610 067 57207
VCID: 1F18E9D43BBC227F343-804A
02433 - Supply Voltage for Right Parking Brake Motor (V283)
Fault Status: 11111100
Reset counter: 111
Mileage: 217888 km
Date: 2017.07.12
Time: 23:43:38
Voltage: 13.25 V
Count: 87
