Audi A8 D3 fault codes. Repairs ideas.
Davekes
C?ID=307009
Hello all,
I have recently bought an A8 d3 2005 (UK) year, and have been experiencing issues with the MMI, it is currently stuck up and blank. Boot screen will load then it shuts down. I have intermittent success by removing the battery, charging and reinstalling. This has worked to return the MMI to operational order a couple of times. But it is not solving the problem, so I have had someone perform a VCDS scan on the full system and the Optical bus.
There appears to be an issue with the battery regulation management system and some of the MMI components.
The dealer I bought the car from (non specialist) has offered to repair the car and I would welcome anyone's thoughts on what a repair/component strategy might be.
From my own research I am thinking, replace battery, battery management module, boss amp.
Full VCDS scan results:
Monday,10,July,2017,13:29:47:06319
VCDS Version: 17.1.3.0 (x64)
VIN: WAUZZZ4E46N002270 License Plate: DHA
Mileage: 238400km-148134mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 1E 25 28 34 36 37 38
42 46 47 4F 52 53 55 56 61 62 67 72 76 77
VIN: WAUZZZ4E46N002270 Mileage: 238400km-148134miles
05-Acc/Start Auth. -- Status: Sporadic communication error 1000
07-Control Head -- Status: Cannot be reached 1100
18-Aux. Heat -- Status: Malfunction 1010
1E-Media Player 2 -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Sporadic communication error 1000
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
67-Voice Control -- Status: Cannot be reached 1100
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4E0 910 401 Q HW: 4E0 907 401 C
Component: 3.0L V6TDI G000AG 0020
Revision: --H01--- Serial number: AUX3Z0E3363322
Coding: 0011973
Shop #: WSC 02313 785 00200
VCID: 2959ED1C80E18D099E-807C
P1653 - 002 - - Intermittent
Mileage: 238122 km
Date: 2017.07.04
Torque: 167.7 Nm
Duty Cycle: 1.0 %
Voltage: 10.56 V
Bin. Bits: 00101111
Torque: 89.7 Nm
006249 - Transmission Mount Valve 1 (N262)
P1869 - 001 - Short to Ground
Mileage: 238122 km
Date: 2017.07.04
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 001 - Open Circuit
Fault Status: 01110001
Mileage: 238128 km
Date: 2017.07.06
Time: 01:05:55
RPM: 882 /min
Torque: 93.6 Nm
Duty Cycle: 1.0 %
Voltage: 11.70 V
Duty Cycle: 24.1 %
Temperature: 10.8°C
Part No SW: 4E0 910 156 F HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0090
Revision: --H01--- Serial number: 4022977
Coding: 0000001
VCID: 2541E12CECF9A969BA-8070
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008357
Shop #: WSC 02313 000 00000
VCID: 224BFA30FDD75E51DF-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0E3363322
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: 58BF98D8EB0BC481F1-800C
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Shop #: WSC 00000 785 00200
VCID: 2345FF34E2CD5759D4-8076
00456 - Control Module for Access and Start Control (J518)
Reset counter: 161
Mileage: 238160 km
Date: 2017.07.06
Time: 18:00:30
Address 07: Control Head
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000065950
Coding: 1394705
VCID: 1C37C4C8DFB368A115-8048
00065 - Rear Left Footwell Heater (Z42)
Reset counter: 119
Mileage: 238128 km
Date: 2017.07.04
Time: 00:18:00
Voltage: 13.20 V
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H12 0210
Coding: 0143121
VCID: 3169057CA831F5C956-8064
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
00908 - Control Module for Wiper Motor
Reset counter: 167
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Reset counter: 167
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
VCID: 63C5BF34A24D175994-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112141
VCID: 65C1A12CAC7969697A-8030
Component: Lenkradmodul H07 0080
Reset counter: 167
Mileage: 238161 km
Date: 2017.07.06
Time: 18:00:28
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 P HW: 4E0 920 950 P
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3E3000050
Coding: 0000413
Shop #: WSC 59921 067 57207
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
Component: Heizgeraet H07 0100
Revision: 0000000B Serial number: 00000009006406
Coding: 0000001
VCID: 1A3BC2D0D587169107-804E
02251 - Heater Unit Locked
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H10 0080
Revision: 10 Serial number: 19003054148122
Coding: FCFE7FDE2B7104
VCID: 275DEB2496F5BB7988-8072
00384 - Optical Databus
Fault Frequency: 59
Reset counter: 127
Mileage: 238128 km
Date: 2017.07.04
Time: 00:34:31
Fault Frequency: 59
Reset counter: 127
Mileage: 238128 km
Date: 2017.07.04
Time: 00:34:31
Reset counter: 161
Mileage: 238161 km
Date: 2017.07.06
Time: 18:00:28
Reset counter: 161
Mileage: 238161 km
Date: 2017.07.06
Time: 18:00:28
Address 1E: Media Player 2
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0220
Revision: 00000018 Serial number: 00000000026754
Coding: 0000000
VCID: 61C9B53CB851054986-8034
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 285FE8189BEBB40181-807C
Component: Sitzmemory FS H08 0060
Coding: 4063338
Address 37: Navigation
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000502500025
Coding: 0035972
VCID: 1D31C9CCC4A961A9E2-8048
Reset counter: 161
Mileage: 238160 km
Date: 2017.07.06
Time: 18:00:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRM003 0060
Coding: 0028462
VCID: 204FF038F3DB4C41C9-8074
Fault Status: 01101000
Fault Frequency: 14
Reset counter: 127
Mileage: 237456 km
Date: 2017.06.20
Time: 18:32:22
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040504090194
Coding: 0004317
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
00985 - Right Tail Light (M2)
014 - Defective
Fault Status: 01101110
Reset counter: 127
Mileage: 220112 km
Date: 2016.08.27
Time: 18:17:24
Reset counter: 127
Mileage: 220112 km
Date: 2016.08.27
Time: 18:17:24
Reset counter: 161
Mileage: 238161 km
Date: 2017.07.06
Time: 18:00:33
Address 47: Sound System
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000059824
Coding: 0010101
VCID: 1E33CEC0C9AF7AB1FB-804A
Reset counter: 161
Date: 2023.06.06
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRM003 0060
Coding: 0028462
Fault Frequency: 0
Reset counter: 146
Mileage: 237680 km
Date: 2017.07.01
Time: 09:49:40
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000221
Shop #: WSC 00443 210 90890
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 D
Component: Dynamische LWR H01 0010
Coding: 0000006
VCID: 3B7527547A7D0F99FC-806E
Address 56: Radio
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: ENERGIEMANAGER H12 0480
Revision: 00000000 Serial number: 00000000006661
Shop #: WSC 00579 210 58584
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 1504150050
Coding: 344530393135313035412056413031353034313530303530
Shop #: WSC 00000 128 00289
02273 - Quiescent Current Stage 2
Mileage: 238128 km
Date: 2017.07.04
Time: 00:37:04
02276 - Quiescent Current Stage 5
Mileage: 238128 km
Date: 2017.07.04
Time: 00:37:04
02277 - Quiescent Current Stage 6
Mileage: 238396 km
Date: 2017.07.08
Time: 00:48:58
Mileage: 238396 km
Date: 2017.07.08
Time: 00:48:58
02255 - Voltage Measuring Lead from Vbat
Fault Status: 00101001
Reset counter: 167
Mileage: 238132 km
Date: 2017.07.06
Time: 01:16:00
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0060
Coding: 0028462
Fault Frequency: 0
Reset counter: 146
Mileage: 237680 km
Date: 2017.07.01
Time: 09:49:40
Address 67: Voice Control
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0060
Coding: 0028462
Fault Frequency: 0
Reset counter: 146
Mileage: 237680 km
Date: 2017.07.01
Time: 09:49:40
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: 06.00.55 Serial number: 00067808720507
Coding: 0001108
VCID: 2149F53CF8D14549C6-8074
Reset counter: 161
Address 77: Telephone
End-------------------------(Elapsed Time: 03:27)--------------------------
Davekes
C?ID=307009
Optical scan results :
Optical Bus Diagnostic : Standard
Controller Electrical Optical
19-CAN Gateway OK OK
07-Control Head(High/D3) OK OK
1E-Media Player 2 OK OK
77-Telephone OK OK
47-Sound System ERROR ERROR
67-Voice Control OK OK
56-Radio OK OK
37-Navigation OK ERROR
First thing I would do is check voltage supply to the amp.
How old is the battery?
Davekes
C?ID=307009
Battery is 2 years old. From the looks of the history that came with the car, it has had a new battery every 2 years since 2013.
I have had the battery tested at 3 auto shops, with the battery on the car. Two readers displayed a 'excessive noise' message and didn't give any useful data. The third, gave a reading of 'battey unserviceable', 100% charged and 60% capacity.
When I have had the battery in charge overnight, my charger says 'full' and I measure 12.8volts at the battery after charging.
I tried a brand new battery on the car today at the shop and the MMI remained the same.
I cannot figure out if the majority of the faults are battery/power management related or component failure.
Can I check the voltage going to the amp using a multimeter? How?
A new battery every two years seems excessive. Given that this car has almost 150,000 miles on it, it's not like it was only driven around the block.
I wonder if the Battery Manager was ever told that the battery has been replaced?
Have you tried the Battery History function available in our current Beta version? Take a look here:
http://www.ross-tech.com/vcds/download/beta/17-5.php
Sure you can check the voltage to the amp using a multi-meter. Wiring diagrams will tell you which pins should have power. The following threads may be useful:
http://forums.ross-tech.com/showthread.php?5999
http://forums.ross-tech.com/showthread.php?2884
Davekes
C?ID=307009
Thanks for the reply.
I don't have the VCDS software, I paid to have a scan done so I can't check the battey history.
Thanks for the links, I'm away from the car for a few days but will check at the weekend.
I opened the car this morning and as I was putting bags in the boot (trunk) the MMI screen stowed itself away, having been up and blank previously. I started the car and turned the MMI on, I got maybe 20 seconds of music playing via CD then it all went blank and non responsive again.
Do you think I have multiple issues here? (Amp, access system, battery manager, battery). Or could all these faults be traced to a single source of failure?
The used car dealer I bought it from has offered to repair the car, but I know they are not VAG specialists so I'm trying to get the diagnosis myself so i know what needs to be done.
Well, if you're going to own a 12 year old A8, I'm going to suggest that getting VCDS yourself would probably be a good investment. :)
I think there are multiple issues here. If it were me, I'd work on the most obvious one first, and that's the MMI. Trouble with these cars is that when some things don't communicate, other things may not properly go to sleep, and then your battery gets drained..
If they are not VAG specialists, I'm not sure they're qualified to work on this car. The systems in a D3 A8 are rather more complex than those in a typical Golf or Skoda.
Davekes
C?ID=307009
Yes, I agree that a VCDS is a much needed investment and it's on my list.
I am more inclined to carry out the repairs myself as I believe that with the research I am doing I will be better equipped to do so.
I do need to agree this with the dealer first.
What are your thoughts on the battery management unit scan results? Does it need to be replaced?
What makes you think it should be replaced?
Davekes
C?ID=307009
The 5 faults found during the scan.
Mileage: 238128 km
Date: 2017.07.04
Time: 00:37:04
Mileage: 238128 km
Date: 2017.07.04
Time: 00:37:04
Mileage: 238396 km
Date: 2017.07.08
Time: 00:48:58
Mileage: 238396 km
Date: 2017.07.08
Time: 00:48:58
Reset counter: 167
Mileage: 238132 km
Date: 2017.07.06
Time: 01:16:00
The first 3 "Quiescent Current Stage" are very common in these cars and not at all indicative of a problem with the module. They're simply informing you that the module is trying to tell other modules to shed load in an attempt to retain enough charge to start the car.
The 4th code, "Control Module for Access and Start Control (J518) -- No Signal/Communication - Intermittent" indicates an intermittent communications problem with the KESSY module. I don't take that as a sign of the the Battery manage module has failed either.
The last code, "Voltage Measuring Lead from Vbat -- Open or Short to Ground - Intermittent" is the only one that would even hint at a hardware problem with the BEM module. But I would carefully check that connection before condemning the module.
Davekes
C?ID=307009
Thanks again, your knowledge and help is greatly appreciated.
I am negotiating with the dealer to agree to some costs so that I can continue with the repairs/diagnostic myself. As I said they are not a specialist and with forums like this around I have access to a wealth of expertise thanks to people like you offering your time. I'll be investing in the VCDS software too.
My initial thoughts are ;
1) Optical loop test, taking the bose amplifier out of the system.
2) replace Amp if needed as it seems to have electrical and optical issues.
3) new battery, coded to car.
4) battery management unit check/replacement.
Re-scan as I go, and probably investigate keyless entry fault codes etc.
One question I have is, when is use keyless start, the car won't start unless I have my foot on the brake pedal (as expected) but if I start using the key in the ignition, it fires right up without my foot on the brake. This is a fault isn't it? Anything in the scan that points to this?
Dave
Sounds like a plan. For step 1, you'll also need a MOST Ring Bypass Loop (part number 4E0 973 802).
I'm not sure whether it's expected to start up w/o your foot on the brake with the key in the ignition.
Davekes
C?ID=307009
I'll look into that then.
Just reached an agreement with the dealer and i will be doing the repairs myself, I've also just ordered VCDS from Gendan(UK).
Will the new battery manager software in the beta version be helpful in my battery regulation diagnosis?
It certainly can't hurt to have look at that history data...
Davekes
C?ID=307009
Ok, I'll give it a go on Friday and will come back with the results.
Davekes
C?ID=307009
I have received my VCDS interface cable today and will be performing my first scan tomorrow. Do you recommend that I use the current software version first and then the beta version afterwards to look at the battery history, or can I do everything with the beta version?
Dave
I would just use the Beta for everything.
Davekes
C?ID=307009
Ok then.
I've installed a fibre optic bypass loop in place of the Bose Amplifier and now the MMI is working again, but obviously without sound.
I've attached my VCDS scan results (after a DTC clear) and the battery history log.
Can you glean anything useful from the battery log? It suggests that the battery currently in the car was never coded. But the dates are weird, the car wasn't built until 2005 but the dates in the log file are earlier than this.
Do you know if there is any way that I can check that the bose amp is getting power?
I noticed after 20 mins of ignition on, my battery voltage was 11.7volts, it recovered back to 12.4volts when I turned the ignition off. I'm trying to figure out if there's a battery related power supply issue which is preventing the bose amp from working before I buy a replacement.
Dave
Friday,14,July,2017,13:56:37:32225
Mileage: 238620km-148271mi   Repair Order:
VIN: WAUZZZ4E46N002270   Mileage: 238620km-148271miles
38-Roof Electronics -- Status: OK 0000
47-Sound System -- Status: Sporadic communication error 1000
   Coding: 0011973
   VCID: 290CF41225FEFC5F38F-807C
               P1653 - 002 -
                    Fault Status: 01100010
                    Fault Frequency: 28
                    Mileage: 238122 km
                    Date: 2017.07.04
                    Torque: 167.7 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 10.56 V
                    Bin. Bits: 00101111
                    Torque: 89.7 Nm
                    Mileage: 238122 km
                    Date: 2017.07.04
                    Time: 00:02:30
                    RPM: 777 /min
                    Torque: 50.7 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 12.16 V
                    Bin. Bits: 00101111
                    Torque: 257.4 Nm
                    Fault Status: 01100001
                    Mileage: 238128 km
                    Date: 2017.07.06
                    Time: 01:05:55
                    RPM: 882 /min
                    Torque: 93.6 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 11.70 V
                    Duty Cycle: 24.1 %
                    Temperature: 10.8°C
   Coding: 0000001
   VCID: 2514F82249E6D83F1C7-8070
   Coding: 0008357
   VCID: 221EE33E58C82F07795-8076
            000 -  -
   Coding: 0412672
   VCID: 58EA81D64E14B5D7571-800C
   Coding: 4063328
   VCID: 2310E63A47D2260F723-8076
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 769 D    HW: 4E0 035 729
   Component: Interfacebox    H43 5150
   Revision: 00000000    Serial number: 343DT057557194
   Coding: 0000002
   VCID: 2D0400021116E07FD47-8078
   Subsystem 1 - Part No: 4E0 910 609 C
   Component: Bedienteil MMI  H42 0100
   Subsystem 2 - Serial number: 318DQ057515438
   Subsystem 3 - Serial number: 7413.04.0500000000218B0014ÿ
   Subsystem 4 - Serial number: 8B0014ÿ
   Coding: 1394705
   VCID: 1C62DDC67AAC19F7B39-8048
                    Reset counter: 119
                    Mileage: 238128 km
                    Date: 2017.07.04
                    Time: 00:18:00
                    Voltage: 13.20 V
                    Reset counter: 168
                    Mileage: 238424 km
                    Date: 2017.07.11
                    Time: 03:15:40
   Part No SW: 4E0 910 279 L    HW: 4E2 955 113 B
   Coding: 0143121
   VCID: 313C1C720D2E849FF0F-8064
   Coding: 00000036
   Shop #: WSC 02313
   Coding: 00139548
   Shop #: WSC 02313
                    Reset counter: 170
                    Reset counter: 161
                    Mileage: 238161 km
                    Date: 2017.07.06
                    Time: 18:00:28
                    Reset counter: 169
                    Mileage: 238424 km
                    Date: 2017.07.11
                    Time: 03:15:20
   Coding: 0431707
   VCID: 6390A63A0752660F323-8036
   Coding: 0112141
   VCID: 6594B8220966183FDC7-8030
   Coding: 0000413
   Coding: 0000001
   VCID: 1A6EDBDE709867C7A15-804E
            000 -  -
Address 19: CAN Gateway        Labels:. 4E0-910-468.clb
   VCID: 2708F22A33EACA2F2EB-8072
                    Fault Frequency: 14
                    Reset counter: 170
                    Mileage: 238628 km
                    Date: 2017.07.11
                    Time: 03:07:32
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBE7147755
   Coding: 0412672
   Coding: 0000000
   VCID: 619CAC321D4E741F20F-8034
   Coding: 0015510
   VCID: 280AF1163EF4C557271-807C
   Coding: 4063338
   Part No SW: 4E0 910 887 D    HW: 4E0 919 887 C
   Component: MNS ECE         H44 0550
   Revision: 00000000    Serial number: 305DY057583886
   VCID: 2E06070E1C109B67EDD-807A
   Coding: 0035972
   VCID: 1D64D0C261B610FF447-8048
   Coding: 0028462
   VCID: 201AE93656C43D176F1-8074
                    Fault Frequency: 14
                    Reset counter: 130
                    Mileage: 237456 km
                    Date: 2017.06.20
                    Time: 18:32:22
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Coding: 0004317
            014 - Defective
                    Reset counter: 130
                    Mileage: 238628 km
                    Date: 2017.07.11
                    Time: 02:13:06
   Coding: 0010101
   VCID: 1E66D7CE6CB00BE75DD-804A
   Coding: 0028462
                    Reset counter: 169
                    Mileage: 237680 km
                    Date: 2017.07.01
                    Time: 09:49:40
   Revision: AV1C1010
   Coding: 0000221
   Coding: 0000006
   VCID: 3B203E5ADF627ECF5A3-806E
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 E
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 396DV057508156
   Coding: 0000001
   Coding: 0028462
                    Reset counter: 169
                    Mileage: 237680 km
                    Date: 2017.07.01
                    Time: 09:49:40
   Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H45 0630
   Revision: 00000000    Serial number: 00000512210056
   Shop #: WSC 12336 024 394758
   VCID: 36362F6EE440A3A7A5D-8062
   Coding: 0028462
                    Reset counter: 169
                    Mileage: 237680 km
                    Date: 2017.07.01
                    Time: 09:49:40
   Coding: 0001108
   VCID: 211CEC325DCE341F60F-8074
   Part No SW: 4E0 910 336 K    HW: 4E0 862 335
   Component: Handyvorb2      H10 0950
   Revision: 00000000    Serial number: 00000007550110
   Coding: 0010900
   VCID: 2A0E0B1E20F8F747315-807E
End----(Elapsed Time: 01:59, VBatt start/end: 11.3V/11.7V. VIgn 11.7V)-----
VCDS Beta 17.6.0:  SRI Reset
Control Module Part Number: 4E0 910 950 P       Labels:  4E0-910-xxx-17.lbl
Component:KOMBIINSTR. VDO H71 0400, Coding:0000413
Channel  	Description                                       	Unit      	Current val.  	New val.
02       	Service Reminder Status                           	          	0             	---
40       	Mileage since Service                             	miles x100	144           	---
41       	Time since Service                                	Days      	420           	---
42       	Min Mileage to Service                            	miles x100	90            	---
43       	Max Mileage to Service                            	miles x100	190           	---
44       	Max Time to Service                               	Days      	730           	---
45       	Oil Quality                                       	          	2             	---
47       	Soot Quantity                                     	km x100   	369           	---
48       	Thermal Load                                      	km x100   	223           	---
49       	Min Time to Service                               	Days      	730           	---
Friday,14,July,2017,09:22:57:32225
Control Module Part Number: 4E0 910 181 C
  Component and/or Version: ENERGIEMANAGER  H12 0480
           Software Coding:
            Work Shop Code: WSC 00579
           Additional Info: 4E0915105A  von VA0  1504150050
           Additional Info: Geraet 58584
History Data
Record 1/18: No-load voltage underranging
2017-07-09,05:00:00*0043*002**
2017-07-08,18:00:00*0008*002**
2017-07-08,11:00:00*0001*002**
2017-07-05,08:00:00*0014*002*48831***
2017-06-27,03:00:00*0055*002**
2017-06-26,07:00:00*0003*002**
2017-06-20,04:00:00*0003*002**
2016-07-27,19:00:00*0015*002*03651***
2000-01-01,00:00:00*0000*000**
2000-01-01,00:00:00*0000*000*00000***
Record 2/18: No-load current overranging
2017-07-09,04:00:00*0045*00.06*002**
2017-07-08,06:00:00*0005*00.45*002**
2017-07-08,00:00:00*0002*00.08*002**
2017-07-07,09:00:00*0001*00.80*002**
2017-07-07,00:00:00*0006*00.07*002**
2017-07-06,00:00:00*0000*03.69*002**
2017-07-04,23:00:00*0001*00.65*002**
2017-07-04,09:00:00*0003*02.44*002**
2017-07-04,04:00:00*0000*03.06*002**
2017-07-02,08:00:00*0012*00.06*002*03478***
Record 3/18: Energy-critical vehicle states
00.48*06.26*-06.62*68*04*+9999*-01751*238106*2017-07-02,00:03:35*0-0-0-0-0-0*00.1*00.3*000.4*09*04*02*002**
Record 4/18: Shut-off stage history
6*5*-01.82*03*2017-07-08,00:49:26*0-0-0-0-0-0*00.0**
3*5*-03.00*03*2017-07-08,00:48:58*0-0-0-0-0-0*00.0**
5*5*-03.20*03*2017-07-08,00:48:48*0-0-0-0-0-0*00.0**
2*5*-02.70*03*2017-07-08,00:48:38*0-0-0-0-0-0*00.0**
3*5*-05.40*03*2017-07-08,00:00:49*0-0-0-0-0-0*00.0**
5*5*-03.70*03*2017-07-08,00:00:44*0-0-0-0-0-0*00.0**
2*5*-03.90*03*2017-07-08,00:00:34*0-0-0-0-0-0*00.0**
6*0*-00.04*71*2017-07-06,00:48:13*0-0-0-0-0-0*00.0**
3*5*-06.40*10*2017-07-04,02:10:17*0-0-0-0-0-0*00.0**
5*5*-06.30*10*2017-07-04,02:10:07*0-0-0-0-0-0*00.0**
2*5*-05.00*10*2017-07-04,02:09:57*0-0-0-0-0-0*00.0**
6*5*-02.10*05*2017-07-04,00:39:51*0-0-0-0-0-0*00.0**
3*5*-04.40*06*2017-07-04,00:37:34*0-0-0-0-0-0*00.0**
5*5*-04.70*06*2017-07-04,00:37:24*0-0-0-0-0-0*00.0**
2*5*-04.50*06*2017-07-04,00:37:14*0-0-0-0-0-0*00.0**
Record 5/18: Battery change history
001*----------*2004-11-27,00:00:00*-00003*-0056**
000*----------*2000-01-01,00:00:00*+00000*+0000**
Record 6/18: Energy balances (last 5 trips)
+000.2*000.0**
+006.3*001.4**
+000.0*000.0**
+000.0*000.0**
+003.2*000.4**
Record 7/18: Energy balances (last 5 standing times)
-000.5*000.0**
-000.3*000.0**
-000.2*000.0**
-004.9*059.1**
-005.7*008.7**
Record 8/18
-999.9*002**
Record 9/18
0000.0*0000.0
Record 10/18: Dynamic energy management
00.0*00.0
Record 11/18
0000.00*0000.00*0000.00*0000.00
Record 12/18: Start-Stop
00.00*00.00*00.00*00.00
Record 13/18: Sporadic alternator faults
0000.0*0000.0
Record 14/18: Small battery for hybrid vehicle
00.0*00.0
Record 15/18: Local activ.
99*99*99*02*99
Record 16/18: Vehicle energy balance
00*00*00*00*00
Record 18/18: Date reprogramming in instrument cluster
15**
2012-02-01,02:00:00*2012-02-01,12:00:00**
2011-05-14,00:00:00*2011-05-14,09:00:00**
2004-12-07,21:00:00*2005-05-13,12:00:00**
2004-12-04,22:00:00*2004-12-04,00:00:00**
2000-01-01,00:00:00*2004-11-26,00:00:00**
I'd speculate the car needs an amp.
Agreed, unless the date in the car was incorrectly set the one time a battery change was coded.
What's the build date on this car?
Wiring diagrams and multimeter.
On a car that's this power-hungry (and that generation of A8 is VERY power-hunrgy) you really should use a battery charger when leaving the ignition on for any length of time.
